path: root/arch/m32r/boot
2009-11-09m32r: fix arch/m32r/boot/compressed/MakefileHirokazu Takata
- Fix a comment string - Fix a typo of $(suffix-y) Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-11-04m32r: bzip2/lzma kernel compression supportHirokazu Takata
- Support bzip2 and lzma kernel compression for m32r. - Clean up arch/m32r/boot/compressed/misc.c. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-09-20kbuild: use INSTALLKERNEL to select customized installkernel scriptSam Ravnborg
Replace the use of CROSS_COMPILE to select a customized installkernel script with the possibility to set INSTALLKERNEL to select a custom installkernel script when running make: make INSTALLKERNEL=arm-installkernel install With this patch we are now more consistent across different architectures - they did not all support use of CROSS_COMPILE. The use of CROSS_COMPILE was a hack as this really belongs to gcc/binutils and the installkernel script does not change just because we change toolchain. The use of CROSS_COMPILE caused troubles with an upcoming patch that saves CROSS_COMPILE when a kernel is built - it would no longer be installable. [Thanks to Peter Z. for this hint] This patch undos what Ian did in commit: 0f8e2d62fa04441cd12c08ce521e84e5bd3f8a46 ("use ${CROSS_COMPILE}installkernel in arch/*/boot/install.sh") The patch has been lightly tested on x86 only - but all changes looks obvious. Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Russell King <linux@arm.linux.org.uk> [arm] Acked-by: Paul Mundt <lethal@linux-sh.org> [sh] Acked-by: "H. Peter Anvin" <hpa@zytor.com> [x86] Cc: Ian Campbell <icampbell@arcom.com> Cc: Tony Luck <tony.luck@intel.com> [ia64] Cc: Fenghua Yu <fenghua.yu@intel.com> [ia64] Cc: Hirokazu Takata <takata@linux-m32r.org> [m32r] Cc: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Cc: Kyle McMartin <kyle@mcmartin.ca> [parisc] Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc] Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Cc: Thomas Gleixner <tglx@linutronix.de> [x86] Cc: Ingo Molnar <mingo@redhat.com> [x86] Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-05-02m32r: build fix for __stringify macroHirokazu Takata
This patch fixes the following build error of 2.6.30-rc3-git2: AS arch/m32r/kernel/head.o In file included from /include/linux/init.h:7, from /arch/m32r/kernel/head.S:11: /include/linux/stringify.h:9: error: syntax error in macro parameter list /include/linux/stringify.h:10: error: syntax error in macro parameter list This build error was caused at __HEAD macro in arch/m32r/kernel/head.S, which uses __stringify() macro. Remove -traditional option from EXTRA_AFLAGS for the m32r, because the __stringify() macro depends on the gcc's variadic macro extension function, due to commit: Make __stringify support variable argument macros too commit: 8f7c2c37319a81ef4c2bfdec67b1ccd5744d97e4 Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-07-25inflate: refactor inflate malloc codeThomas Petazzoni
Inflate requires some dynamic memory allocation very early in the boot process and this is provided with a set of four functions: malloc/free/gzip_mark/gzip_release. The old inflate code used a mark/release strategy rather than implement free. This new version instead keeps a count on the number of outstanding allocations and when it hits zero, it resets the malloc arena. This allows removing all the mark and release implementations and unifying all the malloc/free implementations. The architecture-dependent code must define two addresses: - free_mem_ptr, the address of the beginning of the area in which allocations should be made - free_mem_end_ptr, the address of the end of the area in which allocations should be made. If set to 0, then no check is made on the number of allocations, it just grows as much as needed The architecture-dependent code can also provide an arch_decomp_wdog() function call. This function will be called several times during the decompression process, and allow to notify the watchdog that the system is still running. If an architecture provides such a call, then it must define ARCH_HAS_DECOMP_WDOG so that the generic inflate code calls arch_decomp_wdog(). Work initially done by Matt Mackall, updated to a recent version of the kernel and improved by me. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <mikael.starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m32r: remove dead config symbols from M32R codeJiri Olsa
remove dead config symbols from M32R code Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] m32r: bootloader support for OPSPUT platformHirokazu Takata
This patch supports "m32r-g00ff" bootloader for an OPSPUT platform. Applying this patch, it is possible to do ATA-boot from an IDE drive or HTTP-boot from network by m32r-g00ff. * arch/m32r/boot/compressed/m32r_sio.c: Fix hangup on OPSPUT at boot. * arch/m32r/kernel/io_opsput.c: IDE support for OPSPUT. * arch/m32r/kernel/setup_opsput.c: ditto. * include/asm-m32r/ide.h: ditto. Signed-off-by: Kazuhiro Inaoka <inaoka@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Fix M32104 cache flushing routinesHirokazu Takata
This patch fixes cache memory parameter setting for the M32104 target. So far, its performance seemed to have been degraded due to incorrect cache parameter setting. * arch/m32r/boot/setup.S: Set SFR(Special Fuction Registers) region to be non-cachable explicitly. * arch/m32r/mm/cache.c: Fix cache flushing routines not to switch off the M32104 cache. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Support M32104UT target platformHirokazu Takata
This patch is for supporting a new target platform, Renesas M32104UT evaluation board. The M32104UT is an eval board based on an uT-Engine specification. This board has an MMU-less M32R family processor, M32104. http://www-wa0.personal-media.co.jp/pmc/archive/te/te_m32104_e.pdf This board is one of the most popular M32R platform, so we have ported Linux/M32R to it. Signed-off-by: Naoto Sugai <Sugai.Naoto@ak.MitsubishiElectric.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] m32r: Support M3A-2170(Mappi-III) platformHirokazu Takata
This patchset is for supporting a new m32r platform, M3A-2170(Mappi-III) evaluation board. An M32R chip multiprocessor is equipped on the board. http://http://www.linux-m32r.org/eng/platform/platform.html * arch/m32r/Kconfig: Support Mappi-III platform. * arch/m32r/kernel/Makefile: ditto. * arch/m32r/kernel/io_mappi3.c: ditto. * arch/m32r/kernel/setup.c: ditto. * arch/m32r/kernel/setup_mappi3.c: ditto. * include/asm-m32r/m32102.h: ditto. * include/asm-m32r/m32r.h: ditto. * include/asm-m32r/mappi3/mappi3_pld.h: ditto. * include/asm-m32r/ide.h: CF support for Mappi-III. * arch/m32r/kernel/setup_mappi3.c: ditto. * arch/m32r/mappi3/defconfig.smp: A default config file for Mappi-III. * arch/m32r/mappi3/dot.gdbinit: A default .gdbinit file for Mappi-III. * arch/m32r/boot/compressed/m32r_sio.c: Modified for Mappi-III - At boot time, m32r-g00ff bootloader makes MMU off for Mappi-III, on the contrary it makes MMU on for Mappi-II. * arch/m32r/kernel/io_mappi2.c: Update comments. * arch/m32r/kernel/setup_mappi2.c: ditto. Signed-off-by: Mamoru Sakugawa <sakugawa@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
