path: root/arch/m68k/Kconfig
2016-09-26m68k: move CONFIG_FPU set to per-CPU configurationGreg Ungerer
Move the selection of CONFIG_FPU to each CPU type configuration. Currently for m68k we have a global set of CONFIG_FPU based on if CONFIG_MMU is enabled or not. There is at least one CPU family we support (m5441x) that has an MMU but has no FPU hardware. So we need to be able to have CONFIG_MMU set and CONFIG_FPU not set. Whether we build for a CPU with MMU enabled or not doesn't change the fact that it has FPU hardware support. Our current non-MMU builds have never had CONIG_FPU enabled - and in fact the kernel will not compile with that set and CONFIG_MMU not set at the moment. It is easy enough to fix this - but it would involve a structure change to sigcontext.h, and that is a user space exported header (so ABI change). This change makes no configuration visible changes, and all configs end up with the same configuration settings as before. This change based on changes and discussion from Yannick Gicquel <yannick.gicquel@open.eurogiciel.org>. Signed-off-by: Greg Ungerer <gerg@linux-m68k.org>
2015-09-10kexec: split kexec_load syscall from kexec core codeDave Young
There are two kexec load syscalls, kexec_load another and kexec_file_load. kexec_file_load has been splited as kernel/kexec_file.c. In this patch I split kexec_load syscall code to kernel/kexec.c. And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and use kexec_file_load only, or vice verse. The original requirement is from Ted Ts'o, he want kexec kernel signature being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use kexec_load syscall can bypass the checking. Vivek Goyal proposed to create a common kconfig option so user can compile in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects KEXEC_CORE so that old config files still work. Because there's general code need CONFIG_KEXEC_CORE, so I updated all the architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects KEXEC_CORE in arch Kconfig. Also updated general kernel code with to kexec_load syscall. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14m68k: mark PMD folded and expose number of page table levelsKirill A. Shutemov
We would want to use number of page table level to define mm_struct. Let's expose it as CONFIG_PGTABLE_LEVELS. Core mm expects __PAGETABLE_{PUD,PMD}_FOLDED to be defined if these page table levels folded. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-29kexec: remove CONFIG_KEXEC dependency on cryptoVivek Goyal
New system call depends on crypto. As it did not have a separate config option, CONFIG_KEXEC was modified to select CRYPTO and CRYPTO_SHA256. But now previous patch introduced a new config option for new syscall. So CONFIG_KEXEC does not require crypto. Remove that dependency. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Shaun Ruffell <sruffell@digium.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08kexec: load and relocate purgatory at kernel load timeVivek Goyal
Load purgatory code in RAM and relocate it based on the location. Relocation code has been inspired by module relocation code and purgatory relocation code in kexec-tools. Also compute the checksums of loaded kexec segments and store them in purgatory. Arch independent code provides this functionality so that arch dependent bootloaders can make use of it. Helper functions are provided to get/set symbol values in purgatory which are used by bootloaders later to set things like stack and entry point of second kernel etc. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Greg Kroah-Hartman <greg@kroah.com> Cc: Dave Young <dyoung@redhat.com> Cc: WANG Chao <chaowang@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07Kconfig: rename HAS_IOPORT to HAS_IOPORT_MAPUwe Kleine-König
If the renamed symbol is defined lib/iomap.c implements ioport_map and ioport_unmap and currently (nearly) all platforms define the port accessor functions outb/inb and friend unconditionally. So HAS_IOPORT_MAP is the better name for this. Consequently NO_IOPORT is renamed to NO_IOPORT_MAP. The motivation for this change is to reintroduce a symbol HAS_IOPORT that signals if outb/int et al are available. I will address that at least one merge window later though to keep surprises to a minimum and catch new introductions of (HAS|NO)_IOPORT. The changes in this commit were done using: $ git grep -l -E '(NO|HAS)_IOPORT' | xargs perl -p -i -e 's/\b((?:CONFIG_)?(?:NO|HAS)_IOPORT)\b/$1_MAP/' Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-06m68k: Skip futex_atomic_cmpxchg_inatomic() testFinn Thain
Skip the futex_atomic_cmpxchg_inatomic() test in futex_init(). It causes a fatal exception on 68030 (and presumably 68020 also). Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Link: http://lkml.kernel.org/r/alpine.LNX.2.00.1403061006440.5525@nippy.intranet Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-12-08m68k: Add support to export bootinfo in procfsGeert Uytterhoeven
Add optional support to export the bootinfo used to boot the kernel in a "bootinfo" file in procfs. This is useful with kexec. This is based on the similar feature for ATAGS on ARM. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-12-08m68k: Add kexec supportGeert Uytterhoeven
2013-10-23m68k: select ARCH_MIGHT_HAVE_PC_PARPORTMark Salter
Architectures which support CONFIG_PARPORT_PC should select ARCH_MIGHT_HAVE_PC_PARPORT. Signed-off-by: Mark Salter <msalter@redhat.com> Acked by: Geert Uytterhoeven <geert@linux-m68k.org> CC: linux-m68k@lists.linux-m68k.org
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-26m68knommu: user generic iomap to support ioread*/iowrite*Greg Ungerer
There is no reason we cannot use the generic iomap support to give us the ioread* and iowrite* family of IO access functions. The m68k arch with MMU enabled does, so this makes us consistent for all m68k now. Some potentially valid drivers will fail to compile without these, for example: drivers/i2c/busses/i2c-ocores.c:81:2: error: implicit declaration of function ‘iowrite8’ [-Werror=implicit-function-declaration] drivers/i2c/busses/i2c-ocores.c:86:2: error: implicit declaration of function ‘iowrite16’ [-Werror=implicit-function-declaration] drivers/i2c/busses/i2c-ocores.c:91:2: error: implicit declaration of function ‘iowrite32’ [-Werror=implicit-function-declaration] drivers/i2c/busses/i2c-ocores.c:96:2: error: implicit declaration of function ‘ioread8’ [-Werror=implicit-function-declaration] drivers/i2c/busses/i2c-ocores.c:101:2: error: implicit declaration of function ‘ioread16’ [-Werror=implicit-function-declaration] drivers/i2c/busses/i2c-ocores.c:106:2: error: implicit declaration of function ‘ioread32’ [-Werror=implicit-function-declaration] Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2013-04-16Remove GENERIC_GPIO config optionAlexandre Courbot
GENERIC_GPIO has been made equivalent to GPIOLIB in architecture code and all driver code has been switch to depend on GPIOLIB. It is thus safe to have GENERIC_GPIO removed. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2013-03-12Select VIRT_TO_BUS directly where neededStephen Rothwell
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS") I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where needed. I am not sure what I was thinking. Instead, just directly select VIRT_TO_BUS where it is needed. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUSStephen Rothwell
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures that already provide virt_to_bus(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: H Hartley Sweeten <hartleys@visionengravers.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-14burying unused conditionalsAl Viro
__ARCH_WANT_SYS_RT_SIGACTION, __ARCH_WANT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} - can be assumed always set.
2013-02-03m68k: switch to generic old sigaction()Al Viro
2013-02-03m68k: switch to generic old sigsuspendAl Viro
2013-02-03m68k: switch to generic sigaltstackAl Viro
2012-12-19Bury the conditionals from kernel_thread/kernel_execve seriesAl Viro
All architectures have CONFIG_GENERIC_KERNEL_THREAD CONFIG_GENERIC_KERNEL_EXECVE __ARCH_WANT_SYS_EXECVE None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers of kernel_execve() (which is a trivial wrapper for do_execve() now) left. Kill the conditionals and make both callers use do_execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-17m68k: switch to saner kernel_execve() semanticsAl Viro
Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull pile 2 of execve and kernel_thread unification work from Al Viro: "Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for several more architectures plus assorted signal fixes and cleanups. There'll be more (in particular, real fixes for the alpha do_notify_resume() irq mess)..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits) alpha: don't open-code trace_report_syscall_{enter,exit} Uninclude linux/freezer.h m32r: trim masks avr32: trim masks tile: don't bother with SIGTRAP in setup_frame microblaze: don't bother with SIGTRAP in setup_rt_frame() mn10300: don't bother with SIGTRAP in setup_frame() frv: no need to raise SIGTRAP in setup_frame() x86: get rid of duplicate code in case of CONFIG_VM86 unicore32: remove pointless test h8300: trim _TIF_WORK_MASK parisc: decide whether to go to slow path (tracesys) based on thread flags parisc: don't bother looping in do_signal() parisc: fix double restarts bury the rest of TIF_IRET sanitize tsk_is_polling() bury _TIF_RESTORE_SIGMASK unicore32: unobfuscate _TIF_WORK_MASK mips: NOTIFY_RESUME is not needed in TIF masks mips: merge the identical "return from syscall" per-ABI code ... Conflicts: arch/arm/include/asm/thread_info.h
2012-10-09Kconfig: clean up the long arch list for the DEBUG_BUGVERBOSE config optionCatalin Marinas
Introduce HAVE_DEBUG_BUGVERBOSE config option and select it in corresponding architecture Kconfig files. Architectures that already select GENERIC_BUG don't need to select HAVE_DEBUG_BUGVERBOSE. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the long arch list for the UID16 config optionCatalin Marinas
Introduce HAVE_UID16 config option and select it in corresponding architecture Kconfig files. UID16 now only depends on HAVE_UID16. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-01m68k: split ret_from_fork(), simplify kernel_thread()Al Viro
2012-09-28Make most arch asm/module.h files use asm-generic/module.hDavid Howells
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela, ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version into asm-generic/module.h for all arches bar MIPS. Also, use the generic definition mod_arch_specific where possible. To this end, I've defined three new config bools: (*) HAVE_MOD_ARCH_SPECIFIC Arches define this if they don't want to use the empty generic mod_arch_specific struct. (*) MODULES_USE_ELF_RELA Arches define this if their modules can contain RELA records. This causes the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be defined by the arch rather than have the core emit an error message. (*) MODULES_USE_ELF_REL Arches define this if their modules can contain REL records. This causes the Elf_Rel mapping to be emitted and allows apply_relocate() to be defined by the arch rather than have the core emit an error message. Note that it is possible to allow both REL and RELA records: m68k and mips are two arches that do this. With this, some arch asm/module.h files can be deleted entirely and replaced with a generic-y marker in the arch Kbuild file. Additionally, I have removed the bits from m32r and score that handle the unsupported type of relocation record as that's now handled centrally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-08-17m68k: select CONFIG_GENERIC_ATOMIC64 for all m68k CPU typesGreg Ungerer
There is no specific atomic64 support code for any m68k CPUs, so we should select CONFIG_GENERIC_ATOMC64 for all. Remove the existing per CPU selection of this and select it for all m68k. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2012-08-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: Make sys_atomic_cmpxchg_32 work on classic m68k m68k/apollo: Rename "timer" to "apollo_timer" zorro: Remove unused zorro_bus.devices m68k: Remove never used asm/shm.h m68k/sun3: Remove unselectable code in prom_init() m68k: Use asm-generic version of <asm/sections.h> m68k: Replace m68k-specific _[se]bss by generic __bss_{start,stop} mtd/uclinux: Use generic __bss_stop instead of _ebss m68knommu: Allow ColdFire CPUs to use unaligned accesses m68k: Remove five unused headers m68k: CPU32 does not support unaligned accesses m68k: Introduce config option CPU_HAS_NO_UNALIGNED m68k: delay, muldi3 - Use CONFIG_CPU_HAS_NO_MULDIV64 m68k: Move CPU_HAS_* config options m68k: Remove duplicate FPU config option m68knommu: Clean up printing of sections m68k: Use asm-generic version of <asm/types.h> m68k: Use Kbuild logic to import asm-generic headers
2012-07-30ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSIONWill Deacon
Rather than #define the options manually in the architecture code, add Kconfig options for them and select them there instead. This also allows us to select the compat IPC version parsing automatically for platforms using the old compat IPC interface. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-10m68k: Move CPU_HAS_* config optionsGeert Uytterhoeven
They belong together with the CPU selection Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer<gerg@uclinux.org>
2012-06-10m68k: Remove duplicate FPU config optionGeert Uytterhoeven
It's also defined in arch/m68k/Kconfig.cpu Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer<gerg@uclinux.org>
2012-06-06m68k: Use generic strncpy_from_user(), strlen_user(), and strnlen_user()Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org>
2012-05-21timers: Fixup the Kconfig consolidation falloutThomas Gleixner
Sigh, I missed to check which architecture Kconfig files actually include the core Kconfig file. There are a few which did not. So we broke them. Instead of adding the includes to those, we are better off to move the include to init/Kconfig like we did already with irqs and others. This does not change anything for the architectures using the old style periodic timer mode. It just solves the build wreckage there. For those architectures which use the clock events infrastructure it moves the include of the core Kconfig file to "General setup" which is a way more logical place than having it at random locations specified by the architecture specific Kconfigs. Reported-by: Ingo Molnar <mingo@kernel.org> Cc: Anna-Maria Gleixner <anna-maria@glx-um.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-21m68k: Use generic time configAnna-Maria Gleixner
Signed-off-by: Anna-Maria Gleixner <anna-maria@glx-um.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Link: http://lkml.kernel.org/r/20120518163105.808606368@glx-um.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-05m68k: make support for FPU hardware configurableGreg Ungerer
The classic m68k code has always supported an FPU (although it may have been a software emulated one). The non-MMU m68k code has never supported FPU hardware. To help in merging common code create a configation setting that signifies if we are builing in FPU support or not. This switch, CONFIG_FPU, is set as per the current use cases. So it is always enabled if CONFIG_MMU is set, and disabled otherwise. With a little extra code it will be possible to disable it on the classic m68k platforms as well, and to enable it on non-MMU platforms that do have hardware FPU. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2012-03-05m68knommu: remove unused CONFIG_GENERIC_CMOS_UPDATE optionGreg Ungerer
The CONFIG_GENERIC_CMOS_UPDATE switch is always enabled for the non-MMU m68k case. But the underlying code to support it, update_persistent_clock(), doesn't end up doing anything on the currently supported non-MMU platforms. No platforms supply the necessary function support for writing back the RTC. So lets remove this option and support code. This also brings m68knommu in line with the m68k, which doesn't enabled this switch either. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-01-11cpu: Register a generic CPU device on architectures that currently do notBen Hutchings
frv, h8300, m68k, microblaze, openrisc, score, um and xtensa currently do not register a CPU device. Add the config option GENERIC_CPU_DEVICES which causes a generic CPU device to be registered for each present CPU, and make all these architectures select it. Richard Weinberger <richard@nod.at> covered UML and suggested using per_cpu. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10Merge tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
lib: use generic pci_iomap on all architectures Many architectures don't want to pull in iomap.c, so they ended up duplicating pci_iomap from that file. That function isn't trivial, and we are going to modify it https://lkml.org/lkml/2011/11/14/183 so the duplication hurts. This reduces the scope of the problem significantly, by moving pci_iomap to a separate file and referencing that from all architectures. * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: alpha: drop pci_iomap/pci_iounmap from pci-noop.c mn10300: switch to GENERIC_PCI_IOMAP mn10300: add missing __iomap markers frv: switch to GENERIC_PCI_IOMAP tile: switch to GENERIC_PCI_IOMAP tile: don't panic on iomap sparc: switch to GENERIC_PCI_IOMAP sh: switch to GENERIC_PCI_IOMAP powerpc: switch to GENERIC_PCI_IOMAP parisc: switch to GENERIC_PCI_IOMAP mips: switch to GENERIC_PCI_IOMAP microblaze: switch to GENERIC_PCI_IOMAP arm: switch to GENERIC_PCI_IOMAP alpha: switch to GENERIC_PCI_IOMAP lib: add GENERIC_PCI_IOMAP lib: move GENERIC_IOMAP to lib/Kconfig Fix up trivial conflicts due to changes nearby in arch/{m68k,score}/Kconfig
2011-12-30m68k: ColdFire with MMU enabled uses same clocking code as non-MMUGreg Ungerer
We want to use the same timer support code for ColdFire CPU's when running with MMU enabled or not. So use the same time_no.c code even when the MMU is enabled for ColdFire. This also means we do not want CONFIG_ARCH_USES_GETTIMEOFFSET set, since that code is only in time_mm.c. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Matt Waddel <mwaddel@yahoo.com> Acked-by: Kurt Mahan <kmahan@xmission.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-12-30m68k: compile appropriate mm arch files for ColdFire MMU supportGreg Ungerer
Create a config symbol to enable when using a ColdFire MMU. We then use that to only compile the necessary arch mm files. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Matt Waddel <mwaddel@yahoo.com> Acked-by: Kurt Mahan <kmahan@xmission.com>
2011-12-30m68k: modify user space access functions to support ColdFire CPUsGreg Ungerer
Modify the user space access functions to support the ColdFire V4e cores running with MMU enabled. The ColdFire processors do not support the "moves" instruction used by the traditional 680x0 processors for moving data into and out of another address space. They only support the notion of a single address space, and you use the usual "move" instruction to access that. Create a new config symbol (CONFIG_CPU_HAS_ADDRESS_SPACES) to mark the CPU types that support separate address spaces, and thus also support the sfc/dfc registers and the "moves" instruction that go along with that. The code is almost identical for user space access, so lets just use a define to choose either the "move" or "moves" in the assembler code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Matt Waddel <mwaddel@yahoo.com> Acked-by: Kurt Mahan <kmahan@xmission.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-12-24m68k: handle presence of 64bit mul/div instructions cleanlyGreg Ungerer
The traditional 68000 processors and the newer reduced instruction set ColdFire processors do not support the 32*32->64 multiply or the 64/32->32 divide instructions. This is not a difference based on the presence of a hardware MMU or not. Create a new config symbol to mark that a CPU type doesn't support the longer multiply/divide instructions. Use this then as a basis for using the fast 64bit based divide (in div64.h) and for linking in the extra libgcc functions that may be required (mulsi3, divsi3, etc). Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-12-24m68k: simpler m68k and ColdFire CPU's can use generic csum codeGreg Ungerer
We have two implementations of the IP checksuming code for the m68k arch. One uses the more advanced instructions available in 68020 and above processors, the other uses the simpler instructions available on the original 68000 processors and the modern ColdFire processors. This simpler code is pretty much the same as the generic lib implementation of the IP csum functions. So lets just switch over to using that. That means we can completely remove the checksum_no.c file, and only have the local fast code used for the more complex 68k CPU family members. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-12-24m68k: selection of GENERIC_ATOMIC64 is not MMU specificGreg Ungerer
The selection of the CONFIG_GENERIC_ATOMIC64 option is not specific to the MMU being present and enabled. It is a property of certain CPU families. So select it based on those CPU types being selected. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-11-24lib: move GENERIC_IOMAP to lib/KconfigMichael S. Tsirkin
define GENERIC_IOMAP in a central location instead of all architectures. This will be helpful for the follow-up patch which makes it select other configs. Code is also a bit shorter this way. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-11-08m68k/irq: Remove obsolete m68k irq frameworkGeert Uytterhoeven
2011-11-08m68k/q40: Convert Q40/Q60 to genirqGeert Uytterhoeven
q40_irq_handler() must be kept to translate ISA IRQs to the range 1-15. q40_probe_irq_o{ff,n}() become unused. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Richard Zidlicky <rz@linux-m68k.org>
2011-11-08m68k/sun3: Convert Sun3/3x to genirqGeert Uytterhoeven
Replace the custom irq handler that masks the irq and calls do_IRQ(), and the unmasking in the individual handlers, by handle_level_irq(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Sam Creasey <sammy@sammy.net>
2011-11-08m68k/apollo: Convert Apollo to genirqGeert Uytterhoeven
Replace the custom user vector interrupt handler that calls do_IRQ() and does an EOI by handle_fasteoi_irq(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Peter De Schrijver <p2@debian.org>
