path: root/arch/ia64/kernel/signal.c
2008-05-01[IA64] TS_RESTORE_SIGMASKRoland McGrath
Replace TIF_RESTORE_SIGMASK with TS_RESTORE_SIGMASK and define our own set_restore_sigmask() function. This saves the costly SMP-safe set_bit operation, which we do not need for the sigmask flag since TIF_SIGPENDING always has to be set too. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-04[IA64] signal(ia64): add a signal stack overflow checkShi Weihua
The similar check has been added to x86_32(i386) in commit id 83bd01024b1fdfc41d9b758e5669e80fca72df66. So we add this check to ia64 and improve it a liitle bit in that we need to check for stack overflow only when the signal is on stack. Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-18[IA64] signal: remove redundant code in setup_sigcontext()Shi Weihua
This patch removes some redundant code in the function setup_sigcontext(). The registers ar.ccv,b7,r14,ar.csd,ar.ssd,r2-r3 and r16-r31 are not restored in restore_sigcontext() when (flags & IA64_SC_FLAG_IN_SYSCALL) is true. So we don't need to zero those variables in setup_sigcontext(). Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-12-07[IA64] signal : fix missing error checkingsShi Weihua
Not all the return value of __copy_from_user and __put_user is checked.This patch fixed it. Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] wire up pselect, ppoll [IA64] Add TIF_RESTORE_SIGMASK [IA64] unwind did not work for processes born with CLONE_STOPPED [IA64] Optional method to purge the TLB on SN systems [IA64] SPIN_LOCK_UNLOCKED macro cleanup in arch/ia64 [IA64-SN2][KJ] mmtimer.c-kzalloc [IA64] fix stack alignment for ia32 signal handlers [IA64] - Altix: hotplug after intr redirect can crash system [IA64] save and restore cpus_allowed in cpu_idle_wait [IA64] Removal of percpu TR cleanup in kexec code [IA64] Fix some section mismatch errors
2007-05-08[IA64] Add TIF_RESTORE_SIGMASKAlexey Dobriyan
Preparation for pselect and ppoll. ia32 compat code not tested. :-( Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-26[IA64] Delete MCA/INIT sigdelayed codeKeith Owens
The only user of the MCA/INIT sigdelayed code (SGI's I/O probing) has moved from the kernel into SAL. Delete the MCA/INIT sigdelayed code. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-12[PATCH] ia64: task_thread_info()Al Viro
on ia64 thread_info is at the constant offset from task_struct and stack is embedded into the same beast. Set __HAVE_THREAD_FUNCTIONS, made task_thread_info() just add a constant. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[IA64] align signal-frame even when not using alternate signal-stackDavid Mosberger-Tang
At the moment, attempting to invoke a signal-handler on the normal stack is guaranteed to fail if the stack-pointer happens not to be 16-byte aligned. This is because the signal-trampoline will attempt to store fp-regs with stf.spill instructions, which will trap for misaligned addresses. This isn't terribly useful behavior. It's better to just always align the signal frame to the next lower 16-byte boundary. Signed-off-by: David Mosberger-Tang <David.Mosberger@acm.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-08-29[PATCH] convert signal handling of NODEFER to act like other Unix boxes.Steven Rostedt
It has been reported that the way Linux handles NODEFER for signals is not consistent with the way other Unix boxes handle it. I've written a program to test the behavior of how this flag affects signals and had several reports from people who ran this on various Unix boxes, confirming that Linux seems to be unique on the way this is handled. The way NODEFER affects signals on other Unix boxes is as follows: 1) If NODEFER is set, other signals in sa_mask are still blocked. 2) If NODEFER is set and the signal is in sa_mask, then the signal is still blocked. (Note: this is the behavior of all tested but Linux _and_ NetBSD 2.0 *). The way NODEFER affects signals on Linux: 1) If NODEFER is set, other signals are _not_ blocked regardless of sa_mask (Even NetBSD doesn't do this). 2) If NODEFER is set and the signal is in sa_mask, then the signal being handled is not blocked. The patch converts signal handling in all current Linux architectures to the way most Unix boxes work. Unix boxes that were tested: DU4, AIX 5.2, Irix 6.5, NetBSD 2.0, SFU 3.5 on WinXP, AIX 5.3, Mac OSX, and of course Linux 2.6.13-rcX. * NetBSD was the only other Unix to behave like Linux on point #2. The main concern was brought up by point #1 which even NetBSD isn't like Linux. So with this patch, we leave NetBSD as the lonely one that behaves differently here with #2. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-06[IA64] restore_sigcontext is not preempt safeKeith Owens
restore_sigcontext calls ia64_set_local_fpu_owner() which requires that preempt be disabled. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-21[IA64] ptrace and restore_sigcontext() allow ar.rsc.pl==0Matthew Chapman
This patch fixes handling of accesses to ar.rsc via ptrace & restore_sigcontext [With Thanks to Chris Wright for noticing the restore_sigcontext path] Signed-off-by: Matthew Chapman <matthewc@hp.com> Acked-by: David Mosberger <davidm@hpl.hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-05-03[IA64] fix ia64 syscall auditingDavid Woodhouse
Attached is a patch against David's audit.17 kernel that adds checks for the TIF_SYSCALL_AUDIT thread flag to the ia64 system call and signal handling code paths. The patch enables auditing of system calls set up via fsys_bubble_down, as well as ensuring that audit_syscall_exit() is called on return from sigreturn. Neglecting to check for TIF_SYSCALL_AUDIT at these points results in incorrect information in audit_context, causing frequent system panics when system call auditing is enabled on an ia64 system. I have tested this patch and have seen no problems with it. [Original patch from Amy Griffis ported to current kernel by David Woodhouse] From: Amy Griffis <amy.griffis@hp.com> From: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Chris Wright <chrisw@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
