git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k/math-emu: Remove unnecessary code
m68k/math-emu: Remove commented out old code
m68k: Kill warning in setup_arch() when compiling for Sun3
m68k/atari: Prefix GPIO_{IN,OUT} with CODEC_
sparc: iounmap() and *_free_coherent() - Use lookup_resource()
m68k/atari: Reserve some ST-RAM early on for device buffer use
m68k/amiga: Chip RAM - Use lookup_resource()
resources: Add lookup_resource()
sparc: _sparc_find_resource() should check for exact matches
m68k/amiga: Chip RAM - Offset resource end by CHIP_PHYSADDR
m68k/amiga: Chip RAM - Use resource_size() to fix off-by-one error
m68k/amiga: Chip RAM - Change chipavail to an atomic_t
m68k/amiga: Chip RAM - Always allocate from the start of memory
m68k/amiga: Chip RAM - Convert from printk() to pr_*()
m68k/amiga: Chip RAM - Use tabs for indentation
arch/m68k/kernel/setup_mm.c: In function ‘setup_arch’:
arch/m68k/kernel/setup_mm.c:219: warning: unused variable ‘i’
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68k: Revive reporting of spurious interrupts
m68knommu: Move forward declaration of do_IRQ() from machdep.h to irq.h
m68k: fix some atomic operation asm address modes for ColdFire
m68k: use CPU_HAS_NO_BITFIELDS for signal functions
m68k: merge and clean up delay.h files
m68knommu: correctly use trap_init
m68knommu: merge ColdFire 5206 and 5206e platform code
m68k: merge mmu and non-mmu bitops.h
m68k: merge MMU and non MMU versions of system.h
m68k: merge MMU and non-MMU versions of asm/hardirq.h
m68k: merge the non-mmu and mmu versions of module.c
m68knommu: Fix printk() format in free_initrd_mem()
m68knommu: Make empty_zero_page "void *", like on m68k
The address limit is already set in flush_old_exec() so those calls to
set_fs(USER_DS) are redundant.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Greg Ungerer <gerg@uclinux.org>
commit 2502b667ea835ee16685c74b2a0d89ba8afe117a ("Change the m68knommu irq
handling to use the generic irq framework.") removed the reporting of spurious
interrupts on nommu (68328 and 68360).
Bring it back in a generic way, using "atomic_t irq_err_count", as that's what
most of the other architectures are using.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
Currently trap_init() is an empty function for m68knommu. Instead
the vectors are being setup as part of the IRQ initialization.
This is inconsistent with m68k and other architectures.
Change the local init_vectors() to be trap_init(), and init the
vectors at the correct time during startup. This will help merge of
m68k and m68knommu trap code in the furture.
The non-mmu and mmu versions of the module loader module.c are
nearly identical. Merge them back to a single module.c. There is
a little bit of re-ordering of the struct and enum definitions in
module.h to keep the ifdefery to a minimum.
This patch removes all the module loader hook implementations in the
architecture specific code where the functionality is the same as that
now provided by the recently added default hooks.
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Michal Simek <monstr@monstr.eu>
Older m68k-linux compilers will include pre-defined symbols that
confuse what processor it is being targeted for. For example gcc-4.1.2
will pre-define __mc68020__ even if you specify the target processor
as -m68000 on the gcc command line. Newer versions of gcc have this
corrected.
In a few places the m68k code uses defined(__mc68020__) for optimizations
that include instructions that are specific to the CPU 68020 and above.
When compiling with older compilers this will be true even when we have
selected to compile for the older 68000 processors.
Switch to using the kernel processor defines, CONFIG_M68020 and friends.
The recent commit titled "module: Sort exported symbols" (f02e8a65)
changed the exported symbol name sections. Bring the m68knommu linker
script into line with those changes - including the sorting of the
symbol names.
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
Apart from whitespace differences, /proc/interrupts doesn't change by
enabling GENERIC_IRQ_SHOW.
There is a lot of common code in the sys_m68k.c files. The mmu and non-mmu
versions can easily be merged into a single file.
There is really only 2 functions that differ in the 2 cases. A single
ifdef on CONFIG_MMU can take care of this. Alternatively we could break
those 2 functions out and maintain sys_m68k_no.c and sys_m68k_mm.c with
just this code in it (Makefile could then just build the right one).
Does anyone have strong feelings on which way they want this done?
It is strait forward to merge the mmu and non-mmu versions of
asm-offstes.c. Some name changes are required for the preempt and
thread_info.flags in the non-mmu entry.S assembler to make them
consistent for both setups.
After cleaning up m68k_ksyms_no.c it is now strait forward to merge
the non-mmu and mmu versions of m68k_ksyms.c. The need for the extra
gcc functions is not strictly based on having an MMU or not. It is
based on the family the processor belongs too, so use an appropriate
conditional check.
There is no reason most of the symbols enclosed in a conditional
on CONFIG_COLDFIRE need to be exported. And they sure don't need to
be doing it in m68k_ksyms_no.c. Move the dma symbols export (which
are currently needed) to the definitions of those, and remove the
rest of the exporting here.
The EXPORT_SYMBOL(kernel_thread) belongs at the definition of that function,
not in some other random code file. So move it there.
The EXPORT_SYMBOL() of the local lib checksum functions belongs with
the definitions, not in some other random code file. So move then there.
The EXPORT_SYMBOL(dump_fpu) belongs at the definition of the function,
The implementation of iounmap() and __ioremap() for non-mmu m68k is
trivial. We can inline them in m68knommu headers and remove the trivial
implementations.
Merging the mmu and non-mmu directories we ended up with duplicate
implementations of memcpy(). One is a little more optimized for the
>= 68020 case, but that can easily be inserted into a single
implementation of memcpy(). Clean up the exporting of this symbol
too, otherwise we end up exporting it twice on a no-mmu build.
implementations of memset(). One is a little more optimized for the
implementation of memset(). Clean up the exporting of this symbol
A new utility function (core_kernel_data()) is used to determine if a
passed in address is part of core kernel data or not. It may or may not
return true for RO data, but this utility must work for RW data.
Thus both _sdata and _edata must be defined and continuous,
without .init sections that may later be freed and replaced by
volatile memory (memory that can be freed).
This utility function is used to determine if data is safe from
ever being freed. Thus it should return true for all RW global
data that is not in a module or has been allocated, or false
otherwise.
Also change core_kernel_data() back to the more precise _sdata condition
and document the function.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Hirokazu Takata <takata@linux-m32r.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: linux-m68k@lists.linux-m68k.org
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Helge Deller <deller@gmx.de>
Cc: JamesE.J.Bottomley <jejb@parisc-linux.org>
Link: http://lkml.kernel.org/r/1305855298.1465.19.camel@gandalf.stny.rr.com
arch/alpha/kernel/vmlinux.lds.S | 1 +
arch/m32r/kernel/vmlinux.lds.S | 1 +
arch/m68k/kernel/vmlinux-std.lds | 2 ++
arch/m68k/kernel/vmlinux-sun3.lds | 1 +
arch/mips/kernel/vmlinux.lds.S | 1 +
arch/parisc/kernel/vmlinux.lds.S | 3 +++
kernel/extable.c | 12 +++++++++++-
7 files changed, 20 insertions(+), 1 deletion(-)
We reserved the numbers a long time ago, but never wired them up in the
syscall table as they need TIF_RESTORE_SIGMASK, which we only got last year
in commit cb6831d5d3099e772a510eb3e1ed0760ccffb45e ("m68k: Switch to saner
sigsuspend()")
Acked-by: Greg Ungerer <gerg@uclinux.org>
Cc: stable@kernel.org
Impact for nommu:
- Store table in .rodata instead of .text,
- Let kernel/sys_ni.c handle the stubbing of MMU-only syscalls,
- Implement sys_mremap and sys_nfsservct,
- Remove unused padding at the end of the table.
Impact for mmu:
- Store table in .rodata instead of .data.
syncfs
Scripted with coccinelle.
There is a lot of common code that could be shared between the m68k
and m68knommu arch branches. It makes sense to merge the two branches
into a single directory structure so that we can more easily share
that common code.
This is a brute force merge, based on a script from Stephen King
<sfking@fdwdc.com>, which was originally written by Arnd Bergmann
<arnd@arndb.de>.
> The script was inspired by the script Sam Ravnborg used to merge the
> includes from m68knommu. For those files common to both arches but
> differing in content, the m68k version of the file is renamed to
> <file>_mm.<ext> and the m68knommu version of the file is moved into the
> corresponding m68k directory and renamed <file>_no.<ext> and a small
> wrapper file <file>.<ext> is used to select between the two version. Files
> that are common to both but don't differ are removed from the m68knommu
> tree and files and directories that are unique to the m68knommu tree are
> moved to the m68k tree. Finally, the arch/m68knommu tree is removed.
> To select between the the versions of the files, the wrapper uses
> #ifdef CONFIG_MMU
> #include <file>_mm.<ext>
> #else
> #include <file>_no.<ext>
> #endif
On top of this file merge I have done a simplistic merge of m68k and
m68knommu Kconfig, which primarily attempts to keep existing options and
menus in place. Other than a handful of options being moved it produces
identical .config outputs on m68k and m68knommu targets I tested it on.
With this in place there is now quite a bit of scope for merge cleanups
in future patches.
m68k/block: amiflop - Remove superfluous amiga_chip_alloc() cast
m68k/atari: ARAnyM - Add support for network access
m68k/atari: ARAnyM - Add support for console access
m68k/atari: ARAnyM - Add support for block access
m68k/atari: Initial ARAnyM support
m68k: Kconfig - Remove unneeded "default n"
m68k: Makefiles - Change to new flags variables
m68k/amiga: Reclaim Chip RAM for PPC exception handlers
m68k: Allow all kernel traps to be handled via exception fixups
m68k: Use base_trap_init() to initialize vectors
m68k: Add helper function handle_kernel_fault()
Add improved support for running under the ARAnyM emulator
(Atari Running on Any Machine - http://aranym.org/).
[michael, geert: Cleanups and updates]
Signed-off-by: Petr Stehlik <pstehlik@sophics.cz>
Signed-off-by: Michael Schmitz <schmitz@debian.org>
This will be needed by the ARAnyM Native Feature initialization code.
Also document that the VEC_TRACE check is needed for 68020/30.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
So basic initialization is all in one place.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Add helper function handle_kernel_fault() in signal.c, so frame_extra_sizes
can become static, and to avoid future code duplication.
xtime_update() properly takes the xtime_lock
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: Sam Creasey <sammy@sammy.net>
Cc: johnstul@us.ibm.com
Cc: hch@infradead.org
Cc: yong.zhang0@gmail.com
LKML-Reference: <20110127150006.23248.71790.stgit@localhost>
If we leave sigreturn via ret_from_signal, we end up with syscall
trace only on entry, leading to very unhappy strace, among other
things. Note that this means different behaviours for signals
delivered while we were in pagefault and for ones delivered while
we were in interrupt...
a) we should hold modifying regs->format until we know we *will* be
doing stack expansion; otherwise attacker can modify sigframe to
have wrong ->sc_formatvec and install SIGSEGV handler.
b) we should *not* mix copying saved extra stuff from userland with
expanding the stack; once we'd done that manual memmove, we'd better
not return to C, so cleanup is very hard to do. The easiest way
is to copy it on stack first, making sure we won't overwrite on stack
expansion. Fortunately that's easy to do...
Same principle as with the previous patch - do not destroy the
state if sigframe setup fails. Incidentally, it's actually
_less_ work - we don't need to go through adjust_stack dance
on failure if we don't touch regs->stkadj until we know we'd
written sigframe out.
If we'd failed in setup_frame(), we've no place to store
the original sigmask. It's not an unrecoverable situation -
we raise SIGSEGV, but that SIGSEGV might be successfully
handled (e.g. on altstack). In that case we really don't
want sa_mask of original signal permanently slapped on
the set of blocked signals.
Standard solution: have setup_frame()/setup_rt_frame()
report failure and don't mess with the signal-related
state if that has happened...
Instead of checking the return value of do_signal() we can just do
the work (raise SIGTRAP and clear SR.T1) directly in handle_signal(),
when setting the sigframe up. Simplifies the assembler glue and is
closer to the way we do it on other targets.
Note that do_delayed_trace does *not* disappear; it's still needed
to deal with single-stepping through syscall, since 68040 doesn't
raise the trace exception at all if the trap exception is pending.
We hit it after returning from sys_...() if TIF_DELAYED_TRACE is
set; all that has changed is that we don't reuse it for "single-step
into the handler" codepath.
As the result, do_signal() doesn't need to return anything anymore.
and saner do_signal() arguments, while we are at it
... and had been such since the introduction of get_signal_to_deliver()
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
Use new 'regno', 'datap' variables in order to remove duplicated
expressions and unnecessary castings.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Fix up the arguments to arch_ptrace() to take account of the fact that
@addr and @data are now unsigned long rather than long as of a preceding
patch in this series.
Cc: <linux-arch@vger.kernel.org>
Acked-by: Roland McGrath <roland@redhat.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (21 commits)
m68knommu: convert to using tracehook_report_syscall_*
m68knommu: some boards use fixed phy for FEC ethernet
m68knommu: support the external GPIO based interrupts of the 5272
m68knommu: mask of vector bits in exception word properly
m68knommu: change to new flag variables
m68knommu: Fix MCFUART_TXFIFOSIZE for m548x.
m68knommu: add basic mmu-less m548x support
m68knommu: .gitignore vmlinux.lds
m68knommu: stop using __do_IRQ
m68knommu: rename PT_OFF_VECTOR to PT_OFF_FORMATVEC.
m68knommu: add support for Coldfire 547x/548x interrupt controller
m68k{nommu}: Remove unused DEFINE's from asm-offsets.c
m68knommu: whitespace cleanup in 68328/entry.S
m68knommu: Document supported chips in intc-2.c and intc-simr.c.
m68knommu: fix strace support for 68328/68360
m68knommu: fix default starting date
arch/m68knommu: Removing dead 68328_SERIAL_UART2 config option
arch/m68knommu: Removing dead RAM_{16,32}_MB config option
arch/m68knommu: Removing dead M68KFPU_EMU config option
arch/m68knommu: Removing dead RELOCATE config option
The cache flush code doesn't need a lock, so we can remove the use of the BKL.
Suggested-by: Andreas Schwab <schwab@linux-m68k.org>
CONFIG_SMP doesn't exist in Kconfig (for this architecure), therefore
remove all references to it from the source.
Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de>
