path: root/arch/m68k/hp300
2012-03-28Disintegrate asm/system.h for M68KDavid Howells
Disintegrate asm/system.h for M68K. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@uclinux.org> cc: linux-m68k@lists.linux-m68k.org
2011-12-10m68k/hp300: Export hp300_ledstateGeert Uytterhoeven
The accidental loss of CONFIG_DIO in commit 0e152d80507b75c00aac60f2ffc586360687cd52 ("m68k: reorganize Kconfig options to improve mmu/non-mmu selections") exposed a missing symbol export in m68k allmodconfig. If CONFIG_HP300=y but CONFIG_HPLANCE (which is bool, and depends on CONFIG_DIO) is not set, and CONFIG_MVME147=y and CONFIG_MVME147_NET=m, 7990.c is compiled as a module, giving: ERROR: "ledstate" [drivers/net/ethernet/amd/7990.ko] undefined! Add the missing export, and rename ledstate to hp300_ledstate while we're at it, as it's a too generic name. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-11-08m68k/irq: Remove obsolete IRQ_FLG_* usersGeert Uytterhoeven
The m68k core irq code stopped honoring these flags during the irq restructuring in 2006. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-05-17m68k: hp300 - Checkpatch cleanupAndrea Gelmini
arch/m68k/hp300/time.h:2: WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: hp300 core - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'request_irq', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-02-05m68k: kill arch/m68k/hp300/ksyms.cAdrian Bunk
It was empty. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-07[PATCH] m68k pt_regs fixesAl Viro
m68k_handle_int() split in two functions: __m68k_handle_int() takes pt_regs * and does set_irq_regs(); m68k_handle_int() doesn't get pt_regs *. Places where we used to call m68k_handle_int() recursively with the same pt_regs have simply lost the second argument, the rest is switched to __m68k_handle_int(). The rest of patch is just dropping pt_regs * where needed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68k: convert hp300 irq codeRoman Zippel
Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m68k: Moved initialisation of conswitchp from subarches to global ↵Al Viro
arch setup Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
