path: root/arch/ia64
2019-01-16ia64: remove redundant 'export AWK'Masahiro Yamada
This is exported by the top Makefile. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-01-06arch: remove redundant UAPI generic-y definesMasahiro Yamada
Now that Kbuild automatically creates asm-generic wrappers for missing mandatory headers, it is redundant to list the same headers in generic-y and mandatory-y. Suggested-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2019-01-06arch: remove stale comments "UAPI Header export list"Masahiro Yamada
These comments are leftovers of commit fcc8487d477a ("uapi: export all headers under uapi directories"). Prior to that commit, exported headers must be explicitly added to header-y. Now, all headers under the uapi/ directories are exported. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-01-05Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge more updates from Andrew Morton: - procfs updates - various misc bits - lib/ updates - epoll updates - autofs - fatfs - a few more MM bits * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (58 commits) mm/page_io.c: fix polled swap page in checkpatch: add Co-developed-by to signature tags docs: fix Co-Developed-by docs drivers/base/platform.c: kmemleak ignore a known leak fs: don't open code lru_to_page() fs/: remove caller signal_pending branch predictions mm/: remove caller signal_pending branch predictions arch/arc/mm/fault.c: remove caller signal_pending_branch predictions kernel/sched/: remove caller signal_pending branch predictions kernel/locking/mutex.c: remove caller signal_pending branch predictions mm: select HAVE_MOVE_PMD on x86 for faster mremap mm: speed up mremap by 20x on large regions mm: treewide: remove unused address argument from pte_alloc functions initramfs: cleanup incomplete rootfs scripts/gdb: fix lx-version string output kernel/kcov.c: mark write_comp_data() as notrace kernel/sysctl: add panic_print into sysctl panic: add options to print system info when panic happens bfs: extra sanity checking and static inode bitmap exec: separate MM_ANONPAGES and RLIMIT_STACK accounting ...
2019-01-04ia64: fix compile without swiotlbChristoph Hellwig
Some non-generic ia64 configs don't build swiotlb, and thus should not pull in the generic non-coherent DMA infrastructure. Fixes: 68c608345c ("swiotlb: remove dma_mark_clean") Reported-by: Tony Luck <tony.luck@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-01-04mm: treewide: remove unused address argument from pte_alloc functionsJoel Fernandes (Google)
Patch series "Add support for fast mremap". This series speeds up the mremap(2) syscall by copying page tables at the PMD level even for non-THP systems. There is concern that the extra 'address' argument that mremap passes to pte_alloc may do something subtle architecture related in the future that may make the scheme not work. Also we find that there is no point in passing the 'address' to pte_alloc since its unused. This patch therefore removes this argument tree-wide resulting in a nice negative diff as well. Also ensuring along the way that the enabled architectures do not do anything funky with the 'address' argument that goes unnoticed by the optimization. Build and boot tested on x86-64. Build tested on arm64. The config enablement patch for arm64 will be posted in the future after more testing. The changes were obtained by applying the following Coccinelle script. (thanks Julia for answering all Coccinelle questions!). Following fix ups were done manually: * Removal of address argument from pte_fragment_alloc * Removal of pte_alloc_one_fast definitions from m68k and microblaze. // Options: --include-headers --no-includes // Note: I split the 'identifier fn' line, so if you are manually // running it, please unsplit it so it runs for you. virtual patch @pte_alloc_func_def depends on patch exists@ identifier E2; identifier fn =~ "^(__pte_alloc|pte_alloc_one|pte_alloc|__pte_alloc_kernel|pte_alloc_one_kernel)$"; type T2; @@ fn(... - , T2 E2 ) { ... } @pte_alloc_func_proto_noarg depends on patch exists@ type T1, T2, T3, T4; identifier fn =~ "^(__pte_alloc|pte_alloc_one|pte_alloc|__pte_alloc_kernel|pte_alloc_one_kernel)$"; @@ ( - T3 fn(T1, T2); + T3 fn(T1); | - T3 fn(T1, T2, T4); + T3 fn(T1, T2); ) @pte_alloc_func_proto depends on patch exists@ identifier E1, E2, E4; type T1, T2, T3, T4; identifier fn =~ "^(__pte_alloc|pte_alloc_one|pte_alloc|__pte_alloc_kernel|pte_alloc_one_kernel)$"; @@ ( - T3 fn(T1 E1, T2 E2); + T3 fn(T1 E1); | - T3 fn(T1 E1, T2 E2, T4 E4); + T3 fn(T1 E1, T2 E2); ) @pte_alloc_func_call depends on patch exists@ expression E2; identifier fn =~ "^(__pte_alloc|pte_alloc_one|pte_alloc|__pte_alloc_kernel|pte_alloc_one_kernel)$"; @@ fn(... -, E2 ) @pte_alloc_macro depends on patch exists@ identifier fn =~ "^(__pte_alloc|pte_alloc_one|pte_alloc|__pte_alloc_kernel|pte_alloc_one_kernel)$"; identifier a, b, c; expression e; position p; @@ ( - #define fn(a, b, c) e + #define fn(a, b) e | - #define fn(a, b) e + #define fn(a) e ) Link: http://lkml.kernel.org/r/20181108181201.88826-2-joelaf@google.com Signed-off-by: Joel Fernandes (Google) <joel@joelfernandes.org> Suggested-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Michal Hocko <mhocko@kernel.org> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: William Kucharski <william.kucharski@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-01-04fls: change parameter to unsigned intMatthew Wilcox
When testing in userspace, UBSAN pointed out that shifting into the sign bit is undefined behaviour. It doesn't really make sense to ask for the highest set bit of a negative value, so just turn the argument type into an unsigned int. Some architectures (eg ppc) already had it declared as an unsigned int, so I don't expect too many problems. Link: http://lkml.kernel.org/r/20181105221117.31828-1-willy@infradead.org Signed-off-by: Matthew Wilcox <willy@infradead.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-01-03Remove 'type' argument from access_ok() functionLinus Torvalds
Nobody has actually used the type (VERIFY_READ vs VERIFY_WRITE) argument of the user address range verification function since we got rid of the old racy i386-only code to walk page tables by hand. It existed because the original 80386 would not honor the write protect bit when in kernel mode, so you had to do COW by hand before doing any user access. But we haven't supported that in a long time, and these days the 'type' argument is a purely historical artifact. A discussion about extending 'user_access_begin()' to do the range checking resulted this patch, because there is no way we're going to move the old VERIFY_xyz interface to that model. And it's best done at the end of the merge window when I've done most of my merges, so let's just get this done once and for all. This patch was mostly done with a sed-script, with manual fix-ups for the cases that weren't of the trivial 'access_ok(VERIFY_xyz' form. There were a couple of notable cases: - csky still had the old "verify_area()" name as an alias. - the iter_iov code had magical hardcoded knowledge of the actual values of VERIFY_{READ,WRITE} (not that they mattered, since nothing really used it) - microblaze used the type argument for a debug printout but other than those oddities this should be a total no-op patch. I tried to fix up all architectures, did fairly extensive grepping for access_ok() uses, and the changes are trivial, but I may have missed something. Any missed conversion should be trivially fixable, though. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-12-29Merge tag 'kconfig-v4.21-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull Kconfig file consolidation from Masahiro Yamada: "Consolidation of bus (PCI, PCMCIA, EISA, RapidIO) config entries by Christoph Hellwig. Currently, every architecture that wants to provide common peripheral busses needs to add some boilerplate code and include the right Kconfig files. This series instead just selects the presence (when needed) and then handles everything in the bus-specific Kconfig file under drivers/" * tag 'kconfig-v4.21-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: pcmcia: remove per-arch PCMCIA config entry eisa: consolidate EISA Kconfig entry in drivers/eisa rapidio: consolidate RAPIDIO config entry in drivers/rapidio pcmcia: allow PCMCIA support independent of the architecture PCI: consolidate the PCI_SYSCALL symbol PCI: consolidate the PCI_DOMAINS and PCI_DOMAINS_GENERIC config options PCI: consolidate PCI config entry in drivers/pci MIPS: remove the HT_PCI config option
2018-12-29Merge tag 'kconfig-v4.21' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull Kconfig updates from Masahiro Yamada: - support -y option for merge_config.sh to avoid downgrading =y to =m - remove S_OTHER symbol type, and touch include/config/*.h files correctly - fix file name and line number in lexer warnings - fix memory leak when EOF is encountered in quotation - resolve all shift/reduce conflicts of the parser - warn no new line at end of file - make 'source' statement more strict to take only string literal - rewrite the lexer and remove the keyword lookup table - convert to SPDX License Identifier - compile C files independently instead of including them from zconf.y - fix various warnings of gconfig - misc cleanups * tag 'kconfig-v4.21' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (39 commits) kconfig: surround dbg_sym_flags with #ifdef DEBUG to fix gconf warning kconfig: split images.c out of qconf.cc/gconf.c to fix gconf warnings kconfig: add static qualifiers to fix gconf warnings kconfig: split the lexer out of zconf.y kconfig: split some C files out of zconf.y kconfig: convert to SPDX License Identifier kconfig: remove keyword lookup table entirely kconfig: update current_pos in the second lexer kconfig: switch to ASSIGN_VAL state in the second lexer kconfig: stop associating kconf_id with yylval kconfig: refactor end token rules kconfig: stop supporting '.' and '/' in unquoted words treewide: surround Kconfig file paths with double quotes microblaze: surround string default in Kconfig with double quotes kconfig: use T_WORD instead of T_VARIABLE for variables kconfig: use specific tokens instead of T_ASSIGN for assignments kconfig: refactor scanning and parsing "option" properties kconfig: use distinct tokens for type and default properties kconfig: remove redundant token defines kconfig: rename depends_list to comment_option_list ...
2018-12-29Merge tag 'kbuild-v4.21' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull Kbuild updates from Masahiro Yamada: "Kbuild core: - remove unneeded $(call cc-option,...) switches - consolidate Clang compiler flags into CLANG_FLAGS - announce the deprecation of SUBDIRS - fix single target build for external module - simplify the dependencies of 'prepare' stage targets - allow fixdep to directly write to .*.cmd files - simplify dependency generation for CONFIG_TRIM_UNUSED_KSYMS - change if_changed_rule to accept multi-line recipe - move .SECONDARY special target to scripts/Kbuild.include - remove redundant 'set -e' - improve parallel execution for CONFIG_HEADERS_CHECK - misc cleanups Treewide fixes and cleanups - set Clang flags correctly for PowerPC boot images - fix UML build error with CONFIG_GCC_PLUGINS - remove unneeded patterns from .gitignore files - refactor firmware/Makefile - remove unneeded rules for *offsets.s - avoid unneeded regeneration of intermediate .s files - clean up ./Kbuild Modpost: - remove unused -M, -K options - fix false positive warnings about section mismatch - use simple devtable lookup instead of linker magic - misc cleanups Coccinelle: - relax boolinit.cocci checks for overall consistency - fix warning messages of boolinit.cocci Other tools: - improve -dirty check of scripts/setlocalversion - add a tool to generate compile_commands.json from .*.cmd files" * tag 'kbuild-v4.21' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (51 commits) kbuild: remove unused cmd_gentimeconst kbuild: remove $(obj)/ prefixes in ./Kbuild treewide: add intermediate .s files to targets treewide: remove explicit rules for *offsets.s firmware: refactor firmware/Makefile firmware: remove unnecessary patterns from .gitignore scripts: remove unnecessary ihex2fw and check-lc_ctypes from .gitignore um: remove unused filechk_gen_header in Makefile scripts: add a tool to produce a compile_commands.json file kbuild: add -Werror=implicit-int flag unconditionally kbuild: add -Werror=strict-prototypes flag unconditionally kbuild: add -fno-PIE flag unconditionally scripts: coccinelle: Correct warning message scripts: coccinelle: only suggest true/false in files that already use them kbuild: handle part-of-module correctly for *.ll and *.symtypes kbuild: refactor part-of-module kbuild: refactor quiet_modtag kbuild: remove redundant quiet_modtag for $(obj-m) kbuild: refactor Makefile.asm-generic user/Makefile: Fix typo and capitalization in comment section ...
2018-12-28Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc updates from Andrew Morton: - large KASAN update to use arm's "software tag-based mode" - a few misc things - sh updates - ocfs2 updates - just about all of MM * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (167 commits) kernel/fork.c: mark 'stack_vm_area' with __maybe_unused memcg, oom: notify on oom killer invocation from the charge path mm, swap: fix swapoff with KSM pages include/linux/gfp.h: fix typo mm/hmm: fix memremap.h, move dev_page_fault_t callback to hmm hugetlbfs: Use i_mmap_rwsem to fix page fault/truncate race hugetlbfs: use i_mmap_rwsem for more pmd sharing synchronization memory_hotplug: add missing newlines to debugging output mm: remove __hugepage_set_anon_rmap() include/linux/vmstat.h: remove unused page state adjustment macro mm/page_alloc.c: allow error injection mm: migrate: drop unused argument of migrate_page_move_mapping() blkdev: avoid migration stalls for blkdev pages mm: migrate: provide buffer_migrate_page_norefs() mm: migrate: move migrate_page_lock_buffers() mm: migrate: lock buffers before migrate_page_move_mapping() mm: migration: factor out code to compute expected number of page references mm, page_alloc: enable pcpu_drain with zone capability kmemleak: add config to select auto scan mm/page_alloc.c: don't call kasan_free_pages() at deferred mem init ...
2018-12-28Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is mostly update of the usual drivers: smarpqi, lpfc, qedi, megaraid_sas, libsas, zfcp, mpt3sas, hisi_sas. Additionally, we have a pile of annotation, unused variable and minor updates. The big API change is the updates for Christoph's DMA rework which include removing the DISABLE_CLUSTERING flag. And finally there are a couple of target tree updates" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (259 commits) scsi: isci: request: mark expected switch fall-through scsi: isci: remote_node_context: mark expected switch fall-throughs scsi: isci: remote_device: Mark expected switch fall-throughs scsi: isci: phy: Mark expected switch fall-through scsi: iscsi: Capture iscsi debug messages using tracepoints scsi: myrb: Mark expected switch fall-throughs scsi: megaraid: fix out-of-bound array accesses scsi: mpt3sas: mpt3sas_scsih: Mark expected switch fall-through scsi: fcoe: remove set but not used variable 'port' scsi: smartpqi: call pqi_free_interrupts() in pqi_shutdown() scsi: smartpqi: fix build warnings scsi: smartpqi: update driver version scsi: smartpqi: add ofa support scsi: smartpqi: increase fw status register read timeout scsi: smartpqi: bump driver version scsi: smartpqi: add smp_utils support scsi: smartpqi: correct lun reset issues scsi: smartpqi: correct volume status scsi: smartpqi: do not offline disks for transient did no connect conditions scsi: smartpqi: allow for larger raid maps ...
2018-12-28Merge tag 'dma-mapping-4.21' of git://git.infradead.org/users/hch/dma-mappingLinus Torvalds
Pull DMA mapping updates from Christoph Hellwig: "A huge update this time, but a lot of that is just consolidating or removing code: - provide a common DMA_MAPPING_ERROR definition and avoid indirect calls for dma_map_* error checking - use direct calls for the DMA direct mapping case, avoiding huge retpoline overhead for high performance workloads - merge the swiotlb dma_map_ops into dma-direct - provide a generic remapping DMA consistent allocator for architectures that have devices that perform DMA that is not cache coherent. Based on the existing arm64 implementation and also used for csky now. - improve the dma-debug infrastructure, including dynamic allocation of entries (Robin Murphy) - default to providing chaining scatterlist everywhere, with opt-outs for the few architectures (alpha, parisc, most arm32 variants) that can't cope with it - misc sparc32 dma-related cleanups - remove the dma_mark_clean arch hook used by swiotlb on ia64 and replace it with the generic noncoherent infrastructure - fix the return type of dma_set_max_seg_size (Niklas Söderlund) - move the dummy dma ops for not DMA capable devices from arm64 to common code (Robin Murphy) - ensure dma_alloc_coherent returns zeroed memory to avoid kernel data leaks through userspace. We already did this for most common architectures, but this ensures we do it everywhere. dma_zalloc_coherent has been deprecated and can hopefully be removed after -rc1 with a coccinelle script" * tag 'dma-mapping-4.21' of git://git.infradead.org/users/hch/dma-mapping: (73 commits) dma-mapping: fix inverted logic in dma_supported dma-mapping: deprecate dma_zalloc_coherent dma-mapping: zero memory returned from dma_alloc_* sparc/iommu: fix ->map_sg return value sparc/io-unit: fix ->map_sg return value arm64: default to the direct mapping in get_arch_dma_ops PCI: Remove unused attr variable in pci_dma_configure ia64: only select ARCH_HAS_DMA_COHERENT_TO_PFN if swiotlb is enabled dma-mapping: bypass indirect calls for dma-direct vmd: use the proper dma_* APIs instead of direct methods calls dma-direct: merge swiotlb_dma_ops into the dma_direct code dma-direct: use dma_direct_map_page to implement dma_direct_map_sg dma-direct: improve addressability error reporting swiotlb: remove dma_mark_clean swiotlb: remove SWIOTLB_MAP_ERROR ACPI / scan: Refactor _CCA enforcement dma-mapping: factor out dummy DMA ops dma-mapping: always build the direct mapping code dma-mapping: move dma_cache_sync out of line dma-mapping: move various slow path functions out of line ...
2018-12-28mm, memory_hotplug: add nid parameter to arch_remove_memoryOscar Salvador
Patch series "Do not touch pages in hot-remove path", v2. This patchset aims for two things: 1) A better definition about offline and hot-remove stage 2) Solving bugs where we can access non-initialized pages during hot-remove operations [2] [3]. This is achieved by moving all page/zone handling to the offline stage, so we do not need to access pages when hot-removing memory. [1] https://patchwork.kernel.org/cover/10691415/ [2] https://patchwork.kernel.org/patch/10547445/ [3] https://www.spinics.net/lists/linux-mm/msg161316.html This patch (of 5): This is a preparation for the following-up patches. The idea of passing the nid is that it will allow us to get rid of the zone parameter afterwards. Link: http://lkml.kernel.org/r/20181127162005.15833-2-osalvador@suse.de Signed-off-by: Oscar Salvador <osalvador@suse.de> Reviewed-by: David Hildenbrand <david@redhat.com> Reviewed-by: Pavel Tatashin <pasha.tatashin@soleen.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Jonathan Cameron <Jonathan.Cameron@huawei.com> Cc: "Rafael J. Wysocki" <rafael@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-12-26Merge tag 'please-pull-y2038prep' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull ia64 updates from Tony Luck: "Change ia64 to make it easier to update system call tables (in line with some other architectures). This is in preparation for y2038 changes which are forecasted to add several new system calls" * tag 'please-pull-y2038prep' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: ia64: generate uapi header and system call table files ia64: add system call table generation support ia64: add an offset for system call number ia64: add __NR_syscalls along with NR_syscalls ia64: add __NR_old_getpagesize in uapi header file
2018-12-23treewide: add intermediate .s files to targetsMasahiro Yamada
Avoid unneeded recreation of these in the incremental build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-12-23treewide: remove explicit rules for *offsets.sMasahiro Yamada
These explicit rules are unneeded because scripts/Makefile.build provides a pattern rule to create %.s from %.c Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-12-22treewide: surround Kconfig file paths with double quotesMasahiro Yamada
The Kconfig lexer supports special characters such as '.' and '/' in the parameter context. In my understanding, the reason is just to support bare file paths in the source statement. I do not see a good reason to complicate Kconfig for the room of ambiguity. The majority of code already surrounds file paths with double quotes, and it makes sense since file paths are constant string literals. Make it treewide consistent now. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Ingo Molnar <mingo@kernel.org>
2018-12-18scsi: remove the use_clustering flagChristoph Hellwig
The same effects can be achieved by setting the dma_boundary to PAGE_SIZE - 1 and the max_segment_size to PAGE_SIZE, so shift those settings into the drivers. Note that in many cases the setting might be bogus, but this keeps the status quo. [mkp: fix myrs and myrb] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-12-15ia64: only select ARCH_HAS_DMA_COHERENT_TO_PFN if swiotlb is enabledChristoph Hellwig
Otherwise we get a build failure due in swiotlb-less configs with non-generic kernels. Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-12-13dma-mapping: bypass indirect calls for dma-directChristoph Hellwig
Avoid expensive indirect calls in the fast path DMA mapping operations by directly calling the dma_direct_* ops if we are using the directly mapped DMA operations. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Tested-by: Jesper Dangaard Brouer <brouer@redhat.com> Tested-by: Tony Luck <tony.luck@intel.com>
2018-12-13dma-direct: merge swiotlb_dma_ops into the dma_direct codeChristoph Hellwig
While the dma-direct code is (relatively) clean and simple we actually have to use the swiotlb ops for the mapping on many architectures due to devices with addressing limits. Instead of keeping two implementations around this commit allows the dma-direct implementation to call the swiotlb bounce buffering functions and thus share the guts of the mapping implementation. This also simplified the dma-mapping setup on a few architectures where we don't have to differenciate which implementation to use. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Tested-by: Jesper Dangaard Brouer <brouer@redhat.com> Tested-by: Tony Luck <tony.luck@intel.com>
2018-12-13swiotlb: remove dma_mark_cleanChristoph Hellwig
Instead of providing a special dma_mark_clean hook just for ia64, switch ia64 to use the normal arch_sync_dma_for_cpu hooks instead. This means that we now also set the PG_arch_1 bit for pages in the swiotlb buffer, which isn't stricly needed as we will never execute code out of the swiotlb buffer, but otherwise harmless. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Tested-by: Jesper Dangaard Brouer <brouer@redhat.com> Tested-by: Tony Luck <tony.luck@intel.com>
2018-12-06arch: switch the default on ARCH_HAS_SG_CHAINChristoph Hellwig
These days architectures are mostly out of the business of dealing with struct scatterlist at all, unless they have architecture specific iommu drivers. Replace the ARCH_HAS_SG_CHAIN symbol with a ARCH_NO_SG_CHAIN one only enabled for architectures with horrible legacy iommu drivers like alpha and parisc, and conditionally for arm which wants to keep it disable for legacy platforms. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Palmer Dabbelt <palmer@sifive.com>
2018-12-06ia64/sn: remove the mapping_error dma_map_ops methodChristoph Hellwig
Return DMA_MAPPING_ERROR instead of 0 on a dma mapping failure and let the core dma-mapping code handle the rest. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-12-06ia64/sba_iommu: remove the mapping_error dma_map_ops methodChristoph Hellwig
2018-12-06ia64/sba_iommu: improve internal map_page usersChristoph Hellwig
Remove the odd sba_{un,}map_single_attrs wrappers, check errors everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-11-26ia64: export node_distance functionMatias Bjørling
The numa_slit variable used by node_distance is available to a module as long as it is linked at compile-time. However, it is not available to loadable modules. Leading to errors such as: ERROR: "numa_slit" [drivers/nvme/host/nvme-core.ko] undefined! The error above is caused by the nvme multipath code that makes use of node_distance for its path calculation. When the patch was added, the lightnvm subsystem would select nvme and always compile it in, leading to the node_distance call to always succeed. However, when this requirement was removed, nvme could be compiled in as a module, which exposed this bug. This patch extracts node_distance to a function and exports it. Since ACPI is depending on node_distance being a simple lookup to numa_slit, the previous behavior is exposed as slit_distance and its users updated. Fixes: f333444708f82 "nvme: take node locality into account when selecting a path" Fixes: 73569e11032f "lightnvm: remove dependencies on BLK_DEV_NVME and PCI" Signed-off-by: Matias Bjøring <mb@lightnvm.io> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-11-23pcmcia: allow PCMCIA support independent of the architectureChristoph Hellwig
There is nothing architecture specific in the PCMCIA core, so allow building it everywhere. The actual host controllers will depend on ISA, PCI or a specific SOC. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul Burton <paul.burton@mips.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-11-23PCI: consolidate the PCI_SYSCALL symbolChristoph Hellwig
Let architectures select the syscall support instead of duplicating the kconfig entry. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-11-23PCI: consolidate the PCI_DOMAINS and PCI_DOMAINS_GENERIC config optionsChristoph Hellwig
Move the definitions to drivers/pci and let the architectures select them. Two small differences to before: PCI_DOMAINS_GENERIC now selects PCI_DOMAINS, cutting down the churn for modern architectures. As the only architectured arm did previously also offer PCI_DOMAINS as a user visible choice in addition to selecting it from the relevant configs, this is gone now. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Burton <paul.burton@mips.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-11-23PCI: consolidate PCI config entry in drivers/pciChristoph Hellwig
There is no good reason to duplicate the PCI menu in every architecture. Instead provide a selectable HAVE_PCI symbol that indicates availability of PCI support, and a FORCE_PCI symbol to for PCI on and the handle the rest in drivers/pci. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Palmer Dabbelt <palmer@sifive.com> Acked-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Paul Burton <paul.burton@mips.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-11-13ia64: generate uapi header and system call table filesFiroz Khan
System call table generation script must be run to gener- ate unistd_64.h and syscall_table.h files. This patch will have changes which will invokes the script. This patch will generate unistd_64.h and syscall_table.h files by the syscall table generation script invoked by ia64/Makefile and the generated files against the removed files must be identical. The generated uapi header file will be included in uapi/- asm/unistd.h and generated system call table header file will be included by kernel/entry.S file. Signed-off-by: Firoz Khan <firoz.khan@linaro.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2018-11-13ia64: add system call table generation supportFiroz Khan
The system call tables are in different format in all architecture and it will be difficult to manually add, modify or delete the syscall table entries in the res- pective files. To make it easy by keeping a script and which will generate the uapi header and syscall table file. This change will also help to unify the implemen- tation across all architectures. The system call table generation script is added in kernel/syscalls directory which contain the scripts to generate both uapi header file and system call table files. The syscall.tbl will be input for the scripts. syscall.tbl contains the list of available system calls along with system call number and corresponding entry point. Add a new system call in this architecture will be possible by adding new entry in the syscall.tbl file. Adding a new table entry consisting of: - System call number. - ABI. - System call name. - Entry point name. syscallhdr.sh and syscalltbl.sh will generate uapi header unistd_64.h and syscall_table.h files respectively. Both .sh files will parse the content syscall.tbl to generate the header and table files. unistd_64.h will be included by uapi/asm/unistd.h and syscall_table.h is included by kernel/entry.S - the real system call table. ARM, s390 and x86 architecuture does have similar support. I leverage their implementation to come up with a generic solution. Signed-off-by: Firoz Khan <firoz.khan@linaro.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2018-11-13ia64: add an offset for system call numberFiroz Khan
The system call number in ia64 architecture starts with 1024. But most of the other architecute starts with 0. In order to come up with a common implementation to generate uapi header we need to add an offset - __NR_Linux with a value 1024. One of the patch in this patch series does have a script to generate uapi header which uses syscall.tbl file. In syscall- .tbl contain system call number. With the use of __NR_Linux, we can start the number from 0 instead of 1024. Signed-off-by: Firoz Khan <firoz.khan@linaro.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2018-11-13ia64: add __NR_syscalls along with NR_syscallsFiroz Khan
NR_syscalls macro holds the number of system call exist in ia64 architecture. We have to change the value of NR- _syscalls, if we add or delete a system call. One of the patch in this patch series has a script which will generate a uapi header based on syscall.tbl file. The syscall.tbl file contains the total number of system calls information. So we have two option to update NR_sy- scalls value. 1. Update NR_syscalls in asm/unistd.h manually by count- ing the no.of system calls. No need to update NR_sys- calls until we either add a new system call or delete existing system call. 2. We can keep this feature it above mentioned script, that will count the number of syscalls and keep it in a generated file. In this case we don't need to expli- citly update NR_syscalls in asm/unistd.h file. The 2nd option will be the recommended one. For that, I added the __NR_syscalls macro in uapi/asm/unistd.h along with NR_syscalls asm/unistd.h. The macro __NR_syscalls also added for making the name convention same across all architecture. While __NR_syscalls isn't strictly part of the uapi, having it as part of the generated header to simplifies the implementation. We also need to enclose this macro with #ifdef __KERNEL__ to avoid side effects. Signed-off-by: Firoz Khan <firoz.khan@linaro.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2018-11-13ia64: add __NR_old_getpagesize in uapi header fileFiroz Khan
sys_getpagesize entry is present in kernel/entry.S file to support for old user interface. So we need to add an uapi entry too. Add __NR_old_getpagesize in uapi/asm/unistd.h in order to not break old user space as it is reserved for backwards compatibility with old __NR_getpagesize. Signed-off-by: Firoz Khan <firoz.khan@linaro.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2018-10-31memblock: stop using implicit alignment to SMP_CACHE_BYTESMike Rapoport
When a memblock allocation APIs are called with align = 0, the alignment is implicitly set to SMP_CACHE_BYTES. Implicit alignment is done deep in the memblock allocator and it can come as a surprise. Not that such an alignment would be wrong even when used incorrectly but it is better to be explicit for the sake of clarity and the prinicple of the least surprise. Replace all such uses of memblock APIs with the 'align' parameter explicitly set to SMP_CACHE_BYTES and stop implicit alignment assignment in the memblock internal allocation functions. For the case when memblock APIs are used via helper functions, e.g. like iommu_arena_new_node() in Alpha, the helper functions were detected with Coccinelle's help and then manually examined and updated where appropriate. The direct memblock APIs users were updated using the semantic patch below: @@ expression size, min_addr, max_addr, nid; @@ ( | - memblock_alloc_try_nid_raw(size, 0, min_addr, max_addr, nid) + memblock_alloc_try_nid_raw(size, SMP_CACHE_BYTES, min_addr, max_addr, nid) | - memblock_alloc_try_nid_nopanic(size, 0, min_addr, max_addr, nid) + memblock_alloc_try_nid_nopanic(size, SMP_CACHE_BYTES, min_addr, max_addr, nid) | - memblock_alloc_try_nid(size, 0, min_addr, max_addr, nid) + memblock_alloc_try_nid(size, SMP_CACHE_BYTES, min_addr, max_addr, nid) | - memblock_alloc(size, 0) + memblock_alloc(size, SMP_CACHE_BYTES) | - memblock_alloc_raw(size, 0) + memblock_alloc_raw(size, SMP_CACHE_BYTES) | - memblock_alloc_from(size, 0, min_addr) + memblock_alloc_from(size, SMP_CACHE_BYTES, min_addr) | - memblock_alloc_nopanic(size, 0) + memblock_alloc_nopanic(size, SMP_CACHE_BYTES) | - memblock_alloc_low(size, 0) + memblock_alloc_low(size, SMP_CACHE_BYTES) | - memblock_alloc_low_nopanic(size, 0) + memblock_alloc_low_nopanic(size, SMP_CACHE_BYTES) | - memblock_alloc_from_nopanic(size, 0, min_addr) + memblock_alloc_from_nopanic(size, SMP_CACHE_BYTES, min_addr) | - memblock_alloc_node(size, 0, nid) + memblock_alloc_node(size, SMP_CACHE_BYTES, nid) ) [mhocko@suse.com: changelog update] [akpm@linux-foundation.org: coding-style fixes] [rppt@linux.ibm.com: fix missed uses of implicit alignment] Link: http://lkml.kernel.org/r/20181016133656.GA10925@rapoport-lnx Link: http://lkml.kernel.org/r/1538687224-17535-1-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Suggested-by: Michal Hocko <mhocko@suse.com> Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Michael Ellerman <mpe@ellerman.id.au> [powerpc] Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31mm: remove include/linux/bootmem.hMike Rapoport
Move remaining definitions and declarations from include/linux/bootmem.h into include/linux/memblock.h and remove the redundant header. The includes were replaced with the semantic patch below and then semi-automated removal of duplicated '#include <linux/memblock.h> @@ @@ - #include <linux/bootmem.h> + #include <linux/memblock.h> [sfr@canb.auug.org.au: dma-direct: fix up for the removal of linux/bootmem.h] Link: http://lkml.kernel.org/r/20181002185342.133d1680@canb.auug.org.au [sfr@canb.auug.org.au: powerpc: fix up for removal of linux/bootmem.h] Link: http://lkml.kernel.org/r/20181005161406.73ef8727@canb.auug.org.au [sfr@canb.auug.org.au: x86/kaslr, ACPI/NUMA: fix for linux/bootmem.h removal] Link: http://lkml.kernel.org/r/20181008190341.5e396491@canb.auug.org.au Link: http://lkml.kernel.org/r/1536927045-23536-30-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: replace BOOTMEM_ALLOC_* with MEMBLOCK variantsMike Rapoport
Drop BOOTMEM_ALLOC_ACCESSIBLE and BOOTMEM_ALLOC_ANYWHERE in favor of identical MEMBLOCK definitions. Link: http://lkml.kernel.org/r/1536927045-23536-29-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: rename free_all_bootmem to memblock_free_allMike Rapoport
The conversion is done using sed -i 's@free_all_bootmem@memblock_free_all@' \ $(git grep -l free_all_bootmem) Link: http://lkml.kernel.org/r/1536927045-23536-26-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: replace alloc_bootmem with memblock_allocMike Rapoport
The alloc_bootmem(size) is a shortcut for allocation of SMP_CACHE_BYTES aligned memory. When the align parameter of memblock_alloc() is 0, the alignment is implicitly set to SMP_CACHE_BYTES and thus alloc_bootmem(size) and memblock_alloc(size, 0) are equivalent. The conversion is done using the following semantic patch: @@ expression size; @@ - alloc_bootmem(size) + memblock_alloc(size, 0) Link: http://lkml.kernel.org/r/1536927045-23536-22-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Hocko <mhocko@suse.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: replace __alloc_bootmem with memblock_alloc_fromMike Rapoport
The functions are equivalent, just the later does not require nobootmem translation layer. The conversion is done using the following semantic patch: @@ expression size, align, goal; @@ - __alloc_bootmem(size, align, goal) + memblock_alloc_from(size, align, goal) Link: http://lkml.kernel.org/r/1536927045-23536-21-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: replace alloc_bootmem_node with memblock_alloc_nodeMike Rapoport
Both functions attempt to allocate memory with specified alignment from a particular node. If the allocation from that node fails, they both fall back to allocating from any node in the system. Usage of native memblock API eliminates the nobootmem translation layer. Link: http://lkml.kernel.org/r/1536927045-23536-18-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: replace __alloc_bootmem_node with appropriate memblock_ APIMike Rapoport
Use memblock_alloc_try_nid whenever goal (i.e. minimal address is specified) and memblock_alloc_node otherwise. Link: http://lkml.kernel.org/r/1536927045-23536-17-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: replace alloc_bootmem_pages_node with memblock_alloc_nodeMike Rapoport
The functions are equivalent, just the later does not require nobootmem translation layer. Link: http://lkml.kernel.org/r/1536927045-23536-16-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31mm: remove CONFIG_HAVE_MEMBLOCKMike Rapoport
All architecures use memblock for early memory management. There is no need for the CONFIG_HAVE_MEMBLOCK configuration option. [rppt@linux.vnet.ibm.com: of/fdt: fixup #ifdefs] Link: http://lkml.kernel.org/r/20180919103457.GA20545@rapoport-lnx [rppt@linux.vnet.ibm.com: csky: fixups after bootmem removal] Link: http://lkml.kernel.org/r/20180926112744.GC4628@rapoport-lnx [rppt@linux.vnet.ibm.com: remove stale #else and the code it protects] Link: http://lkml.kernel.org/r/1538067825-24835-1-git-send-email-rppt@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/1536927045-23536-4-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Tested-by: Jonathan Cameron <jonathan.cameron@huawei.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31mm: remove CONFIG_NO_BOOTMEMMike Rapoport
All achitectures select NO_BOOTMEM which essentially becomes 'Y' for any kernel configuration and therefore it can be removed. [alexander.h.duyck@linux.intel.com: remove now defunct NO_BOOTMEM from depends list for deferred init] Link: http://lkml.kernel.org/r/20180925201814.3576.15105.stgit@localhost.localdomain Link: http://lkml.kernel.org/r/1536927045-23536-3-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Alexander Duyck <alexander.h.duyck@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31kernel/signal.c: fix a comment errorWeikang Shi
Because get_signal_to_deliver() was renamed to get_signal() the comment should be fixed. Link: http://lkml.kernel.org/r/1539179128-45709-1-git-send-email-swkhack@gmail.com Signed-off-by: Weikang Shi <swkhack@gmail.com> Reported-by: Christian Brauner <christian@brauner.io> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Anna-Maria Gleixner <anna-maria@linutronix.de> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
