The reality is that you do not need the abiltity to configure the
clock divider for ColdFire CPUs. It is a fixed ratio on any given
ColdFire family member. It is not the same for all ColdFire parts,
but it is always the same in a model range. So hard define the divider
for each supported ColdFire CPU type and remove the Kconfig option.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
In some of the RAM size autodetection code on ColdFire CPU startup
we reference DRAM registers relative to the MBAR register. Not all of
the supported ColdFire CPUs have an MBAR, and currently this works
because we fake an MBAR address on those registers. In an effort to
clean this up, and eventually remove the fake MBAR setting make the
DRAM register address definitions actually contain the MBAR (or IPSBAR
as appropriate) value as required.
Not all ColdFire CPUs that use the old style timer hardware module use
an MBAR set peripheral region. Move the TIMER base address defines to the
per-CPU header files where we can set it correctly based on how the
peripherals are mapped - instead of using a fake MBAR for some platforms.
The base addresses of the ColdFire DMA unit registers belong with
all the other address definitions in the per-cpu headers. The current
definitions assume they are relative to an MBAR register. Not all
ColdFire CPUs have an MBAR register. A clean address define can only
be acheived in the per-cpu headers along with all the other chips
peripheral base addresses.
Move the inclusion of the version 4 cache controller registers so that
it is with all the other register bit flag definitions. This makes it
consistent with the other version core inclusion points, and means we
don't need "#ifdef"ery in odd-ball places for these definitions.
The ColdFire UART base addresses varies between the different ColdFire
family members. Instead of keeping the base addresses with the UART
definitions keep them with the other addresses definitions for each
ColdFire part.
The motivation for this move is so that when we add new ColdFire
part definitions, they are all in a single file (and we shouldn't
normally need to modify the UART definitions in mcfuart.h at all).
The instruction timings of the ColdFire 54xx family parts are
different to other version 4 parts (or version 2 or 3 parts for
that matter too).
Move the instruction timing setting into the ColdFire part
specific headers, and set the 54xx value appropriately.
Move the ColdFire CPU names out of setup.c and into their repsective
headers. That way when we add new ones we won't need to modify
setup.c any more.
Add the missing 548x CPU name.
The MCF548x have the same cache control registers as the MCF5407.
Extract the bit definitions for the ACR and CACR registers from m5407sim.h
and move them to a new file m54xxacr.h. Those definitions are not used
anywhere yet, so no other file is involved. This is a preparation for
m54xx cache support cleanup.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
The ColdFire "timers" clock setup can be simplified. There is really no
need for the flexible per-platform setup code. The clock interrupt can be
hard defined per CPU platform (in CPU include files). This makes the
actual timer code simpler.
Currently the code that supports setting the old style ColdFire interrupt
controller mask registers is macros in the include files of each of the
CPU types. Merge all these into a set of real masking functions in the
old Coldfire interrupt controller code proper. All the macros are basically
the same (excepting a register size difference on really early parts).
Add support for the 5407.
Signed-off-by: Steven King <sfking@fdwdc.com>
Merge header files for m68k and m68knommu to the single location:
arch/m68k/include/asm
The majority of this patch was the result of the
script that is included in the changelog below.
The script was originally written by Arnd Bergman and
exten by me to cover a few more files.
When the header files differed the script uses the following:
The original m68k file is named <file>_mm.h [mm for memory manager]
The m68knommu file is named <file>_no.h [no for no memory manager]
The files uses the following include guard:
This include gaurd works as the m68knommu toolchain set
the __uClinux__ symbol - so this should work in userspace too.
Merging the header files for m68k and m68knommu exposes the
(unexpected?) ABI differences thus it is easier to actually
identify these and thus to fix them.
The commit has been build tested with both a m68k and
a m68knommu toolchain - with success.
The commit has also been tested with "make headers_check"
and this patch fixes make headers_check for m68knommu.
The script used:
TARGET=arch/m68k/include/asm
SOURCE=arch/m68knommu/include/asm
INCLUDE="cachectl.h errno.h fcntl.h hwtest.h ioctls.h ipcbuf.h \
linkage.h math-emu.h md.h mman.h movs.h msgbuf.h openprom.h \
oplib.h poll.h posix_types.h resource.h rtc.h sembuf.h shmbuf.h \
shm.h shmparam.h socket.h sockios.h spinlock.h statfs.h stat.h \
termbits.h termios.h tlb.h types.h user.h"
EQUAL="auxvec.h cputime.h device.h emergency-restart.h futex.h \
ioctl.h irq_regs.h kdebug.h local.h mutex.h percpu.h \
sections.h topology.h"
NOMUUFILES="anchor.h bootstd.h coldfire.h commproc.h dbg.h \
elia.h flat.h m5206sim.h m520xsim.h m523xsim.h m5249sim.h \
m5272sim.h m527xsim.h m528xsim.h m5307sim.h m532xsim.h \
m5407sim.h m68360_enet.h m68360.h m68360_pram.h m68360_quicc.h \
m68360_regs.h MC68328.h MC68332.h MC68EZ328.h MC68VZ328.h \
mcfcache.h mcfdma.h mcfmbus.h mcfne.h mcfpci.h mcfpit.h \
mcfsim.h mcfsmc.h mcftimer.h mcfuart.h mcfwdebug.h \
nettel.h quicc_simple.h smp.h"
FILES="atomic.h bitops.h bootinfo.h bug.h bugs.h byteorder.h cache.h \
cacheflush.h checksum.h current.h delay.h div64.h \
dma-mapping.h dma.h elf.h entry.h fb.h fpu.h hardirq.h hw_irq.h io.h \
irq.h kmap_types.h machdep.h mc146818rtc.h mmu.h mmu_context.h \
module.h page.h page_offset.h param.h pci.h pgalloc.h \
pgtable.h processor.h ptrace.h scatterlist.h segment.h \
setup.h sigcontext.h siginfo.h signal.h string.h system.h swab.h \
thread_info.h timex.h tlbflush.h traps.h uaccess.h ucontext.h \
unaligned.h unistd.h"
mergefile() {
BASE=${1%.h}
git mv ${SOURCE}/$1 ${TARGET}/${BASE}_no.h
git mv ${TARGET}/$1 ${TARGET}/${BASE}_mm.h
cat << EOF > ${TARGET}/$1
EOF
git add ${TARGET}/$1
set -e
mkdir -p ${TARGET}
git mv include/asm-m68k/* ${TARGET}
rmdir include/asm-m68k
git rm ${SOURCE}/Kbuild
for F in $INCLUDE $EQUAL; do
git rm ${SOURCE}/$F
done
for F in $NOMUUFILES; do
git mv ${SOURCE}/$F ${TARGET}/$F
done
for F in $FILES ; do
mergefile $F
done
rmdir arch/m68knommu/include/asm
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
