path: root/arch/blackfin/mach-bf538
2012-12-13blackfin: anomaly: add anomaly 16000030 for bf5xxSonic Zhang
Drivers common to both bf5xx and bf60x chip families may use this anomaly id. So add it to bf5xx header files also. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-05-21blackfin: twi: Move TWI peripheral pin request array to platform dataSonic Zhang
2012-05-21blackfin: license: Change ADI BSD licenseSonic Zhang
Change ADI BSD license to standart 3 clause BSD license for some blackfin arch code requested by ADI Legal. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-05-21blackfin: twi: move twi bit mask macro to twi head fileSonic Zhang
2012-04-26blackfin: fix ifdef fustercluck in mach-bf538/boards/ezkit.cPaul Gortmaker
This file has lots and lots of ifdef, around structure decls and structure usages. The failure issue was that we would build the BF538-EZKIT_defconfig and get: arch/blackfin/mach-bf538/boards/ezkit.c:924:3: error: 'bfin_lq035q1_device' undeclared here (not in a function) even though the same ifdef _appeared_ to enable both the struct declaration and the code that used it. Yet cpp was telling us we didn't have the struct, but we still had the usage of it. However, _appeared_ is the operative word. After marking all the anonymous #endif with their parent #ifdef config options, it was _then_ clear that there was a misplaced #endif that was hiding the struct declaration. The real guts of the patch boils down to this: -#endif +#endif /* CONFIG_MTD_M25P80 */ +#endif /* CONFIG_SPI_BFIN5XX */ [...] -#endif /* spi master and devices */ but since I had to tag the #endif with their respective #ifdef options to find this misplaced SPI endif, it would be silly to then go and delete them all. So they stay. Cc: Sonic Zhang <sonic.zhang@analog.com> Cc: Bob Liu <lliubbo@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-09blackfin: config: update macro SPI_BFIN in board fileSonic Zhang
Macro name for spi controller driver has been modified, so update default board file accordingly. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2011-11-14Blackfin: add serial TX IRQ in individual platform resourceSonic Zhang
The serial TX IRQ is not simply (RX IRQ + 1) on some Blackfin chips, so move the values to the platform resources. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2011-07-23Blackfin: bf538: pull gpio/port logic out of core hibernate pathsMike Frysinger
Re-architect how we save/restore the gpio/port logic that only pertains to bf538/bf539 parts by pulling it out of the core code paths and pushing it out to bf538-specific locations. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-23Blackfin: update anomaly lists to latest public infoMike Frysinger
2011-07-23Blackfin: boards: clean up redundant/dead spi resourcesMike Frysinger
The default for the Blackfin SPI driver is 8 bits and dma disabled, so many of the bfin5xx_spi_chip resources are redundant. So punt those parts. Further, drivers should themselves be declaring 16 bit transfers, so for those that do, and for the ones which no longer do 16 bit transfers, drop the bfin5xx_spi_chip resources. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-28Blackfin: mach/bfin_serial_5xx.h: punt now-unused headerMike Frysinger
Now that the serial code has been unified in bfin_serial.h, and the Blackfin UART driver pushed its resources to the boards files, we don't need these headers anymore. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-25Blackfin: update anomaly lists to latest public infoMike Frysinger
2011-05-25Blackfin: clean up style in irq definesMike Frysinger
These files had a lot of whitespace damage, mostly due to copying and pasting original files that had damage. The BF561 header also had a lot of unused CONFIG_DEF_xxx defines, so punt them all. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-25Blackfin: unify core IRQ definitionsMike Frysinger
Start a new common IRQ header and move all of the CEC pieces there. This lets the individual part headers worry just about its SIC defines. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-10Blackfin: boards: add missing "static" to peripheral listsMike Frysinger
2011-01-10Blackfin: sport_uart resources: remove unused secondary RX/TX pinsSonic Zhang
The SPORT/UART driver doesn't use the secondary channel pins, so don't try and request them thus keeping other drivers from using them. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-10Blackfin: unify pll.h headersMike Frysinger
2011-01-10Blackfin: drop asm/irq.h include from mach headersMike Frysinger
These were only included because of the irq handling of the PLL funcs, and those PLL funcs have been moved out into their own header now. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-10Blackfin: clean up mach header includesMike Frysinger
The main asm/blackfin.h header will pull in mach/blackfin.h to get all the fun Blackfin defines. So having any of the sub-mach headers trying to include asm/blackfin.h makes no sense -- punt it. The mach/blackfin.h header takes care of including the part-specific def headers which in turn will include any other needed def file. Similarly, it takes care of pulling in the part-specific cdef header. So move this logic out of the blackfin.h when necessary. Further, make sure the cdef headers do not waste time including the def headers again. Since all parts need the common def/cdef headers, move this logic out of the part-specific headers and into the mach/blackfin.h file. Finally, we need to split the BF539 def header since the BF538 does not have MXVR and we don't want to expose those MMRs. So now all parts should have the same behavior: mach/blackfin.h asm/def_LPBlackfin.h part-specific def.h if ! asm asm/cdef_LPBlackfin.h part-specific cdef.h And the sub def/cdef headers only tail into what they need. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-10Blackfin: push gpio (port) defines into common headersMike Frysinger
2011-01-10Blackfin: dma: constify MMR pointer arrayMike Frysinger
The array of pointers is never written, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-10Blackfin: standardize DMAC traffic control MMRs & MDMA MMRsMike Frysinger
Use the same naming convention for DMA traffic MMRs (most were legacy anyways) so we can avoid useless ifdef trees. Same goes for MDMA names -- this actually allows us to undo a bunch of ifdef redirects that existed for this purpose alone. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-10Blackfin: bfin_serial.h: unify heavily duplicated serial codeMike Frysinger
Each Blackfin port has been duplicating UART structures and defines when there really is no need for it. So start a new bfin_serial.h header to unify all these pieces and give ourselves a fresh start. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-22Blackfin: bf538: add missing SIC_RVECT defineMike Frysinger
2010-10-22Blackfin: boards: fix num_chipselect values for on-chip SPI busesMike Frysinger
The num_chipselect field for on-chip Blackfin SPI buses is supposed to be 1 larger than the number of actual CSs available. This is because the hardware starts counting at 1 and not 0. There is a field for "CS0", but it is marked as "reserved" everywhere. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-22Blackfin: punt short SPI MMR bit namesMike Frysinger
Now that the common header defines everything and the SPI drivers are using it, we can drop these duplicated global namespace polluters. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-07Blackfin: Rename IRQ flags handling functionsDavid Howells
Rename h/w IRQ flags handling functions to be in line with what is expected for the irq renaming patch. This renames local_*_hw() to hard_local_*() using the following perl command: perl -pi -e 's/local_irq_(restore|enable|disable)_hw/hard_local_irq_\1/ or s/local_irq_save_hw([_a-z]*)[(]flags[)]/flags = hard_local_irq_save\1()/' `find arch/blackfin/ -name "*.[ch]"` and then fixing up asm/irqflags.h manually. Additionally, arch/hard_local_save_flags() and arch/hard_local_irq_save() both return the flags rather than passing it through the argument list. Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-07Blackfin: Split PLL code from mach-specific cdef headersDavid Howells
Split the PLL control code from the Blackfin machine-specific cdef headers so that the irqflags functions can be renamed without incurring a header loop. Signed-off-by: David Howells <dhowells@redhat.com>
2010-08-27Blackfin: punt duplicate SPORT MMR definesMike Frysinger
The common bfin_sport.h header now has unified definitions of these, so stop polluting the global namespace. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-06Blackfin: TWI: clean up the MMR namesMike Frysinger
The standard short name for control is CTL and not CTRL. Use TWI0_xxx even on parts that only have one TWI bus to keep things simple. Drop all the cdef helpers since the bus driver takes care of everything. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-06Blackfin: gpio/portmux: clean up whitespace corruptionMike Frysinger
Random tabs instead of spaces, mixes of the two, and unicode spaces instead of ascii spaces. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-06Blackfin: add a GPIO_DEFAULT_BOOT_SPI_CSMike Frysinger
This is parallel to the existing P_DEFAULT_BOOT_SPI_CS, but in terms of the GPIO value so it can be used with the normal gpio API. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-06Blackfin: update anomaly lists to latest public infoMike Frysinger
2010-05-21Blackfin: punt duplicated CAN MMRsMike Frysinger
Now that there's a common header with everything unified, drop the defines from the global namespace. Pollution sucks. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: increase NR_IRQS beyond NR on-chip IRQsMichael Hennerich
This makes room for off-chip IRQ controllers. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: update AD7879 resources to match the new gpiolib driver supportMichael Hennerich
2010-03-09Blackfin: extend bfin-lq035q1-fb resources to include PPI modeMichael Hennerich
This lets us support the new BF527-EZKIT V2.1 via platform resources tweaks only. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: add UART/SPORT early platform resourcesSonic Zhang
This lets people easily select the UART/SPORT consoles for early printk while leveraging the pins declared in the boards file. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: move SPORT UART resources to boards filesSonic Zhang
Rather than keeping the pins in the actual driver and worrying about a mess of Kconfig options, declare all the desired pin resources in the boards file. This lets people easily select the specific pins/ports for the normal emulated UART as well as GPIOs for CTS/RTS. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: move on-chip UART resources to boards filesSonic Zhang
Rather than keeping the pins in the actual driver and worrying about a mess of Kconfig options, declare all the desired pin resources in the boards file. This lets people easily select the specific pins/ports for the normal UART as well as GPIOs for CTS/RTS. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: bf537-stamp: add CAN resourcesBarry Song
Signed-off-by: Barry Song <barry.song@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: unify DMA masksMike Frysinger
Every Blackfin variant has the same DMA bit masks, so avoid duplicating them over and over in each mach header. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: unify duplicated power masksMike Frysinger
2009-12-15Blackfin: punt unused MXVR masksMike Frysinger
There are no MXVR device drivers, and if someday there is, we can put these in a dedicated header rather than polluting the global namespace. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: scrub unused watchdog mmr masksMike Frysinger
The watchdog code doesn't need these, and the other parts had these punted, so keep the global namespace clean. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: scrub unused RTC masksMike Frysinger
The RTC driver code doesn't need these, and the other parts had these punted, so keep the global namespace clean. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-15Blackfin: bf538: add support for extended GPIO banksMichael Hennerich
The GPIOs on ports C/D/E on the BF538/BF539 do not behave the same way as the other ports on the part and the same way as all other Blackfin parts. The MMRs are programmed slightly different and they cannot be used to generate interrupts or wakeup a sleeping system. Since these guys don't fit into the existing code, create a simple gpiolib driver for them. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-11-25Blackfin: update anomaly listsMike Frysinger
Add some recently documented anomalies (473, 474, 475, 477). Also stick a "do not edit" notice in here so people know these are copies of some master version. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-08Blackfin: drop all simple-gpio board resourcesMike Frysinger
The simple-gpio has been replaced by the gpio sysfs interface, so drop the unused simple-gpio resources from all Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-08Blackfin: drop cs_change_per_word settingMike Frysinger
Structs get initialized to 0 already, and we want to punt this field, so scrub it from all of our boards. Reported-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
