path: root/arch/m68k/Kconfig.devices
2013-04-16m68k/atari: EtherNEC - add platform device supportMichael Schmitz
Add platform device for the Atari ROM port ethernet adapter, EtherNEC. This platform device will be used by the ne.c driver. [Geert] Conditionalize platform device data structures Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-04-16m68k/atari: EtherNAT - platform device and IRQ support codeMichael Schmitz
Add platform device and interrupt definitions necessary for the EtherNAT Ethernet/USB adapter for the Falcon extension port. EtherNAT interrupt numbers are 139/140 so the max. interrupt number for Atari has to be increased. [Geert] Conditionalize platform device data structures Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-14arch/m68k: remove CONFIG_EXPERIMENTALKees Cook
This config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it. CC: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2012-01-04m68k/mac: Make CONFIG_HEARTBEAT unavailable on MacGeert Uytterhoeven
mac_heartbeat() was never really implemented. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org>
2011-12-28m68k/serial: Remove references to obsolete serial config optionsGeert Uytterhoeven
- ATARI_MFPSER, ATARI_MIDI, MULTIFACE_III_TTY, and DN_SERIAL have no corresponding drivers (anymore), - Clean up SERIAL_CONSOLE dependencies and help text. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-12-10m68k/serial: Remove references to obsolete CONFIG_SERIAL167Geert Uytterhoeven
commit 51c9d654c2def97827395a7fbfd0c6f865c26544 ("Staging: delete tty drivers") removed the MVME167 serial driver, but forgot to remove these references. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-11-08m68k: Revive lost ARAnyM config optionsGeert Uytterhoeven
commit 0e152d80507b75c00aac60f2ffc586360687cd52 ("m68k: reorganize Kconfig options to improve mmu/non-mmu selections") accidentally dropped the ARAnyM config options. Re-add them to the "Platform devices" section. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org>
2011-10-21m68k: drop unused Kconfig symbolsPaul Bolle
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-10-18m68k: reorganize Kconfig options to improve mmu/non-mmu selectionsGreg Ungerer
The current mmu and non-mmu Kconfig files can be merged to form a more general selection of options. The current break up of options is due to the simple brute force merge from the m68k and m68knommu arch directories. Many of the options are not at all specific to having the MMU enabled or not. They are actually associated with a particular CPU type or platform type. Ultimately as we support all processors with the MMU disabled we need many of these options to be selectable without the MMU option enabled. And likewise some of the ColdFire processors, which currently are only supported with the MMU disabled, do have MMU hardware, and will need to have options selected on CPU type, not MMU disabled. This patch removes the old mmu and non-mmu Kconfigs and instead breaks up the configuration into four areas: cpu, machine, bus, devices. The Kconfig.cpu lists all the options associated with selecting a CPU, and includes options specific to each CPU type as well. Kconfig.machine lists all options associated with selecting a machine type. Almost always the machines selectable is restricted by the chosen CPU. Kconfig.bus contains options associated with selecting bus types on the various machine types. That includes PCI bus, PCMCIA bus, etc. Kconfig.devices contains options for drivers and driver associated options. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
