path: root/arch/frv
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01frv: unbreak misalignment handling changesDavid Howells
Fix a reference in a arch/frv/mm/Makefile to unaligned.c which has now been deleted. Also revert the change to the guard macro name in include/asm-frv/unaligned.h. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits) ACPI: Fix acpi_processor_idle and idle= boot parameters interaction acpi: fix section mismatch warning in pnpacpi intel_menlo: fix build warning ACPI: Cleanup: Remove unneeded, multiple local dummy variables ACPI: video - fix permissions on some proc entries ACPI: video - properly handle errors when registering proc elements ACPI: video - do not store invalid entries in attached_array list ACPI: re-name acpi_pm_ops to acpi_suspend_ops ACER_WMI/ASUS_LAPTOP: fix build bug thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed ACPI: check a return value correctly in acpi_power_get_context() #if 0 acpi/bay.c:eject_removable_drive() eeepc-laptop: add hwmon fan control eeepc-laptop: add backlight eeepc-laptop: add base driver ACPI: thinkpad-acpi: bump up version to 0.20 ACPI: thinkpad-acpi: fix selects in Kconfig ACPI: thinkpad-acpi: use a private workqueue ACPI: thinkpad-acpi: fluff really minor fix ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation ... Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c manually.
2008-04-30Merge branches 'release', 'acpica', 'bugzilla-10224', 'bugzilla-9772', ↵Len Brown
'bugzilla-9916', 'ec', 'eeepc', 'idle', 'misc', 'pm-legacy', 'sysfs-links-2.6.26', 'thermal', 'thinkpad' and 'video' into release
2008-04-29frv: use kbuild.h instead of defining macros in asm-offsets.cChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: Move arches to use common unaligned accessHarvey Harrison
Unaligned access is ok for the following arches: cris, m68k, mn10300, powerpc, s390, x86 Arches that use the memmove implementation for native endian, and the byteshifting for the opposite endianness. h8300, m32r, xtensa Packed struct for native endian, byteshifting for other endian: alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh m86knommu is generic_be for Coldfire, otherwise unaligned access is ok. frv, arm chooses endianness based on compiler settings, uses the byteshifting versions. Remove the unaligned trap handler from frv as it is now unused. v850 is le, uses the byteshifting versions for both be and le. Remove the now unused asm-generic implementation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Remove the macro get_personalityWANG Cong
Remove the macro get_personality, use ->personality instead. Cc: Christoph Hellwig <hch@infradead.org Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29iomap: fix 64 bits resources on 32 bitsBenjamin Herrenschmidt
Almost all implementations of pci_iomap() in the kernel, including the generic lib/iomap.c one, copies the content of a struct resource into unsigned long's which will break on 32 bits platforms with 64 bits resources. This fixes all definitions of pci_iomap() to use resource_size_t. I also "fixed" the 64bits arch for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28frv si_addr annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21frv: unexport kmap_atomic_to_pageAdrian Bunk
This patch removes the no longer used export of kmap_atomic_to_page. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-20PCI: remove pcibios_fixup_ghosts()Greg Kroah-Hartman
This function was obviously never being used since early 2.5 days as any device that it would try to remove would never really be removed from the system due to the PCI device list being held in the driver core, not the general list of PCI devices. As we have not had a single report of a problem here in 4 years, I think it's safe to remove now. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI: remove initial bios sort of PCI devices on x86Greg Kroah-Hartman
We currently keep 2 lists of PCI devices in the system, one in the driver core, and one all on its own. This second list is sorted at boot time, in "BIOS" order, to try to remain compatible with older kernels (2.2 and earlier days). There was also a "nosort" option to turn this sorting off, to remain compatible with even older kernel versions, but that just ends up being what we have been doing from 2.5 days... Unfortunately, the second list of devices is not really ever used to determine the probing order of PCI devices or drivers[1]. That is done using the driver core list instead. This change happened back in the early 2.5 days. Relying on BIOS ording for the binding of drivers to specific device names is problematic for many reasons, and userspace tools like udev exist to properly name devices in a persistant manner if that is needed, no reliance on the BIOS is needed. Matt Domsch and others at Dell noticed this back in 2006, and added a boot option to sort the PCI device lists (both of them) in a breadth-first manner to help remain compatible with the 2.4 order, if needed for any reason. This option is not going away, as some systems rely on them. This patch removes the sorting of the internal PCI device list in "BIOS" mode, as it's not needed at all anymore, and hasn't for many years. I've also removed the PCI flags for this from some other arches that for some reason defined them, but never used them. This should not change the ordering of any drivers or device probing. [1] The old-style pci_get_device and pci_find_device() still used this sorting order, but there are very few drivers that use these functions, as they are deprecated for use in this manner. If for some reason, a driver rely on the order and uses these functions, the breadth-first boot option will resolve any problem. Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-15PM: Remove legacy PMPavel Machek
AFAICT pm_send_all is a nop when noone uses pm_register... Hmm.. can we just force CONFIG_PM_LEGACY=n, and see what happens? Or maybe this is better idea? It may break build somewhere, but it should be easy to fix... (it builds here, i386 and x86-64). Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-14FRV: Correctly determine the address of an illegal instructionDavid Howells
Correctly determine the address of an illegal instruction. The EPCR0 register holds this value (masked by EPCR0_PC) if the validity bit is set (masked by EPCR0_V). So the test as to whether the contents of the register are usable should be involve checking the _V bit, not the _PC bits. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10FRV: Make NOMMU-mode work with base addresses other than 0xC0000000 [try #2]David Howells
Make NOMMU-mode work with base addresses other than 0xC0000000 by: (1) Giving the code that sets up the protection registers the right address in __sdram_base. Rather than being hard coded to 0xC0000000, the value of __page_offset is obtained from the linker script. (2) Eliminate the check in __switch_to() that verifies the current thread info is in the 0xCxxxxxxx region. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10FRV: Add support for emulation of userspace atomic ops [try #2]David Howells
Use traps 120-126 to emulate atomic cmpxchg32, xchg32, and XOR-, OR-, AND-, SUB- and ADD-to-memory operations for userspace. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-20FRV: Change the timerfd syscalls to be the same as i386David Howells
Change the FRV timerfd syscalls to be the same as i386 timerfd syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-20FRV: Drop the .data.idt section for FRVDavid Howells
There is no .data.idt section for FRV, so drop it from the linker script. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13xtime_lock vs update_process_timesPeter Zijlstra
Commit d3d74453c34f8fd87674a8cf5b8a327c68f22e99 ("hrtimer: fixup the HRTIMER_CB_IRQSAFE_NO_SOFTIRQ fallback") broke several archs, and since only Russell bothered to merge the fix, and Greg to ACK his arch, I'm sending this for merger. I have confirmation that the Alpha bit results in a booting kernel. That leaves: blackfin, frv, sh and sparc untested. The deadlock in question was found by Russell: IRQ handle -> timer_tick() - xtime seqlock held for write -> update_process_times() -> run_local_timers() -> hrtimer_run_queues() -> hrtimer_get_softirq_time() - tries to get a read lock Now, Thomas assures me the fix is trivial, only do_timer() needs to be done under the xtime_lock, and update_process_times() can savely be removed from under it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Greg Ungerer <gerg@uclinux.org> CC: Richard Henderson <rth@twiddle.net> CC: Bryan Wu <bryan.wu@analog.com> CC: David Howells <dhowells@redhat.com> CC: Paul Mundt <lethal@linux-sh.org> CC: William Irwin <wli@holomorphy.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13FRV: Fix up parse error in linker scriptDavid Howells
Fix up parse error in FRV linker script, presumably introduced through changes to the INIT_TEXT and EXIT_TEXT macros. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09ide: introduce HAVE_IDESam Ravnborg
To allow flexible configuration of IDE introduce HAVE_IDE. All archs except arm, um and s390 unconditionally select it. For arm the actual configuration determine if IDE is supported. This is a step towards introducing drivers/Kconfig for arm. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08avoid overflows in kernel/time.cH. Peter Anvin
When the conversion factor between jiffies and milli- or microseconds is not a single multiply or divide, as for the case of HZ == 300, we currently do a multiply followed by a divide. The intervening result, however, is subject to overflows, especially since the fraction is not simplified (for HZ == 300, we multiply by 300 and divide by 1000). This is exposed to the user when passing a large timeout to poll(), for example. This patch replaces the multiply-divide with a reciprocal multiplication on 32-bit platforms. When the input is an unsigned long, there is no portable way to do this on 64-bit platforms there is no portable way to do this since it requires a 128-bit intermediate result (which gcc does support on 64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but since the output is a 32-bit integer in the cases affected, just simplify the multiply-divide (*3/10 instead of *300/1000). The reciprocal multiply used can have off-by-one errors in the upper half of the valid output range. This could be avoided at the expense of having to deal with a potential 65-bit intermediate result. Since the intent is to avoid overflow problems and most of the other time conversions are only semiexact, the off-by-one errors were considered an acceptable tradeoff. At Ralf Baechle's suggestion, this version uses a Perl script to compute the necessary constants. We already have dependencies on Perl for kernel compiles. This does, however, require the Perl module Math::BigInt, which is included in the standard Perl distribution starting with version 5.8.0. In order to support older versions of Perl, include a table of canned constants in the script itself, and structure the script so that Math::BigInt isn't required if pulling values from said table. Running the script requires that the HZ value is available from the Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the architectures which didn't already have it (alpha, cris, frv, h8300, m32r, m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or sh64 architectures, since Paul Mundt has dealt with those separately in the sh tree. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org>, Cc: Sam Ravnborg <sam@ravnborg.org>, Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Richard Henderson <rth@twiddle.net>, Cc: Michael Starvik <starvik@axis.com>, Cc: David Howells <dhowells@redhat.com>, Cc: Yoshinori Sato <ysato@users.sourceforge.jp>, Cc: Hirokazu Takata <takata@linux-m32r.org>, Cc: Geert Uytterhoeven <geert@linux-m68k.org>, Cc: Roman Zippel <zippel@linux-m68k.org>, Cc: William L. Irwin <sparclinux@vger.kernel.org>, Cc: Chris Zankel <chris@zankel.net>, Cc: H. Peter Anvin <hpa@zytor.com>, Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08procfs: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06calibrate_delay() must be __cpuinitAdrian Bunk
calibrate_delay() must be __cpuinit, not __{dev,}init. I've verified that this is correct for all users. While doing the latter, I also did the following cleanups: - remove pointless additional prototypes in C files - ensure all users #include <linux/delay.h> This fixes the following section mismatches with CONFIG_HOTPLUG=n, CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x1128d): Section mismatch: reference to .init.text.1:calibrate_delay (between 'check_cx686_slop' and 'set_cx86_reorder') WARNING: vmlinux.o(.text+0x25102): Section mismatch: reference to .init.text.1:calibrate_delay (between 'smp_callin' and 'cpu_coregroup_map') Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christian Zankel <chris@zankel.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05timerfd: fix remaining architecturesAndrew Morton
Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05frv: use find_task_by_vpid in cxn_pin_by_pidPavel Emelyanov
The function is question gets the pid from sysctl table, so this one is a virtual pid, i.e. the pid of a task as it is seen from inside a namespace. So the find_task_by_vpid() must be used here. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05FRV: permit the memory to be located elsewhere in NOMMU modeDavid Howells
Permit the memory to be located somewhere other than address 0xC0000000 in NOMMU mode. The configuration options are already present, it just requires wiring up in the linker script. Note that only a limited set of locations of runtime addresses are available because of the way the CPU protection registers work. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-03move frv docs one level upAdrian Bunk
My first guess for "fujitsu" was it might be related to the fujitsu-laptop.c driver... Move the frv directory one level up since frv is the name of the architecture in the Linux kernel. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Move Kconfig.instrumentation to arch/Kconfig and init/KconfigMathieu Desnoyers
Move the instrumentation Kconfig to arch/Kconfig for architecture dependent options - oprofile - kprobes and init/Kconfig for architecture independent options - profiling - markers Remove the "Instrumentation Support" menu. Everything moves to "General setup". Delete the kernel/Kconfig.instrumentation file. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-02Merge branch 'suspend' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'suspend' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (38 commits) suspend: cleanup reference to swsusp_pg_dir[] PM: Remove obsolete /sys/devices/.../power/state docs Hibernation: Invoke suspend notifications after console switch Suspend: Invoke suspend notifications after console switch Suspend: Clean up suspend_64.c Suspend: Add config option to disable the freezer if architecture wants that ACPI: Print message before calling _PTS ACPI hibernation: Call _PTS before suspending devices Hibernation: Introduce begin() and end() callbacks ACPI suspend: Call _PTS before suspending devices ACPI: Separate disabling of GPEs from _PTS ACPI: Separate invocations of _GTS and _BFS from _PTS and _WAK Suspend: Introduce begin() and end() callbacks suspend: fix ia64 allmodconfig build ACPI: clear GPE earily in resume to avoid warning Suspend: Clean up Kconfig (V2) Hibernation: Clean up Kconfig (V2) Hibernation: Update messages Suspend: Use common prefix in messages Hibernation: Remove unnecessary variable declaration ...
2008-02-01Suspend: Clean up Kconfig (V2)Johannes Berg
This cleans up the suspend Kconfig and removes the need to declare centrally which architectures support suspend. All architectures that currently support suspend are modified accordingly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Russell King <rmk@arm.linux.org.uk> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01PCI: Kconfig help: don't refer to the PCI-HOWTOAdrian Bunk
A HOWTO that hasn't been updated for half a dozen years no longer "contains valuable information about which PCI hardware does work under Linux and which doesn't". Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-28Remove references to "make dep"Adrian Bunk
"make dep" is no longer required in kernel 2.6, but was still mentioned in some places. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28FRV: Drop 'TOPDIR' from MakefilesWANG Cong
This patch drops TOPDIR from frv Makefiles. Cc: David Howells <dhowells@redhat.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-11-29FRV: arrange things such that BRA can reach from the trap tableDavid Howells
Arrange the sections in the FRV arch so that a BRA instruction with a 16-bit displacement can always reach from the trap table to entry.S, tlb-miss.S and break.S. The problem otherwise is that the linker can insert sufficient code between the slots in the trap table and the targets of the branch instructions in those slots that the displacement field in the instruction isn't sufficiently large. This is because the branch targets were in the .text section along with most of the other code in the kernel. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-09FRV: Remove the section annotation on free_initmem()David Howells
Remove the section annotation on FRV's free_initmem(). It can't be marked __init, lest it free itself. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-27scatterlist fallout: frvAl Viro
2007-10-20spelling fixes: arch/frv/Simon Arlott
Spelling fixes in arch/frv/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-By: David Howells <dhowells@redhat.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Combine instrumentation menus in kernel/Kconfig.instrumentationMathieu Desnoyers
Quoting Randy: "It seems sad that this patch sources Kconfig.marker, a 7-line file, 20-something times. Yes, you (we) don't want to put those 7 lines into 20-something different files, so sourcing is the right thing. However, what you did for avr32 seems more on the right track to me: make _one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES, and MARKERS and then use (source) that in all of the arches." Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17remove include/asm-*/ipc.hAdrian Bunk
All asm/ipc.h files do only #include <asm-generic/ipc.h>. This patch therefore removes all include/asm-*/ipc.h files and moves the contents of include/asm-generic/ipc.h to include/linux/ipc.h. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-16FRV: cleanup struct irqaction initializersThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
