path: root/arch/blackfin/configs/BF527-EZKIT_defconfig
2011-05-25Blackfin: bf527-ezkit: tweak sound defconfigMike Frysinger
Build the sound pieces that the board actually has into the kernel, and punt older devices that we discourage. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-03-18Blackfin: ADI boards: enable pseudo debug insns supportMike Frysinger
We use these insns when testing, so enable them by default for all of our development boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Blackfin: update defconfigsMike Frysinger
- enable pm for ADI boards - drop security option as no one uses it - enable uninitialized mmap for everyone - disable wireless by default as no one uses it - disable cfq io sched as noop is fine Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-06Blackfin: update defconfigsMike Frysinger
2010-03-09Blackfin: update defconfigsSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Barry Song <barry.song@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: update defconfigsMike Frysinger
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-16Blackfin: increase default async timings for parallel flashesSonic Zhang
The default async timings are a little too fast for the parallel flash that is attached by default to the async banks. So slow things down a bit so accessing the hardware is stable. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-22Blackfin: update defconfigsMike Frysinger
2009-06-12Blackfin: update defconfigsSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-03-28Blackfin arch: update default kernel configurationSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-03-04Blackfin arch: Enable Write Back Cache on all Blackfin BoardsMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-02-04Blackfin arch: build jtag tty driver as a module by defaultMike Frysinger
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2009-01-07Blackfin arch: update board default configsSonic Zhang
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-07Blackfin arch: merge adeos blackfin part to arch/blackfin/Yi Li
[Mike Frysinger <vapier.adi@gmail.com>: - handle bf531/bf532/bf534/bf536 variants in ipipe.h - cleanup IPIPE logic for bfin_set_irq_handler() - cleanup ipipe asm code a bit and add missing ENDPROC() - simplify IPIPE code in trap_c - unify some of the IPIPE code and fix style - simplify DO_IRQ_L1 handling with ipipe code - revert IRQ_SW_INT# addition from ipipe merge - remove duplicate get_{c,s}clk() prototypes ] Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-07Blackfin arch: enable DEBUG_KERNEL for ADI boardsMike Frysinger
2009-01-07Blackfin arch: Set TWI/I2C Clock to 100kHzMike Frysinger
All slaves I'm aware of should support at least 100kHz Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-11-18Blackfin arch: update defconfig file for all boardsMike Frysinger
- do not bother generating deprecated /sys files by default now since mdev does not need it - Don't built-in char sport driver and build it as a module in defconfig - disable CONFIG_DEVKMEM by default - enable spi flash driver on boards that have one - switch config to the NAND platfrom driver rather than the bfin async one - do not make BFIN_DMA_5XX optional since a large portion of our code relies on dma functions existing Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-10-16Blackfin arch: disable CONFIG_HW_RANDOM and CONFIG_DAB in defconfig filesMike Frysinger
2008-07-26Blackfin arch: update board defconfigsSonic Zhang
2008-05-19Blackfin arch: update boards defconfig filesMichael Hennerich
2008-04-24[Blackfin] arch: boards and machines defconfig updatesBryan Wu
2008-02-29[Blackfin] arch: turn generic time on by defaultMike Frysinger
2008-02-22[Blackfin] arch: Update default configSonic Zhang
2008-01-24[Blackfin] arch: update defconfig of boardsBryan Wu
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-11-21Blackfin arch: update defconfig filesMike Frysinger
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-10-30Blackfin arch: update board defconfig files according to latest information ↵Bryan Wu
from ADI datasheet Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-10-21Blackfin arch: add new processor ADSP-BF52x arch/mach supportMichael Hennerich
