path: root/arch/m68knommu
2010-01-18untangle the do_mremap() messAl Viro
This backports the following upstream commits all as one patch: 54f5de709984bae0d31d823ff03de755f9dcac54 ecc1a8993751de4e82eb18640d631dae1f626bd6 1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f f106af4e90eadd76cfc0b5325f659619e08fb762 097eed103862f9c6a97f2e415e21d1134017b135 935874141df839c706cd6cdc438e85eb69d1525e 0ec62d290912bb4b989be7563851bc364ec73b56 c4caa778157dbbf04116f0ac2111e389b5cd7a29 2ea1d13f64efdf49319e86c87d9ba38c30902782 570dcf2c15463842e384eb597a87c1e39bead99b 564b3bffc619dcbdd160de597b0547a7017ea010 0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301 f8b7256096a20436f6d0926747e3ac3d64c81d24 8c7b49b3ecd48923eb64ff57e07a1cdb74782970 9206de95b1ea68357996ec02be5db0638a0de2c1 2c6a10161d0b5fc047b5bd81b03693b9af99fab5 05d72faa6d13c9d857478a5d35c85db9adada685 bb52d6694002b9d632bb355f64daa045c6293a4e e77414e0aad6a1b063ba5e5750c582c75327ea6a aa65607373a4daf2010e8c3867b6317619f3c1a3 Backport done by Greg Kroah-Hartman. Only minor tweaks were needed. Cc: David S. Miller <davem@davemloft.net> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-30m68knommu: fix rename of pt_regs offset defines breakageGreg Ungerer
Commit f159ee782990aacb5494738c98f13a2aa61dbb4a ("locking, m68k/asm-offsets: Rename pt_regs offset defines") breaks the m68knommu entry code that relies on these define names. Fix the files to match the new define names. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-30m68knommu: remove duplicated #includeHuang Weiyi
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-30m68knommu: show KiB rather than pages in "Freeing initrd memory:" messageLennart Sorensen
Fix "Freeing initrd memory:" message m68knommu to show kilobytes as claimed rather than number of pages. Signed-off-by: Lennart Sorensen <lsorense@csclub.uwaterloo.ca> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-18Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (34 commits) time: Prevent 32 bit overflow with set_normalized_timespec() clocksource: Delay clocksource down rating to late boot clocksource: clocksource_select must be called with mutex locked clocksource: Resolve cpu hotplug dead lock with TSC unstable, fix crash timers: Drop a function prototype clocksource: Resolve cpu hotplug dead lock with TSC unstable timer.c: Fix S/390 comments timekeeping: Fix invalid getboottime() value timekeeping: Fix up read_persistent_clock() breakage on sh timekeeping: Increase granularity of read_persistent_clock(), build fix time: Introduce CLOCK_REALTIME_COARSE x86: Do not unregister PIT clocksource on PIT oneshot setup/shutdown clocksource: Avoid clocksource watchdog circular locking dependency clocksource: Protect the watchdog rating changes with clocksource_mutex clocksource: Call clocksource_change_rating() outside of watchdog_lock timekeeping: Introduce read_boot_clock timekeeping: Increase granularity of read_persistent_clock() timekeeping: Update clocksource with stop_machine timekeeping: Add timekeeper read_clock helper functions timekeeping: Move NTP adjusted clock multiplier to struct timekeeper ... Fix trivial conflict due to MIPS lemote -> loongson renaming.
2009-09-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (53 commits) m68knommu: Make PAGE_SIZE available to assembly files. m68knommu: fix ColdFire definition of CLOCK_TICK_RATE m68knommu: set multi-function pins for ethernet when enabled m68knommu: remove special interrupt handling code for ne2k support m68knommu: relax IO_SPACE_LIMIT setting m68knommu: remove ColdFire direct interrupt register access m68knommu: create a speciailized ColdFire 5272 interrupt controller m68knommu: add support for second interrupt controller of ColdFire 5249 m68knommu: clean up old ColdFire timer irq setup m68knommu: map ColdFire interrupts to correct masking bits m68knommu: clean up ColdFire 532x CPU timer setup m68knommu: simplify ColdFire "timers" clock initialization m68knommu: support code to mask external interrupts on old ColdFire CPU's m68knommu: merge old ColdFire interrupt controller masking macros m68knommu: remove duplicate ColdFire mcf_autovector() code m68knommu: move ColdFire INTC definitions to new include file m68knommu: mask off all interrupts in ColdFire intc-simr controller m68knommu: remove timer device interrupt setup for ColdFire 532x m68knommu: remove interrupt masking from ColdFire pit timer m68knommu: remove unecessary interrupt level setting in ColdFire 520x setup ...
2009-09-16m68knommu: set multi-function pins for ethernet when enabledGreg Ungerer
The ethernet pins on the 532x ColdFire CPU family are multi-function pins. We need to enable them as ethernet pins when using the FEC ethernet driver. Bug report, and older patch, from timothee@manaud.net. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: remove ColdFire direct interrupt register accessGreg Ungerer
Now that the ColdFire 5272 has full interrupt controller functionality we can remove all the interrupt masking and acking code from the FEC ethernet driver. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: create a speciailized ColdFire 5272 interrupt controllerGreg Ungerer
The ColdFire 5272 CPU has a very different interrupt controller than any of the other ColdFire parts. It needs its own controller code to correctly setup and ack interrupts. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: add support for second interrupt controller of ColdFire 5249Greg Ungerer
The ColdFire 5249 CPU has a second (compleletly different) interrupt controller. It is the only ColdFire CPU that has this type. It controlls GPIO interrupts amongst a number of interrupts from other internal peripherals. Add support code for it. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: clean up old ColdFire timer irq setupGreg Ungerer
The recent changes to the old ColdFire interrupt controller code means we no longer need to manually unmask the timer interrupt. That is now done in the interrupt controller code proper. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: map ColdFire interrupts to correct masking bitsGreg Ungerer
The older simple ColdFire interrupt controller has no one-to-one mapping of interrupt numbers to bits in the interrupt mask register. Create a mapping array that each ColdFire CPU type can populate with its available interrupts and the bits that each use in the interrupt mask register. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: clean up ColdFire 532x CPU timer setupGreg Ungerer
The newer ColdFire 532x family of CPU's uses the old timer, but has a newer interrupt controller. It doesn't need the special timer setup that was required when using the older interrupt controller. Remove the dead timer irq and level setting code, and define the hard coded vector. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: simplify ColdFire "timers" clock initializationGreg Ungerer
The ColdFire "timers" clock setup can be simplified. There is really no need for the flexible per-platform setup code. The clock interrupt can be hard defined per CPU platform (in CPU include files). This makes the actual timer code simpler. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: support code to mask external interrupts on old ColdFire CPU'sGreg Ungerer
The external interrupts used on the old Coldfire parts with the old style interrupt controller can be properly mask/unmasked in the interrupt handling code. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: merge old ColdFire interrupt controller masking macrosGreg Ungerer
Currently the code that supports setting the old style ColdFire interrupt controller mask registers is macros in the include files of each of the CPU types. Merge all these into a set of real masking functions in the old Coldfire interrupt controller code proper. All the macros are basically the same (excepting a register size difference on really early parts). Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: remove duplicate ColdFire mcf_autovector() codeGreg Ungerer
Each of the ColdFire CPU platform code that used the old style interrupt controller had its own copy of the mcf_autovector() function. They are all the same, remove them all and create a single function in the common coldfire/intc.c code. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: mask off all interrupts in ColdFire intc-simr controllerGreg Ungerer
The ColdFire intc-simr interrupt controller should mask off all interrupt sources at init time. Doing it here instead of separately in each platform setup. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: remove timer device interrupt setup for ColdFire 532xGreg Ungerer
With fully implemented interrupt controller code we don't need to do the custom interrupt setup for the timer device of the ColdFire 532x. Remove that code. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: remove interrupt masking from ColdFire pit timerGreg Ungerer
With proper interrupt controller code in place there is no need for devices like the timers to have custom interrupt masking code. Remove it (and the defines that go along with it). Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: remove unecessary interrupt level setting in ColdFire 520x setupGreg Ungerer
The new code for the interrupt controller in the ColdFire 520x takes care of all the interrupt controller setup. No manual config of the level registers (ICR) is required by the platform device setup code. So remove it. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: remove the common interrupt controller structureGreg Ungerer
Each different m68knommu CPU interrupt controller type has its own interrupt controller data structures now. Remove the old, and now not used, common irq structs and init code from here. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: complete interrupt controller code for the 68360 CPUGreg Ungerer
Define the interrupt controller structures along with the interrupt controller code for the 68360 CPU. This brings the interrupt setup and control into one place for this CPU family. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: complete interrupt controller code for the 68328 CPU'sGreg Ungerer
Define the interrupt controller structures along with the interrupt controller code for the 68328 CPU family. This brings the interrupt setup and control into one place for this CPU family. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: use common interrupt controller code for older ColdFire CPU'sGreg Ungerer
The old ColdFire CPU's (5206, 5307, 5407, 5249 etc) use a simple interrupt controller. Use common setup code for them. This addition means that all ColdFire CPU's now have some specific type of interrupt controller code. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: clean up ColdFire 532x interrupt setupGreg Ungerer
With the common intc-simr interrupt controller code in place the ColdFire 532x family startup code can be greatly simplified. Remove all the interrupt masking code, and the per-device interrupt config here. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: general interrupt controller for ColdFire 532x partsGreg Ungerer
The ColdFire 532x family of parts uses 2 of the same INTC interrupt controlers used in the ColdFire 520x family. So modify the code to support both parts. The extra code for the second INTC controler in the case of the 520x is easily optimized away to nothing. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: clean up ColdFire 523x interrupt setupGreg Ungerer
With the common intc-2 interrupt controller code in place the ColdFire 523x family startup code can be greatly simplified. Remove all the interrupt masking code, and the per-device interrupt config here. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: clean up ColdFire 528x interrupt setupGreg Ungerer
With the common intc-2 interrupt controller code in place the ColdFire 528x family startup code can be greatly simplified. Remove all the interrupt masking code, and the per-device interrupt config here. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: clean up ColdFire 527x interrupt setupGreg Ungerer
With the common intc-2 interrupt controller code in place the ColdFire 527x family startup code can be greatly simplified. Remove all the interrupt masking code, and the per-device interrupt config here. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: general interrupt controller for ColdFire many 52xx partsGreg Ungerer
Create general interrupt controller code for the many ColdFire version 2 cores that use the two region INTC interrupt controller. This includes the 523x family, 5270, 5271, 5274, 5275, and the 528x families. This code does proper masking and unmasking of interrupts. With this in place some of the driver hacks in place to support ColdFire interrupts can finally go away. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: remove per device interrupt mask setting for ColdFire 520xGreg Ungerer
With general interrupt controller code in place we don't need specific unmasking code for the internal ColdFire 520x UARTs or ethernet (FEC). Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: use general interrupt controller for ColdFire 520x familyGreg Ungerer
Create general interrupt controller code for the ColdFire 520x family, that does proper masking and unmasking of interrupts. With this in place some of the driver hacks in place to support ColdFire interrupts can finally go away. Within the ColdFire family there is a variety of different interrupt controllers in use. Some are used on multiple parts, some on only one. There is quite some differences in some varients, so much so that common code for all ColdFire parts would be impossible. This commit introduces code to support one of the newer interrupt controllers in the ColdFire 5208 and 5207 parts. It has very simple mask and unmask operations, so is one of the easiest to support. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68k: merge the mmu and non-mmu versions of checksum.hGreg Ungerer
The mmu and non-mmu versions of checksum.h are mostly the same, merge them. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16m68knommu: convert to asm-generic/hardirq.hChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-16arch/m68knommu/kernel/time.c: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-10generic GPIO support for the Freescale Coldfire 5407.sfking@fdwdc.com
Add support for the 5407. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-10generic GPIO support for the Freescale Coldfire 532x.sfking@fdwdc.com
Add support for the 532x. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-10generic GPIO support for the Freescale Coldfire 5307.sfking@fdwdc.com
Add support for the 5307. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-10generic GPIO support for the Freescale Coldfire 528x.sfking@fdwdc.com
Add support for the 528x. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-10generic GPIO support for the Freescale Coldfire 5272.sfking@fdwdc.com
Add support for the 5272. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-10generic GPIO support for the Freescale Coldfire 527x.sfking@fdwdc.com
Add support for the 5271 & 5275. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-10generic GPIO support for the Freescale Coldfire 5249.sfking@fdwdc.com
Add support for the 5249. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-10generic GPIO support for the Freescale Coldfire 523x.sfking@fdwdc.com
Add support for the 523x. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-09-10generic GPIO support for the Freescale Coldfire 520x.sfking@fdwdc.com
Add support for the 520x. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
