path: root/arch/ia64/kvm
2008-06-06KVM: ia64: fix zero extending for mmio ld1/2/4 emulation in KVMJes Sorensen
Only copy in the data actually requested by the instruction emulation and zero pad the destination register first. This avoids the problem where emulated mmio access got garbled data from ld2.acq instructions in the vga console driver. Signed-off-by: Jes Sorensen <jes@sgi.com> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-18KVM: ia64: fix GVMM module including position-dependent objectsXiantao Zhang
The GVMM module is position independent since it is relocated to the guest address space. Commit ea696f9cf ("ia64 kvm fixes for O=... builds") broke this by linking GVMM with non-PIC objects. Fix by creating two files: memset.S and memcpy.S which just include the files under arch/ia64/lib/{memset.S, memcpy.S} respectively. [akpm: don't delete files which we need] Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ia64 kvm fixes for O=... buildsAl Viro
* EXTRA_CFLAGS do not apply for *.S * don't bother with symlinks to ../lib/mem*.S, just add ../lib/mem*.o to object list Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27KVM: add ioctls to save/store mpstateMarcelo Tosatti
So userspace can save/restore the mpstate during migration. [avi: export the #define constants describing the value] [christian: add s390 stubs] [avi: ditto for ia64] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: Rename VCPU_MP_STATE_* to KVM_MP_STATE_*Avi Kivity
We wish to export it to userspace, so move it into the kvm namespace. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: hlt emulation should take in-kernel APIC/PIT timers into accountMarcelo Tosatti
Timers that fire between guest hlt and vcpu_block's add_wait_queue() are ignored, possibly resulting in hangs. Also make sure that atomic_inc and waitqueue_active tests happen in the specified order, otherwise the following race is open: CPU0 CPU1 if (waitqueue_active(wq)) add_wait_queue() if (!atomic_read(pit_timer->pending)) schedule() atomic_inc(pit_timer->pending) Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Stub out kvmtraceAvi Kivity
2008-04-27KVM: ia64: Enable kvm build for ia64Xiantao Zhang
Update the related Makefile and KConfig for kvm build Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add kvm sal/pal virtulization supportXiantao Zhang
Some sal/pal calls would be traped to kvm for virtulization from guest firmware. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add guest interruption injection supportXiantao Zhang
process.c mainly handle interruption injection, and some faults handling. Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Generate offset values for assembly code useXiantao Zhang
asm-offsets.c will generate offset values used for assembly code for some fileds of special structures. Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add optimization for some virtulization faultsXiantao Zhang
optvfault.S Add optimization for some performance-critical virtualization faults. Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add processor virtulization supportXiantao Zhang
vcpu.c provides processor virtualization logic for kvm. Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add trampoline for guest/host mode switchXiantao Zhang
trampoline code targets for guest/host world switch. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add mmio decoder for kvm/ia64Xiantao Zhang
mmio.c includes mmio decoder, and related mmio logics. Signed-off-by: Anthony Xu <Anthony.xu@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add interruption vector table for vmmXiantao Zhang
vmm_ivt.S includes an ivt for vmm use. Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add TLB virtulization supportXiantao Zhang
vtlb.c includes tlb/VHPT virtulization. Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: VMM module interfacesXiantao Zhang
vmm.c adds the interfaces with kvm/module, and initialize global data area. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add header files for kvm/ia64Xiantao Zhang
kvm_minstate.h : Marcos about Min save routines. lapic.h: apic structure definition. vcpu.h : routions related to vcpu virtualization. vti.h : Some macros or routines for VT support on Itanium. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add kvm arch-specific core code for kvm/ia64Xiantao Zhang
kvm_ia64.c is created to handle kvm ia64-specific core logic. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
