path: root/arch/blackfin/Kconfig
2012-12-19Bury the conditionals from kernel_thread/kernel_execve seriesAl Viro
All architectures have CONFIG_GENERIC_KERNEL_THREAD CONFIG_GENERIC_KERNEL_EXECVE __ARCH_WANT_SYS_EXECVE None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers of kernel_execve() (which is a trivial wrapper for do_execve() now) left. Kill the conditionals and make both callers use do_execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-14blackfin: convert kernel_thread() and kernel_execve() to generic onesAl Viro
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-09Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge patches from Andrew Morton: "A few misc things and very nearly all of the MM tree. A tremendous amount of stuff (again), including a significant rbtree library rework." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (160 commits) sparc64: Support transparent huge pages. mm: thp: Use more portable PMD clearing sequenece in zap_huge_pmd(). mm: Add and use update_mmu_cache_pmd() in transparent huge page code. sparc64: Document PGD and PMD layout. sparc64: Eliminate PTE table memory wastage. sparc64: Halve the size of PTE tables sparc64: Only support 4MB huge pages and 8KB base pages. memory-hotplug: suppress "Trying to free nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning mm: memcg: clean up mm_match_cgroup() signature mm: document PageHuge somewhat mm: use %pK for /proc/vmallocinfo mm, thp: fix mlock statistics mm, thp: fix mapped pages avoiding unevictable list on mlock memory-hotplug: update memory block's state and notify userspace memory-hotplug: preparation to notify memory block's state at memory hot remove mm: avoid section mismatch warning for memblock_type_name make GFP_NOTRACK definition unconditional cma: decrease cc.nr_migratepages after reclaiming pagelist CMA: migrate mlocked pages kpageflags: fix wrong KPF_THP on non-huge compound pages ...
2012-10-09Kconfig: clean up the long arch list for the UID16 config optionCatalin Marinas
Introduce HAVE_UID16 config option and select it in corresponding architecture Kconfig files. UID16 now only depends on HAVE_UID16. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-08Blackfin: add bf548 v0.4 revisionSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-09-28Make most arch asm/module.h files use asm-generic/module.hDavid Howells
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela, ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version into asm-generic/module.h for all arches bar MIPS. Also, use the generic definition mod_arch_specific where possible. To this end, I've defined three new config bools: (*) HAVE_MOD_ARCH_SPECIFIC Arches define this if they don't want to use the empty generic mod_arch_specific struct. (*) MODULES_USE_ELF_RELA Arches define this if their modules can contain RELA records. This causes the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be defined by the arch rather than have the core emit an error message. (*) MODULES_USE_ELF_REL Arches define this if their modules can contain REL records. This causes the Elf_Rel mapping to be emitted and allows apply_relocate() to be defined by the arch rather than have the core emit an error message. Note that it is possible to allow both REL and RELA records: m68k and mips are two arches that do this. With this, some arch asm/module.h files can be deleted entirely and replaced with a generic-y marker in the arch Kbuild file. Additionally, I have removed the bits from m32r and score that handle the unsupported type of relocation record as that's now handled centrally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-07blackfin: smp: adapt to generic smp helpersSteven Miao
Replace blackfin ipi message queue with generic smp helper function. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-30Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's first set of patches: "Non-MM patches: - lots of misc bits - tree-wide have_clk() cleanups - quite a lot of printk tweaks. I draw your attention to "printk: convert the format for KERN_<LEVEL> to a 2 byte pattern" which looks a bit scary. But afaict it's solid. - backlight updates - lib/ feature work (notably the addition and use of memweight()) - checkpatch updates - rtc updates - nilfs updates - fatfs updates (partial, still waiting for acks) - kdump, proc, fork, IPC, sysctl, taskstats, pps, etc - new fault-injection feature work" * Merge emailed patches from Andrew Morton <akpm@linux-foundation.org>: (128 commits) drivers/misc/lkdtm.c: fix missing allocation failure check lib/scatterlist: do not re-write gfp_flags in __sg_alloc_table() fault-injection: add tool to run command with failslab or fail_page_alloc fault-injection: add selftests for cpu and memory hotplug powerpc: pSeries reconfig notifier error injection module memory: memory notifier error injection module PM: PM notifier error injection module cpu: rewrite cpu-notifier-error-inject module fault-injection: notifier error injection c/r: fcntl: add F_GETOWNER_UIDS option resource: make sure requested range is included in the root range include/linux/aio.h: cpp->C conversions fs: cachefiles: add support for large files in filesystem caching pps: return PTR_ERR on error in device_create taskstats: check nla_reserve() return sysctl: suppress kmemleak messages ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSION ipc: compat: use signed size_t types for msgsnd and msgrcv ipc: allow compat IPC version field parsing if !ARCH_WANT_OLD_COMPAT_IPC ipc: add COMPAT_SHMLBA support ...
2012-07-30ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSIONWill Deacon
Rather than #define the options manually in the architecture code, add Kconfig options for them and select them there instead. This also allows us to select the compat IPC version parsing automatically for platforms using the old compat IPC interface. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30Merge branch 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull PWM subsystem from Thierry Reding: "The new PWM subsystem aims at collecting all implementations of the legacy PWM API and to eventually replace it completely. The subsystem has been in development for over half a year now and many drivers have already been converted. It has been in linux-next for a couple of weeks and there have been no major issues so I think it is ready for inclusion in your tree." Arnd Bergmann <arnd@arndb.de>: "Very much Ack on the new subsystem. It uses the interface declarations as the previously separate pwm drivers, so nothing changes for now in the drivers using it, although it enables us to change those more easily in the future if we want to. This work is also one of the missing pieces that are required to eventually build ARM kernels for multiple platforms, which is currently prohibited (amongs other things) by the fact that you cannot have more than one driver exporting the pwm functions." Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Philip, Avinash <avinashphilip@ti.com> # TI's AM33xx platforms Acked-By: Alexandre Pereira da Silva <aletes.xgr@gmail.com> # LPC32XX Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sachin Kamat <sachin.kamat@linaro.org> Fix up trivial conflicts with other cleanups and DT updates. * 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwm: (36 commits) pwm: pwm-tiehrpwm: PWM driver support for EHRPWM pwm: pwm-tiecap: PWM driver support for ECAP APWM pwm: fix used-uninitialized warning in pwm_get() pwm: add lpc32xx PWM support pwm_backlight: pass correct brightness to callback pwm: Use pr_* functions in pwm-samsung.c file pwm: Convert pwm-samsung to use devm_* APIs pwm: Convert pwm-tegra to use devm_clk_get() pwm: pwm-mxs: Return proper error if pwmchip_remove() fails pwm: pwm-bfin: Return proper error if pwmchip_remove() fails pwm: pxa: Propagate pwmchip_remove() error pwm: Convert pwm-pxa to use devm_* APIs pwm: Convert pwm-vt8500 to use devm_* APIs pwm: Convert pwm-imx to use devm_* APIs pwm: Conflict with legacy PWM API pwm: pwm-mxs: add pinctrl support pwm: pwm-mxs: use devm_* managed functions pwm: pwm-mxs: use global reset function stmp_reset_block pwm: pwm-mxs: encode soc name in compatible string pwm: Take over maintainership of the PWM subsystem ...
2012-07-24cache: enable L2 sram icache in menuconfigSteven Miao
2012-07-24blackfin: Kconfig: fix ROM range for bf60xBob Liu
ROM range of bf60x is above 0xb0000000. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bfin: reorg clock init steps for bf609Bob Liu
So that user can set the clocks through menuconfig. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-24bfin: add 32M, 16M and 8M uncached DMA region optionsScott Jiang
We need larger DMA region to support HD video. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-07-02pwm: Move Blackfin PWM driver to PWM frameworkThierry Reding
This commit moves the Blackfin PWM driver to the drivers/pwm sub- directory and converts it to register with the new PWM framework. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-05-24Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO driver changes from Grant Likely: "Lots of gpio changes, both to core code and drivers. Changes do touch architecture code to remove the need for separate arm/gpio.h includes in most architectures. Some new drivers are added, and a number of gpio drivers are converted to use irq_domains for gpio inputs used as interrupts. Device tree support has been amended to allow multiple gpio_chips to use the same device tree node. Remaining changes are primarily bug fixes." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (33 commits) gpio/generic: initialize basic_mmio_gpio shadow variables properly gpiolib: Remove 'const' from data argument of gpiochip_find() gpio/rc5t583: add gpio driver for RICOH PMIC RC5T583 gpiolib: quiet gpiochip_add boot message noise gpio: mpc8xxx: Prevent NULL pointer deref in demux handler gpio/lpc32xx: Add device tree support gpio: Adjust of_xlate API to support multiple GPIO chips gpiolib: Implement devm_gpio_request_one() gpio-mcp23s08: dbg_show: fix pullup configuration display Add support for TCA6424A gpio/omap: (re)fix wakeups on level-triggered GPIOs gpio/omap: fix broken context restore for non-OFF mode transitions gpio/omap: fix missing check in *_runtime_suspend() gpio/omap: remove cpu_is_omapxxxx() checks from *_runtime_resume() gpio/omap: remove suspend/resume callbacks gpio/omap: remove retrigger variable in gpio_irq_handler gpio/omap: remove saved_wakeup field from struct gpio_bank gpio/omap: remove suspend_wakeup field from struct gpio_bank gpio/omap: remove saved_fallingdetect, saved_risingdetect gpio/omap: remove virtual_irq_start variable ... Conflicts: drivers/gpio/gpio-samsung.c
2012-05-24Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner. Various trivial conflict fixups in arch Kconfig due to addition of unrelated entries nearby. And one slightly more subtle one for sparc32 (new user of GENERIC_CLOCKEVENTS), fixed up as per Thomas. * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits) timekeeping: Fix a few minor newline issues. time: remove obsolete declaration ntp: Fix a stale comment and a few stray newlines. ntp: Correct TAI offset during leap second timers: Fixup the Kconfig consolidation fallout x86: Use generic time config unicore32: Use generic time config um: Use generic time config tile: Use generic time config sparc: Use: generic time config sh: Use generic time config score: Use generic time config s390: Use generic time config openrisc: Use generic time config powerpc: Use generic time config mn10300: Use generic time config mips: Use generic time config microblaze: Use generic time config m68k: Use generic time config m32r: Use generic time config ...
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-21Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull smp hotplug cleanups from Thomas Gleixner: "This series is merily a cleanup of code copied around in arch/* and not changing any of the real cpu hotplug horrors yet. I wish I'd had something more substantial for 3.5, but I underestimated the lurking horror..." Fix up trivial conflicts in arch/{arm,sparc,x86}/Kconfig and arch/sparc/include/asm/thread_info_32.h * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) um: Remove leftover declaration of alloc_task_struct_node() task_allocator: Use config switches instead of magic defines sparc: Use common threadinfo allocator score: Use common threadinfo allocator sh-use-common-threadinfo-allocator mn10300: Use common threadinfo allocator powerpc: Use common threadinfo allocator mips: Use common threadinfo allocator hexagon: Use common threadinfo allocator m32r: Use common threadinfo allocator frv: Use common threadinfo allocator cris: Use common threadinfo allocator x86: Use common threadinfo allocator c6x: Use common threadinfo allocator fork: Provide kmemcache based thread_info allocator tile: Use common threadinfo allocator fork: Provide weak arch_release_[task_struct|thread_info] functions fork: Move thread info gfp flags to header fork: Remove the weak insanity sh: Remove cpu_idle_wait() ...
2012-05-21timers: Fixup the Kconfig consolidation falloutThomas Gleixner
Sigh, I missed to check which architecture Kconfig files actually include the core Kconfig file. There are a few which did not. So we broke them. Instead of adding the includes to those, we are better off to move the include to init/Kconfig like we did already with irqs and others. This does not change anything for the architectures using the old style periodic timer mode. It just solves the build wreckage there. For those architectures which use the clock events infrastructure it moves the include of the core Kconfig file to "General setup" which is a way more logical place than having it at random locations specified by the architecture specific Kconfigs. Reported-by: Ingo Molnar <mingo@kernel.org> Cc: Anna-Maria Gleixner <anna-maria@glx-um.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-21blackfin: Use generic time configAnna-Maria Gleixner
Use seperate selector for clockevents. Signed-off-by: Anna-Maria Gleixner <anna-maria@glx-um.de> Cc: Mike Frysinger <vapier@gentoo.org> Link: http://lkml.kernel.org/r/20120518163105.026597932@glx-um.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-21blackfin: bf60x: add wakeup source selectSteven Miao
Support select the wakeup source for power management on bf60x. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-05-21blackfin: bf60x: make clock changeable in kernel menuconfigBob Liu
Add clock changeable support in kernel menuconfig for bf60x. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-05-21blackfin: add bf60x to current frameworkBob Liu
This patch added bf60x to current blackfin kernel framework. Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-05-11gpiolib/arches: Centralise bolierplate asm/gpio.hMark Brown
Rather than requiring architectures that use gpiolib but don't have any need to define anything custom to copy an asm/gpio.h provide a Kconfig symbol which architectures must select in order to include gpio.h and for other architectures just provide the trivial implementation directly. This makes it much easier to do gpiolib updates and is also a step towards making gpiolib APIs available on every architecture. For architectures with existing boilerplate code leave a stub header in place which warns on direct inclusion of asm/gpio.h and includes linux/gpio.h to catch code that's doing this. Direct inclusion of asm/gpio.h has long been deprecated. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jonas Bonn <jonas@southpole.se> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-05-05init_task: Replace CONFIG_HAVE_GENERIC_INIT_TASKThomas Gleixner
Now that all archs except ia64 are converted, replace the config and let the ia64 select CONFIG_ARCH_INIT_TASK Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120503085035.867948914@linutronix.de
2012-05-05blackfin: Use generic init_taskThomas Gleixner
Same code. Use the generic version. The special Makefile treatment is pointless anyway as init_task.o contains only data which is handled by the linker script. So no point on being treated like head text. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Frysinger <vapier@gentoo.org> Link: http://lkml.kernel.org/r/20120503085034.350246420@linutronix.de
2012-04-26blackfin: Use generic idle thread allocationThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Link: http://lkml.kernel.org/r/20120420124557.717064871@linutronix.de
2012-04-18Fix "the the" in various KconfigMasanari Iida
Fix typo "the the" in various Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-04-06blackfin: fix L1 data A overflow link issueMike Frysinger
This patch fix below compile error: "bfin-uclinux-ld: L1 data A overflow!" It is due to the recent lib/gen_crc32table.c change: 46c5801eaf86e83cb3a4142ad35188db5011fff0 crc32: bolt on crc32c it added 8KiB more data to __cacheline_aligned which cause blackfin L1 data cache overflow. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-03-23nmi watchdog: do not use cpp symbol in KconfigCong Wang
ARCH_HAS_NMI_WATCHDOG is a macro defined by arch, but config HARDLOCKUP_DETECTOR depends on it. This is wrong, ARCH_HAS_NMI_WATCHDOG has to be a Kconfig config, and arch's need it should select it explicitly. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Don Zickus <dzickus@redhat.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-25Blackfin: drop unused Kconfig symbolPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: pwm: implement linux/pwm.h APIMike Frysinger
For now, this only supports gptimers. Support for dedicated PWM devices as found on newer parts to come. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Blackfin: initial perf_event supportMike Frysinger
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-22Blackfin: enable atomic64_t supportMike Frysinger
2011-03-18Blackfin: enable GENERIC_HARDIRQS_NO_DEPRECATEDThomas Gleixner
All chips converted. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-03-18Blackfin: SMP: work around anomaly 05000491Sonic Zhang
In order to safely work around anomaly 05000491, we have to execute IFLUSH from L1 instruction sram. The trouble with multi-core systems is that all L1 sram is visible only to the active core. So we can't just place the functions into L1 and call it directly. We need to setup a jump table and place the entry point in external memory. This will call the right func based on the active core. In the process, convert from the manual relocation of a small bit of code into Core B's L1 to the more general framework we already have in place for loading arbitrary pieces of code into L1. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-03-18Blackfin: split optimization settings moreMike Frysinger
We need to place icache flush funcs into L1 inst sram to work around a hardware anomaly. But this currently breaks SMP support as the L1 inst sram is per-core and cannot be called directly. So in preparation for making that work, split the two options. Further, split out the SMP depend so that we can allow some for SMP. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-21blackfin: Use generic irq KconfigThomas Gleixner
No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Frysinger <vapier@gentoo.org>
2011-01-21genirq: Remove __do_IRQThomas Gleixner
All architectures are finally converted. Remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Michal Simek <monstr@monstr.eu> Acked-by: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com>
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-22Blackfin: glue XIP/ROM kernel kconfigsMike Frysinger
Different arches use different names, so make sure we define both so common code (like MTD_XIP) "just works". Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-22Blackfin: bf51x: enable support for 0.2 siliconMike Frysinger
2010-10-22Blackfin: ad7160eval: new board portMichael Hennerich
2010-10-12Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
We need to revert the temporary hack in 71ebc01, hence the merge.
2010-09-19kbuild: migrate all arch to the kconfig mainmenu upgradeArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-08-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (32 commits) Blackfin: gpio: add a debounce stub Blackfin: update defconfigs Blackfin: remove CONFIG_MEM_GENERIC_BOARD Blackfin: dpmc: punt unnecessary RTC_ISTAT clearing Blackfin: unify rotary encoder bitmasks Blackfin: unify SDH/RSI bitmasks Blackfin: BF54x: tweak DMAC MMR naming to match other ports Blackfin: TWI: clean up the MMR names Blackfin: add EVT_OVERRIDE/IPRIO core MMR helpers Blackfin: add support for dynamic ftrace Blackfin: add support for LZO compressed kernels Blackfin: portmux: fix peripheral map overflow when requesting pins Blackfin: document SPI CS limitations with CPHA=0 Blackfin: remove useless and outdated documentation Blackfin: BF51x/BF52x: support GPIO Hysteresis/Schmitt Trigger options Blackfin: gpio/portmux: clean up whitespace corruption Blackfin: make sure mmiowb inserts a write barrier with SSYNC Blackfin: fix DMA/cache bug when resuming from suspend to RAM Blackfin: BF51x: fix handling of PH8 (the "internal" SPI0SEL4 pin) Blackfin: add a GPIO_DEFAULT_BOOT_SPI_CS ...
