* git://git.infradead.org/mtd-2.6: (97 commits)
mtd: kill CONFIG_MTD_PARTITIONS
mtd: remove add_mtd_partitions, add_mtd_device and friends
mtd: convert remaining users to mtd_device_register()
mtd: samsung onenand: convert to mtd_device_register()
mtd: omap2 onenand: convert to mtd_device_register()
mtd: txx9ndfmc: convert to mtd_device_register()
mtd: tmio_nand: convert to mtd_device_register()
mtd: socrates_nand: convert to mtd_device_register()
mtd: sharpsl: convert to mtd_device_register()
mtd: s3c2410 nand: convert to mtd_device_register()
mtd: ppchameleonevb: convert to mtd_device_register()
mtd: orion_nand: convert to mtd_device_register()
mtd: omap2: convert to mtd_device_register()
mtd: nomadik_nand: convert to mtd_device_register()
mtd: ndfc: convert to mtd_device_register()
mtd: mxc_nand: convert to mtd_device_register()
mtd: mpc5121_nfc: convert to mtd_device_register()
mtd: jz4740_nand: convert to mtd_device_register()
mtd: h1910: convert to mtd_device_register()
mtd: fsmc_nand: convert to mtd_device_register()
Fixed up trivial conflicts in
- drivers/mtd/maps/integrator-flash.c: removed in ARM tree
- drivers/mtd/maps/physmap.c: addition of afs partition probe type
clashing with removal of CONFIG_MTD_PARTITIONS
Now that the Blackfin machine drivers have been updated to the
multicomponent support, update the resources to match. The pin
settings are now a board issue and removed from the driver.
Signed-off-by: Scott Jiang <scott.jiang@analog.com>
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Cc: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
The SPORT/UART driver doesn't use the secondary channel pins, so don't
try and request them thus keeping other drivers from using them.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Move all the pin settings out of the Kconfig and into the platform
resources (MII vs RMII). This clean up also lets us push out the
phy settings so that board porters may control the layout.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
Signed-off-by: steven miao <realmz6@gmail.com>
The predefined i2c address 0x2c doesn't match the configuration of the
ad5280 PINs AD0 and AD1 on the tftlcd add-on board. Both AD0 and AD1
are of voltage 3.3V, which means the i2c address should be 0x2F.
We don't need our own header and structure to hook up the ad5398 part,
so drop the custom resources for it.
Rather than write our own ADP switch driver, use the existing fixed
regulator driver and rewrite the platform resources accordingly.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Barry Song <barry.song@analog.com>
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
Signed-off-by: Yi Li <yi.li@analog.com>
The NAND platform driver expects the registers to have a "mem"
resource type rather than "io".
With the recent kernel update the isp1362-hcd driver evaluates the
IORESOURCE_IRQ resource flags and requests the irq with the given
polarity/edge settings. However the ISP1362 config requires low
level/edge interrupts. Most of the Blackfin boards use some random
flag or no flag at all. Make all boards use a know good flag
IORESOURCE_IRQ_LOWEDGE.
Make sure we use the right Kconfig names and platform strings.
Now that we've rewritten the GPIO CS handling in the Blackfin SPI
peripheral, we need to update the platform resources accordingly.
These two platforms didn't properly fill nr_chips in gen_nand
registration and therefore depended on gen_nand bug fixed by by commit
81cbb0b17796d81cbd92defe113cf2a7c7a21fbb ("mtd: gen_nand: fix support for
multiple chips")
To avoid more patches, I also fixed other spelling
and grammar bugs when they were in the same or
following line:
successfull -> successful
parse -> parses
controler -> controller
controlers -> controllers
Cc: Jiri Kosina <trivial@kernel.org>
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
Signed-off-by: Graf Yang <graf.yang@analog.com>
The ASoC codec driver was generalized and renamed, so update the board
Rather than declaring pin resources in the drivers, do it in the board.
Just generate a random MAC on the demo board since the ADF702x lacks
dedicated storage for such things.
When the kernel is executing out of parallel flash (XIP), we can't have
the flash go into an erase/programming cycle, otherwise the instruction
fetching steps fail and everything crashes.
The Kconfig option was never mainlined, so replace the define with the
actual pin that it is hooked up to by default.
This lets us support the new BF527-EZKIT V2.1 via platform resources
tweaks only.
This lets people easily select the UART/SPORT consoles for early printk
while leveraging the pins declared in the boards file.
Rather than keeping the pins in the actual driver and worrying about a
mess of Kconfig options, declare all the desired pin resources in the
boards file. This lets people easily select the specific pins/ports for
the normal emulated UART as well as GPIOs for CTS/RTS.
the normal UART as well as GPIOs for CTS/RTS.
The ax88180 driver was never merged, so drop the corresponding resources.
