minix bit operations are only used by minix filesystem and useless by
other modules. Because byte order of inode and block bitmaps is different
on each architecture like below:
m68k:
big-endian 16bit indexed bitmaps
h8300, microblaze, s390, sparc, m68knommu:
big-endian 32 or 64bit indexed bitmaps
m32r, mips, sh, xtensa:
big-endian 32 or 64bit indexed bitmaps for big-endian mode
little-endian bitmaps for little-endian mode
Others:
In order to move minix bit operations from asm/bitops.h to architecture
independent code in minix filesystem, this provides two config options.
CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k.
CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use
native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu,
m32r, mips, sh, xtensa). The architectures which always use little-endian
bitmaps do not select these options.
Finally, we can remove minix bit operations from asm/bitops.h for all
architectures.
Acked-by: Greg Ungerer <gerg@uclinux.org>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Cc: Chris Zankel <chris@zankel.net>
As the result of conversions, there are no users of ext2 non-atomic bit
operations except for ext2 filesystem itself. Now we can put them into
architecture independent code in ext2 filesystem, and remove from
asm/bitops.h for all architectures.
Cc: Jan Kara <jack@suse.cz>
Introduce little-endian bit operations to the big-endian architectures
which do not have native little-endian bit operations and the
little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300,
ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa)
These architectures can just include generic implementation
(asm-generic/bitops/le.h).
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Matthew Wilcox <willy@debian.org>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Like fls, but can't be handed 0 and returns the bit number.
Done as a script (well, a single "git mv" actually) on request from
Yoshinori Sato as a way to avoid a huge diff.
Requested-by: Yoshinori Sato <ysato@users.sourceforge.jp>
