path: root/arch/cris/boot
2010-08-04CRIS: Discard .note.gnu.build-id sectionJesper Nilsson
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2010-08-04CRIS: Avoid compilation warning for putsJesper Nilsson
Rename to aputs. Also, simplify code by moving some common code out to macros. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2009-04-21CRIS: Merge machine dependent boot/compressed and boot/rescueJesper Nilsson
Merge the machine dependent boot directories for v10 and v32. This avoids some code duplication and eases the way for further merging later on. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
