path: root/arch/h8300/mm
2008-10-16h8300: GENERIC_BUG supportYoshinori Sato
CONFIG_GENERIC_BUG support. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12h8300: fix section mismatchesYoshinori Sato
WARNING: vmlinux.o(.text+0x2fdf): Section mismatch in reference from the variable .LM3 to the variable .init.text:___alloc_bootmem The function .LM3() references the variable __init ___alloc_bootmem. This is often because .LM3 lacks a __init annotation or the annotation of ___alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x2ff5): Section mismatch in reference from the variable .LM4 to the variable .init.text:___alloc_bootmem The function .LM4() references the variable __init ___alloc_bootmem. This is often because .LM4 lacks a __init annotation or the annotation of ___alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x300b): Section mismatch in reference from the variable .LM5 to the variable .init.text:___alloc_bootmem The function .LM5() references the variable __init ___alloc_bootmem. This is often because .LM5 lacks a __init annotation or the annotation of ___alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x304b): Section mismatch in reference from the variable .LM10 to the variable .init.text:_free_area_init The function .LM10() references the variable __init _free_area_init. This is often because .LM10 lacks a __init annotation or the annotation of _free_area_init is wrong. WARNING: vmlinux.o(.text+0x30a3): Section mismatch in reference from the variable .LM17 to the variable .init.text:_free_all_bootmem The function .LM17() references the variable __init _free_all_bootmem. This is often because .LM17 lacks a __init annotation or the annotation of _free_all_bootmem is wrong. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26h8300: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free pages, printed by show_free_areas() - pages in swapcache, printed by show_swap_cache_info() where show_mem() calls show_free_areas(), which calls show_swap_cache_info(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07h8300 generic irqYoshinori Sato
h8300 using generic irq handler patch. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] reduce MAX_NR_ZONES: fix MAX_NR_ZONES array initializationsChristoph Lameter
Fix array initialization in lots of arches The number of zones may now be reduced from 4 to 2 for many arches. Fix the array initialization for the zones array for all architectures so that it is not initializing a fixed number of elements. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] remove set_page_count() outside mm/Nick Piggin
set_page_count usage outside mm/ is limited to setting the refcount to 1. Remove set_page_count from outside mm/, and replace those users with init_page_count() and set_page_refcounted(). This allows more debug checking, and tighter control on how code is allowed to play around with page->_count. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] h8300: remove MAGIC_ROM_PTR from memory.cGreg Ungerer
Remove obsolete MAGIC_ROM_PTR code from h8300 architecture. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
