Moving irq ack notification logic as common, and make
it shared with ia64 side.
Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
include/asm-x86/statfs.h
arch/x86/kernel/signal_64.c
x86-v28-for-linus-phase3-B
arch/x86/kernel/pci-gart_64.c
include/asm-x86/dma-mapping.h
Initial fix for making sure that we can access percpu variables
in all C code (commit: 10617bbe84628eb18ab5f723d3ba35005adde143)
inadvertantly allocated the memory in the "percpu" section of
the vmlinux ELF executable. This confused kexec/dump.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Currently a SIGTRAP can denote any one of below reasons.
- Breakpoint hit
- H/W debug register hit
- Single step
- Signal sent through kill() or rasie()
Architectures like powerpc/parisc provides infrastructure to demultiplex
SIGTRAP signal by passing down the information for receiving SIGTRAP through
si_code of siginfot_t structure. Here is an attempt is generalise this
infrastructure by extending it to x86 and x86_64 archs.
Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com>
Cc: Roland McGrath <roland@redhat.com>
Cc: akpm@linux-foundation.org
Cc: paulus@samba.org
Cc: linuxppc-dev@ozlabs.org
lib/swiotlb.c
bte.h expects a #define of L1_CACHE_MASK which is currently only
in bte.c. This small patch gets bte.h to include cleanly and makes
BTE_UNALIGNED_COPY not report errors.
Signed-off-by: Robin Holt <holt@sgi.com>
Broke the non modular builds by moving an essential function into
modules.c. Fix this by moving it out again and into asm/sections.h as
an inline. To do this, the definitions of struct fdesc and struct
got_val have been lifted out of modules.c and put in asm/elf.h where
they belong.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
It was introduced by "vsprintf: add support for '%pS' and '%pF' pointer
formats" in commit 0fe1ef24f7bd0020f29ffe287dfdb9ead33ca0b2. However,
the current way its coded doesn't work on parisc64. For two reasons: 1)
parisc isn't in the #ifdef and 2) parisc has a different format for
function descriptors
Make dereference_function_descriptor() more accommodating by allowing
architecture overrides. I put the three overrides (for parisc64, ppc64
and ia64) in arch/kernel/module.c because that's where the kernel
internal linker which knows how to deal with function descriptors sits.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Tony Luck <tony.luck@intel.com>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
This patch makes dma_alloc_coherent use GFP_DMA at all times. This is
necessary for swiotlb, which requires the callers to set up the gfp
flags properly.
swiotlb_alloc_coherent tries to allocate pages with the gfp flags. If
the allocated memory isn't fit for dev->coherent_dma_mask,
swiotlb_alloc_coherent reserves some of the swiotlb memory area, which
is precious resource. So the callers need to set up the gfp flags
properly.
This patch means that other IA64 IOMMUs' dma_alloc_coherent also use
GFP_DMA. These IOMMUs (e.g. SBA IOMMU) don't need GFP_DMA since they
can map a memory to any address. But IA64's GFP_DMA is large,
generally drivers allocate small memory with dma_alloc_coherent only
at startup. So I chose the simplest way to set up the gfp flags for
swiotlb.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Joerg Roedel <joerg.roedel@amd.com>
This patch also includes the required removal of (unused) inclusion of
<asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these
architectures.
[dwmw2: updated for 2.6.27-rc]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Some ia64 systems produce several repeats of kernel messages like this:
kernel unaligned access to 0xe000000644220466, ip=0xa000000100516fa1
This was tracked to ide code using the __cmd[] field in "struct request"
via the __outsw() function. __cmd[] is a char array, so is not guaranteed
to be properly aligned when accessed as words.
Tested-by: Nishanth Aravamudan <nacc@us.ibm.com>
Rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZE, because control
page is used for not only code on some platform. For example in kexec
jump, it is used for data and stack too.
[akpm@linux-foundation.org: unbreak powerpc and arm, finish conversion]
Signed-off-by: Huang Ying <ying.huang@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
This patch changes ia64 to use the new bcd2bin/bin2bcd functions instead
of the obsolete BCD2BIN/BIN2BCD macros.
After moving the the include files there were a few clean-ups:
1) Some files used #include <asm-ia64/xyz.h>, changed to <asm/xyz.h>
2) Some comments alerted maintainers to look at various header files to
make matching updates if certain code were to be changed. Updated these
comments to use the new include paths.
3) Some header files mentioned their own names in initial comments. Just
deleted these self references.
