path: root/arch/m68k/configs/hp300_defconfig
2014-07-17tgt: defconfig cleanupBart Van Assche
Because of the removal of the scsi_tgt kernel module, the kbuild variables CONFIG_SCSI_TGT, CONFIG_SCSI_SRP_TGT_ATTRS and CONFIG_SCSI_FC_TGT_ATTRS are obsolete. This patch removes these variables. This patch is the result of the following command: find -name '*defconfig' | while read f; do grep -vwE 'CONFIG_SCSI_TGT|CONFIG_SCSI_SRP_TGT_ATTRS|CONFIG_SCSI_FC_TGT_ATTRS|CONFIG_SRP' $f >/tmp/t && mv /tmp/t $f; done Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-05-28m68k: Update defconfigs for v3.15-rc2Geert Uytterhoeven
2014-03-31m68k: Update defconfigs for v3.14-rc1Geert Uytterhoeven
2013-12-30m68k: Update defconfigs for v3.13-rc1Geert Uytterhoeven
2013-12-30m68k/defconfig: Disable /sbin/hotplug fork-bomb by defaultGeert Uytterhoeven
Cfr. commit 7934779a69f1184f29d786b89e77dd14519bd226 ("Driver-Core: disable /sbin/hotplug by default"). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-12-08m68k/defconfig: Use ext4 for ext2/ext3 file systemsGeert Uytterhoeven
This reduces the kernel image size by ca. 160 KiB. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-11-26m68k/defconfig: Make NFS_V4 modular instead of builtinGeert Uytterhoeven
This reduces the kernel image size by ca. 100 KiB, while still allowing NFS root. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-05-28m68k: Update defconfigs for v3.9Geert Uytterhoeven
2012-09-03netfilter: remove xt_NOTRACKCong Wang
It was scheduled to be removed for a long time. Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: Patrick McHardy <kaber@trash.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: netfilter@vger.kernel.org Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-04-22m68k: Update defconfigs for 2.6.30-rc3Geert Uytterhoeven
2008-12-02m68k: Update defconfigs for 2.6.28-rc7Geert Uytterhoeven
2008-09-10m68k: Update defconfigs for 2.6.27-rc6Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06m68k: enable CONFIG_COMPAT_BRK by defaultGeert Uytterhoeven
As some m68k machines have plenty of libc5 binaries in active use, enable CONFIG_COMPAT_BRK by default. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Update defconfigsGeert Uytterhoeven
Update the m68k defconfigs Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-04m68k: update defconfigs for 2.6.25Geert Uytterhoeven
Long overdue update of the m68k defconfigs Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-06-12[PATCH] M68k: Update defconfigsGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-18[PATCH] M68k: Update defconfigs for 2.6.12-rc2Geert Uytterhoeven
2005-04-18[PATCH] M68k: Update defconfigs for 2.6.11Geert Uytterhoeven
