Remove the old timers/timer_opts infrastructure which has been disabled. It
is a fairly straightforward set of deletions
Note that this does not provide any i386 clocksources, so you will only have
the jiffies clocksource. To get full replacements for the code being removed
here, the timeofday-clocks-i386 patch will be needed.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
This variable is rarely written to. Mark the variable accordingly.
Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org>
Signed-off-by: Shai Fultheim <shai@scalex86.org>
I just found out that some precision is unnecessarily lost in the
arch/i386/kernel/timers/timer_tsc.c:set_cyc2ns_scale function. It uses a
cpu_mhz parameter when it could use a cpu_khz. In the specific case of an
Intel P4 running at 3001.171 Mhz, the truncation to 3001 Mhz leads to an
imprecision of 19 microseconds per second : this is very sad for a timer with
nearly nanosecond accuracy.
Fix the x86_64 architecture too.
Cc: george anzinger <george@mvista.com>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Andi Kleen <ak@muc.de>
Mark variables which are usually accessed for reads with __readmostly.
Signed-off-by: Alok N Kataria <alokk@calsoftinc.com>
Move some more frequently read variables that showed up during some of our
performance tests as sometimes ending up in hot cachelines to the
read_mostly section.
Fix: Move the __read_mostly from before hpet_usec_quotient to follow the
variable like the other uses of __read_mostly.
Signed-off-by: Christoph Lameter <christoph@scalex86.org>
The timers lack .suspend/.resume methods. Because of this, jiffies got a
big compensation after a S3 resume. And then softlockup watchdog reports
an oops. This occured with HPET enabled, but it's also possible for other
timers.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Only use read_timer_tsc only when CPU has TSC. Thanks to Andrea for
pointing this out. Should not be issue on any platforms as all recent
systems that has HPET also has CPUs that supports TSC. The patch is still
required for correctness.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Add a new section called ".data.read_mostly" for data items that are read
frequently and rarely written to like cpumaps etc.
If these maps are placed in the .data section then these frequenly read
items may end up in cachelines with data is is frequently updated. In that
case all processors in an SMP system must needlessly reload the cachelines
again and again containing elements of those frequently used variables.
The ability to share these cachelines will allow each cpu in an SMP system
to keep local copies of those shared cachelines thereby optimizing
performance.
Signed-off-by: Shobhit Dayal <shobhit@calsoftinc.com>
x86_64's cpu_khz is unsigned int and there is no reason why x86 needs to use
unsigned long.
So make cpu_khz unsigned int on x86 as well.
Issue:
Current tsc based delay_calibration can result in significant errors in
loops_per_jiffy count when the platform events like SMIs
(System Management Interrupts that are non-maskable) are present. This could
lead to potential kernel panic(). This issue is becoming more visible with 2.6
kernel (as default HZ is 1000) and on platforms with higher SMI handling
latencies. During the boot time, SMIs are mostly used by BIOS (for things
like legacy keyboard emulation).
Description:
The psuedocode for current delay calibration with tsc based delay looks like
(0) Estimate a value for loops_per_jiffy
(1) While (loops_per_jiffy estimate is accurate enough)
(2) wait for jiffy transition (jiffy1)
(3) Note down current tsc (tsc1)
(4) loop until tsc becomes tsc1 + loops_per_jiffy
(5) check whether jiffy changed since jiffy1 or not and refine
Consider the following cases
Case 1:
If SMIs happen between (2) and (3) above, we can end up with a
loops_per_jiffy value that is too low. This results in shorted delays and
kernel can panic () during boot (Mostly at IOAPIC timer initialization
timer_irq_works() as we don't have enough timer interrupts in a specified
interval).
Case 2:
If SMIs happen between (3) and (4) above, then we can end up with a
loops_per_jiffy value that is too high. And with current i386 code, too
high lpj value (greater than 17M) can result in a overflow in
delay.c:__const_udelay() again resulting in shorter delay and panic().
Solution:
The patch below makes the calibration routine aware of asynchronous events
like SMIs. We increase the delay calibration time and also identify any
significant errors (greater than 12.5%) in the calibration and notify it to
user.
Patch below changes both i386 and x86-64 architectures to use this
new and improved calibrate_delay_direct() routine.
Currently the i386 HPET code assumes the entire HPET implementation from
the spec is present. This breaks on boxes that do not implement the
optional legacy timer replacement functionality portion of the spec.
This patch, which is very similar to my x86-64 patch for the same issue,
fixes the problem allowing i386 systems that cannot use the HPET for the
timer interrupt and RTC to still use the HPET as a time source. I've
tested this patch on a system systems without HPET, with HPET but without
legacy timer replacement, as well as HPET with legacy timer replacement.
infrastructure for it.
Let it rip!
