No code uses these, and the short define names are polluting the global
namespace where they collide with things like common irq files. So just
punt the damned things. If in the future we need HDMA support, we can
make a standalone header for these things.
The board doesn't actually have a pin hooked up to do card detection,
so punt the code for it.
Signed-off-by: Andreas Schallenberg <Andreas.Schallenberg@3alitydigital.de>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
The SPORT/UART driver doesn't use the secondary channel pins, so don't
try and request them thus keeping other drivers from using them.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
These were only included because of the irq handling of the PLL funcs,
and those PLL funcs have been moved out into their own header now.
The main asm/blackfin.h header will pull in mach/blackfin.h to get
all the fun Blackfin defines. So having any of the sub-mach headers
trying to include asm/blackfin.h makes no sense -- punt it.
The mach/blackfin.h header takes care of including the part-specific
def headers which in turn will include any other needed def file.
Similarly, it takes care of pulling in the part-specific cdef header.
So move this logic out of the blackfin.h when necessary.
Further, make sure the cdef headers do not waste time including the
def headers again.
Since all parts need the common def/cdef headers, move this logic
out of the part-specific headers and into the mach/blackfin.h file.
Finally, we need to split the BF539 def header since the BF538 does
not have MXVR and we don't want to expose those MMRs.
So now all parts should have the same behavior:
mach/blackfin.h
asm/def_LPBlackfin.h
part-specific def.h
if ! asm
asm/cdef_LPBlackfin.h
part-specific cdef.h
And the sub def/cdef headers only tail into what they need.
The array of pointers is never written, so constify it.
Use the same naming convention for DMA traffic MMRs (most were legacy
anyways) so we can avoid useless ifdef trees.
Same goes for MDMA names -- this actually allows us to undo a bunch of
ifdef redirects that existed for this purpose alone.
Each Blackfin port has been duplicating UART structures and defines when
there really is no need for it. So start a new bfin_serial.h header to
unify all these pieces and give ourselves a fresh start.
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
Move all the pin settings out of the Kconfig and into the platform
resources (MII vs RMII). This clean up also lets us push out the
phy settings so that board porters may control the layout.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
Signed-off-by: steven miao <realmz6@gmail.com>
The predefined i2c address 0x2c doesn't match the configuration of the
ad5280 PINs AD0 and AD1 on the tftlcd add-on board. Both AD0 and AD1
are of voltage 3.3V, which means the i2c address should be 0x2F.
We don't need our own header and structure to hook up the ad5398 part,
so drop the custom resources for it.
Rather than write our own ADP switch driver, use the existing fixed
regulator driver and rewrite the platform resources accordingly.
Some peripherals might generate an error interrupt shortly after the
data interrupt due to the fact that the peripheral isn't serviced fast
enough. In most cases this isn't a problem and is expected behavior.
This hasn't been a problem on most parts since you simply don't request
the error interrupt (or you leave it disabled while there is an expected
state) and do the peripheral status checking in the data interrupt.
The Blackfin SIC allows people to prioritize data and error interrupts,
and the Blackfin CEC allows interrupts of equal or higher priority to
nest. The current default settings gives error interrupts a higher
priority than data interrupts. So if an error occurs while processing
the data interrupt, it will be serviced immediately.
However, the error interrupt on the BF537 SIC cannot be enabled on a
per-peripheral basis. Once the error interrupt is enabled for one
peripheral, it is automatically enabled for all peripherals.
Therefore lower the default multiplexed error interrupt priority so
most people need not worry themselves with this issue.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Barry Song <barry.song@analog.com>
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
Signed-off-by: Yi Li <yi.li@analog.com>
The NAND platform driver expects the registers to have a "mem"
resource type rather than "io".
With the recent kernel update the isp1362-hcd driver evaluates the
IORESOURCE_IRQ resource flags and requests the irq with the given
polarity/edge settings. However the ISP1362 config requires low
level/edge interrupts. Most of the Blackfin boards use some random
flag or no flag at all. Make all boards use a know good flag
IORESOURCE_IRQ_LOWEDGE.
Make sure we use the right Kconfig names and platform strings.
Now that we've rewritten the GPIO CS handling in the Blackfin SPI
peripheral, we need to update the platform resources accordingly.
Now that the common header defines everything and the SPI drivers are
using it, we can drop these duplicated global namespace polluters.
Rename h/w IRQ flags handling functions to be in line with what is expected for
the irq renaming patch. This renames local_*_hw() to hard_local_*() using the
following perl command:
perl -pi -e 's/local_irq_(restore|enable|disable)_hw/hard_local_irq_\1/ or s/local_irq_save_hw([_a-z]*)[(]flags[)]/flags = hard_local_irq_save\1()/' `find arch/blackfin/ -name "*.[ch]"`
and then fixing up asm/irqflags.h manually.
Additionally, arch/hard_local_save_flags() and arch/hard_local_irq_save() both
return the flags rather than passing it through the argument list.
Split the PLL control code from the Blackfin machine-specific cdef headers so
that the irqflags functions can be renamed without incurring a header loop.
The common bfin_sport.h header now has unified definitions of these, so
stop polluting the global namespace.
These two platforms didn't properly fill nr_chips in gen_nand
registration and therefore depended on gen_nand bug fixed by by commit
81cbb0b17796d81cbd92defe113cf2a7c7a21fbb ("mtd: gen_nand: fix support for
multiple chips")
arch/arm/mach-omap1/board-nokia770.c
To avoid more patches, I also fixed other spelling
and grammar bugs when they were in the same or
following line:
successfull -> successful
parse -> parses
controler -> controller
controlers -> controllers
Cc: Jiri Kosina <trivial@kernel.org>
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
The standard short name for control is CTL and not CTRL. Use TWI0_xxx
even on parts that only have one TWI bus to keep things simple. Drop
all the cdef helpers since the bus driver takes care of everything.
Random tabs instead of spaces, mixes of the two, and unicode spaces
instead of ascii spaces.
This is parallel to the existing P_DEFAULT_BOOT_SPI_CS, but in terms of
the GPIO value so it can be used with the normal gpio API.
Now that there's a common header with everything unified, drop the defines
from the global namespace. Pollution sucks.
Signed-off-by: Graf Yang <graf.yang@analog.com>
