path: root/arch/i386/math-emu
2007-10-11i386: move math-emuThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-06-08potential parse error in ifdef part 3Yoann Padioleau
Fix various bits of obviously-busted code which we're not happening to compile, due to ifdefs. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13[PATCH] i386: avoid gcc extensionRandy Dunlap
setcc() in math-emu is written as a gcc extension statement expression macro that returns a value. However, it's not used that way and it's not needed like that, so just make it a inline function so that we don't use an extension when it's not needed. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Cc: Christoph Hellwig <hch@infradead.org> Cc: Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-02-13[PATCH] i386: Convert i386 PDA code to use %fsJeremy Fitzhardinge
Convert the PDA code to use %fs rather than %gs as the segment for per-processor data. This is because some processors show a small but measurable performance gain for reloading a NULL segment selector (as %fs generally is in user-space) versus a non-NULL one (as %gs generally is). On modern processors the difference is very small, perhaps undetectable. Some old AMD "K6 3D+" processors are noticably slower when %fs is used rather than %gs; I have no idea why this might be, but I think they're sufficiently rare that it doesn't matter much. This patch also fixes the math emulator, which had not been adjusted to match the changed struct pt_regs. [frederik.deweerdt@gmail.com: fixit with gdb] [mingo@elte.hu: Fix KVM too] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Ian Campbell <Ian.Campbell@XenSource.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Zachary Amsden <zach@vmware.com> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] i386: fix must_checksRandy Dunlap
Fix __must_check warnings in i386/math-emu. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andi Kleen <ak@suse.de>
2005-09-05[PATCH] i386: inline assembler: cleanup and encapsulate descriptor and task ↵Zachary Amsden
register management i386 inline assembler cleanup. This change encapsulates descriptor and task register management. Also, it is possible to improve assembler generation in two cases; savesegment may store the value in a register instead of a memory location, which allows GCC to optimize stack variables into registers, and MOV MEM, SEG is always a 16-bit write to memory, making the casting in math-emu unnecessary. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
