path: root/arch/ia64/kernel/acpi.c
2008-07-17[IA64] Avoid overflowing ia64_cpu_to_sapicid in acpi_map_lsapic()Alex Chiang
acpi_map_lsapic tries to stuff a long into ia64_cpu_to_sapicid[], which can only hold ints, so let's fix that. We need to update the signature of acpi_map_cpu2node() too. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-06-11ACPI: handle invalid ACPI SLIT tableFenghua Yu
This is a SLIT sanity checking patch. It moves slit_valid() function to generic ACPI code and does sanity checking for both x86 and ia64. It sets up node_distance with LOCAL_DISTANCE and REMOTE_DISTANCE when hitting invalid SLIT table on ia64. It also cleans up unused variable localities in acpi_parse_slit() on x86. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-05-14[IA64] Properly unregister legacy interruptsPrarit Bhargava
acpi_unregister_gsi() should "undo" what acpi_register_gsi() does. On systems that have legacy interrupts, acpi_unregister_gsi erroneously calls iosapci_unregister_intr() which is wrong to do and causes a loud warning. acpi_unregister_gsi() should just return in these cases. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] machvec support for SGI UV platformJack Steiner
This patch adds the basic IA64 machvec infrastructure to support the SGI "UV" platform. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-30[IA64] fix section mismatch in arch/ia64/kernel/acpi.cHidetoshi Seto
This patch kills: WARNING: vmlinux.o(.text+0x1702): Section mismatch in reference from the function acpi_register_ioapic() to the function .devinit.text:iosapic_init() Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-08[IA64] Minimize per_cpu reservations.holt@sgi.com
This attached patch significantly shrinks boot memory allocation on ia64. It does this by not allocating per_cpu areas for cpus that can never exist. In the case where acpi does not have any numa node description of the cpus, I defaulted to assigning the first 32 round-robin on the known nodes.. For the !CONFIG_ACPI I used for_each_possible_cpu(). Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-07Merge branches 'release' and 'fluff' into releaseLen Brown
Conflicts: drivers/acpi/scan.c include/linux/acpi.h Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: misc cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - drivers/acpi/bay.c:dev_attr_eject - drivers/acpi/bay.c:dev_attr_present - drivers/acpi/dock.c:dev_attr_docked - drivers/acpi/dock.c:dev_attr_flags - drivers/acpi/dock.c:dev_attr_uid - drivers/acpi/dock.c:dev_attr_undock - drivers/acpi/pci_bind.c:acpi_pci_unbind() - drivers/acpi/pci_link.c:acpi_link_lock - drivers/acpi/sbs.c:acpi_sbs_callback() - drivers/acpi/sbshc.c:acpi_smbus_transaction() - drivers/acpi/sleep/main.c:acpi_sleep_prepare() - #if 0 the following unused global functions: - drivers/acpi/numa.c:acpi_unmap_pxm_to_node() - remove the following unused EXPORT_SYMBOL's: - acpi_register_gsi - acpi_unregister_gsi - acpi_strict - acpi_bus_receive_event - register_acpi_bus_type - unregister_acpi_bus_type - acpi_os_printf - acpi_os_sleep - acpi_os_stall - acpi_os_read_pci_configuration - acpi_os_create_semaphore - acpi_os_delete_semaphore - acpi_os_wait_semaphore - acpi_os_signal_semaphore - acpi_os_signal - acpi_pci_irq_enable - acpi_get_pxm Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07Merge branches 'release', 'misc' and 'misc-2.6.25' into releaseLen Brown
2008-02-07Merge branches 'release', 'bugzilla-6217', 'bugzilla-6629', 'bugzilla-6933', ↵Len Brown
'bugzilla-7186', 'bugzilla-8269', 'bugzilla-8570', 'bugzilla-9139', 'bugzilla-9277', 'bugzilla-9341', 'bugzilla-9444', 'bugzilla-9614', 'bugzilla-9643' and 'bugzilla-9644' into release
2007-12-14ACPI: tables: complete searching upon RSDP w/ bad checksum.Len Brown
ACPI tables follow a tree structure in memory. The root of the tree is the RSDP (Root System Description Pointer). To find the RSDP, the OS searches for the signature "RSD PTR " in well known physical memory locations. Then the OS computes a table checksum to verify that the signature is really part of a valid table header. Some systems have a proper signature but an invalid checksum; followed elsewhere by a proper signature with valid checksum. http://bugzilla.kernel.org/show_bug.cgi?id=9444 The Linux RSDP scanning code bailed out on those systems and as a result they booted with ACPI disabled. Fix this by deleting the Linux RSDP scanning code and plugging in the ACPICA RSDP scanning code. Signed-off-by: Len Brown <len.brown@intel.com>
2007-12-13acpi: make __acpi_map_table() and __init functionJan Beulich
.. as it it used only during early boot. Signed-off-by: Jan Beulich <jbeulich@novell.com> arch/ia64/kernel/acpi.c | 2 +- arch/x86/kernel/acpi/boot.c | 4 ++-- drivers/acpi/osl.c | 3 ++- 3 files changed, 5 insertions(+), 4 deletions(-) Signed-off-by: Len Brown <len.brown@intel.com>
2007-12-07[IA64] operator priority fix in acpi_map_lsapic()Roel Kluin
'!' has a higher priority than '&', so as was this won't test the first bit, but rather evaluates to false for any non-zero lsapic->lapic_flags. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-11-09[IA64] IOSAPIC bogus error cleanupGeorge Beshers
On Altix (sn2) machines the "Error parsing MADT" message is misleading because the lack of IOSAPIC entries is expected. Since I am sure someone will ask, I have been told that the chance of this changing anytime soon is close to nil. Signed-off-by: George Beshers <gbeshers@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-26[IA64] Fix wrong assumption in acpi_gsi_to_irqKenji Kaneshige
The ia64's acpi_gsi_to_irq() function assumes irq == vector. But in fact irq can be different from vector. This patch fix this wrong assumption. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-25ACPI: Kconfig: remove CONFIG_ACPI_SLEEP from sourceLen Brown
As it was a synonym for (CONFIG_ACPI && CONFIG_X86), the ifdefs for it were more clutter than they were worth. For ia64, just add a few stubs in anticipation of future S3 or S4 support. Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-24[IA64] acpi_get_sysname() should be __initTony Luck
Section mismatch: reference to .init.text:acpi_find_rsdp (between 'acpi_get_sysname' and 'acpi_request_vector') acpi_get_sysname() needs to call the __init function acpi_find_rsdp, but it doesn't have the __init attribute itself, hence the warning. Luckily it is only called from machvec_init() which has __init attribute, so the fix is to define acpi_get_sysname() as __init too. Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] spelling fixes: arch/ia64/Simon Arlott
Spelling and apostrophe fixes in arch/ia64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-16ACPI: IA64: react to acpi_table_parse() return value changeJohn Keller
acpi_boot_init() is making a bad check on the return status from acpi_table_parse(). acpi_table_parse() now returns zero on success, one on failure. Signed-off-by: Aaron Young <ayoung@sgi.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-06Pull test into release branchLen Brown
2007-02-03[PATCH] Altix: more ACPI PRT supportJohn Keller
The SN Altix platform does not conform to the IOSAPIC IRQ routing model. Add code in acpi_unregister_gsi() to check if (acpi_irq_model == ACPI_IRQ_MODEL_PLATFORM) and return. Due to an oversight, this code was not added previously when similar code was added to acpi_register_gsi(). http://marc.theaimsgroup.com/?l=linux-acpi&m=116680983430121&w=2 Signed-off-by: John Keller <jpk@sgi.com> Acked-by: Len Brown <lenb@kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-02ACPI_NUMA: fix HP IA64 simulator issue with extended memory domainAlexey Starikovskiy
ACPI 3.0 incorporated the SRAT spec, upping the table version to 2, and extending the size of the proximity domain from 1-byte to 4-bytes. This extension was into a reserved field that firmware should set to 0, but the HP simulator had non-zero values there resulting in unexpected huge numbers. So mask the domain down to 8-bits for now. A more general fix will be to check the table version supplied by firmware and get paranoid about reserved fields. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Allow ACPI id to be u32 instead of u8.Alexey Starikovskiy
Allow ACPI id to be u32 instead of u8. Requires drop of conversion tables with the acpiid as index. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Remove duplicate table definitions (non-conflicting)Alexey Starikovskiy
2007-02-02ACPICA: use new ACPI headers.Alexey Starikovskiy
2007-02-02ACPICA: minimal patch to integrate new tables into LinuxAlexey Starikovskiy
2007-01-04ACPI: Altix: ACPI _PRT supportJohn Keller
Provide ACPI _PRT support for SN Altix systems. The SN Altix platform does not conform to the IOSAPIC IRQ routing model, so a new acpi_irq_model (ACPI_IRQ_MODEL_PLATFORM) has been defined. The SN platform specific code sets acpi_irq_model to this new value, and keys off of it in acpi_register_gsi() to avoid the iosapic code path. Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-17[IA64] remove unused acpi_kbd_controller_present, acpi_legacy_devicesBjorn Helgaas
Nobody uses either one anymore. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-09-25[PATCH] cpu to node relationship fixup: acpi_map_cpu2nodeKAMEZAWA Hiroyuki
Problem description: We have additional_cpus= option for allocating possible_cpus. But nid for possible cpus are not fixed at boot time. cpus which is offlined at boot or cpus which is not on SRAT is not tied to its node. This will cause panic at cpu onlining. Usually, pxm_to_nid() mapping is fixed at boot time by SRAT. But, unfortunately, some system (my system!) do not include full SRAT table for possible cpus. (Then, I use additiona_cpus= option.) For such possible cpus, pxm<->nid should be fixed at hot-add. We now have acpi_map_pxm_to_node() which is also used at boot. It's suitable here. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-18ACPI: relax BAD_MADT_ENTRY check to allow LSAPIC variable length string UIDsStarikovskiy, Alexey Y
ACPI 3.0 appended a variable length UID string to the LAPIC structure as part of support for > 256 processors. So the BAD_MADT_ENTRY() sanity check can no longer compare for equality with a fixed structure length. Signed-off-by: Alexey Y Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-07-01Pull acpi_os_free into release branchLen Brown
2006-06-30ACPI: delete acpi_os_free(), use kfree() directlyLen Brown
2006-06-23[IA64] fix ia64 build (fadt_descriptor)Tony Luck
arch/ia64/kernel/acpi.c got forgotten when include/acpi/actbl.h got a cleanup. Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-06-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (65 commits) ACPI: suppress power button event on S3 resume ACPI: resolve merge conflict between sem2mutex and processor_perflib.c ACPI: use for_each_possible_cpu() instead of for_each_cpu() ACPI: delete newly added debugging macros in processor_perflib.c ACPI: UP build fix for bugzilla-5737 Enable P-state software coordination via _PDC P-state software coordination for speedstep-centrino P-state software coordination for acpi-cpufreq P-state software coordination for ACPI core ACPI: create acpi_thermal_resume() ACPI: create acpi_fan_suspend()/acpi_fan_resume() ACPI: pass pm_message_t from acpi_device_suspend() to root_suspend() ACPI: create acpi_device_suspend()/acpi_device_resume() ACPI: replace spin_lock_irq with mutex for ec poll mode ACPI: Allow a WAN module enable/disable on a Thinkpad X60. sem2mutex: acpi, acpi_link_lock ACPI: delete unused acpi_bus_drivers_lock sem2mutex: drivers/acpi/processor_perflib.c ACPI add ia64 exports to build acpi_memhotplug as a module ACPI: asus_acpi_init(): propagate correct return value ... Manual resolve of conflicts in: arch/i386/kernel/cpu/cpufreq/acpi-cpufreq.c arch/i386/kernel/cpu/cpufreq/speedstep-centrino.c include/acpi/processor.h
2006-06-23[PATCH] Unify pxm_to_node() and node_to_pxm()Yasunori Goto
Consolidate the various arch-specific implementations of pxm_to_node() and node_to_pxm() into a single generic version. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-13ACPI: silence ia64 build warningLen Brown
When building sim_defconfig, which does not define CONFIG_ACPI arch/ia64/kernel/acpi.c:71: warning: 'acpi_madt_rev' defined but not used really acpi.c should not be built when CONFIG_ACPI=n... Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-26[PATCH] EFI: keep physical table addresses in efi structureBjorn Helgaas
Almost all users of the table addresses from the EFI system table want physical addresses. So rather than doing the pa->va->pa conversion, just keep physical addresses in struct efi. This fixes a DMI bug: the efi structure contained the physical SMBIOS address on x86 but the virtual address on ia64, so dmi_scan_machine() used ioremap() on a virtual address on ia64. This is essentially the same as an earlier patch by Matt Tolentino: http://marc.theaimsgroup.com/?l=linux-kernel&m=112130292316281&w=2 except that this changes all table addresses, not just ACPI addresses. Matt's original patch was backed out because it caused MCAs on HP sx1000 systems. That problem is resolved by the ioremap() attribute checking added for ia64. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[IA64] Increase max node count on SN platformsJack Steiner
Add support in IA64 acpi for platforms that support more than 256 nodes. Currently, ACPI is limited to 256 nodes because the proximity domain number is 8-bits. Long term, we expect to use ACPI3.0 to support >256 nodes. This patch is an interim solution that works with platforms that pass the high order bits of the proximity domain in "reserved" fields of the ACPI tables. This code is enabled ONLY on SN platforms. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-22[IA64] Ignore disabled Local SAPIC Affinity Structure in SRATKenji Kaneshige
According to the ACPI spec, the OSPM must ignore the contents of the Processor Local APIC/SAPIC Affinity Structure in System Resource Affinity Table (SRAT), if its enable flag is cleared. However, ia64 linux refers all of the Processor Local APIC/SAPIC Affinity Structures in SRAT regardless of the enable flag. This is obviously against the ACPI spec. This patch fixes this bug. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-21Pull bsp-removal into release branchTony Luck
2006-02-16[IA64] Count disabled cpus as potential hot-pluggable CPUsAshok Raj
Minor updates to earlier patch. - Added to documentation to add ia64 as well. - Minor clarification on how to use disabled cpus - used plain max instead of max_t per Andew Morton. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-14[IA64] Count disabled cpus as potential hot-pluggable CPUsAshok Raj
Have a facility to account for potentially hot-pluggable CPUs. ACPI doesnt give a determinstic method to find hot-pluggable CPUs. Hence we use 2 methods to assist. - BIOS can mark potentially hot-pluggable CPUs as disabled in the MADT tables. - User can specify the number of hot-pluggable CPUs via parameter additional_cpus=X The option is enabled only if ACPI_CONFIG_HOTPLUG_CPU=y which enables the physical hotplug option. Without which user can still use logical onlining and offlining of CPUs by enabling CONFIG_HOTPLUG_CPU=y Adds more bits to cpu_possible_map for potentially hot-pluggable cpus. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-19[IA64] Fix UP build with BSP removal support.Ashok Raj
Causes undefined force_cpei_retarget defined in arch/ia64/kernel/smpboot.c Push the unneeded code inside #ifdef CONFIG_HOTPLUG_CPU. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-05[IA64] support for cpu0 removalAshok Raj
here is the BSP removal support for IA64. Its pretty much the same thing that was released a while back, but has your feedback incorporated. - Removed CONFIG_BSP_REMOVE_WORKAROUND and associated cmdline param - Fixed compile issue with sn2/zx1 due to a undefined fix_b0_for_bsp - some formatting nits (whitespace etc) This has been tested on tiger and long back by alex on hp systems as well. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-12-28[ACPI] acpi_register_gsi() fix needed for ACPICA 20051021Len Brown
Use the #define for ACPI_LEVEL_SENSITIVE instead of assuming non-zero, because ACPICA 20051021 changes its value to zero. Also, use uniform variable names: edge_level -> triggering active_high_low -> polarity Signed-off-by: Len Brown <len.brown@intel.com>
2005-09-19[IA64] move ACPI IOSAPIC locality domain mapping from pci.c to acpi.cBjorn Helgaas
Move acpi_map_iosapics() from pci.c to acpi.c, since it doesn't have anything to do with PCI. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-16[IA64] Remove warnings for gcc 4.0 IA64 compilation.Peter Chubb
This patch removes some compilation warnings, mostly trivially. acpi.c fix also noted by Kenji Kaneshige. Signed-off-by; Peter Chubb <peterc@gelato.unsw.edu.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-08[IA64] Manual merge fix for 3 filesTony Luck
arch/ia64/Kconfig arch/ia64/kernel/acpi.c include/asm-ia64/irq.h Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-07[IA64] Minor cleanups - remove CONFIG_ACPI_DEALLOCATE_IRQKenji Kaneshige
The config option 'CONFIG_ACPI_DEALLOCATE_IRQ' is no longer needed. This patch removes it. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
