path: root/arch/cris/kernel/process.c
2013-04-08cris: Use generic idle loopThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Link: http://lkml.kernel.org/r/20130321215234.148829489@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-08arch: Cleanup enable/disable_hltThomas Gleixner
enable/disable_hlt() does not need to be exported and can be killed on architectures which do not use it at all. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130321215233.377959540@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-02-17cris idle: delete idle and pm_idleLen Brown
pm_idle() and idle() served no purpose on cris -- invoke default_idle() directly. Signed-off-by: Len Brown <len.brown@intel.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
2012-09-23cris: Add missing RCU idle APIs on idle loopFrederic Weisbecker
In the old times, the whole idle task was considered as an RCU quiescent state. But as RCU became more and more successful overtime, some RCU read side critical section have been added even in the code of some architectures idle tasks, for tracing for example. So nowadays, rcu_idle_enter() and rcu_idle_exit() must be called by the architecture to tell RCU about the part in the idle loop that doesn't make use of rcu read side critical sections, typically the part that puts the CPU in low power mode. This is necessary for RCU to find the quiescent states in idle in order to complete grace periods. Add this missing pair of calls in the Cris's idle loop. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Cris <linux-cris-kernel@axis.com> Cc: <stable@vger.kernel.org> # 3.3+ Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-05-05cris: Use generic init_taskThomas Gleixner
Same code. Use the generic version. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Link: http://lkml.kernel.org/r/20120503085034.475552133@linutronix.de
2012-03-28Disintegrate asm/system.h for CRISDavid Howells
Disintegrate asm/system.h for CRIS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> cc: linux-cris-kernel@axis.com
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Get rid of indirect include of fs_struct.hAl Viro
Don't pull it in sched.h; very few files actually need it and those can include directly. sched.h itself only needs forward declaration of struct fs_struct; Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-31take init_fs to saner placeAl Viro
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-02-08CRIS: Remove useless CVS id and log from kernel/process.cJesper Nilsson
2007-11-14cris build fixes: corrected and improved NMI and IRQ handlingJesper Nilsson
Corrects compile errors and the following: - Remove oldset parameter from do_signal and do_notify_resume. - Modified to fit new consolidated IRQ handling code. - Reverse check order between external nmi and watchdog nmi to avoid false watchdog oops in case of a glitch on the nmi pin. - Return from an pin-generated NMI the same way as for other interrupts. - Moved blocking of ethernet rx/tx irq from ethernet interrupt handler to low-level asm interrupt handlers. Fixed in the multiple interrupt handler also. - Add space for thread local storage in thread_info struct. - Add NO_DMA to Kconfig, and include arch specific Kconfig using arch independent path. Include subsystem Kconfigs for pcmcia, usb, i2c, rtc and pci. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-24[PATCH] kill include/linux/platform.h, default_idle() cleanupAdrian Bunk
include/linux/platform.h contained nothing that was actually used except the default_idle() prototype, and is therefore removed by this patch. This patch does the following with the platform specific default_idle() functions on different architectures: - remove the unused function: - parisc - sparc64 - make the needlessly global function static: - arm - h8300 - m68k - m68knommu - s390 - v850 - x86_64 - add a prototype in asm/system.h: - cris - i386 - ia64 Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Patrick Mochel <mochel@digitalimplant.org> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dump_thread() cleanupakpm@osdl.org
) From: Adrian Bunk <bunk@stusta.de> - create one common dump_thread() prototype in kernel.h - dump_thread() is only used in fs/binfmt_aout.c and can therefore be removed on all architectures where CONFIG_BINFMT_AOUT is not available Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: disable preempt in idle tasksNick Piggin
Run idle threads with preempt disabled. Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()). How did it ever work before? Might fix the CPU hotplugging hang which Nigel Cunningham noted. We think the bug hits if the idle thread is preempted after checking need_resched() and before going to sleep, then the CPU offlined. After calling stop_machine_run, the CPU eventually returns from preemption and into the idle thread and goes to sleep. The CPU will continue executing previous idle and have no chance to call play_dead. By disabling preemption until we are ready to explicitly schedule, this bug is fixed and the idle threads generally become more robust. From: alexs <ashepard@u.washington.edu> PPC build fix From: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> MIPS build fix Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] CRIS update: updates for 2.6.12Mikael Starvik
Patches to make CRIS work with 2.6.12. Signed-off-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Don't export machine_restart, machine_halt, or machine_power_off.Eric W. Biederman
machine_restart, machine_halt and machine_power_off are machine specific hooks deep into the reboot logic, that modules have no business messing with. Usually code should be calling kernel_restart, kernel_halt, kernel_power_off, or emergency_restart. So don't export machine_restart, machine_halt, and machine_power_off so we can catch buggy users. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Fix the arguments to machine_restart on crisEric W. Biederman
It appears machine_restart has been working cris just by luck. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
