it has been a synonym for CONFIG_ACPI since 2.6.12
Signed-off-by: Len Brown <len.brown@intel.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Just `make oldconfig' doesn't help for the zx1 defconfig ---
because we need the MPT Fusion drivers, which are picked up as not
selected.
Tested on HP ZX2000 and ZX2600.
Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au>
Signed-off-by: Greg Edwards <edwardsg@sgi.com>
This patch removes the CONFIG_IA64_SGI_SN_SIM option entirely, allowing
any kernel bootable on sn2 to also be booted in the simulator.
Boot tested on Altix and HP rx2600.
Altix patch to enable use of vgacon driver on that platform. Depends on the
PCDP generalization patch discussed at:
http://marc.theaimsgroup.com/?l=linux-ia64&m=111446235101939&w=2
Signed-off-by: Mark Maule <maule@sgi.com>
This will at least suppress one prompt that users would have received the
first time they compile with the new DISCONTIG arch option. They'll still
get the "Memory Model" prompt, but 99% of them will have the default work
there.
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Do arch/ia64/defconfig by hand.
The SGI IOC4 I/O controller chip drivers are currently all configured by
CONFIG_BLK_DEV_SGIIOC4. This is undesirable as not all IOC4 hardware features
are needed by all systems.
This patch adds two configuration variables, CONFIG_SGI_IOC4 for core IOC4
driver support (see patch 1/3 in this series for further explanation) and
CONFIG_SERIAL_SGI_IOC4 to independently enable serial port support.
Signed-off-by: Brent Casavant <bcasavan@sgi.com>
Acked-by: Pat Gefre <pfg@sgi.com>
Acked-by: Jeremy Higdon <jeremy@sgi.com>
Kristen did most of the checking, bring this up to -rc2.
This patch is to provide CX port infrastructure for SGI TIO-based
h/w. Also a 'core services' driver for SGI FPGA-based h/w.
Signed-off-by: Bruce Losure <blosure@sgi.com>
infrastructure for it.
Let it rip!
