path: root/arch/ia64/kernel/perfmon.c
2011-01-13[IA64] fix build error - arch/ia64/kernel/perfmon.cTony Luck
arch/ia64/kernel/perfmon.c:621: error: duplicate 'static' Introduced by commit c74a1cbb3cac348f276fabc381758f5b0b4713b2 pass default dentry_operations to mount_pseudo() Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-01-12pass default dentry_operations to mount_pseudo()Al Viro
2011-01-10Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Avoid array overflow if there are too many cpus in SRAT table [IA64] Remove unlikely from cpu_is_offline [IA64] irq_ia64, use set_irq_chip [IA64] perfmon: Change vmalloc to vzalloc and drop memset. [IA64] eliminate race condition in smp_flush_tlb_mm
2011-01-07fs: scale mntget/mntputNick Piggin
The problem that this patch aims to fix is vfsmount refcounting scalability. We need to take a reference on the vfsmount for every successful path lookup, which often go to the same mount point. The fundamental difficulty is that a "simple" reference count can never be made scalable, because any time a reference is dropped, we must check whether that was the last reference. To do that requires communication with all other CPUs that may have taken a reference count. We can make refcounts more scalable in a couple of ways, involving keeping distributed counters, and checking for the global-zero condition less frequently. - check the global sum once every interval (this will delay zero detection for some interval, so it's probably a showstopper for vfsmounts). - keep a local count and only taking the global sum when local reaches 0 (this is difficult for vfsmounts, because we can't hold preempt off for the life of a reference, so a counter would need to be per-thread or tied strongly to a particular CPU which requires more locking). - keep a local difference of increments and decrements, which allows us to sum the total difference and hence find the refcount when summing all CPUs. Then, keep a single integer "long" refcount for slow and long lasting references, and only take the global sum of local counters when the long refcount is 0. This last scheme is what I implemented here. Attached mounts and process root and working directory references are "long" references, and everything else is a short reference. This allows scalable vfsmount references during path walking over mounted subtrees and unattached (lazy umounted) mounts with processes still running in them. This results in one fewer atomic op in the fastpath: mntget is now just a per-CPU inc, rather than an atomic inc; and mntput just requires a spinlock and non-atomic decrement in the common case. However code is otherwise bigger and heavier, so single threaded performance is basically a wash. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-12-28[IA64] perfmon: Change vmalloc to vzalloc and drop memset.Jesper Juhl
vzalloc() nicely zeroes memory for us, so we don't have to do a vmalloc() and then manually memset() the returned memory when all we want is for it to be zero. Patch changes this for pfm_rvmalloc(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Tony Luck <tony.luck@intel.com>
2010-10-29convert get_sb_pseudo() usersAl Viro
2010-09-23[IA64] Remove unnecessary casts of private_data in perfmon.cJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2010-08-11ia64: perfmon: add d_dname methodMiklos Szeredi
Switch ia64/perfmon to using the d_dname() instead of relying on __d_path() to prepend the name of the root dentry to the path. CC: Tony Luck <tony.luck@intel.com> CC: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-07-06[IA64] perfmon: convert to unlocked_ioctlArnd Bergmann
The ioctl function in this driver does not do anything that requires the BKL, so make it use unlocked_ioctl. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06mm: change anon_vma linking to fix multi-process server scalability issueRik van Riel
The old anon_vma code can lead to scalability issues with heavily forking workloads. Specifically, each anon_vma will be shared between the parent process and all its child processes. In a workload with 1000 child processes and a VMA with 1000 anonymous pages per process that get COWed, this leads to a system with a million anonymous pages in the same anon_vma, each of which is mapped in just one of the 1000 processes. However, the current rmap code needs to walk them all, leading to O(N) scanning complexity for each page. This can result in systems where one CPU is walking the page tables of 1000 processes in page_referenced_one, while all other CPUs are stuck on the anon_vma lock. This leads to catastrophic failure for a benchmark like AIM7, where the total number of processes can reach in the tens of thousands. Real workloads are still a factor 10 less process intensive than AIM7, but they are catching up. This patch changes the way anon_vmas and VMAs are linked, which allows us to associate multiple anon_vmas with a VMA. At fork time, each child process gets its own anon_vmas, in which its COWed pages will be instantiated. The parents' anon_vma is also linked to the VMA, because non-COWed pages could be present in any of the children. This reduces rmap scanning complexity to O(1) for the pages of the 1000 child processes, with O(N) complexity for at most 1/N pages in the system. This reduces the average scanning cost in heavily forking workloads from O(N) to 2. The only real complexity in this patch stems from the fact that linking a VMA to anon_vmas now involves memory allocations. This means vma_adjust can fail, if it needs to attach a VMA to anon_vma structures. This in turn means error handling needs to be added to the calling functions. A second source of complexity is that, because there can be multiple anon_vmas, the anon_vma linking in vma_adjust can no longer be done under "the" anon_vma lock. To prevent the rmap code from walking up an incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h to make sure it is impossible to compile a kernel that needs both symbolic values for the same bitflag. Some test results: Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test box with 16GB RAM and not quite enough IO), the system ends up running >99% in system time, with every CPU on the same anon_vma lock in the pageout code. With these changes, AIM7 hits the cross-over point around 29.7k users. This happens with ~99% IO wait time, there never seems to be any spike in system time. The anon_vma lock contention appears to be resolved. [akpm@linux-foundation.org: cleanups] Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-26[IA64] remove trailing space in messagesFrans Pop
ia64 parts of system wide cleanup to drop trailing whitespace from lines in message strings. Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: Tony Luck <tony.luck@intel.com>
2010-01-06[IA64] use helpers for rlimitsJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in 3e10e716abf3c71bdb5d86b8f507f9e72236c9cd or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-12-16switch alloc_file() to passing struct pathAl Viro
... and have the caller grab both mnt and dentry; kill leak in infiniband, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl ia64: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name and .strategy members of sysctl tables are dead code. Remove them. Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-06-30[IA64] address compiler warnings perfmon.c/salinfo.cJan Beulich
perfmon.c has a dubious cast directly from "int" to "void *". Add an intermediate cast to "long" to keep gcc happy. salinfo.c uses "down_trylock()" in a highly creative way (explained in the comments in the file) ... but it does kick out this warning: arch/ia64/kernel/salinfo.c:195: warning: ignoring return value of 'down_trylock' which people occasionally try to "fix" in ways that do not work. Use some casts to keep gcc quiet. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-17Pull for-2.6.31 into releaseTony Luck
2009-06-17[IA64] Convert ia64 to use int-ll64.hMatthew Wilcox
It is generally agreed that it would be beneficial for u64 to be an unsigned long long on all architectures. ia64 (in common with several other 64-bit architectures) currently uses unsigned long. Migrating piecemeal is too painful; this giant patch fixes all compilation warnings and errors that come as a result of switching to use int-ll64.h. Note that userspace will still see __u64 defined as unsigned long. This is important as it affects C++ name mangling. [Updated by Tony Luck to change efi.h:efi_freemem_callback_t to use u64 for start/end rather than unsigned long] Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-06-16remove put_cpu_no_resched()Thomas Gleixner
put_cpu_no_resched() is an optimization of put_cpu() which unfortunately can cause high latencies. The nfs iostats code uses put_cpu_no_resched() in a code sequence where a reschedule request caused by an interrupt between the get_cpu() and the put_cpu_no_resched() can delay the reschedule for at least HZ. The other users of put_cpu_no_resched() optimize correctly in interrupt code, but there is no real harm in using the put_cpu() function which is an alias for preempt_enable(). The extra check of the preemmpt count is not as critical as the potential source of missing a reschedule. Debugged in the preempt-rt tree and verified in mainline. Impact: remove a high latency source [akpm@linux-foundation.org: build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Pull cpumask into release branchTony Luck
2009-03-27constify dentry_operations: restAl Viro
2009-03-16cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits.: ia64Rusty Russell
Impact: cleanup, futureproof In fact, all cpumask ops will only be valid (in general) for bit numbers < nr_cpu_ids. So use that instead of NR_CPUS in various places. This is always safe: no cpu number can be >= nr_cpu_ids, and nr_cpu_ids is initialized to NR_CPUS at boot. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the IA64 archDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-ia64@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-06[IA64] utrace use generic trace hookShaohua Li
Make IA64 use generic trace hook in some paths. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-07-26tracehook: wait_task_inactiveRoland McGrath
This extends wait_task_inactive() with a new argument so it can be used in a "soft" mode where it will check for the task changing state unexpectedly and back off. There is no change to existing callers. This lays the groundwork to allow robust, noninvasive tracing that can try to sample a blocked thread but back off safely if it wakes up. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-26smp_call_function: get rid of the unused nonatomic/retry argumentJens Axboe
It's never used and the comments refer to nonatomic and retry interchangably. So get rid of it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-11[IA64] perfmon: fix async exit bugstephane eranian
Move the cleanup of the async queue to the close callback from the flush callback. This avoids losing asynchronous overflow notifications when the file descriptor is shared by multiple processes and one terminates. Signed-off-by: Stephane Eranian <eranian@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-14[IA64] trivial cleanup for perfmon.cHidetoshi Seto
Fix a typo, and coding style cleanups for pfm_handle_work(). Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-01[IA64] fix file and descriptor handling in perfmonAl Viro
Races galore... General rule: as soon as it's in descriptor table, it's over; another thread might have started IO on it/dup2() it elsewhere/dup2() something *over* it/etc. fd_install() is the very last step one should take - it's a point of no return. Besides, the damn thing leaked on failure exits... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29ia64: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-22[IA64] minor irq handler cleanupsJeff Garzik
- remove unused 'irq' argument from pfm_do_interrupt_handler() - remove pointless cast to void* - add KERN_xxx prefix to printk() - remove braces around singleton C statement - in tioce_provider.c, start tioce_dma_consistent() and tioce_error_intr_handler() function declarations in column 0 This change's main purpose is to prepare for the patchset in jgarzik/misc-2.6.git#irq-remove, that explores removal of the never-used 'irq' argument in each interrupt handler. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] use goto to jump out do/while_each_threadLi Zefan
do_each_thread/while_each_thread is a double loop, so should use 'goto' rather than 'break' to break out the loop. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-06[IA64] remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Long lines have been kept where they exist, some small spacing changes have been done. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-08[IA64] Rename TIF_PERFMON_WORK back to TIF_NOTIFY_RESUMEPetr Tesarik
Since the RSE synchronization will need a TIF_ flag, but all work-to-be-done bits are already used, so we have to multiplex TIF_NOTIFY_RESUME again. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-05[IA64] make pfm_get_task work with virtual pidsPavel Emelyanov
This pid comes from user space, so treat it accordingly. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-04[IA64] constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-06perfmon: Use task_is_*Matthew Wilcox
2007-11-06[IA64] Fix perfmon sysctl directory modesTony Luck
New sanity checks in sysctl_check_table() complain about a couple of mode 0755 that should be 0555 in the perfmon code: sysctl table check failed: /kernel .1 Writable sysctl directory sysctl table check failed: /kernel/perfmon Writable sysctl directory Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-10-19Use helpers to obtain task pid in printks (arch code)Alexey Dobriyan
One of the easiest things to isolate is the pid printed in kernel log. There was a patch, that made this for arch-independent code, this one makes so for arch/xxx files. It took some time to cross-compile it, but hopefully these are all the printks in arch code. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[IA64] perfmon: Remove exit_pfm_fs()Satyam Sharma
Because it is dead code and not referenced by anybody else (that file cannot be built modular). Signed-off-by: Satyam Sharma <satyam@infradead.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-31remove unused TIF_NOTIFY_RESUME flagStephane Eranian
Remove unused TIF_NOTIFY_RESUME flag for all processor architectures. The flag was not used excecpt on IA-64 where the patch replaces it with TIF_PERFMON_WORK. Signed-off-by: stephane eranian <eranian@hpl.hp.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[IA64] spelling fixes: arch/ia64/Simon Arlott
Spelling and apostrophe fixes in arch/ia64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Tony Luck <tony.luck@intel.com>
