path: root/arch/ia64/Makefile
2013-12-10ia64/xen: Remove Xen support for ia64Boris Ostrovsky
ia64 has not been supported by Xen since 4.2 so it's time to drop Xen/ia64 from Linux as well. Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2010-08-04Merge commit 'v2.6.35' into kbuild/kbuildMichal Marek
Conflicts: arch/powerpc/Makefile
2010-08-03kbuild: allow assignment to {A,C}FLAGS_KERNEL on the command lineSam Ravnborg
It is now possible to assign options to AS and CC on the command line - which is only used for built-in code. {A,C}FLAGS_KERNEL was used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC without overriding the original value. Introduce a new set of variables KBUILD_{A,C}FLAGS_KERNEL that is used by arch specific files and free up {A,C}FLAGS_KERNEL so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-03kbuild: allow assignment to {A,C,LD}FLAGS_MODULE on the command lineSam Ravnborg
It is now possible to assign options to AS, CC and LD on the command line - which is only used when building modules. {A,C,LD}FLAGS_MODULE was all used both in the top-level Makefile in the arch makefiles, thus users had no way to specify additional options to AS, CC, LD when building modules without overriding the original value. Introduce a new set of variables KBUILD_{A,C,LD}FLAGS_MODULE that is used by arch specific files and free up {A,C,LD}FLAGS_MODULE so they can be assigned on the command line. All arch Makefiles that used the old variables has been updated. Note: Previously we had a MODFLAGS variable for both AS and CC. But in favour of consistency this was dropped. So in some cases arch Makefile has one assignmnet replaced by two assignmnets. Note2: MODFLAGS was not documented and is dropped without any notice. I do not expect much/any breakage from this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [avr32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-02-08[IA64] Remove COMPAT_IA32 supportTony Luck
This has been broken since May 2008 when Al Viro killed altroot support. Since nobody has complained, it would appear that there are no users of this code (A plausible theory since the main OSVs that support ia64 prefer to use the IA32-EL software emulation). Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-12-12ia64: move nr-irqs.h to include/generatedSam Ravnborg
Avoid generating files in the now deprecated asm-ia64 dir Simplified the logic in the Makefile when editing stuff in the area Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-08-11arch/ia64/Makefile: Remove -mtune=merced in IA64 kernel buildFenghua Yu
Between GCC version 3.4.0 and 4.3.3 (including 3.4.0 and 4.3.3), -mtune=merced is implemented in GCC. Starting from 4.4.0, -mtune=merced is deprecated. Even implemented in versions between 3.4.0 and 4.3.3, the -mtune=merced feature has been broken in some of the versions. For example, GCC 4.1.2 reports interanl tuning function errors during kernel building with -mtune=merced. Or GCC Bugzilla 16130 reports another -mtune=merced issue on GCC 3.4.1. So I would remove the -mtune=merced from IA64 kernel build. Without this option, kernel on Merced will remain the same except losing an unstable and out-of-date performance tunning feature. Since GCC version 3.4.0, -mtune=mckinley has been implemented. The -mtune=mckinley option functions the same as mtune=itanium2. And mtune=itanium2 is the default option. So we don't need to add mtune=mckinley either since its been the default option in any GCC version which implements this option. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
2008-10-17Pull vtd-iommu into release branchTony Luck
Conflicts: arch/ia64/kernel/acpi.c
2008-10-17[IA64] Add Variable Page Size and IA64 Support in Intel IOMMUFenghua Yu
The patch contains Intel IOMMU IA64 specific code. It defines new machvec dig_vtd, hooks for IOMMU, DMAR table detection, cache line flush function, etc. For a generic kernel with CONFIG_DMAR=y, if Intel IOMMU is detected, dig_vtd is used for machinve vector. Otherwise, kernel falls back to dig machine vector. Kernel parameter "machvec=dig" or "intel_iommu=off" can be used to force kernel to boot dig machine vector. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-10-17ia64/xen: define xen machine vector for domU.Isaku Yamahata
define xen machine vector for domU. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-07-17Pull pvops into release branchTony Luck
2008-06-16[IA64] Fix CONFIG_IA64_SGI_UV build errorJack Steiner
Fix build error in CONFIG_IA64_SGI_UV config. (GENERIC builds are ok). Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-27[IA64] pvops: paravirtualize NR_IRQSIsaku Yamahata
Make NR_IRQ overridable by each pv instances. Pv instance may need each own number of irqs so that NR_IRQS should be the maximum number of nr_irqs each pv instances need. Cc: Jes Sorensen <jes@sgi.com> Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] machvec support for SGI UV platformJack Steiner
This patch adds the basic IA64 machvec infrastructure to support the SGI "UV" platform. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-27KVM: ia64: Enable kvm build for ia64Xiantao Zhang
Update the related Makefile and KConfig for kvm build Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-03-04[IA64] move defconfig to arch/ia64/configs/Adrian Bunk
This patch moves the default ia64 defconfig to arch/ia64/configs/generic_defconfig where it belongs and selects it as the default defconfig through KBUILD_DEFCONFIG. Signed-off-by: Adrian Bunk <adrian.bunk@movial.fi> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-07[IA64] don't assume that unwcheck.py is executableAndrew Morton
Don't assume that this file has execute permissions. For example, patch(1) loses that information. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-10-15kbuild: enable 'make CPPFLAGS=...' to add additional options to CPPSam Ravnborg
The variable CPPFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. This patch replace use of CPPFLAGS with KBUILD_CPPFLAGS all over the tree and enabling one to use: make CPPFLAGS=... to specify additional CPP commandline options. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-21[IA64] add vmlinuz targetAlex Williamson
This is a trivial stand-alone patch out of the Xen/ia64 patches. Add a vmlinuz build target to be more compatible with x86-ish targets. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-06kbuild: change kbuild to not rely on incorrect GNU make behaviorPaul Smith
The kbuild system takes advantage of an incorrect behavior in GNU make. Once this behavior is fixed, all files in the kernel rebuild every time, even if nothing has changed. This patch ensures kbuild works with both the incorrect and correct behaviors of GNU make. For more details on the incorrect behavior, see: http://lists.gnu.org/archive/html/bug-make/2006-03/msg00003.html Changes in this patch: - Keep all targets that are to be marked .PHONY in a variable, PHONY. - Add .PHONY: $(PHONY) to mark them properly. - Remove any $(PHONY) files from the $? list when determining whether targets are up-to-date or not. Signed-off-by: Paul Smith <psmith@gnu.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-08kbuild: remove GCC_VERSIONSam Ravnborg
This was causing some ordering problems. Remove the up-front evaluation and just revaluate the compiler version each time we need it. (The up-front evaluation was problematic because some architectures modify the value of $(CC)). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-13[IA64] fix circular dependency on generation of asm-offsets.hTony Luck
Fix? One ugly hack is replaced by a different ugly hack. Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-11kbuild: rename prepare to archprepare to fix dependency chainSam Ravnborg
When introducing the generic asm-offsets.h support the dependency chain for the prepare targets was changed. All build scripts expecting include/asm/asm-offsets.h to be made when using the prepare target would broke. With the limited number of prepare targets left in arch Makefiles the trivial solution was to introduce a new arch specific target: archprepare The dependency chain looks like this now: prepare | +--> prepare0 | +--> archprepare | +--> scripts_basic +--> prepare1 | +---> prepare2 | +--> prepare3 So prepare 3 is processed before prepare2 etc. This guaantees that the asm symlink, version.h, scripts_basic are all updated before archprepare is processed. prepare0 which build the asm-offsets.h file will need the actions performed by archprepare. The head target is now named prepare, because users scripts will most likely use that target, but prepare-all has been kept for compatibility. Updated Documentation/kbuild/makefiles.txt. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-09kbuild: ia64 use generic asm-offsets.h supportSam Ravnborg
Delete obsolete stuff from arch Makefile Rename file to asm-offsets.h The trick used in the arch Makefile to circumvent the circular dependency is kept. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
