path: root/arch/m68k/fpsp040
2008-12-28m68k: fix trigraph ignored warning in setox.SFinn Thain
Fix the warning: trigraph ??/ ignored, use -trigraphs to enable caused by the recent removal of -traditional option. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-07-20Stringify support commasMathieu Desnoyers
> This is a no-no for those archs that still use -traditional. > > I dunno if this is a problem for you at the moment and the > > right fix is anyway to nuke -traditional. > > > > Sam Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-02-11[PATCH] Add wording to m68k .S files to help clarify license infoMatt Waddel
Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Matt Waddel <Matt.Waddel@freescale.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] m68k: convert thread flags to use bit fieldsRoman Zippel
Remove task_work structure, use the standard thread flags functions and use shifts in entry.S to test the thread flags. Add a few local labels to entry.S to allow gas to generate short jumps. Finally it changes a number of inline functions in thread_info.h to macros to delay the current_thread_info() usage, which requires on m68k a structure (task_struct) not yet defined at this point. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: m68k,parisc,ppc,ppc64,s390,xtensa use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
