path: root/arch/blackfin/lib/checksum.c
2009-06-13Blackfin: export ip_compute_csum/csum_partial_copy_from_user symbolsMike Frysinger
All other arches do this, and some places like the net/scsi code will fail as modules without them. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-28Blackfin arch: move EXPORT_SYMBOL to the place where it is actually definedMike Frysinger
- kernel_thread - irq_flags - checksum Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-12[Blackfin] arch: Blackfin checksum annotationsAl Viro
FSVOtest in this case, since I don't have the hardware... However, all changes seen by gcc are actually - explicit cast to unsigned short in return expression of functions returning unsigned short - csum_fold() return type changed from unsigned int to __sum16 (unsigned short), same as for all other architecture and as net/* expects; expression actually returned is ((~(sum << 16)) >> 16) with sum being unsigned 32bit, so it's (a) going to fit into the range of unsigned short and (b) had been unsigned all along, so no sign expansion mess happened. Tested-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Miller <davem@davemloft.net> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
