The coldfire timer must be initialised to n - 1 if we want it to count n
cycles between each tick interrupt. This was already fixed, but has been
lost with the conversion to GENERIC_TIMER.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Acked-by: Greg Ungerer <gerg@snapgear.com>
I was looking at timers in the Coldfire system and I noticed that the
CONFIG_HIGHPROFILE option seems to be a little out of date.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
Switch the ColdFire TIMER timer to use GENERIC_TIME.
Move common ColdFire CPU timers.c to common coldfire platform directory.
Currently the common ColdFire CPU family code sits in the
arch/m68knommu/platform/5307 directory. This is confusing, the files
containing this common code are in no way specific to the 5307 ColdFire.
Create an arch/m68knommu/platform/coldfire directory to contain this
common code. Other m68knommu CPU varients do not need use this code
though, so it doesn't make sense to move it to arch/m68knommu/kernel.
