We use these insns when testing, so enable them by default for all
of our development boards.
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
- enable pm for ADI boards
- drop security option as no one uses it
- enable uninitialized mmap for everyone
- disable wireless by default as no one uses it
- disable cfq io sched as noop is fine
Use the defconfig files generated by "make savedefconfig" for
remaining defconfig files.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Barry Song <barry.song@analog.com>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
Signed-off-by: Yi Li <yi.li@analog.com>
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
Signed-off-by: Graf Yang <graf.yang@analog.com>
The default async timings are a little too fast for the parallel flash
that is attached by default to the async banks. So slow things down a bit
so accessing the hardware is stable.
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Now that all EEPROM drivers live in the same place, let's harmonize
their symbol names.
Also fix eeprom's dependencies, it definitely needs sysfs, and is no
longer experimental after many years in the kernel tree.
Cc: David Brownell <dbrownell@users.sourceforge.net>
All slaves I'm aware of should support at least 100kHz
Turn to use the mmc_spi driver in mainline kernel.
- do not bother generating deprecated /sys files by default now since
mdev does not need it
- Don't built-in char sport driver and build it as a module in defconfig
- disable CONFIG_DEVKMEM by default
- enable spi flash driver on boards that have one
- switch config to the NAND platfrom driver rather than the bfin async one
- do not make BFIN_DMA_5XX optional since a large portion of our code relies
on dma functions existing
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com>
from ADI datasheet
Signed-off-by: Robin Getz <robin.getz@analog.com>
now all BLKFIN should be BFIN, should be no functional changes.
