path: root/arch/ia64
2012-01-23iommu: Add option to group multi-function devicesAlex Williamson
The option iommu=group_mf indicates the that the iommu driver should expose all functions of a multi-function PCI device as the same iommu_device_group. This is useful for disallowing individual functions being exposed as independent devices to userspace as there are often hidden dependencies. Virtual functions are not affected by this option. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-01-23iommu/core: Convert iommu_found to iommu_presentJoerg Roedel
With per-bus iommu_ops the iommu_found function needs to work on a bus_type too. This patch adds a bus_type parameter to that function and converts all call-places. The function is also renamed to iommu_present because the function now checks if an iommu is present for a given bus and does not check for a global iommu anymore. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-01-23iommu: Rename the DMAR and INTR_REMAP config optionsSuresh Siddha
Change the CONFIG_DMAR to CONFIG_INTEL_IOMMU to be consistent with the other IOMMU options. Rename the CONFIG_INTR_REMAP to CONFIG_IRQ_REMAP to match the irq subsystem name. And define the CONFIG_DMAR_TABLE for the common ACPI DMAR routines shared by both CONFIG_INTEL_IOMMU and CONFIG_IRQ_REMAP. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: yinghai@kernel.org Cc: youquan.song@intel.com Cc: joerg.roedel@amd.com Cc: tony.luck@intel.com Cc: dwmw2@infradead.org Link: http://lkml.kernel.org/r/20110824001456.558630224@sbsiddha-desk.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu> Conflicts: arch/x86/include/asm/irq_remapping.h arch/x86/kernel/apic/io_apic.c drivers/iommu/Makefile Change-Id: I3f09baf327e59d94f38801d107268f4e20c1da8e
2012-01-23iommu: Cleanup ifdefs in detect_intel_iommu()Suresh Siddha
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: yinghai@kernel.org Cc: youquan.song@intel.com Cc: joerg.roedel@amd.com Cc: tony.luck@intel.com Cc: dwmw2@infradead.org Link: http://lkml.kernel.org/r/20110824001456.386003047@sbsiddha-desk.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-09[IA64] fix "allnoconfig" buildTony Luck
Link errors: arch/ia64/kernel/built-in.o: In function `arch_setup_dmar_msi': (.text+0x35972): undefined reference to `dmar_msi_write' ... and more ... because allnoconfig has CONFIG_DMAR=y due to the "select DMAR" in arch/ia64/Kconfig under config IA64_GENERIC. Drop that select, but add CONFIG_DMAR=y to generic_defconfig so we keep testbuilding the DMAR code. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-08-04Merge branch 'fixefi' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'fixefi' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: efi: Fix argument types for SetVariable() for ia64
2011-08-04efi: Fix argument types for SetVariable() for ia64Matthew Garrett
The spec says this takes uint32 for attributes, not uintn. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-08-03Merge branch 'apei' into apei-releaseLen Brown
Some trivial conflicts due to other various merges adding to the end of common lists sooner than this one. arch/ia64/Kconfig arch/powerpc/Kconfig arch/x86/Kconfig lib/Kconfig lib/Makefile Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-03Add Kconfig option ARCH_HAVE_NMI_SAFE_CMPXCHGHuang Ying
cmpxchg() is widely used by lockless code, including NMI-safe lockless code. But on some architectures, the cmpxchg() implementation is not NMI-safe, on these architectures the lockless code may need a spin_trylock_irqsave() based implementation. This patch adds a Kconfig option: ARCH_HAVE_NMI_SAFE_CMPXCHG, so that NMI-safe lockless code can depend on it or provide different implementation according to it. On many architectures, cmpxchg is only NMI-safe for several specific operand sizes. So, ARCH_HAVE_NMI_SAFE_CMPXCHG define in this patch only guarantees cmpxchg is NMI-safe for sizeof(unsigned long). Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Richard Henderson <rth@twiddle.net> CC: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> CC: Yoshinori Sato <ysato@users.sourceforge.jp> CC: Tony Luck <tony.luck@intel.com> CC: Hirokazu Takata <takata@linux-m32r.org> CC: Geert Uytterhoeven <geert@linux-m68k.org> CC: Michal Simek <monstr@monstr.eu> Acked-by: Ralf Baechle <ralf@linux-mips.org> CC: Kyle McMartin <kyle@mcmartin.ca> CC: Martin Schwidefsky <schwidefsky@de.ibm.com> CC: Chen Liqin <liqin.chen@sunplusct.com> CC: "David S. Miller" <davem@davemloft.net> CC: Ingo Molnar <mingo@redhat.com> CC: Chris Zankel <chris@zankel.net> Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-01Merge branch 'gpiolib' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'gpiolib' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Hook up gpiolib support
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic: add another generic ext2 atomic bitopsAkinobu Mita
The majority of architectures implement ext2 atomic bitops as test_and_{set,clear}_bit() without spinlock. This adds this type of generic implementation in ext2-atomic-setbit.h and use it wherever possible. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andreas Dilger <adilger@dilger.ca> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: modpost: Fix modpost's license checking V3 module: add /sys/module/<name>/uevent files module: change attr callbacks to take struct module_kobject modules: make arch's use default loader hooks modules: add default loader hook implementations param: fix return value handling in param_set_*
2011-07-24Merge branch 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits) KVM: IOMMU: Disable device assignment without interrupt remapping KVM: MMU: trace mmio page fault KVM: MMU: mmio page fault support KVM: MMU: reorganize struct kvm_shadow_walk_iterator KVM: MMU: lockless walking shadow page table KVM: MMU: do not need atomicly to set/clear spte KVM: MMU: introduce the rules to modify shadow page table KVM: MMU: abstract some functions to handle fault pfn KVM: MMU: filter out the mmio pfn from the fault pfn KVM: MMU: remove bypass_guest_pf KVM: MMU: split kvm_mmu_free_page KVM: MMU: count used shadow pages on prepareing path KVM: MMU: rename 'pt_write' to 'emulate' KVM: MMU: cleanup for FNAME(fetch) KVM: MMU: optimize to handle dirty bit KVM: MMU: cache mmio info on page fault path KVM: x86: introduce vcpu_mmio_gva_to_gpa to cleanup the code KVM: MMU: do not update slot bitmap if spte is nonpresent KVM: MMU: fix walking shadow page table KVM guest: KVM Steal time registration ...
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-23virtio: expose for non-virtualization users tooOhad Ben-Cohen
virtio has been so far used only in the context of virtualization, and the virtio Kconfig was sourced directly by the relevant arch Kconfigs when VIRTUALIZATION was selected. Now that we start using virtio for inter-processor communications, we need to source the virtio Kconfig outside of the virtualization scope too. Moreover, some architectures might use virtio for both virtualization and inter-processor communications, so directly sourcing virtio might yield unexpected results due to conflicting selections. The simple solution offered by this patch is to always source virtio's Kconfig in drivers/Kconfig, and remove it from the appropriate arch Kconfigs. Additionally, a virtio menu entry has been added so virtio drivers don't show up in the general drivers menu. This way anyone can use virtio, though it's arguably less accessible (and neat!) for virtualization users now. Note: some architectures (mips and sh) seem to have a VIRTUALIZATION menu merely for sourcing virtio's Kconfig, so that menu is removed too. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22Merge branch 'x86-vdso-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-64, vdso: Do not allocate memory for the vDSO clocksource: Change __ARCH_HAS_CLOCKSOURCE_DATA to a CONFIG option x86, vdso: Drop now wrong comment Document the vDSO and add a reference parser ia64: Replace clocksource.fsys_mmio with generic arch data x86-64: Move vread_tsc and vread_hpet into the vDSO clocksource: Replace vread with generic arch data x86-64: Add --no-undefined to vDSO build x86-64: Allow alternative patching in the vDSO x86: Make alternative instruction pointers relative x86-64: Improve vsyscall emulation CS and RIP handling x86-64: Emulate legacy vsyscalls x86-64: Fill unused parts of the vsyscall page with 0xcc x86-64: Remove vsyscall number 3 (venosys) x86-64: Map the HPET NX x86-64: Remove kernel.vsyscall64 sysctl x86-64: Give vvars their own page x86-64: Document some of entry_64.S x86-64: Fix alignment of jiffies variable
2011-07-22Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: Fix wrong check in list_splice_init_rcu() net,rcu: Convert call_rcu(xt_rateest_free_rcu) to kfree_rcu() sysctl,rcu: Convert call_rcu(free_head) to kfree vmalloc,rcu: Convert call_rcu(rcu_free_vb) to kfree_rcu() vmalloc,rcu: Convert call_rcu(rcu_free_va) to kfree_rcu() ipc,rcu: Convert call_rcu(ipc_immediate_free) to kfree_rcu() ipc,rcu: Convert call_rcu(free_un) to kfree_rcu() security,rcu: Convert call_rcu(sel_netport_free) to kfree_rcu() security,rcu: Convert call_rcu(sel_netnode_free) to kfree_rcu() ia64,rcu: Convert call_rcu(sn_irq_info_free) to kfree_rcu() block,rcu: Convert call_rcu(disk_free_ptbl_rcu_cb) to kfree_rcu() scsi,rcu: Convert call_rcu(fc_rport_free_rcu) to kfree_rcu() audit_tree,rcu: Convert call_rcu(__put_tree) to kfree_rcu() security,rcu: Convert call_rcu(whitelist_item_free) to kfree_rcu() md,rcu: Convert call_rcu(free_conf) to kfree_rcu()
2011-07-21clocksource: Change __ARCH_HAS_CLOCKSOURCE_DATA to a CONFIG optionH. Peter Anvin
The machinery for __ARCH_HAS_CLOCKSOURCE_DATA assumed a file in asm-generic would be the default for architectures without their own file in asm/, but that is not how it works. Replace it with a Kconfig option instead. Link: http://lkml.kernel.org/r/4E288AA6.7090804@zytor.com Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@mit.edu> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Tony Luck <tony.luck@intel.com>
2011-07-21treewide: fix potentially dangerous trailing ';' in #defined values/expressionsPhil Carmody
All these are instances of #define NAME value; or #define NAME(params_opt) value; These of course fail to build when used in contexts like if(foo $OP NAME) while(bar $OP NAME) and may silently generate the wrong code in contexts such as foo = NAME + 1; /* foo = value; + 1; */ bar = NAME - 1; /* bar = value; - 1; */ baz = NAME & quux; /* baz = value; & quux; */ Reported on comp.lang.c, Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com> Initial analysis of the dangers provided by Keith Thompson in that thread. There are many more instances of more complicated macros having unnecessary trailing semicolons, but this pile seems to be all of the cases of simple values suffering from the problem. (Thus things that are likely to be found in one of the contexts above, more complicated ones aren't.) Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-20ia64,rcu: Convert call_rcu(sn_irq_info_free) to kfree_rcu()Lai Jiangshan
The rcu callback sn_irq_info_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sn_irq_info_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-07-14ia64: Replace clocksource.fsys_mmio with generic arch dataAndy Lutomirski
Now that clocksource.archdata is available, use it for ia64-specific code. Cc: Clemens Ladisch <clemens@ladisch.de> Cc: linux-ia64@vger.kernel.org Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andy Lutomirski <luto@mit.edu> Link: http://lkml.kernel.org/r/d31de0ee0842a0e322fb6441571c2b0adb323fa2.1310563276.git.luto@mit.edu Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-14ia64: add jump labels for paravirtGlauber Costa
Since in a later patch I intend to call jump labels inside CONFIG_PARAVIRT, IA64 would fail to compile if they are not provided. This patch provides those jump labels for the IA64 architecture. Signed-off-by: Glauber Costa <glommer@redhat.com> Acked-by: Isaku Yamahata <yamahata@valinux.co.jp> Acked-by: Rik van Riel <riel@redhat.com> CC: Tony Luck <tony.luck@intel.com> CC: Eddie Dong <eddie.dong@intel.com> CC: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> CC: Peter Zijlstra <peterz@infradead.org> CC: Anthony Liguori <aliguori@us.ibm.com> CC: Eric B Munson <emunson@mgebm.net> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-06-21x86/ia64: intel-iommu: move to drivers/iommu/Ohad Ben-Cohen
This should ease finding similarities with different platforms, with the intention of solving problems once in a generic framework which everyone can use. Note: to move intel-iommu.c, the declaration of pci_find_upstream_pcie_bridge() has to move from drivers/pci/pci.h to include/linux/pci.h. This is handled in this patch, too. As suggested, also drop DMAR's EXPERIMENTAL tag while we're at it. Compile-tested on x86_64. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-06-14drivers: iommu: move to a dedicated folderOhad Ben-Cohen
Create a dedicated folder for iommu drivers, and move the base iommu implementation over there. Grouping the various iommu drivers in a single location will help finding similar problems shared by different platforms, so they could be solved once, in the iommu framework, instead of solved differently (or duplicated) in each driver. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-06-01[IA64] Hook up gpiolib supportMark Brown
Allow people to use gpiolib on ia64, mostly for build coverage as it seems more useful to standardise on availablity of the API than handle it being optional. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-31[IA64] wire up sendmmsg() syscall for ItaniumTony Luck
Add entries in unistd.h and entry.S to make this new syscall visible. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26Merge branches 'core-fixes-for-linus' and 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: seqlock: Get rid of SEQLOCK_UNLOCKED * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: irq: Remove smp_affinity_list when unregister irq proc
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25ia64: mmu_gather reworkPeter Zijlstra
Fix up the ia64 mmu_gather code to conform to the new API. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25arch, mm: filter disallowed nodes from arch specific show_mem functionsDavid Rientjes
Architectures that implement their own show_mem() function did not pass the filter argument to show_free_areas() to appropriately avoid emitting the state of nodes that are disallowed in the current context. This patch now passes the filter argument to show_free_areas() so those nodes are now avoided. This patch also removes the show_free_areas() wrapper around __show_free_areas() and converts existing callers to pass an empty filter. ia64 emits additional information for each node, so skip_free_areas_zone() must be made global to filter disallowed nodes and it is converted to use a nid argument rather than a zone for this use case. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24seqlock: Get rid of SEQLOCK_UNLOCKEDEric Dumazet
All static seqlock should be initialized with the lockdep friendly __SEQLOCK_UNLOCKED() macro. Remove legacy SEQLOCK_UNLOCKED() macro. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/%3C1306238888.3026.31.camel%40edumazet-laptop%3E Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-23Merge branch 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.40' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (131 commits) KVM: MMU: Use ptep_user for cmpxchg_gpte() KVM: Fix kvm mmu_notifier initialization order KVM: Add documentation for KVM_CAP_NR_VCPUS KVM: make guest mode entry to be rcu quiescent state KVM: x86 emulator: Make jmp far emulation into a separate function KVM: x86 emulator: Rename emulate_grpX() to em_grpX() KVM: x86 emulator: Remove unused arg from emulate_pop() KVM: x86 emulator: Remove unused arg from writeback() KVM: x86 emulator: Remove unused arg from read_descriptor() KVM: x86 emulator: Remove unused arg from seg_override() KVM: Validate userspace_addr of memslot when registered KVM: MMU: Clean up gpte reading with copy_from_user() KVM: PPC: booke: add sregs support KVM: PPC: booke: save/restore VRSAVE (a.k.a. USPRG0) KVM: PPC: use ticks, not usecs, for exit timing KVM: PPC: fix exit accounting for SPRs, tlbwe, tlbsx KVM: PPC: e500: emulate SVR KVM: VMX: Cache vmcs segment fields KVM: x86 emulator: consolidate segment accessors KVM: VMX: Avoid reading %rip unnecessarily when handling exceptions ...
2011-05-22KVM: ia64: fix sparse warningsJeff Mahoney
This patch fixes some sparse warning about "dubious one-bit signed bitfield." Signed-off-by: Jeff Mahoney <jeffm@suse.com> Originally-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-20Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] define "_sdata" symbol pstore: Fix Kconfig dependencies for apei->pstore pstore: fix potential logic issue in pstore read interface pstore: fix pstore filesystem mount/remount issue pstore: fix one type of return value in pstore [IA64] fix build warning in arch/ia64/oprofile/backtrace.c
2011-05-20sanitize <linux/prefetch.h> usageLinus Torvalds
Commit e66eed651fd1 ("list: remove prefetching from regular list iterators") removed the include of prefetch.h from list.h, which uncovered several cases that had apparently relied on that rather obscure header file dependency. So this fixes things up a bit, using grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]') grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]') to guide us in finding files that either need <linux/prefetch.h> inclusion, or have it despite not needing it. There are more of them around (mostly network drivers), but this gets many core ones. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-20[IA64] define "_sdata" symbolTony Luck
core_kernel_data() wants to know if an address looks like kernel data. IA64 has had _edata forever, but never needed _sdata until now. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-20Pull misc-2.6.40 into release branchTony Luck
2011-05-19Merge branch 'timers-clocksource-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: convert mips to generic i8253 clocksource clocksource: convert x86 to generic i8253 clocksource clocksource: convert footbridge to generic i8253 clocksource clocksource: add common i8253 PIT clocksource blackfin: convert to clocksource_register_hz mips: convert to clocksource_register_hz/khz sparc: convert to clocksource_register_hz/khz alpha: convert to clocksource_register_hz microblaze: convert to clocksource_register_hz/khz ia64: convert to clocksource_register_hz/khz x86: Convert remaining x86 clocksources to clocksource_register_hz/khz Make clocksource name const
2011-05-19Merge branches 'sched-core-for-linus' and 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits) sched: Fix and optimise calculation of the weight-inverse sched: Avoid going ahead if ->cpus_allowed is not changed sched, rt: Update rq clock when unthrottling of an otherwise idle CPU sched: Remove unused parameters from sched_fork() and wake_up_new_task() sched: Shorten the construction of the span cpu mask of sched domain sched: Wrap the 'cfs_rq->nr_spread_over' field with CONFIG_SCHED_DEBUG sched: Remove unused 'this_best_prio arg' from balance_tasks() sched: Remove noop in alloc_rt_sched_group() sched: Get rid of lock_depth sched: Remove obsolete comment from scheduler_tick() sched: Fix sched_domain iterations vs. RCU sched: Next buddy hint on sleep and preempt path sched: Make set_*_buddy() work on non-task entities sched: Remove need_migrate_task() sched: Move the second half of ttwu() to the remote cpu sched: Restructure ttwu() some more sched: Rename ttwu_post_activation() to ttwu_do_wakeup() sched: Remove rq argument from ttwu_stat() sched: Remove rq->lock from the first half of ttwu() sched: Drop rq->lock from sched_exec() ... * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix rt_rq runtime leakage bug
2011-05-14Merge branch 'consolidate-clksrc-i8253' of ↵Thomas Gleixner
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource Conflicts: arch/ia64/kernel/cyclone.c arch/mips/kernel/i8253.c arch/x86/kernel/i8253.c Reason: Resolve conflicts so further cleanups do not conflict further Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
