path: root/arch/blackfin/lib
2011-06-03Blackfin: strncpy: fix handling of zero lengthsSteven Miao
The jump to 4f will cause the NUL padding loop to run at least one time, so if string length is zero just jump to the end. Otherwise we wrongly write one NUL byte when size==0. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-03-04Blackfin: outs[lwb]: make sure count is greater than 0Mike Frysinger
Some devices will use the outs* funcs with a length of zero, so make sure we do not write any data in that case. Reported-by: Gilbert Inho <gneny@edevice.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: optimize strncpy a bitRobin Getz
Add a little strncpy optimization which can easily cut boot time by 20%. When the kernel is booting with initramfs, it builds up the filesystem from a cpio archive by calling strncpy_from_user() via fs/namei.c's do_getname() on every file in the archive (which can be lots) with a length of PATH_MAX (1024). This causes the dest of the strncpy to be padded with many NUL bytes. This optimization mostly causes these NUL bytes to be padded with a call to memset() which is already optimized for filling memory quickly, but the hardware loop helps a little bit as well. Boot time measured with 'loglevel=0' so UART speed doesn't get in the way. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: move string functions to normal lib/ assemblyRobin Getz
Since 'extern inline' doesn't work correctly in the context of the Linux kernel (too many overriding defines), move the string functions to normal lib/ assembly files (like the existing mem funcs). This avoids the forced inline all over the kernel and allows us to place them constantly in L1. This also avoids some module failures when gcc inserts calls to string functions but the kernel build system doesn't fully consult the library archives. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: convert to generic checksum codeMike Frysinger
The Blackfin port only implemented an optimized version of the csum_tcpudp_nofold function, so convert everything else to the new generic code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-07Blackfin: mass clean up of copyright/licensing infoRobin Getz
Bill Gatliff & David Brownell pointed out we were missing some copyrights, and licensing terms in some of the files in ./arch/blackfin, so this fixes things, and cleans them up. It also removes: - verbose GPL text(refer to the top level ./COPYING file) - file names (you are looking at the file) - bug url (it's in the ./MAINTAINERS file) - "or later" on GPL-2, when we did not have that right It also allows some Blackfin-specific assembly files to be under a BSD like license (for people to use them outside of Linux). Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-16Blackfin: fix misnomer of some I-pipe helpersPhilippe Gerum
__ipipe_{stall, unstall}_root_raw() identifiers may leave the reader under the impression that only the virtual state is affected by these operations, which is wrong. Pick names following the convention used throughout the interrupt pipeline code. Signed-off-by: Philippe Gerum <rpm@xenomai.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-16Blackfin: fix miscompilation in lshrdi3Jie Zhang
The code used in the Blackfin lshrdi3 utilizes gcc constructs. However, the structures declared don't line up with the code gcc generates, so under certain optimizations, we get bad code and things crap out in fun random ways. So rather than trying to maintain different gcc definitions ourselves, just use the ones available in gcclib.h. URL: http://blackfin.uclinux.org/gf/tracker/5286 Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-13Blackfin: export ip_compute_csum/csum_partial_copy_from_user symbolsMike Frysinger
All other arches do this, and some places like the net/scsi code will fail as modules without them. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-05-27Blackfin: fix strncmp.o build errorMike Frysinger
Fix some more fallout of the string changes: CC arch/blackfin/lib/strncmp.o In file included from include/linux/bitmap.h:9, from include/linux/nodemask.h:90, from include/linux/mmzone.h:17, from include/linux/gfp.h:5, from include/linux/kmod.h:23, from include/linux/module.h:14, from arch/blackfin/lib/strncmp.c:14: include/linux/string.h: In function ‘strstarts’: include/linux/string.h:132: error: implicit declaration of function ‘strncmp’ make[1]: *** [arch/blackfin/lib/strncmp.o] Error 1 Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Rusty Russell <rusty@rustcorp.com.au>
2009-01-07Blackfin arch: cleanup and unify the ins functionsMike Frysinger
this also fixes some errors in the ipipe merge Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-07Blackfin arch: merge adeos blackfin part to arch/blackfin/Yi Li
[Mike Frysinger <vapier.adi@gmail.com>: - handle bf531/bf532/bf534/bf536 variants in ipipe.h - cleanup IPIPE logic for bfin_set_irq_handler() - cleanup ipipe asm code a bit and add missing ENDPROC() - simplify IPIPE code in trap_c - unify some of the IPIPE code and fix style - simplify DO_IRQ_L1 handling with ipipe code - revert IRQ_SW_INT# addition from ipipe merge - remove duplicate get_{c,s}clk() prototypes ] Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-07Blackfin arch: Replace C version of 64 bit multiply with hand optimized assemblyBernd Schmidt
Signed-off-by: Bernd Schmidt <bernds_cb1@t-online.de> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-10-28Blackfin arch: move EXPORT_SYMBOL to the place where it is actually definedMike Frysinger
- kernel_thread - irq_flags - checksum Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-08-14Blackfin arch: Allow ins functions to have a low latency versionRobin Getz
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-20Blackfin arch: Fix typo. it should be _outsw_8Bryan Wu
2008-05-17Blackfin arch: IO Port functions to read/write unalligned memoryMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-12[Blackfin] arch: Blackfin checksum annotationsAl Viro
FSVOtest in this case, since I don't have the hardware... However, all changes seen by gcc are actually - explicit cast to unsigned short in return expression of functions returning unsigned short - csum_fold() return type changed from unsigned int to __sum16 (unsigned short), same as for all other architecture and as net/* expects; expression actually returned is ((~(sum << 16)) >> 16) with sum being unsigned 32bit, so it's (a) going to fit into the range of unsigned short and (b) had been unsigned all along, so no sign expansion mess happened. Tested-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Miller <davem@davemloft.net> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2007-12-21[Blackfin] arch: fix bug - make memcpy return the dest addr.Yi Li
The memcpy() function returns the src pointer instead of the dst pointer. This patch fix this bug. Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-11-21Blackfin arch: move EXPORT_SYMBOL() to C files where the symbol is actually ↵Mike Frysinger
defined Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-11-17Blackfin arch: Add assembly function insl_16Michael Hennerich
/* * CPUs often take a performance hit when accessing unaligned memory * locations. The actual performance hit varies, it can be small if the * hardware handles it or large if we have to take an exception and fix * it * in software. * * Since an ethernet header is 14 bytes network drivers often end up * with * the IP header at an unaligned offset. The IP header can be aligned by * shifting the start of the packet by 2 bytes. Drivers should do this * with: * * skb_reserve(NET_IP_ALIGN); * * The downside to this alignment of the IP header is that the DMA is * now * unaligned. On some architectures the cost of an unaligned DMA is high * and this cost outweighs the gains made by aligning the IP header. * * Since this trade off varies between architectures, we allow * NET_IP_ALIGN * to be overridden. */ This new function insl_16 allows to read form 32-bit IO and writes to 16-bit aligned memory. This is useful in above described scenario - In particular with the AXIS AX88180 Gigabit Ethernet MAC. Once the device is in 32-bit mode, reads from the RX FIFO always decrements 4bytes. While on the other side the destination address in SDRAM is always 16-bit aligned. If we use skb_reserve(0) the receive buffer is 32-bit aligned but later we hit a unaligned exception in the IP code. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-11-23Blackfin arch: use do_div() for the 64bit division as pointed out by BerndMike Frysinger
If you need a 64 bit divide in the kernel, use asm/div64.h. Revert the addition of udivdi3. Cc: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-10-21Blackfin arch: add assembly function for doing 64bit unsigned divisionMike Frysinger
2007-07-25Blackfin arch: revise anomaly handling by basing things on the compiler not ↵Mike Frysinger
the kconfig defines revise anomaly handling by basing things on the compiler not the kconfig defines, so the header is stable and usable outside of the kernel. This also allows us to move some code from preprocessing to compiling (gcc culls dead code) which should help with code quality (readability, catch minor bugs, etc...). Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-07-12Blackfin arch: cleanup warnings from checkpatch -- no functional changesMike Frysinger
2007-06-21Blackfin arch: update ANOMALY handlingRobin Getz
update lists for 533, 537, and add SSYNC workaround into assembly files. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-06-11Blackfin arch: add proper ENDPROC()Mike Frysinger
add proper ENDPROC() to close out assembly functions so size/type is set properly in the final ELF image Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-05-21Blackfin arch: Add Workaround for ANOMALY 05000257Michael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
