path: root/arch/blackfin
2010-05-27blackfin: use use asm-generic/scatterlist.hFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27ptrace: unify FDPIC implementationsMike Frysinger
The Blackfin/FRV/SuperH guys all have the same exact FDPIC ptrace code in their arch handlers (since they were probably copied & pasted). Since these ptrace interfaces are an arch independent aspect of the FDPIC code, unify them in the common ptrace code so new FDPIC ports don't need to copy and paste this fundamental stuff yet again. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (30 commits) Blackfin: SMP: fix continuation lines Blackfin: acvilon: fix timeout usage for I2C Blackfin: fix typo in BF537 IRQ comment Blackfin: unify duplicate MEM_MT48LC32M8A2_75 kconfig options Blackfin: set ARCH_KMALLOC_MINALIGN Blackfin: use atomic kmalloc in L1 alloc so it too can be atomic Blackfin: another year of changes (update copyright in boot log) Blackfin: optimize strncpy a bit Blackfin: isram: clean up ITEST_COMMAND macro and improve the selftests Blackfin: move string functions to normal lib/ assembly Blackfin: SIC: cut down on IAR MMR reads a bit Blackfin: bf537-minotaur: fix build errors due to header changes Blackfin: kgdb: pass up the CC register instead of a 0 stub Blackfin: handle HW errors in the new "FAULT" printing code Blackfin: show the whole accumulator in the pseudo DBG insn Blackfin: support all possible registers in the pseudo instructions Blackfin: add support for the DBG (debug output) pseudo insn Blackfin: change the BUG opcode to an unused 16-bit opcode Blackfin: allow NMI watchdog to be used w/RETN as a scratch reg Blackfin: add support for the DBGA (debug assert) pseudo insn ...
2010-05-22Blackfin: SMP: fix continuation linesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: acvilon: fix timeout usage for I2CWolfram Sang
The timeout value is in jiffies, so it should be using HZ, not a plain number. As '10000' is ambiguous, 1HZ is used as conservative default. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Valentin Yakovenkov <yakovenkov@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: fix typo in BF537 IRQ commentMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: unify duplicate MEM_MT48LC32M8A2_75 kconfig optionsMike Frysinger
Reported-by: Christoph Egger <siccegge@cs.fau.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: set ARCH_KMALLOC_MINALIGNFUJITA Tomonori
Architectures that handle DMA-non-coherent memory need to set ARCH_KMALLOC_MINALIGN to make sure that kmalloc'ed buffer is DMA-safe: the buffer doesn't share a cache with the others. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: use atomic kmalloc in L1 alloc so it too can be atomicMike Frysinger
Some drivers allocate L1 SRAM in atomic contexts, so make sure these functions also use GFP_ATOMIC to avoid BUG()'s. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: another year of changes (update copyright in boot log)Mike Frysinger
2010-05-22Blackfin: optimize strncpy a bitRobin Getz
Add a little strncpy optimization which can easily cut boot time by 20%. When the kernel is booting with initramfs, it builds up the filesystem from a cpio archive by calling strncpy_from_user() via fs/namei.c's do_getname() on every file in the archive (which can be lots) with a length of PATH_MAX (1024). This causes the dest of the strncpy to be padded with many NUL bytes. This optimization mostly causes these NUL bytes to be padded with a call to memset() which is already optimized for filling memory quickly, but the hardware loop helps a little bit as well. Boot time measured with 'loglevel=0' so UART speed doesn't get in the way. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: isram: clean up ITEST_COMMAND macro and improve the selftestsMike Frysinger
The IADDR2DTEST() macro had some duplicated logic with bit 11 and some incorrect comments, so scrub all of that. In order to verify these aren't a problem (and won't be in the future), extend the self tests to operate on as much L1 SRAM as possible. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: move string functions to normal lib/ assemblyRobin Getz
Since 'extern inline' doesn't work correctly in the context of the Linux kernel (too many overriding defines), move the string functions to normal lib/ assembly files (like the existing mem funcs). This avoids the forced inline all over the kernel and allows us to place them constantly in L1. This also avoids some module failures when gcc inserts calls to string functions but the kernel build system doesn't fully consult the library archives. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: SIC: cut down on IAR MMR reads a bitMike Frysinger
Tweak the for loops that operate on the SIC IAR system MMRs to avoid re-reading them multiple times in a row. System MMRs are a little slower to access, so avoid the penalty when possible. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: bf537-minotaur: fix build errors due to header changesMike Frysinger
2010-05-22Blackfin: kgdb: pass up the CC register instead of a 0 stubMike Frysinger
While the CC pseudo register can be deduced from the ASTAT register, make sure we set its value correctly instead of always stubbing it out as 0. GDB itself looks at this pseudo register instead of ASTAT, so we have to supply the right value. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: handle HW errors in the new "FAULT" printing codeRobin Getz
2010-05-22Blackfin: show the whole accumulator in the pseudo DBG insnRobin Getz
Rather than print just part of the accumulator register, show the whole 40 bits. This matches the simulator behavior better. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: support all possible registers in the pseudo instructionsRobin Getz
Rather than decoding just the common R/P registers, handle all of them. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: add support for the DBG (debug output) pseudo insnRobin Getz
Another pseudo insn used by Blackfin simulators. Also factor some now common register lookup code out of the DBGA handlers. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: change the BUG opcode to an unused 16-bit opcodeRobin Getz
The current BUG opcode includes the bit that flags the insn as a 32bit opcode, but it wasn't declaring it as 32bits. So pick an unused 16bit. URL: http://blackfin.uclinux.org/gf/tracker/5973 Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: allow NMI watchdog to be used w/RETN as a scratch regGraf Yang
NMIs are not safe to return from because many anomaly workarounds are implemented by disabling interrupts. The NMI obviously violates this assumption. Since the NMI watchdog never returns, we don't have to worry about it clobbering RETN when it is being used as a scratch register with the exception stack. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-22Blackfin: add support for the DBGA (debug assert) pseudo insnRobin Getz
A few pseudo debug insns exist to make testing of simulators easier. Since these don't actually exist in the hardware, we have to have the exception handler take care of emulating these. This allows sim test cases to be executed unmodified under Linux and thus simplify debugging greatly. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-21Blackfin: SMP: add flush_tlb_kernel_range stubGraf Yang
Newer code in mm/page_alloc.c requires this function now in arches. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-21Blackfin: make hardware trace output a little more usefulRobin Getz
Decode the vast majority of insns that appear in the trace buffer to get a better idea of what's going on at a glance. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-21Blackfin: print out the faulting insn in the trace outputRobin Getz
Print out the faulting instruction so when people send traces as part of bug reports, we have a better idea of what is going on. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-21Blackfin: remove CONFIG_DEBUG_VERBOSE from trace.cRobin Getz
Now that the split traps code has moved all the verbose output to the trace.c file, we can unify all the CONFIG_DEBUG_VERBOSE handling. This gets rid of much of the crappy ifdef forest and enables usage of normal pr_xxx functions so checkpatch stops complaining. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-21Blackfin: split kernel/traps.cRobin Getz
The current kernel/traps.c file has grown a bit unwieldy as more debugging functionality has been added over time, so split it up into more logical files. There should be no functional changes here, just minor whitespace tweaking. This should make future extensions easier to manage. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-21Blackfin: punt Blackfin-specific GPIO wakeup APIMichael Hennerich
This patch removes a custom GPIO wakeup API which allowed GPIOs to act as wakeup sources, which are not configured as Interrupts. This API is a leftover from the time before irq_wake was established. From now on people must use enable_irq_wake(GPIO_IRQx) and the GPIO in question needs to be configured as Interrupt. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-21Blackfin: mark MUSB VRSEL as active high for appropriate boardsCliff Cai
These boards all have the GPIO VRSEL hooked up as an active high. Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-21Blackfin: punt duplicated CAN MMRsMike Frysinger
Now that there's a common header with everything unified, drop the defines from the global namespace. Pollution sucks. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-21Blackfin: cleanup style/comments/etc... in paging_init()Mike Frysinger
2010-05-21Blackfin: drop unused bad_page pages and move zero_page to the bssMike Frysinger
The empty_bad_page/empty_bad_page_table pages are unused, so punt them. The zero_page is always allocated, so push it out to the bss to speed up the booting process a bit and pack data nicer. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-20kgdb,blackfin: Add in kgdb_arch_set_pc for blackfinJason Wessel
The new debug core api requires all architectures that use to debug core to implement a function to set the program counter. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Sonic Zhang <sonic.zhang@analog.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-19Merge branch 'timers-for-linus-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: avr32: Fix typo in read_persistent_clock() sparc: Convert sparc to use read/update_persistent_clock cris: Convert cris to use read/update_persistent_clock m68k: Convert m68k to use read/update_persistent_clock m32r: Convert m32r to use read/update_peristent_clock blackfin: Convert blackfin to use read/update_persistent_clock ia64: Convert ia64 to use read/update_persistent_clock avr32: Convert avr32 to use read/update_persistent_clock h8300: Convert h8300 to use read/update_persistent_clock frv: Convert frv to use read/update_persistent_clock mn10300: Convert mn10300 to use read/update_persistent_clock alpha: Convert alpha to use read/update_persistent_clock xtensa: Fix unnecessary setting of xtime time: Clean up direct xtime usage in xen
2010-05-14add descriptive comment for TIF_MEMDIE task flag declaration.Andreas Dilger
Signed-off-by: Andreas Dilger <adilger@dilger.ca> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (96 commits) Blackfin: stop cleaning include/asm/asm-offsets.h Blackfin: scale calibration when cpu freq changes Blackfin: eat spurious space in asm/dpmc.h Blackfin: fix anomaly 283 handling with exact hardware error Blackfin: bf537-stamp: add example ADXL346 orientation resources Blackfin: bf537-stamp: add example AD2S1210 IIO resources Blackfin: don't support keypad wakeup from hibernate Blackfin: bf537-stamp: add example AD7416 IIO resources Blackfin: bf537-stamp: add example ADP8860 backlight/led resources Blackfin: bf537-stamp: add example AD7414 temp sensor resources Blackfin: rename AD1836 to AD183X in board files Blackfin: bf537-stamp: add example AD2S120x resources Blackfin: add support for the on-chip MAC status interrupts Blackfin: asm/page.h: pull in asm-generic headers Blackfin: mark gpio lib functions static Blackfin: bf537-stamp: add example ADAU1361 resources Blackfin: GPIO: implement to_irq handler Blackfin: bf537-stamp: add example ADP122/ADP150 power regulator resources Blackfin: bf537-stamp: add example AD2S90 resources Blackfin: bf537-stamp: add example AD5398 power regulator resources ...
2010-03-13blackfin: Convert blackfin to use read/update_persistent_clockJohn Stultz
This patch converts the blackfin architecture to use the generic read_persistent_clock and update_persistent_clock interfaces, reducing the amount of arch specific code we have to maintain, and allowing for further cleanups in the future. I have not built or tested this patch, so help from arch maintainers would be appreciated. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1267675049-12337-10-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12dma-mapping: blackfin: remove the obsolete and unnecessary DMA API commentsFUJITA Tomonori
pci_dma_sync_single was obsoleted long ago. All the comments are generic, not architecture specific, simply describes some of the DMA-API (and the same comments are in other files). Documentation/DMA-API.txt have more detailed descriptions. This removes the above obsolete and unnecessary DMA API comments. Let's describe the DMA API in only Documentation/DMA-API.txt. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-09Blackfin: stop cleaning include/asm/asm-offsets.hMike Frysinger
The file is no longer generated, so we don't want to clean it. Reported-by: Vivi Li <vivi.li@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: scale calibration when cpu freq changesGraf Yang
Need to make sure we update the loops_per_jiffy values when we start changing the core clock. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: eat spurious space in asm/dpmc.hMike Frysinger
2010-03-09Blackfin: fix anomaly 283 handling with exact hardware errorRobin Getz
The exact hardware error handling code was added before the workaround for anomaly 283 which caused the anomaly to be triggered in some cases (an infinite core stall). So re-order the code to avoid this. Reported-by: Andrew Rook <andrew.rook@speakerbus.co.uk> Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: bf537-stamp: add example ADXL346 orientation resourcesMichael Hennerich
2010-03-09Blackfin: bf537-stamp: add example AD2S1210 IIO resourcesGraf Yang
2010-03-09Blackfin: don't support keypad wakeup from hibernateMichael Hennerich
The on-chip keypad peripheral requires different registers to be setup depending on the standby type (standby vs hibernation). However, since the power management framework doesn't differentiate between these types, the driver doesn't know which registers to program and subsequently it avoids doing so. Always enabling the keyboard wakeup source causes misbehavior when the pins are not assigned to the keypad. If they happen to drive a certain level, they'll trigger a wake up event which is not wanted. So until the aforementioned issue can be sorted out, drop support for the wakeup source completely. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-09Blackfin: bf537-stamp: add example AD7416 IIO resourcesSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
