The printk level in this printk is bogus, as the previous printk
didn't have a terminating \n resulting in ..
Intel E7520/7320/7525 detected.<6>Disabling irq balancing and affinity
It also never printed a \n at all in the case where we didn't do
the quirk.
Change it to only make noise if it actually does something useful.
Signed-off-by: Dave Jones <davej@redhat.com>
Obsoleted by Ingo's genapic stuff.
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Andi Kleen <ak@suse.de>
Cc: "Li, Shaohua" <shaohua.li@intel.com>
Signed-off-by: Andi Kleen <ak@suse.de>
This is unneeded with Ingo's genapic rework.
Fix verify_quirk_intel_irqbalance(). genapic checks should really
happen only on affected versions of the E7520/E7320/E7525 based platforms.
AK: This should akpm's Coyote SDV
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Move the irqbalance quirks for E7320/E7520/E7525(Errata 23 in
http://download.intel.com/design/chipsets/specupdt/30304203.pdf) to early
quirks.
And add a PCI quirk for these platforms to check(which happens very late
during the boot) if the APIC routing is indeed set to default flat mode.
This fixes the breakage(in x86_64) of this quirk due to cpu hotplug which
selects physical mode instead of the logical flat(as needed for this errata
workaround).
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This is a subset of the bluesmoke project core code, stripped of the NMI work
which isn't ready to merge and some of the "interesting" proc functionality
that needs reworking or just has no place in kernel. It requires no core
kernel changes except the added scrub functions already posted.
The goal is to merge further functionality only after the core code is
accepted and proven in the base kernel, and only at the point the upstream
extras are really ready to merge.
This converts EDAC to sysfs and is the final chunk neccessary before EDAC
has a stable user space API and can be considered for submission into the
base kernel.
Signed-off-by: Alan Cox <alan@redhat.com>
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Signed-off-by: doug thompson <norsk5@xmission.com>
Signed-off-by: Pavel Machek <pavel@suse.cz>
infrastructure for it.
Let it rip!
