path: root/arch/m68k/hp300
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-04char/genrtc: remove m68k supportArnd Bergmann
The asm/rtc.h header is only used for the old gen_rtc driver that has been replaced by rtc-generic. According to Geert Uytterhoeven, nobody has used the old driver on m68k for a long time, so we can now just remove the header file and disallow the driver in Kconfig. All files that used to include asm/rtc.h are now changed so they include the headers that were used implicitly through asm/rtc.h. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2014-05-28m68k/hp300: Convert printk to pr_foo()Fabian Frederick
This patch also fixes some checkpatch warnings This is untested Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-11-26m68k/UAPI: Use proper types (endianness/size) in <asm/bootinfo*.h>Geert Uytterhoeven
2013-11-26m68k/UAPI: Disintegrate arch/m68k/include/asm/bootinfo.hGeert Uytterhoeven
Export the bootinfo definitions that are used by bootstrap loaders, and split them up in generic and platform-specific parts. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2012-12-24m68k: set arch_gettimeoffset directlyStephen Warren
remove m68k's mach_gettimeoffset function pointer, and instead directly set the arch_gettimeoffset function pointer. This requires multiplying all function results by 1000, since the removed m68k_gettimeoffset() did this. Also, s/unsigned long/u32/ just to make the function prototypes exactly match that of arch_gettimeoffset. Cc: Joshua Thompson <funaho@jurai.org> Cc: Sam Creasey <sammy@sammy.net> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Phil Blundell <philb@gnu.org> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-03-28Disintegrate asm/system.h for M68KDavid Howells
Disintegrate asm/system.h for M68K. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@uclinux.org> cc: linux-m68k@lists.linux-m68k.org
2011-12-10m68k/hp300: Export hp300_ledstateGeert Uytterhoeven
The accidental loss of CONFIG_DIO in commit 0e152d80507b75c00aac60f2ffc586360687cd52 ("m68k: reorganize Kconfig options to improve mmu/non-mmu selections") exposed a missing symbol export in m68k allmodconfig. If CONFIG_HP300=y but CONFIG_HPLANCE (which is bool, and depends on CONFIG_DIO) is not set, and CONFIG_MVME147=y and CONFIG_MVME147_NET=m, 7990.c is compiled as a module, giving: ERROR: "ledstate" [drivers/net/ethernet/amd/7990.ko] undefined! Add the missing export, and rename ledstate to hp300_ledstate while we're at it, as it's a too generic name. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-11-08m68k/irq: Remove obsolete IRQ_FLG_* usersGeert Uytterhoeven
The m68k core irq code stopped honoring these flags during the irq restructuring in 2006. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-05-17m68k: hp300 - Checkpatch cleanupAndrea Gelmini
arch/m68k/hp300/time.h:2: WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: hp300 core - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'request_irq', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-02-05m68k: kill arch/m68k/hp300/ksyms.cAdrian Bunk
It was empty. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-07[PATCH] m68k pt_regs fixesAl Viro
m68k_handle_int() split in two functions: __m68k_handle_int() takes pt_regs * and does set_irq_regs(); m68k_handle_int() doesn't get pt_regs *. Places where we used to call m68k_handle_int() recursively with the same pt_regs have simply lost the second argument, the rest is switched to __m68k_handle_int(). The rest of patch is just dropping pt_regs * where needed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68k: convert hp300 irq codeRoman Zippel
Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: Moved initialisation of conswitchp from subarches to global ↵Al Viro
arch setup Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
