path: root/arch/m68k
2010-01-12m68knommu: fix definitions of __pa() and __va()Greg Ungerer
Fix compilation breakage of all m68knommu targets: CC arch/m68knommu/kernel/asm-offsets.s In file included from include/linux/sched.h:77, from arch/m68knommu/kernel/asm-offsets.c:12: include/linux/percpu.h: In function 'per_cpu_ptr_to_phys': include/linux/percpu.h:161: error: implicit declaration of function 'virt_to_phy This is broken in linux-2.6.33-rc3. Change the definitions of __pa() and __va() to not use virt_to_phys() and phys_to_virt(). Trivial 1:1 conversion required for the non-MMU case. A side effect if this is that the m68knommu can now use asm/virtconvert.h for the definition of virt_to_phys() and phys_to_virt(). Also cleaned up the definition of page_to_phys() when moving into virtconvert.h. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-12kbuild: move autoconf.h to include/generatedSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move asm-offsets.h to include/generatedSam Ravnborg
The simplest method was to add an extra asm-offsets.h file in arch/$ARCH/include/asm that references the generated file. We can now migrate the architectures one-by-one to reference the generated file direct - and when done we can delete the temporary arch/$ARCH/include/asm/asm-offsets.h file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68knommu: export clk_* symbols in clk.c m68knommu: Split the .init section into INIT_TEXT_SECTION and INIT_DATA_SECTION. m68knommu: Move __init_end out of the .init section. m68knommu: Move __init_begin out of the .init section. m68knommu: Use more macros inside the .init section. m68knommu: Use INIT_TASK_DATA and CACHELINE_ALIGNED_DATA. m68knommu: Make THREAD_SIZE available to assembly files. m68knommu: Don't hardcode the value of PAGE_SIZE in the linker script. m68knommu: rename BSS define in linker script m68knommu: add a task_pt_regs() macro m68knommu: define arch_has_single_step() and friends m68knommu: add uboot commandline argument passing support m68knommu: Coldfire GPIO corrections m68knommu: move mcf_remove to .devexit.text Fixed up (?) conflict in arch/m68k/include/asm/ptrace.h
2009-12-09m68k: rename global variable vmalloc_end to m68k_vmalloc_endTejun Heo
On SUN3, m68k defines macro VMALLOC_END as unsigned long variable vmalloc_end which is adjusted from mmu_emu_init(). This becomes problematic if a local variables vmalloc_end is defined in some function (not very unlikely) and VMALLOC_END is used in the function - the function thinks its referencing the global VMALLOC_END value but would be referencing its own local vmalloc_end variable. Rename the global variable to m68k_vmlloc_end which is much less likely to be used as local variable name. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2009-12-08Merge branch 'for-2.6.33' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block: (113 commits) cfq-iosched: Do not access cfqq after freeing it block: include linux/err.h to use ERR_PTR cfq-iosched: use call_rcu() instead of doing grace period stall on queue exit blkio: Allow CFQ group IO scheduling even when CFQ is a module blkio: Implement dynamic io controlling policy registration blkio: Export some symbols from blkio as its user CFQ can be a module block: Fix io_context leak after failure of clone with CLONE_IO block: Fix io_context leak after clone with CLONE_IO cfq-iosched: make nonrot check logic consistent io controller: quick fix for blk-cgroup and modular CFQ cfq-iosched: move IO controller declerations to a header file cfq-iosched: fix compile problem with !CONFIG_CGROUP blkio: Documentation blkio: Wait on sync-noidle queue even if rq_noidle = 1 blkio: Implement group_isolation tunable blkio: Determine async workload length based on total number of queues blkio: Wait for cfq queue to get backlogged if group is empty blkio: Propagate cgroup weight updation to cfq groups blkio: Drop the reference to queue once the task changes cgroup blkio: Provide some isolation between groups ...
2009-12-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: parport_mfc3 - Not makes it a bool before the comparison. m68k: don't export static inline functions fbdev: atafb - add palette register check m68k: Remove the BKL from sys_execve m68k: Cleanup linker scripts using new linker script macros. m68k: Make thread_info.h usable from assembly. m68knommu: define arch_has_single_step() and friends m68k: ptrace fixes m68k: use generic code for ptrace requests rtc: Add an RTC driver for the Ricoh RP5C01 rtc: Add an RTC driver for the Oki MSM6242
2009-12-06m68k: Remove the BKL from sys_execveJohn Kacur
This seems like a copy-and-paste from code that no-longer needs the BKL Just remove it. Signed-off-by: John Kacur <jkacur@redhat.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-12-06m68k: Cleanup linker scripts using new linker script macros.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Tested-by: Andreas Schwab <schwab@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-12-06m68k: Make thread_info.h usable from assembly.Tim Abbott
[Geert] <asm/thread_info_mm.h> pulls in <asm/current.h>, which contains C only. So the include must be moved inside #ifndef __ASSEMBLY__. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-12-06m68knommu: define arch_has_single_step() and friendsGreg Ungerer
Towards adding CONFIG_UTRACE support for non-mmu m68k add arch_has_single_step, and its support functions user_enable_single_step() and user_disable_single_step(). [Geert] m68k conflict resolution from linux-next Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-12-04m68k: ptrace fixesAndreas Schwab
This fixes the following issues in ptrace: - when single stepping into the signal handler stop at the first insn of the handler - handle non-zero stkadj when accessing pc and sr in ptregs - correctly handle PT_SR in PTRACE_POKEUSR - report -EIO when trying to read unknown offset in PTRACE_PEEKUSR Additionally, the handling of the special case that PT_SR accesses a 16 bit word instead of a 32 bit word has been moved into get_reg/put_reg. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-12-04m68k: use generic code for ptrace requestsAndreas Schwab
Remove all but PTRACE_{PEEK,POKE}USR and PTRACE_{GET,SET}{REGS,FPREGS} from arch_ptrace and let the rest be handled by generic code. Define PTRACE_SINGLEBLOCK to enable singleblock tracing. [Geert] Not yet applicable for m68knommu Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-04m68knommu: Make THREAD_SIZE available to assembly files.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-12-04m68knommu: add a task_pt_regs() macroGreg Ungerer
Add a task_pt_regs() macro as per the CONFIG_UTRACE requirements. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-12-04m68knommu: define arch_has_single_step() and friendsGreg Ungerer
Towards adding CONFIG_UTRACE support for non-mmu m68k add arch_has_single_step, and its support functions user_enable_single_step() and user_disable_single_step(). Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-11-26block: add helpers to run flush_dcache_page() against a bio and a request's ↵Ilya Loginov
pages Mtdblock driver doesn't call flush_dcache_page for pages in request. So, this causes problems on architectures where the icache doesn't fill from the dcache or with dcache aliases. The patch fixes this. The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid pointless empty cache-thrashing loops on architectures for which flush_dcache_page() is a no-op. Every architecture was provided with this flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is equal 1 or do nothing otherwise. See "fix mtd_blkdevs problem with caches on some architectures" discussion on LKML for more information. Signed-off-by: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Peter Horton <phorton@bitbox.co.uk> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-10-30tty: Mark generic_serial users as BROKENAlan Cox
There isn't much else I can do with these. I can find no hardware for any of them and no users. The code is broken. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-01revert "m68k: convert to asm-generic/hardirq.h"Andrew Morton
Revert 45d80eea87c9f8292d2d33173d6866c0ec57238a ("m68k: convert to asm-generic/hardirq.h") - it fails to compile due to an inclusion tangle: In file included from include/linux/irq.h:12, from include/asm-generic/hardirq.h:6, from /usr/src/devel/arch/m68k/include/asm/hardirq_mm.h:6, from /usr/src/devel/arch/m68k/include/asm/hardirq.h:4, from include/linux/hardirq.h:10, from /usr/src/devel/arch/m68k/include/asm/system_mm.h:69, from /usr/src/devel/arch/m68k/include/asm/system.h:4, from include/linux/list.h:7, from include/linux/preempt.h:11, from include/linux/spinlock.h:50, from include/linux/seqlock.h:29, from include/linux/time.h:8, from include/linux/timex.h:56, from include/linux/sched.h:56, from arch/m68k/kernel/asm-offsets.c:14: include/linux/smp.h:17: error: field 'list' has incomplete type Cc: Christoph Hellwig <hch@lst.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-22m68k: convert to asm-generic/hardirq.hChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22m68k: convert to use arch_gettimeoffset()john stultz
Convert m68k to use GENERIC_TIME via the arch_getoffset() infrastructure, reducing the amount of arch specific code we need to maintain. I've taken my best swing at converting this, but I'm not 100% confident I got it right. My cross-compiler is now out of date (gcc4.2) so I wasn't able to check if it compiled. Any assistance from arch maintainers or testers to get this merged would be great. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: remove duplicate asm/mman.h filesArnd Bergmann
A number of architectures have identical asm/mman.h files so they can all be merged by using the new generic file. The remaining asm/mman.h files are substantially different from each other. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: add MAP_HUGETLB for mmaping pseudo-anonymous huge page regionsArnd Bergmann
Add a flag for mmap that will be used to request a huge page region that will look like anonymous memory to user space. This is accomplished by using a file on the internal vfsmount. MAP_HUGETLB is a modifier of MAP_ANONYMOUS and so must be specified with it. The region will behave the same as a MAP_ANONYMOUS region using small pages. The patch also adds the MAP_STACK flag, which was previously defined only on some architectures but not on others. Since MAP_STACK is meant to be a hint only, architectures can define it without assigning a specific meaning to it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: David Rientjes <rientjes@google.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22arches: drop superfluous casts in nr_free_pages() callersGeert Uytterhoeven
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()") modified nr_free_pages() to return 'unsigned long' instead of 'unsigned int'. This made the casts to 'unsigned long' in most callers superfluous, so remove them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <zankel@tensilica.com> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20kbuild: use INSTALLKERNEL to select customized installkernel scriptSam Ravnborg
Replace the use of CROSS_COMPILE to select a customized installkernel script with the possibility to set INSTALLKERNEL to select a custom installkernel script when running make: make INSTALLKERNEL=arm-installkernel install With this patch we are now more consistent across different architectures - they did not all support use of CROSS_COMPILE. The use of CROSS_COMPILE was a hack as this really belongs to gcc/binutils and the installkernel script does not change just because we change toolchain. The use of CROSS_COMPILE caused troubles with an upcoming patch that saves CROSS_COMPILE when a kernel is built - it would no longer be installable. [Thanks to Peter Z. for this hint] This patch undos what Ian did in commit: 0f8e2d62fa04441cd12c08ce521e84e5bd3f8a46 ("use ${CROSS_COMPILE}installkernel in arch/*/boot/install.sh") The patch has been lightly tested on x86 only - but all changes looks obvious. Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Russell King <linux@arm.linux.org.uk> [arm] Acked-by: Paul Mundt <lethal@linux-sh.org> [sh] Acked-by: "H. Peter Anvin" <hpa@zytor.com> [x86] Cc: Ian Campbell <icampbell@arcom.com> Cc: Tony Luck <tony.luck@intel.com> [ia64] Cc: Fenghua Yu <fenghua.yu@intel.com> [ia64] Cc: Hirokazu Takata <takata@linux-m32r.org> [m32r] Cc: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Cc: Kyle McMartin <kyle@mcmartin.ca> [parisc] Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc] Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Cc: Thomas Gleixner <tglx@linutronix.de> [x86] Cc: Ingo Molnar <mingo@redhat.com> [x86] Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (53 commits) m68knommu: Make PAGE_SIZE available to assembly files. m68knommu: fix ColdFire definition of CLOCK_TICK_RATE m68knommu: set multi-function pins for ethernet when enabled m68knommu: remove special interrupt handling code for ne2k support m68knommu: relax IO_SPACE_LIMIT setting m68knommu: remove ColdFire direct interrupt register access m68knommu: create a speciailized ColdFire 5272 interrupt controller m68knommu: add support for second interrupt controller of ColdFire 5249 m68knommu: clean up old ColdFire timer irq setup m68knommu: map ColdFire interrupts to correct masking bits m68knommu: clean up ColdFire 532x CPU timer setup m68knommu: simplify ColdFire "timers" clock initialization m68knommu: support code to mask external interrupts on old ColdFire CPU's m68knommu: merge old ColdFire interrupt controller masking macros m68knommu: remove duplicate ColdFire mcf_autovector() code m68knommu: move ColdFire INTC definitions to new include file m68knommu: mask off all interrupts in ColdFire intc-simr controller m68knommu: remove timer device interrupt setup for ColdFire 532x m68knommu: remove interrupt masking from ColdFire pit timer m68knommu: remove unecessary interrupt level setting in ColdFire 520x setup ...
2009-09-16m68knommu: Make PAGE_SIZE available to assembly files.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: fix ColdFire definition of CLOCK_TICK_RATEPhilippe De Muyter
The good definition of CLOCK_TICK_RATE for coldfires has been lost in the merge of m68k and m68knommu include files. Restore it. Culprit : commit ebafc17468d58bd903c886175ca84a4edc69ae1d Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: remove special interrupt handling code for ne2k supportGreg Ungerer
The improved interrupt support for ColdFire CPU cores means we no longer need all the interrupt setup and ack hacks to support the NE2000 driver on ColdFire platforms. Remove all that code. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: relax IO_SPACE_LIMIT settingGreg Ungerer
There is really no limit to the addresses which can be used by the in*() and out*() family of IO space calls in m68k non-MMU environments. So don't impose an artificial address limit, allow the full 32bit range. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: create a speciailized ColdFire 5272 interrupt controllerGreg Ungerer
The ColdFire 5272 CPU has a very different interrupt controller than any of the other ColdFire parts. It needs its own controller code to correctly setup and ack interrupts. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: add support for second interrupt controller of ColdFire 5249Greg Ungerer
The ColdFire 5249 CPU has a second (compleletly different) interrupt controller. It is the only ColdFire CPU that has this type. It controlls GPIO interrupts amongst a number of interrupts from other internal peripherals. Add support code for it. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: map ColdFire interrupts to correct masking bitsGreg Ungerer
The older simple ColdFire interrupt controller has no one-to-one mapping of interrupt numbers to bits in the interrupt mask register. Create a mapping array that each ColdFire CPU type can populate with its available interrupts and the bits that each use in the interrupt mask register. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: clean up ColdFire 532x CPU timer setupGreg Ungerer
The newer ColdFire 532x family of CPU's uses the old timer, but has a newer interrupt controller. It doesn't need the special timer setup that was required when using the older interrupt controller. Remove the dead timer irq and level setting code, and define the hard coded vector. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: simplify ColdFire "timers" clock initializationGreg Ungerer
The ColdFire "timers" clock setup can be simplified. There is really no need for the flexible per-platform setup code. The clock interrupt can be hard defined per CPU platform (in CPU include files). This makes the actual timer code simpler. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: merge old ColdFire interrupt controller masking macrosGreg Ungerer
Currently the code that supports setting the old style ColdFire interrupt controller mask registers is macros in the include files of each of the CPU types. Merge all these into a set of real masking functions in the old Coldfire interrupt controller code proper. All the macros are basically the same (excepting a register size difference on really early parts). Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: move ColdFire INTC definitions to new include fileGreg Ungerer
Create an mcfintc.h include file with the definitions for the old style ColdFire interrupt controller. They are only needed on CPU's that use this old controller - so isolate them on their own. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: mask off all interrupts in ColdFire intc-simr controllerGreg Ungerer
The ColdFire intc-simr interrupt controller should mask off all interrupt sources at init time. Doing it here instead of separately in each platform setup. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
