The PB15 GPIO line is used to control the enable and disable signal for
the backlight regulator on EVKLCD10x boards. This patch hands the I/O
line over to the LCDC driver, which will control when to enable and
disable the backlight.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
[haavard.skinnemoen@atmel.com: reverted ac97c change]
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
This patch removes the special handling of MCI platform data for
EVKLCD10x boards. This is now possible since the pin mask for the LCD
controller is no longer reserving the I/O lines used for MCI card
detection and write protect.
This patch will set the pin mask to alternative 18 bits per pixel output
for EVKLCD10x boards.
This patch adds two defines for setting a pin mask for 18-bit LCD panels
connected to the LCD controller. One mask for primary output and one
mask for alternative output.
This patch corrects the 15-bit LCDC pin mask definitions to select the
five upper lines in each color byte from the LCDC data output. When
reducing the color depth the LCDC will start filling MSB and downwards.
Also only enable 5 bits per color as the define indicates.
Remove duplicated #include in arch/avr32/boards/hammerhead/flash.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Acked-by: Alex Raimondi <mailinglist@miromico.ch>
arch/x86/Kconfig
block/blktrace.c
kernel/irq/handle.c
Semantic conflict:
kernel/trace/blktrace.c
The current definition of CALLER_ADDRx isn't suitable for all platforms.
E.g. for ARM __builtin_return_address(N) doesn't work for N > 0 and
AFAIK for powerpc there are no frame pointers needed to have a working
__builtin_return_address. This patch allows defining the CALLER_ADDRx
macros in <asm/ftrace.h> and let these take precedence.
Because now <asm/ftrace.h> is included unconditionally in
<linux/ftrace.h> all archs that don't already had this include get an
empty one for free.
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into core/percpu
arch/x86/include/asm/pgtable.h
Impact: cleaner and consistent bootmem wrapping
By setting CONFIG_HAVE_ARCH_BOOTMEM_NODE, archs can define
arch-specific wrappers for bootmem allocation. However, this is done
a bit strangely in that only the high level convenience macros can be
changed while lower level, but still exported, interface functions
can't be wrapped. This not only is messy but also leads to strange
situation where alloc_bootmem() does what the arch wants it to do but
the equivalent __alloc_bootmem() call doesn't although they should be
able to be used interchangeably.
This patch updates bootmem such that archs can override / wrap the
backend function - alloc_bootmem_core() instead of the highlevel
interface functions to allow simpler and consistent wrapping. Also,
HAVE_ARCH_BOOTMEM_NODE is renamed to HAVE_ARCH_BOOTMEM.
Cc: Johannes Weiner <hannes@saeurebad.de>
arch/x86/mach-default/setup.c
Semantic conflict resolution:
arch/x86/kernel/setup.c
controller
Add support for inverted rdy_busy pin for Atmel nand device controller
It will fix building error on NeoCore926 board.
Acked-by: Andrew Victor <linux@maxim.org.za>
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Signed-off-by: Gregory CLEMENT <gclement@adeneo.adetelgroup.com>
User space can request hardware and/or software time stamping.
Reporting of the result(s) via a new control message is enabled
separately for each field in the message because some of the
fields may require additional computation and thus cause overhead.
User space can tell the different kinds of time stamps apart
and choose what suits its needs.
When a TX timestamp operation is requested, the TX skb will be cloned
and the clone will be time stamped (in hardware or software) and added
to the socket error queue of the skb, if the skb has a socket
associated with it.
The actual TX timestamp will reach userspace as a RX timestamp on the
cloned packet. If timestamping is requested and no timestamping is
done in the device driver (potentially this may use hardware
timestamping), it will be done in software after the device's
start_hard_xmit routine.
Signed-off-by: Patrick Ohly <patrick.ohly@intel.com>
To add a bit in the preempt_count to be set when in NMI context, we
found that some archs did not have enough bits to spare. This is
due to the hardirq_count being a mask that can hold NR_IRQS.
Some archs allow for over 16000 IRQs, and that would require a mask
of 14 bits. The sofitrq mask is 8 bits and the preempt disable mask
is also 8 bits. The PREEMP_ACTIVE bit is bit 30, and bit 31 would
make the preempt_count (which is type int) a negative number.
A negative preempt_count is a sign of failure.
Add them up 14+8+8+1+1 you get 32 bits. No room for the NMI bit.
But the hardirq_count is to track the number of nested IRQs, not
the number of total IRQs. This originally took the paranoid approach
of setting the max nesting to NR_IRQS. But when we have archs with
over 1000 IRQs, it is not practical to think they will ever all
nest on a single CPU. Not to mention that this would most definitely
cause a stack overflow.
This patch sets a max of 10 bits to be used for IRQ nesting.
I did a 'git grep HARDIRQ' to examine all users of HARDIRQ_BITS and
HARDIRQ_MASK, and found that making it a max of 10 would not hurt
anyone. I did find that the m68k expected it to be 8 bits, so
I allow for the archs to set the number to be less than 10.
I removed the setting of HARDIRQ_BITS from the archs that set it
to more than 10. This includes ALPHA, ia64 and avr32.
This will always allow room for the NMI bit, and if we need to allow
for NMI nesting, we have 4 bits to play with.
fix the following 'make headers_check' warnings:
usr/include/asm-avr32/swab.h:7: include of <linux/types.h> is preferred over <asm/types.h>
usr/include/asm-avr32/swab.h:22: found __[us]{8,16,32,64} type without #include <linux/types.h>
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Use .subsection to place fixups closer to their jump targets. This
increases the maximum size of the kernel before we get link errors
significantly.
The problem here is that we don't have a "call"-ish pseudo-instruction
to use instead of rjmp...we could add one, but that means we'll have to
wait for a new toolchain release, wait until we're fairly sure most
people are using it, etc...
As an added bonus, it should decrease the RAM footprint slightly,
though it might pollute the icache a bit more.
Replace handcoded rcall instructions with the call pseudo-instruction.
For kernels too far over 1MB the rcall instruction can't reach and
linking will fail. We already call the final linker with --relax which
converts call pseudo-instructions to the right things anyway.
This fixes
arch/avr32/kernel/built-in.o: In function `syscall_exit_work':
(.ex.text+0x198): relocation truncated to fit: R_AVR32_22H_PCREL against symbol `schedule' defined in .sched.text section in kernel/built-in.o
arch/avr32/kernel/built-in.o: In function `fault_exit_work':
(.ex.text+0x3b6): relocation truncated to fit: R_AVR32_22H_PCREL against symbol `schedule' defined in .sched.text section in kernel/built-in.o
But I'm still left with
arch/avr32/kernel/built-in.o:(.fixup+0x2): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+45a
arch/avr32/kernel/built-in.o:(.fixup+0x8): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+8ea
arch/avr32/kernel/built-in.o:(.fixup+0xe): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+abe
arch/avr32/kernel/built-in.o:(.fixup+0x14): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+ac8
arch/avr32/kernel/built-in.o:(.fixup+0x1a): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+ad2
arch/avr32/kernel/built-in.o:(.fixup+0x20): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+adc
arch/avr32/kernel/built-in.o:(.fixup+0x26): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+ae6
arch/avr32/kernel/built-in.o:(.fixup+0x2c): relocation truncated to fit: R_AVR32_22H_PCREL against `.text'+af0
arch/avr32/kernel/built-in.o:(.fixup+0x32): additional relocation overflows omitted from the output
These are caused by a similar problem with 'rjmp' instructions.
Unfortunately, there's no easy fix for these at the moment since we
don't have a arbitrary-range 'jmp' instruction similar to 'call'.
Signed-off-by: Ben Nizette <bn@niasdigital.com>
Add swab.h to kbuild.asm and remove the individual entries from
each arch, mark as unifdef as some arches have some kernel-only
bits inside.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
so we could move kstat_irqs array to irq_desc struct.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (22 commits)
ioat: fix self test for multi-channel case
dmaengine: bump initcall level to arch_initcall
dmaengine: advertise all channels on a device to dma_filter_fn
dmaengine: use idr for registering dma device numbers
dmaengine: add a release for dma class devices and dependent infrastructure
ioat: do not perform removal actions at shutdown
iop-adma: enable module removal
iop-adma: kill debug BUG_ON
iop-adma: let devm do its job, don't duplicate free
dmaengine: kill enum dma_state_client
dmaengine: remove 'bigref' infrastructure
dmaengine: kill struct dma_client and supporting infrastructure
dmaengine: replace dma_async_client_register with dmaengine_get
atmel-mci: convert to dma_request_channel and down-level dma_slave
dmatest: convert to dma_request_channel
dmaengine: introduce dma_request_channel and private channels
net_dma: convert to dma_find_channel
dmaengine: provide a common 'issue_pending_all' implementation
dmaengine: centralize channel allocation, introduce dma_find_channel
dmaengine: up-level reference counting to the module level
This file was added to the old include/asm-avr32/ directory by mistake.
Whatever the hell that is. Needed to make kernel/trace/trace.c compile
again.
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (60 commits)
uio: make uio_info's name and version const
UIO: Documentation for UIO ioport info handling
UIO: Pass information about ioports to userspace (V2)
UIO: uio_pdrv_genirq: allow custom irq_flags
UIO: use pci_ioremap_bar() in drivers/uio
arm: struct device - replace bus_id with dev_name(), dev_set_name()
libata: struct device - replace bus_id with dev_name(), dev_set_name()
avr: struct device - replace bus_id with dev_name(), dev_set_name()
block: struct device - replace bus_id with dev_name(), dev_set_name()
chris: struct device - replace bus_id with dev_name(), dev_set_name()
dmi: struct device - replace bus_id with dev_name(), dev_set_name()
gadget: struct device - replace bus_id with dev_name(), dev_set_name()
gpio: struct device - replace bus_id with dev_name(), dev_set_name()
gpu: struct device - replace bus_id with dev_name(), dev_set_name()
hwmon: struct device - replace bus_id with dev_name(), dev_set_name()
i2o: struct device - replace bus_id with dev_name(), dev_set_name()
IA64: struct device - replace bus_id with dev_name(), dev_set_name()
i7300_idle: struct device - replace bus_id with dev_name(), dev_set_name()
infiniband: struct device - replace bus_id with dev_name(), dev_set_name()
ISDN: struct device - replace bus_id with dev_name(), dev_set_name()
While looking at reducing the amount of architecture namespace pollution
in the generic kernel, I found that asm/irq.h is included in the vast
majority of compilations on ARM (around 650 files.)
Since asm/irq.h includes a sub-architecture include file on ARM, this
causes a negative impact on the ccache's ability to re-use the build
results from other sub-architectures, so we have a desire to reduce the
dependencies on asm/irq.h.
It turns out that a major cause of this is the needless include of
linux/hardirq.h into asm-generic/local.h. The patch below removes this
include, resulting in some 250 to 300 files (around half) of the kernel
then omitting asm/irq.h.
My test builds still succeed, provided two ARM files are fixed
(arch/arm/kernel/traps.c and arch/arm/mm/fault.c) - so there may be
negative impacts for this on other architectures.
Note that x86 does not include asm/irq.h nor linux/hardirq.h in its
asm/local.h, so this patch can be viewed as bringing the generic version
into line with the x86 version.
[kosaki.motohiro@jp.fujitsu.com: add #include <linux/irqflags.h> to acpi/processor_idle.c]
[adobriyan@gmail.com: fix sparc64]
Cc: Alexey Dobriyan <adobriyan@gmail.com>
The atomic_t type cannot currently be used in some header files because it
would create an include loop with asm/atomic.h. Move the type definition
to linux/types.h to break the loop.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: <linux-arch@vger.kernel.org>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
dma_request_channel provides an exclusive channel, so we no longer need to
pass slave data through dmaengine.
Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
In the defconfigs for ATNGW100 and ATSTK100[236] the DMA Test driver is
compiled as a module. This means systems built with *_defconfig +
CONFIG_MODULES=n are unusable as the 3 dma test channels monopolise the
CPU.
I 'spose Haavard uses this module a lot but IMO it isn't really
something needed on all eval boards by default.
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b,
alloc_bootmem and related functions never return NULL and always return a
zeroed region of memory. Thus a NULL test or memset after calls to these
functions is unnecessary.
This was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
expression E;
statement S;
E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\|alloc_bootmem_node\|alloc_bootmem_low_pages_node\|alloc_bootmem_pages_node\)(...)
... when != E
- BUG_ON (E == NULL);
- if (E == NULL) S
expression E,E1;
... when != E
- memset(E,0,E1);
// </smpl>
at32_add_device_mci() will refuse to add the mci device if the data
parameter is NULL. Fix up the favr-32 and hammerhead boards so that this
doesn't happen.
Cc: Alex Raimondi <mailinglist@miromico.ch>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Needed to use the atmel-mci driver in an architecture
independant maner.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The Hammerhead platform is built around a AVR32 32-bit microcontroller
from Atmel. It offers versatile peripherals, such as ethernet, usb
device, usb host etc.
The board also incooperates a power supply and is a Power over Ethernet
(PoE) Powered Device (PD).
Additonally, a Cyclone III FPGA from Altera is integrated on the board.
The FPGA is mapped into the 32-bit AVR memory bus. The FPGA offers two
DDR2 SDRAM interfaces, which will cover even the most exceptional need
of memory bandwidth. Together with the onboard video decoder the board
is ready for video processing.
This patch does include the basic support for the fpga device driver,
but not the device driver itself.
Signed-off-by: Alex Raimondi <mailinglist@miromico.ch>
at32_reserve_pin now takes an u32 bitmask rather than a single pin.
This allows to reserve multiple pins at once.
Remove (undocumented) SDCS (pin PE26) from reservation in board
setup code.
Signed-off-by: Alex Raimondi <raimondi@miromico.ch>
at32_add_system_devices() is deprecated, so remove the call to it.
This patch removes a call to the deprecated function
at32_add_system_devices().
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
(I did not compile or test it, please let me know, or help fixing
it, if something is wrong with the conversion)
This patch is part of a larger patch series which will remove
the "char bus_id[20]" name string from struct device. The device
name is managed in the kobject anyway, and without any size
limitation, and just needlessly copied into "struct device".
To set and read the device name dev_name(dev) and dev_set_name(dev)
must be used. If your code uses static kobjects, which it shouldn't
do, "const char *init_name" can be used to statically provide the
name the registered device should have. At registration time, the
init_name field is cleared, to enforce the use of dev_name(dev) to
access the device name at a later time.
We need to get rid of all occurrences of bus_id in the entire tree
to be able to enable the new interface. Please apply this patch,
and possibly convert any remaining remaining occurrences of bus_id.
We want to submit a patch to -next, which will remove bus_id from
"struct device", to find the remaining pieces to convert, and finally
switch over to the new api, which will remove the 20 bytes array
and does no longer have a size limitation.
Thanks,
Kay
Subject: avr: struct device - replace bus_id with dev_name(), dev_set_name()
* 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits)
x86: setup_per_cpu_areas() cleanup
cpumask: fix compile error when CONFIG_NR_CPUS is not defined
cpumask: use alloc_cpumask_var_node where appropriate
cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t
x86: use cpumask_var_t in acpi/boot.c
x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids
sched: put back some stack hog changes that were undone in kernel/sched.c
x86: enable cpus display of kernel_max and offlined cpus
ia64: cpumask fix for is_affinity_mask_valid()
cpumask: convert RCU implementations, fix
xtensa: define __fls
mn10300: define __fls
m32r: define __fls
h8300: define __fls
frv: define __fls
cris: define __fls
cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS
cpumask: zero extra bits in alloc_cpumask_var_node
cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/
cpumask: convert mm/
* 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits)
x86: export vector_used_by_percpu_irq
x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and()
sched: nominate preferred wakeup cpu, fix
x86: fix lguest used_vectors breakage, -v2
x86: fix warning in arch/x86/kernel/io_apic.c
sched: fix warning in kernel/sched.c
sched: move test_sd_parent() to an SMP section of sched.h
sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0
sched: activate active load balancing in new idle cpus
sched: bias task wakeups to preferred semi-idle packages
sched: favour lower logical cpu number for sched_mc balance
sched: framework for sched_mc/smt_power_savings=N
sched: convert BALANCE_FOR_xx_POWER to inline functions
x86: use possible_cpus=NUM to extend the possible cpus allowed
x86: fix cpu_mask_to_apicid_and to include cpu_online_mask
x86: update io_apic.c to the new cpumask code
x86: Introduce topology_core_cpumask()/topology_thread_cpumask()
x86: xen: use smp_call_function_many()
x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c
Fixed up trivial conflict in kernel/time/tick-sched.c manually
Like fls, but can't be handed 0 and returns the bit number.
(I broke this arch in linux-next by using __fls in generic code).
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
