path: root/arch/blackfin/mm
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-09Blackfin: simplify SMP handling in SRAM codeYi Li
There is no need to use {get,put}_cpu() when we already have a spinlock to protect against multiple processors running simultaneously. Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: isram: add unlikely to sanity checksMike Frysinger
Don't want the compiler assuming the rare sanity checks are the norm and optimize for those paths. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-07blackfin,kgdb,probe_kernel: Cleanup probe_kernel_read/writeJason Wessel
Blackfin needs it own arch specific probe_kernel_read() and probe_kernel_write(). This was moved out of the kgdb code and into the arch/blackfin/maccess.c, because it is a generic kernel api. The arch specific kgdb.c for blackfin was cleaned of all functions which exist in the kgdb core that do the same thing after resolving the probe_kernel_read() and probe_kernel_write(). This also eliminated the need for most of the #include's. CC: Sonic Zhang <sonic.adi@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-07Blackfin: mass clean up of copyright/licensing infoRobin Getz
Bill Gatliff & David Brownell pointed out we were missing some copyrights, and licensing terms in some of the files in ./arch/blackfin, so this fixes things, and cleans them up. It also removes: - verbose GPL text(refer to the top level ./COPYING file) - file names (you are looking at the file) - bug url (it's in the ./MAINTAINERS file) - "or later" on GPL-2, when we did not have that right It also allows some Blackfin-specific assembly files to be under a BSD like license (for people to use them outside of Linux). Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-16Blackfin: fix typo in isram_write()Robin Getz
The DTEST write bit is 2, not 1. Improve comments in the related macro while we're here. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-16Blackfin: add some isram-driver self testsMike Frysinger
Make it easy to figure out if code changes here are correct. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-16Blackfin: catch hardware errors earlier during bootingRobin Getz
Allow hardware errors to be caught during early portions of booting, and leave something in the shadow console that people can use to debug their system with (to be printed out by the bootloader on next reset). This enables the hardare error interrupts in head.S, allowing us to find hardware errors when they happen (well, as much as you can with a hardware error) and prints out the trace if it is enabled. This will catch errors (like booting the wrong image on a 533) which previously resulted in a infinite loop/hang, as well as random hardware errors before before setup_arch(). To disable this debug only feature - turn off EARLY_PRINTK. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-16Blackfin: push SRAM locks down into related ifdefsMike Frysinger
Rather than defining the locks and initializing them all the time, only do so when we actually need them (i.e. the SRAM regions exist). This avoids dead data and code bloat during runtime. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-04Merge branch 'master' into for-nextTejun Heo
Pull linus#master to merge PER_CPU_DEF_ATTRIBUTES and alpha build fix changes. As alpha in percpu tree uses 'weak' attribute instead of inline assembly, there's no need for __used attribute. Conflicts: arch/alpha/include/asm/percpu.h arch/mn10300/kernel/vmlinux.lds.S include/linux/percpu-defs.h
2009-06-24percpu: use DEFINE_PER_CPU_SHARED_ALIGNED()Tejun Heo
There are a few places where ___cacheline_aligned* is used with DEFINE_PER_CPU(). Use DEFINE_PER_CPU_SHARED_ALIGNED() instead. DEFINE_PER_CPU_SHARED_ALIGNED() applies alignment only on SMPs. While all other converted places used _in_smp variant or only get compiled for SMP, net/rds used unconditional ____cacheline_aligned. I don't see any reason these data structures should be aligned on UP and thus converted together. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Andy Grover <andy.grover@oracle.com>
2009-06-22Blackfin: decouple unrelated cache settings to get exact behaviorJie Zhang
The current cache options don't really represent the hardware features. They end up setting different aspects of the hardware so that the end result is to turn on/off the cache. Unfortunately, when we hit cache problems with the hardware, it's difficult to test different settings to root cause the problem. The current settings also don't cleanly allow for different caching behaviors with different regions of memory. So split the configure options such that they properly reflect the settings that are applied to the hardware. Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12Blackfin: document the lsl variants of the L1 allocatorMike Frysinger
Make sure the meaning of "lsl" is covered somewhere and it is clear why we somewhat duplicate the sram alloc/free functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12Blackfin: fix handling of initial L1 reservationGraf Yang
This restores some L1 reservation logic that was lost during the Blackfin SMP merge. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12Blackfin: merge sram init functionsGraf Yang
Now that the sram_init() function exists only to call the bfin_sram_init() after the punting of the reserve_pda() function, simply merge the two to avoid pointless overhead. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12Blackfin: drop unused reserve_pda() functionGraf Yang
The Per-processor Data Area isn't actually reserved by this function, and all it ended up doing was issuing a printk(), so punt it. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12Blackfin: fix bug found by traps test case 21Graf Yang
The traps test case 21 "exception 0x3f: l1_instruction_access" would make the kernel panic on BF533's because we end up calling show_stack() infinitely. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-06-12Blackfin: fix link failure due to CONFIG_EXCEPTION_L1_SCRATCHGraf Yang
Move exception stack mess from entry.S to init.c to fix link failure when CONFIG_EXCEPTION_L1_SCRATCH is in use. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-05Blackfin arch: mark init_pda as __init as only __init funcs all itMike Frysinger
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-07Blackfin arch: Faster C implementation of no-MPU CPLB handlerBernd Schmidt
This is a mixture ofcMichael McTernan's patch and the existing cplb-mpu code. We ditch the old cplb-nompu implementation, which is a good example of why a good algorithm in a HLL is preferrable to a bad algorithm written in assembly. Rather than try to construct a table of all posible CPLBs and search it, we just create a (smaller) table of memory regions and their attributes. Some of the data structures are now unified for both the mpu and nompu cases. A lot of needless complexity in cplbinit.c is removed. Further optimizations: * compile cplbmgr.c with a lot of -ffixed-reg options, and omit saving these registers on the stack when entering a CPLB exception. * lose cli/nop/nop/sti sequences for some workarounds - these don't * make sense in an exception context Additional code unification should be possible after this. [Mike Frysinger <vapier.adi@gmail.com>: - convert CPP if statements to C if statements - remove redundant statements - use a do...while loop rather than a for loop to get slightly better optimization and to avoid gcc "may be used uninitialized" warnings ... we know that the [id]cplb_nr_bounds variables will never be 0, so this is OK - the no-mpu code was the last user of MAX_MEM_SIZE and with that rewritten, we can punt it - add some BUG_ON() checks to make sure we dont overflow the small cplb_bounds array - add i/d cplb entries for the bootrom because there is functions/data in there we want to access - we do not need a NULL trailing entry as any time we access the bounds arrays, we use the nr_bounds variable ] Signed-off-by: Michael McTernan <mmcternan@airvana.com> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bernd Schmidt <bernds_cb1@t-online.de> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2009-01-07Blackfin arch: smp patch cleanup from LKML reviewGraf Yang
1. Use inline get_l1_... functions instead of macro 2. Fix compile issue about smp barrier functions Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-11-18Blackfin arch: fix unused warning for some blackfin derivativesMike Frysinger
2008-11-18Blackfin arch: SMP supporting patchset: Blackfin kernel and memory ↵Graf Yang
management code Blackfin dual core BF561 processor can support SMP like features. https://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:smp-like In this patch, we provide SMP extend to Blackfin kernel and memory management code Singed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-10-28Blackfin arch: fix bug - shared lib function in L2 failed be calledJie Zhang
Allow user space to access L2 SRAM. Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-10-08Blackfin arch: Use DTEST rather than DMA to poke at L1 SRAM during exception ↵Robin Getz
context Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-10-08Blackfin arch: rename blackfin_sram.c to sram-alloc.cRobin Getz
rename blackfin_sram.c to sram-alloc.c (we know it is a blackfin file, since it is in arch/blackfin) - and there is no "driver" code in there, it is just an allocator/deallocator for L1 and L2 sram. Also fix a problem that checkpatch pointed out Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-08-28Blackfin arch: sram: use 'unsigned long' for irqflagsVegard Nossum
Using just 'unsigned' will make flags an unsigned int. While this is arguably not an error on blackfin where sizeof(int) == sizeof(long), the patch is still justified on the grounds of principle. The patch was generated using the Coccinelle semantic patch framework. Cc: Julia Lawall <julia@diku.dk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-08-25Blackfin arch: Fix bug - when to rmmod the L1_module, it stucks and then ↵Sonic Zhang
reboot the board. Fix this by correcting the wrong pointer Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-08-13Blackfin arch: convert L2 defines to be the same as the L1 definesMike Frysinger
2008-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: (30 commits) Blackfin arch: If we double fault, rather than hang forever, reset Blackfin arch: When icache is off, make sure people know it Blackfin arch: Fix bug - skip single step in high priority interrupt handler instead of disabling all interrupts in single step debugging. Blackfin arch: cache the values of vco/sclk/cclk as the overhead of doing so (~24 bytes) is worth avoiding the software mult/div routines Blackfin arch: fix bug - IMDMA is not type struct dma_register Blackfin arch: check the EXTBANKS field of the DDRCTL1 register to see if we are using both memory banks Blackfin arch: Apply Bluetechnix CM-BF527 board support patch Blackfin arch: Add unwinding for stack info, and a little more detail on trace buffer Blackfin arch: Add ISP1760 board resources to BF548-EZKIT Blackfin arch: fix bug - detect 0.1 silicon revision BF527-EZKIT as 0.0 version Blackfin arch: add missing IORESOURCE_MEM flags to UART3 Blackfin arch: Add return value check in bfin_sir_probe(), remove SSYNC(). Blackfin arch: Extend sram malloc to handle L2 SRAM. Blackfin arch: Remove useless config option. Blackfin arch: change L1 malloc to base on slab cache and lists. Blackfin arch: use local labels and ENDPROC() markings Blackfin arch: Do not need this dualcore test module in kernel. Blackfin arch: Allow ptrace to peek and poke application data in L1 data SRAM. Blackfin arch: Add ANOMALY_05000368 workaround Blackfin arch: Functional power management support ...
2008-07-26blackfin: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free pages, printed by show_free_areas() - pages in swapcache, printed by show_swap_cache_info() where show_mem() calls show_free_areas(), which calls show_swap_cache_info(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Acked-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-19Blackfin arch: Extend sram malloc to handle L2 SRAM.Sonic Zhang
Extend system call to alloc L2 SRAM in application. Automatically move following sections to L2 SRAM: 1. kernel built-in l2 attribute section 2. kernel module l2 attribute section 3. elf-fdpic application l2 attribute section Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-07-19Blackfin arch: change L1 malloc to base on slab cache and lists.Sonic Zhang
Remove the sram piece limitation and improve the performance to alloc/free sram piece data. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-07-14Blackfin arch: Fix bug - do not overflow the buffer given to us which tends ↵Mike Frysinger
to happen when CONFIG_L1_MAX_PIECE is increased past its default Singed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-04-23[Blackfin] arch: fix bug - make sure we check the right L1 lengthMeihui Fan
Signed-off-by: Meihui Fan <mhfan@hhcn.com> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-02-29[Blackfin] arch: kill section mismatch warningsBryan Wu
2008-02-09[Blackfin] arch: add "memmap=nn[KMG]@ss[KMG]" and "memmap=nn[KMG]$ss[KMG]" ↵Yi Li
options to blackfin, based on arch/i386/kernel/e820.c Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-01-27[Blackfin] arch: fix bug kernel boot message: memory information is not ↵Yi Li
reasonable Some of the information in kernel boot message is not reasonable. http://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=3846 - use _rambase as the start of kernel image. kernel is in the region [_rambase, _ramstart] - count in pages in per-cpu-page list as available memory - reserved memory now include: [0 - 4K] for bad pointer catching, memory reserved for abnormaly 05000263, memory reserved by kernel itself. Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-01-27[Blackfin] arch: Initial checkin of the memory protection support.Bernd Schmidt
Enable it with CONFIG_MPU. Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-11-15Blackfin arch: do not include linux/autoconf.hMike Frysinger
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-10-10Blackfin arch: show_mem can not be marked as init, since it is called during ↵Robin Getz
OOM condition show_mem can not be marked as init, since it is called during OOM condition from /mm/oom_kill.c:out_of_memory() and /mm/page_alloc.c:__alloc_pages() Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12Blackfin arch: combine the common code of free_initrd_mem and free_initmemMike Frysinger
2007-07-12Blackfin arch: cleanup warnings from checkpatch -- no functional changesMike Frysinger
2007-06-14Blackfin arch: make sure we initialize our L1 Data B section properly based ↵Mike Frysinger
on the linked kernel Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-06-14Blackfin arch: implement a basic /proc/sram file for L1 allocation visibilityMike Frysinger
implement a basic /proc/sram file for L1 allocation visibility until we can rewrite the entire L1 allocator (which would include a proper mechanism) Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-06-11Blackfin arch: mark our memory init functions with __init so they get freed ↵Mike Frysinger
after init Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-06-11Blackfin arch: spelling fixesSimon Arlott
Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-05-21Blackfin arch: ISP1761 doesn't work for USB flash diskAubrey Li
ZONE_DMA is required for some drivers subsystem, such as USB/SCSI. Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
