path: root/arch/m68k/atari
2011-07-30m68k/atari: Reserve some ST-RAM early on for device buffer useMichael Schmitz
Based on an original patch from Michael Schmitz: Because mem_init() is now called before device init, devices that rely on ST-RAM may find all ST-RAM already allocated to other users by the time device init happens. In particular, a large initrd RAM disk may use up enough of ST-RAM to cause atari_stram_alloc() to resort to __get_dma_pages() allocation. In the current state of Atari memory management, all of RAM is marked DMA capable, so __get_dma_pages() may well return RAM that is not in actual fact DMA capable. Using this for frame buffer or SCSI DMA buffer causes subtle failure. The ST-RAM allocator has been changed to allocate memory from a pool of reserved ST-RAM of configurable size, set aside on ST-RAM init (i.e. before mem_init()). As long as this pool is not exhausted, allocation of real ST-RAM can be guaranteed. Other changes: - Replace the custom allocator in the ST-RAM pool by the existing allocator in the resource subsystem, - Remove mem_init_done and its hook, as memory init is now done before device init, - Remove /proc/stram, as ST-RAM usage now shows up under /proc/iomem, e.g. 005f2000-006f1fff : ST-RAM Pool 005f2000-0063dfff : atafb 0063e000-00641fff : ataflop 00642000-00642fff : SCSI Signed-off-by: Michael Schmitz <schmitz@debian.org> [Andreas Schwab <schwab@linux-m68k.org>: Use memparse()] [Geert: Use the resource subsystem instead of a custom allocator] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-19input/atari: Use the correct mouse interrupt hookMichael Schmitz
The Atari keyboard driver calls atari_mouse_interrupt_hook if it's set, not atari_input_mouse_interrupt_hook. Fix below. [geert] Killed off atari_mouse_interrupt_hook completely, after fixing another incorrect assignment in atarimouse.c. Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-05-19m68k/atari: Do not use "/" in interrupt namesGeert Uytterhoeven
It may trigger a warning in fs/proc/generic.c:__xlate_proc_name() when trying to add an entry for the interrupt handler to sysfs. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-01-23m68k/atari: Rename "scc" to "atari_scc"Geert Uytterhoeven
It's a way too generic name for a global #define and conflicts with a variable with the same name, causing build errors like: | drivers/staging/brcm80211/brcmfmac/../util/siutils.c: In function ‘_si_clkctl_cc’: | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1364: error: expected identifier or ‘(’ before ‘volatile’ | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1364: error: expected ‘)’ before ‘(’ token | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1421: error: incompatible types in assignment | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1422: error: invalid operands to binary & | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1423: error: invalid operands to binary & | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1424: error: invalid operands to binary | | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: incompatible type for argument 4 of ‘bcmsdh_reg_write’ | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1428: error: invalid operands to binary & | make[8]: *** [drivers/staging/brcm80211/brcmfmac/../util/siutils.o] Error 1 Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-02-22m68k: atari - Rename "mfp" to "st_mfp"Geert Uytterhoeven
http://kisskb.ellerman.id.au/kisskb/buildresult/72115/: | net/mac80211/ieee80211_i.h:327: error: syntax error before 'volatile' | net/mac80211/ieee80211_i.h:350: error: syntax error before '}' token | net/mac80211/ieee80211_i.h:455: error: field 'sta' has incomplete type | distcc[19430] ERROR: compile net/mac80211/main.c on sprygo/32 failed This is caused by | # define mfp ((*(volatile struct MFP*)MFP_BAS)) in arch/m68k/include/asm/atarihw.h, which conflicts with the new "mfp" enum in net/mac80211/ieee80211_i.h. Rename "mfp" to "st_mfp", as it's a way too generic name for a global #define. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12m68k: atari core - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'request_irq', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: Kill several external declarations in source filesGeert Uytterhoeven
- Replace external declarations by proper includes where availiable. The accesses to some symbols had to be modified, as before they were declared using e.g. "extern int _end", while asm-generic/sections.h uses e.g. "extern char _end[]" - Remove unused or superfluous external declarations Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-10-23proc: move /proc/stram to m68k-specific codeAlexey Dobriyan
2008-10-23proc: move /proc/hardware to m68k-specific codeAlexey Dobriyan
2008-10-14m68k: Remove the broken Hades supportAdrian Bunk
This patch removes the Hades support that was marked as BROKEN 5 years ago. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14m68k: Define rtc_lock on AtariGeert Uytterhoeven
The nvram and rtc-cmos drivers use the spinlock rtc_lock to protect against concurrent accesses to the CMOS memory. As m68k doesn't support SMP or preempt yet, the spinlock calls tend to get optimized away, but not for all configurations, causing in some rare cases: | ERROR: "rtc_lock" [drivers/rtc/rtc-cmos.ko] undefined! | ERROR: "rtc_lock" [drivers/char/nvram.ko] undefined! Add the spinlock to the Atari core code to avoid this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14m68k: Remove unused atari_kbd_translate()Geert Uytterhoeven
If CONFIG_VT=n, I get: | arch/m68k/atari/built-in.o: In function `atari_kbd_translate': | arch/m68k/atari/atakeyb.c:640: undefined reference to `shift_state' Just remove atari_kbd_translate(), as it's unused. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14m68k: use bcd2bin/bin2bcdAdrian Bunk
This patch changes m68k to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. It also remove local bcd2bin/bin2bcd implementations in favor of the global ones. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02m68k: atari_keyb_init operator precedence fixMichael Schmitz
Fix operator precedence bug in atari_keyb_init, which caused a failure on CT60 Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k/atari/debug.c: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global functions (always) static: - atari_mfp_console_write() - atari_scc_console_write() - atari_midi_console_write() - atari_init_mfp_port() - atari_init_scc_port() - atari_init_midi_port() - #if 0 the following unused functions: - atari_mfp_console_wait_key() - atari_scc_console_wait_key() - atari_midi_console_wait_key() - remove the following unused variables: - atari_MFP_init_done - atari_SCC_init_done Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18arch: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m68k: kill arch/m68k/atari/atari_ksyms.cAdrian Bunk
EXPORT_SYMBOL's belong to the actual code. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m68k: Balance ioremap and iounmap in m68k/atari/hades-pci.cRoel Kluin
Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-26m68k: export atari_keyb_initAdrian Bunk
m68k: export atari_keyb_init This patch fixes the following build error: .. MODPOST 25 modules ERROR: "atari_keyb_init" [drivers/input/mouse/atarimouse.ko] undefined! ERROR: "atari_keyb_init" [drivers/input/keyboard/atakbd.ko] undefined! make[2]: *** [__modpost] Error 1 Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15Atari keyboard: incorporate additional review commentsGeert Uytterhoeven
Atari keyboard: incorporate additional review comments: o Kill reference to source file name o Return error value from input_register_device() instead of -ENOMEM Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Michael Schmitz <schmitz@biophys.uni-duesseldorf.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-13m68k: Atari keyboard ACIA driver cleanupGeert Uytterhoeven
m68k: Atari keyboard ACIA driver cleanup: - removed dead key autorepeat code - removed hardcoded initial keymap Signed-off-by: Michael Schmitz <schmitz@biophys.uni-duesseldorf.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20m68k: missing exportsAl Viro
2007-05-07SPIN_LOCK_UNLOCKED cleanup in arch/m68kMilind Arun Choudhary
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07remove unused header file: arch/m68k/atari/atasound.hRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: early parameter supportRoman Zippel
Add early parameter support and convert current users to it. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: reformat various m68k filesRoman Zippel
Reformat various m68k files, so they actually look like Linux sources. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: Atari keyboard and mouse support.Michael Schmitz
Atari keyboard and mouse support. (reformating and Kconfig fixes by Roman Zippel) Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-09[PATCH] m68k/Atari: 2.6.18 Atari IDE interrupt needs SA_SHIRQMichael Schmitz
Atari IDE: The interrupt needs SA_SHIRQ now to get registered. Signed-off-by: Michael Schmitz <schmitz@biophys.uni-duesseldorf.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] m68k: replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-09[PATCH] m68k/Atari: Interrupt updatesGeert Uytterhoeven
Misc Atari fixes: - initialize correct number of atari irqs - silence vbl interrupt until it's used by atafb - use mdelay() to read clock if necessary Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-07[PATCH] m68k pt_regs fixesAl Viro
m68k_handle_int() split in two functions: __m68k_handle_int() takes pt_regs * and does set_irq_regs(); m68k_handle_int() doesn't get pt_regs *. Places where we used to call m68k_handle_int() recursively with the same pt_regs have simply lost the second argument, the rest is switched to __m68k_handle_int(). The rest of patch is just dropping pt_regs * where needed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68k: convert atari irq codeRoman Zippel
Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68k: separate handler for auto and user vector interruptRoman Zippel
Use separate entry points for auto and user vector interrupts and cleanup naming a little. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: kill mach_floppy_setup, convert to proper __setup() in driversAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: Moved initialisation of conswitchp from subarches to global ↵Al Viro
arch setup Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] m68k: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: m68k kill stram swapHugh Dickins
Please, please now delete the Atari CONFIG_STRAM_SWAP code. It may be excellent and ingenious code, but its reference to swap_vfsmnt betrays that it hasn't been built since 2.5.1 (four years old come December), it's delving deep into matters which are the preserve of core mm code, its only purpose is to give the more conscientious mm guys an anxiety attack from time to time; yet we keep on breaking it more and more. If you want to use RAM for swap, then if the MTD driver does not already provide just what you need, I'm sure David could be persuaded to add the extra. But you'd also like to be able to allocate extents of that swap for other use: we can give you a core interface for that if you need. But unbuilt for four years suggests to me that there's no need at all. I cannot swear the patch below won't break your build, but believe so. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
