path: root/arch/m68k/configs/mvme16x_defconfig
2011-12-28m68k/serial: Remove references to obsolete serial config optionsGeert Uytterhoeven
- ATARI_MFPSER, ATARI_MIDI, MULTIFACE_III_TTY, and DN_SERIAL have no corresponding drivers (anymore), - Clean up SERIAL_CONSOLE dependencies and help text. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-12-10m68k/serial: Remove references to obsolete CONFIG_SERIAL167Geert Uytterhoeven
commit 51c9d654c2def97827395a7fbfd0c6f865c26544 ("Staging: delete tty drivers") removed the MVME167 serial driver, but forgot to remove these references. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-04-22m68k: Update defconfigs for 2.6.30-rc3Geert Uytterhoeven
2008-12-02m68k: Update defconfigs for 2.6.28-rc7Geert Uytterhoeven
2008-09-10m68k: Update defconfigs for 2.6.27-rc6Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06m68k: enable CONFIG_COMPAT_BRK by defaultGeert Uytterhoeven
As some m68k machines have plenty of libc5 binaries in active use, enable CONFIG_COMPAT_BRK by default. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Update defconfigsGeert Uytterhoeven
Update the m68k defconfigs Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-04m68k: update defconfigs for 2.6.25Geert Uytterhoeven
Long overdue update of the m68k defconfigs Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-06-12[PATCH] M68k: Update defconfigsGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-18[PATCH] M68k: Update defconfigs for 2.6.12-rc2Geert Uytterhoeven
2005-04-18[PATCH] M68k: Update defconfigs for 2.6.11Geert Uytterhoeven
