It reports machine check capability in CPUID, but doesn't actually
implement all the necessary MSRs of the standard Intel machine
check architecture.
This fixes a boot failure on K6s recently introduced.
Signed-off-by: Andi Kleen <ak@suse.de>
Currently the i386 architecture checks the family for mce capability and this
removes that and uses the CPUID information. Tested on a K8 revE and a
family10h processor.
This eliminates checking of a set AMD procesor family if mce is
allowed and relies on the information being in CPUID.
Signed-off-by: Joachim Deguara <joachim.deguara@amd.com>
Cc: Andi Kleen <ak@suse.de>
As a bug workaround bank 0 on K7s is normally disabled, but no need
to do that on other AMD CPUs.
Cc: davej@redhat.com
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
It's widely seen a MCE non-fatal error reported after resume. It seems MCE
resume is lacked under ia32. This patch tries to fix the gap.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Most of these guys are simply not needed (pulled by other stuff
via asm-i386/hardirq.h). One that is not entirely useless is hilarious -
arch/i386/oprofile/nmi_timer_int.c includes linux/irq.h... as a way to
get linux/errno.h
Using CPU hotplug to support suspend/resume SMP. Both S3 and S4 use
disable/enable_nonboot_cpus API. The S4 part is based on Pavel's original S4
SMP patch.
Signed-off-by: Li Shaohua<shaohua.li@intel.com>
infrastructure for it.
Let it rip!
