path: root/arch/m32r
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-05-09m32r: use generic sys_pipeChristoph Hellwig
m32r can use the generic sys_pipe implementation. The current sys_pipe implementation on m32r only differes from the generic one by passing a lot of additional unused registers to sys_pipe. Reviewed and tested by Hirokazu Takata. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08sys_pipe(): fix file descriptor leaksUlrich Drepper
Remember to close the files if copy_to_user() failed. Spotted by dm.n9107@gmail.com. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: DM <dm.n9107@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29m32r: cleanup: drop .data.idt section in vmlinux.lds scriptCyrill Gorcunov
The section .data.idt is not used at all - so drop it. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-04-29m32r: use KBUILD_DEFCONFIGAdrian Bunk
With using KBUILD_DEFCONFIG we don't have to ship a second copy of m32700ut.smp_defconfig Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Hirokazu Takata <takata@linux-m32r.org>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-02-09ide: introduce HAVE_IDESam Ravnborg
To allow flexible configuration of IDE introduce HAVE_IDE. All archs except arm, um and s390 unconditionally select it. For arm the actual configuration determine if IDE is supported. This is a step towards introducing drivers/Kconfig for arm. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-08avoid overflows in kernel/time.cH. Peter Anvin
When the conversion factor between jiffies and milli- or microseconds is not a single multiply or divide, as for the case of HZ == 300, we currently do a multiply followed by a divide. The intervening result, however, is subject to overflows, especially since the fraction is not simplified (for HZ == 300, we multiply by 300 and divide by 1000). This is exposed to the user when passing a large timeout to poll(), for example. This patch replaces the multiply-divide with a reciprocal multiplication on 32-bit platforms. When the input is an unsigned long, there is no portable way to do this on 64-bit platforms there is no portable way to do this since it requires a 128-bit intermediate result (which gcc does support on 64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but since the output is a 32-bit integer in the cases affected, just simplify the multiply-divide (*3/10 instead of *300/1000). The reciprocal multiply used can have off-by-one errors in the upper half of the valid output range. This could be avoided at the expense of having to deal with a potential 65-bit intermediate result. Since the intent is to avoid overflow problems and most of the other time conversions are only semiexact, the off-by-one errors were considered an acceptable tradeoff. At Ralf Baechle's suggestion, this version uses a Perl script to compute the necessary constants. We already have dependencies on Perl for kernel compiles. This does, however, require the Perl module Math::BigInt, which is included in the standard Perl distribution starting with version 5.8.0. In order to support older versions of Perl, include a table of canned constants in the script itself, and structure the script so that Math::BigInt isn't required if pulling values from said table. Running the script requires that the HZ value is available from the Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the architectures which didn't already have it (alpha, cris, frv, h8300, m32r, m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or sh64 architectures, since Paul Mundt has dealt with those separately in the sh tree. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org>, Cc: Sam Ravnborg <sam@ravnborg.org>, Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Richard Henderson <rth@twiddle.net>, Cc: Michael Starvik <starvik@axis.com>, Cc: David Howells <dhowells@redhat.com>, Cc: Yoshinori Sato <ysato@users.sourceforge.jp>, Cc: Hirokazu Takata <takata@linux-m32r.org>, Cc: Geert Uytterhoeven <geert@linux-m68k.org>, Cc: Roman Zippel <zippel@linux-m68k.org>, Cc: William L. Irwin <sparclinux@vger.kernel.org>, Cc: Chris Zankel <chris@zankel.net>, Cc: H. Peter Anvin <hpa@zytor.com>, Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08procfs: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: mark arches that support A.OUT formatDavid Howells
Mark arches that support A.OUT format by including the following in their master Kconfig files: config ARCH_SUPPORTS_AOUT def_bool y This should also be set if the arch provides compatibility A.OUT support for an older arch, for instance x86_64 for i386 or sparc64 for sparc. I've guessed at which arches don't, based on comments in the code, however I'm sure that some of the ones I've marked as 'yes' actually should be 'no'. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07m32r: build fix of arch/m32r/kernel/smpboot.cMathieu Desnoyers
This patch is for Mathieu Desnoyers's include/asm-m32r/local.h. Applying the new include/asm-m32r/local.h, inclusion of linux/sched.h is needed to fix a build error of arch/m32r/kernel/smpboot.c. <-- snip --> ... CC arch/m32r/kernel/smpboot.o /project/m32r-linux/kernel/work/linux-2.6_dev.git/arch/m32r/kernel/smpboot.c: In function 'do_boot_cpu': /project/m32r-linux/kernel/work/linux-2.6_dev.git/arch/m32r/kernel/smpboot.c:279: error: implicit declaration of function 'fork_idle' /project/m32r-linux/kernel/work/linux-2.6_dev.git/arch/m32r/kernel/smpboot.c:279: warning: assignment makes pointer from integer without a cast /project/m32r-linux/kernel/work/linux-2.6_dev.git/arch/m32r/kernel/smpboot.c:283: error: dereferencing pointer to incomplete type /project/m32r-linux/kernel/work/linux-2.6_dev.git/arch/m32r/kernel/smpboot.c:289: error: dereferencing pointer to incomplete type /project/m32r-linux/kernel/work/linux-2.6_dev.git/arch/m32r/kernel/smpboot.c:290: error: implicit declaration of function 'task_thread_info' /project/m32r-linux/kernel/work/linux-2.6_dev.git/arch/m32r/kernel/smpboot.c:290: error: invalid type argument of '->' /project/m32r-linux/kernel/work/linux-2.6_dev.git/arch/m32r/kernel/smpboot.c: In function 'start_secondary': /project/m32r-linux/kernel/work/linux-2.6_dev.git/arch/m32r/kernel/smpboot.c:429: error: implicit declaration of function 'cpu_init' make[2]: *** [arch/m32r/kernel/smpboot.o] Error 1 <-- snip --> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05timerfd: fix remaining architecturesAndrew Morton
Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m32r: remove dead config symbols from M32R codeJiri Olsa
remove dead config symbols from M32R code Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-03arch/m32r/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03remove Documentation/smp.txtAdrian Bunk
After seeing the filename I'd have expected something about the implementation of SMP in the Linux kernel - not some notes on kernel configuration and building trivialities noone would search at this place. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alan Cox <alan@redhat.com>
2008-02-03Move Kconfig.instrumentation to arch/Kconfig and init/KconfigMathieu Desnoyers
Move the instrumentation Kconfig to arch/Kconfig for architecture dependent options - oprofile - kprobes and init/Kconfig for architecture independent options - profiling - markers Remove the "Instrumentation Support" menu. Everything moves to "General setup". Delete the kernel/Kconfig.instrumentation file. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03Add HAVE_OPROFILEMathieu Desnoyers
Linus: On the per-architecture side, I do think it would be better to *not* have internal architecture knowledge in a generic file, and as such a line like depends on X86_32 || IA64 || PPC || S390 || SPARC64 || X86_64 || AVR32 really shouldn't exist in a file like kernel/Kconfig.instrumentation. It would be much better to do depends on ARCH_SUPPORTS_KPROBES in that generic file, and then architectures that do support it would just have a bool ARCH_SUPPORTS_KPROBES default y in *their* architecture files. That would seem to be much more logical, and is readable both for arch maintainers *and* for people who have no clue - and don't care - about which architecture is supposed to support which interface... Changelog: Actually, I know I gave this as the magic incantation, but now that I see it, I realize that I should have told you to just use config ARCH_SUPPORTS_KPROBES def_bool y instead, which is a bit denser. We seem to use both kinds of syntax for these things, but this is really what "def_bool" is there for... Changelog : - Moving to HAVE_*. - Add AVR32 oprofile. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-01PCI: Kconfig help: don't refer to the PCI-HOWTOAdrian Bunk
A HOWTO that hasn't been updated for half a dozen years no longer "contains valuable information about which PCI hardware does work under Linux and which doesn't". Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-30spinlock: lockbreak cleanupNick Piggin
The break_lock data structure and code for spinlocks is quite nasty. Not only does it double the size of a spinlock but it changes locking to a potentially less optimal trylock. Put all of that under CONFIG_GENERIC_LOCKBREAK, and introduce a __raw_spin_is_contended that uses the lock data itself to determine whether there are waiters on the lock, to be used if CONFIG_GENERIC_LOCKBREAK is not set. Rename need_lockbreak to spin_needbreak, make it use spin_is_contended to decouple it from the spinlock implementation, and make it typesafe (rwlocks do not have any need_lockbreak sites -- why do they even get bloated up with that break_lock then?). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-11-28m32r: Update sys_rt_sigsuspendHirokazu Takata
Update sys_rt_sigsuspend() of arch/m32r/signal.c. This modification is derived from generic one of kernel/signal.c. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-11-28m32r: Add missing syscallsHirokazu Takata
Add the following 39 syscalls for m32r: sys_add_key, sys_request_key, sys_keyctl, sys_ioprio_set, sys_ioprio_get, sys_inotify_init, sys_inotify_add_watch, sys_inotify_rm_watch, sys_migrate_pages, sys_openat, sys_mkdirat, sys_mknodat, sys_fchownat, sys_futimesat, sys_fstatat64, sys_unlinkat, sys_renameat, sys_linkat, sys_symlinkat, sys_readlinkat, sys_fchmodat, sys_faccessat, sys_pselect6, sys_ppoll, sys_unshare, sys_set_robust_list, sys_get_robust_list, sys_splice, sys_sync_file_range, sys_tee, sys_vmsplice, sys_move_pages, sys_getcpu, sys_epoll_pwait, sys_utimensat, sys_signalfd, sys_timerfd, sys_eventfd, sys_fallocate Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-10-20spelling fixes: arch/m32r/Simon Arlott
Spelling fixes in arch/m32r/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Combine instrumentation menus in kernel/Kconfig.instrumentationMathieu Desnoyers
Quoting Randy: "It seems sad that this patch sources Kconfig.marker, a 7-line file, 20-something times. Yes, you (we) don't want to put those 7 lines into 20-something different files, so sourcing is the right thing. However, what you did for avr32 seems more on the right track to me: make _one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES, and MARKERS and then use (source) that in all of the arches." Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Use helpers to obtain task pid in printks (arch code)Alexey Dobriyan
One of the easiest things to isolate is the pid printed in kernel log. There was a patch, that made this for arch-independent code, this one makes so for arch/xxx files. It took some time to cross-compile it, but hopefully these are all the printks in arch code. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17remove include/asm-*/ipc.hAdrian Bunk
All asm/ipc.h files do only #include <asm-generic/ipc.h>. This patch therefore removes all include/asm-*/ipc.h files and moves the contents of include/asm-generic/ipc.h to include/linux/ipc.h. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-16m32r: convert to generic sys_ptraceChristoph Hellwig
Convert m32r to the generic sys_ptrace. The conversion requires an architecture hook after ptrace_attach which this patch adds. The hook will also be needed for a conersion of ia64 to the generic ptrace code. Thanks to Hirokazu Takata for fixing a bug in the first version of this code. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16M32R: cleanup struct irqaction initializersThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16During VM oom condition, kill all threads in process groupWill Schmidt
We have had complaints where a threaded application is left in a bad state after one of it's threads is killed when we hit a VM: out_of_memory condition. Killing just one of the process threads can leave the application in a bad state, whereas killing the entire process group would allow for the application to restart, or be otherwise handled, and makes it very obvious that something has gone wrong. This change allows the entire process group to be taken down, rather than just the one thread. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Consolidate PTRACE_DETACHAlexey Dobriyan
Identical handlers of PTRACE_DETACH go into ptrace_request(). Not touching compat code. Not touching archs that don't call ptrace_request. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-09-06m32r: Rename STI/CLI macrosHirokazu Takata
The names of STI and CLI macros were derived from i386 arch historically, but their name are incomprehensible. So, for easy to understand, rename these macros to ENABLE_INTERRUPTS and DISABLE_INTERRUPTS, respectively. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-06m32r: build fix of entry.SHirokazu Takata
This patch fixes the following compile error: <-- snip --> ... AS arch/m32r/kernel/entry.o /home/bunk/linux/kernel-2.6/linux-2.6.23-rc3-mm1/arch/m32r/kernel/entry.S: Assembler messages: /home/bunk/linux/kernel-2.6/linux-2.6.23-rc3-mm1/arch/m32r/kernel/entry.S:358: Error: bad instruction `addi r0,#(((((0)+(64))+(32))+(32)))' make[2]: *** [arch/m32r/kernel/entry.o] Error 1 <-- snip --> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Adrian Bunk <bunk@kernel.org>
2007-09-03m32r: Separate syscall table from entry.SHirokazu Takata
- Separate sys_call_table from arch/m32r/kernel/entry.S and move it to arch/m32r/kernel/system_call.S. - Change sys_call_table section from .data to .rodata. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Cosmetic updates of arch/m32r/kernel/entry.SHirokazu Takata
- Remove unused symbols *_MASK - Change indentation of comments, etc. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Exit ei_handler directly for no IRQ case or IPI operationsHirokazu Takata
If no IRQ request is found in the IRQ check of ei_handler, we can exit directly by jumping "restore_all", instead of via "ret_from_intr". This modification is also likely effective for IPI operations, because scheduler call never happen at the exit of IPIs. Signed-off-by: Hitoshi Yamamoto <hitoshiy@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Simplify ei_handler codeHirokazu Takata
Simplify and clean up messy ei_handler code in arch/m32r/kernel/entry.S. - Remove ifdef's for CONFIG_CHIP_* configulations. - Rearrange the M32700 workaround code. - Remove the messy platform-dependent interrupt check routines and consolidate them to common INT0/INT1/INT2 check routines for all platforms with cascaded interrupt controllers. Signed-off-by: Hitoshi Yamamoto <hitoshiy@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Define symbols to unify platform-dependent ICU checksHirokazu Takata
On some m32r platforms, cascaded ICUs are used. This patch is required to simplify ei_handler and consolidate platform- dependent ICU check routines. platform ICU/INT1 ICU/INT0 ICU/INT2 -------------- -------- -------- -------- m32104ut o - - m32700ut o o o opsput o o o usrv o - - (others) - - - Signed-off-by: Hitoshi Yamamoto <hitoshiy@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Move dot.gdbinit filesHirokazu Takata
Move dot.gdbinit files from arch/m32r/{platforms}/dot.gdbinit* to arch/m32r/platforms/{platform}/. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Rearrange platform-dependent codesHirokazu Takata
Rearrange platform-dependent codes from arch/m32r/kernel/*.c to arch/m32r/platforms/{platform}/. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Add defconfig file for the usrv platform.Hirokazu Takata
Add usrv_defcofig file for the usrv (M32R MicroServer) platform. platform defconfig Note ---------- ---------------------- --------------------------- usrv usrv_defconfig SMP Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Update defconfig files for 2.6.23-rc1Hirokazu Takata
Update defconfig files for 2.6.23-rc1 in arch/m32r/configs/. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Move defconfig files to arch/m32r/configs/Hirokazu Takata
Change defconfig file's location from arch/m32r/{platform}/defconfig* to arch/m32r/configs/{platform}_defconfig. Applying this patch, we can use defconfig file for each m32r platform easily, like other architectures. ex. Setup defconfig for cross-building $ make ARCH=m32r CROSS_COMPILE=m32r-linux-gnu- {platform}_defconfig. platform defconfig Note ---------- ---------------------- --------------------------- m32104ut m32104ut_defconfig MMU-less m32700ut m32700ut.smp_defconfig SMP m32700ut m32700ut.up_defconfig UP mappi mappi.smp_defconfig SMP mappi mappi.up_defconfig UP mappi mappi.nommu_defconfig MMU-less mappi2 mappi2.opsp_defconfig FPGA env. (CPU Core: OPSP) mappi2 mappi2.vdec2_defconfig FPGA env. (CPU Core: VDEC2) mappi3 imappi3.smp_defconfig SMP oaks32r oaks32r_defconfig MMU-less opsput opsput_defconfig UP Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-07-30m32r: build fix for removing fs.h from mm.hHirokazu Takata
This patch fixes the m32r build after the commit "Remove fs.h from mm.h" was merged (commit 4e950f6f0189f65f8bf069cf2272649ef418f5e4). Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26m32r: Fix ei_tx_timeout() in drivers/net/lib8390.cHirokazu Takata
Change INT0 trigger mode from edge-sense mode to level-sense mode, in order to fix the following timeout error: 'NETDEV WATCHDOG: eth0: transmit timed out'. This patch is required only for the Mappi platform. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Hitoshi Yamamoto <hitoshiy@linux-m32r.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
