path: root/arch/h8300
2011-07-26h8300/m68k/xtensa: __FD_ISSET should return 0/1Andrew Morton
Harmonise these return values with other architectures. In some cases this affects all compilers and in other cases non-gcc compilers only. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Chris Zankel <chris@zankel.net> Cc: Ulrich Drepper <drepper@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25h8300, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-21treewide: fix potentially dangerous trailing ';' in #defined values/expressionsPhil Carmody
All these are instances of #define NAME value; or #define NAME(params_opt) value; These of course fail to build when used in contexts like if(foo $OP NAME) while(bar $OP NAME) and may silently generate the wrong code in contexts such as foo = NAME + 1; /* foo = value; + 1; */ bar = NAME - 1; /* bar = value; - 1; */ baz = NAME & quux; /* baz = value; & quux; */ Reported on comp.lang.c, Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com> Initial analysis of the dangers provided by Keith Thompson in that thread. There are many more instances of more complicated macros having unnecessary trailing semicolons, but this pile seems to be all of the cases of simple values suffering from the problem. (Thus things that are likely to be found in one of the contexts above, more complicated ones aren't.) Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-05h8300: Use generic config PREEMPT definitionFrederic Weisbecker
So that it can handle the new CONFIG_PREEMPT_COUNT. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-25Merge branch 'irq-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (23 commits) genirq: Expand generic show_interrupts() gpio: Fold irq_set_chip/irq_set_handler to irq_set_chip_and_handler gpio: Cleanup genirq namespace arm: ep93xx: Add basic interrupt info arm/gpio: Remove three copies of broken and racy debug code xtensa: Use generic show_interrupts() xtensa: Convert genirq namespace xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATED xtensa: Convert s6000 gpio irq_chip to new functions xtensa: Convert main irq_chip to new functions um: Use generic show_interrupts() um: Convert genirq namespace m32r: Use generic show_interrupts() m32r: Convert genirq namespace h8300: Use generic show_interrupts() h8300: Convert genirq namespace avr32: Cleanup eic_set_irq_type() avr32: Use generic show_interrupts() avr: Cleanup genirq namespace avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATED ... Fix up trivial conflict in drivers/gpio/timbgpio.c
2011-03-24h8300: Use generic show_interrupts()Thomas Gleixner
2011-03-24h8300: Convert genirq namespaceThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-23bitops: remove minix bitops from asm/bitops.hAkinobu Mita
minix bit operations are only used by minix filesystem and useless by other modules. Because byte order of inode and block bitmaps is different on each architecture like below: m68k: big-endian 16bit indexed bitmaps h8300, microblaze, s390, sparc, m68knommu: big-endian 32 or 64bit indexed bitmaps m32r, mips, sh, xtensa: big-endian 32 or 64bit indexed bitmaps for big-endian mode little-endian bitmaps for little-endian mode Others: little-endian bitmaps In order to move minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this provides two config options. CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k. CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu, m32r, mips, sh, xtensa). The architectures which always use little-endian bitmaps do not select these options. Finally, we can remove minix bit operations from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce CONFIG_GENERIC_FIND_BIT_LEAkinobu Mita
This introduces CONFIG_GENERIC_FIND_BIT_LE to tell whether to use generic implementation of find_*_bit_le() in lib/find_next_bit.c or not. For now we select CONFIG_GENERIC_FIND_BIT_LE for all architectures which enable CONFIG_GENERIC_FIND_NEXT_BIT. But m68knommu wants to define own faster find_next_zero_bit_le() and continues using generic find_next_{,zero_}bit(). (CONFIG_GENERIC_FIND_NEXT_BIT and !CONFIG_GENERIC_FIND_BIT_LE) Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22add the common dma_addr_t typedef to include/linux/types.hFUJITA Tomonori
All architectures can use the common dma_addr_t typedef now. We can remove the arch specific dma_addr_t. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17h8300: change to new flag variablematt mooney
Replace EXTRA_AFLAGS with asflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-01-31h8300: Switch do_timer() to xtime_update()Torben Hohn
xtime_update() takes the xtime_lock itself. Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: hch@infradead.org Cc: yong.zhang0@gmail.com LKML-Reference: <20110127145951.23248.92727.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-21h8300: Use generic irq KconfigThomas Gleixner
Switch to the generic irq Kconfig. h8300 has all irq chips converted to the new functions, so select the GENERIC_HARDIRQS_NO_DEPRECATED switch as well. Fixup the resulting fallout in show_interrupts(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-21h8300: Convert interrupt handling to flow handlerThomas Gleixner
__do_IRQ is deprecated so h8300 needs to be converted to proper flow handling. The irq chip is simple and does not required any mask/ack/eoi functions, so we can use handle_simple_irq. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-21h8300: Convert to new irq_chip functionsThomas Gleixner
No functional change, just straight forward conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-27ptrace: cleanup arch_ptrace() on h8300Namhyung Kim
Use new 'regno', 'datap' variables in order to remove duplicated expressions and unnecessary castings. Alse remove checking @addr less than 0 because addr is now unsigned. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (49 commits) serial8250: ratelimit "too much work" error serial: bfin_sport_uart: speed up sport RX sample rate to be 3% faster serial: abstraction for 8250 legacy ports serial/imx: check that the buffer is non-empty before sending it out serial: mfd: add more baud rates support jsm: Remove the uart port on errors Alchemy: Add UART PM methods. 8250: allow platforms to override PM hook. altera_uart: Don't use plain integer as NULL pointer altera_uart: Fix missing prototype for registering an early console altera_uart: Fixup type usage of port flags altera_uart: Make it possible to use Altera UART and 8250 ports together altera_uart: Add support for different address strides altera_uart: Add support for getting mapbase and IRQ from resources altera_uart: Add support for polling mode (IRQ-less) serial: Factor out uart_poll_timeout() from 8250 driver serial: mark the 8250 driver as maintained serial: 8250: Don't delay after transmitter is ready. tty: MAINTAINERS: add drivers/serial/jsm/ as maintained driver vcs: invoke the vt update callback when /dev/vcs* is written to ...
2010-10-22ioctl: Use asm-generic/ioctls.h on h8300 (enables termiox)Jeff Mahoney
This patch converts h8300 to use asm-generic/ioctls.h instead of its own version. The differences between the arch-specific version and the generic version are as follows: - H8300 defines its own value for FIOQSIZE, asm-generic/ioctls.h keeps it - The generic version adds TIOCSRS485 and TIOGSRS485, but are unused by any driver available on this architecture. - The generic version adds support for termiox Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-18Update broken web addresses in arch directory.Justin P. Mattock
The patch below updates broken web addresses in the arch directory. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-12Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
We need to revert the temporary hack in 71ebc01, hence the merge.
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
2010-10-05modules: Fix module_bug_list list corruption raceLinus Torvalds
With all the recent module loading cleanups, we've minimized the code that sits under module_mutex, fixing various deadlocks and making it possible to do most of the module loading in parallel. However, that whole conversion totally missed the rather obscure code that adds a new module to the list for BUG() handling. That code was doubly obscure because (a) the code itself lives in lib/bugs.c (for dubious reasons) and (b) it gets called from the architecture-specific "module_finalize()" rather than from generic code. Calling it from arch-specific code makes no sense what-so-ever to begin with, and is now actively wrong since that code isn't protected by the module loading lock any more. So this commit moves the "module_bug_{finalize,cleanup}()" calls away from the arch-specific code, and into the generic code - and in the process protects it with the module_mutex so that the list operations are now safe. Future fixups: - move the module list handling code into kernel/module.c where it belongs. - get rid of 'module_bug_list' and just use the regular list of modules (called 'modules' - imagine that) that we already create and maintain for other reasons. Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-19kbuild: migrate all arch to the kconfig mainmenu upgradeArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-09-07h8300: Fix missing consts in kernel_execve()David Howells
Fix missing consts in h8300's kernel_execve(): arch/h8300/kernel/sys_h8300.c: In function 'kernel_execve': arch/h8300/kernel/sys_h8300.c:59: warning: initialization from incompatible pointer type arch/h8300/kernel/sys_h8300.c:60: warning: initialization from incompatible pointer type Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-07h8300: Fix die()David Howells
Fix h8300's die() to take care of a number of problems: CC arch/h8300/kernel/traps.o In file included from arch/h8300/include/asm/bitops.h:10, from include/linux/bitops.h:22, from include/linux/kernel.h:17, from include/linux/sched.h:54, from arch/h8300/kernel/traps.c:18: arch/h8300/include/asm/system.h:136: warning: 'struct pt_regs' declared inside parameter list arch/h8300/include/asm/system.h:136: warning: its scope is only this definition or declaration, which is probably not what you want arch/h8300/kernel/traps.c:100: error: conflicting types for 'die' arch/h8300/include/asm/system.h:136: error: previous declaration of 'die' was here make[2]: *** [arch/h8300/kernel/traps.o] Error 1 Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-07h8300: IRQ flags should be stored in an unsigned longDavid Howells
Fix h8300's asm/atomic.h to store the IRQ flags in an unsigned long to deal with warnings of the following type: arch/h8300/include/asm/atomic.h: In function 'atomic_add_return': arch/h8300/include/asm/atomic.h:22: warning: comparison of distinct pointer types lacks a cast arch/h8300/include/asm/atomic.h:24: warning: comparison of distinct pointer types lacks a cast Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-10tty: Add EXTPROC support for LINEMODEhyc@symas.com
This patch is against the 2.6.34 source. Paraphrased from the 1989 BSD patch by David Borman @ cray.com: These are the changes needed for the kernel to support LINEMODE in the server. There is a new bit in the termios local flag word, EXTPROC. When this bit is set, several aspects of the terminal driver are disabled. Input line editing, character echo, and mapping of signals are all disabled. This allows the telnetd to turn off these functions when in linemode, but still keep track of what state the user wants the terminal to be in. New ioctl: TIOCSIG Generate a signal to processes in the current process group of the pty. There is a new mode for packet driver, the TIOCPKT_IOCTL bit. When packet mode is turned on in the pty, and the EXTPROC bit is set, then whenever the state of the pty is changed, the next read on the master side of the pty will have the TIOCPKT_IOCTL bit set. This allows the process on the server side of the pty to know when the state of the terminal has changed; it can then issue the appropriate ioctl to retrieve the new state. Since the original BSD patches accompanied the source code for telnet I've left that reference here, but obviously the feature is useful for any remote terminal protocol, including ssh. The corresponding feature has existed in the BSD tty driver since 1989. For historical reference, a good copy of the relevant files can be found here: http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741 Signed-off-by: Howard Chu <hyc@symas.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-09alpha/h8300/m68k: remove obsolete <asm/md.h> filesGeert Uytterhoeven
Removal of these started in 2.3.43pre3, ca. 10 years ago. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
