path: root/arch/metag
2018-02-13.gitignore: move *.dtb and *.dtb.S patterns to the top-level .gitignoreMasahiro Yamada
commit 10b62a2f785ab55857380f0c63d9fa468fd8c676 upstream. Most of DT files are compiled under arch/*/boot/dts/, but we have some other directories, like drivers/of/unittest-data/. We often miss to add gitignore patterns per directory. Since there are no source files that end with .dtb or .dtb.S, we can ignore the patterns globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02License cleanup: add SPDX license identifier to uapi header files with a licenseGreg Kroah-Hartman
Many user space API headers have licensing information, which is either incomplete, badly formatted or just a shorthand for referring to the license under which the file is supposed to be. This makes it hard for compliance tools to determine the correct license. Update these files with an SPDX license identifier. The identifier was chosen based on the license information in the file. GPL/LGPL licensed headers get the matching GPL/LGPL SPDX license identifier with the added 'WITH Linux-syscall-note' exception, which is the officially assigned exception identifier for the kernel syscall exception: NOTE! This copyright does *not* cover user programs that use kernel services by normal system calls - this is merely considered normal use of the kernel, and does *not* fall under the heading of "derived work". This exception makes it possible to include GPL headers into non GPL code, without confusing license compliance tools. Headers which have either explicit dual licensing or are just licensed under a non GPL license are updated with the corresponding SPDX identifier and the GPLv2 with syscall exception identifier. The format is: ((GPL-2.0 WITH Linux-syscall-note) OR SPDX-ID-OF-OTHER-LICENSE) SPDX license identifiers are a legally binding shorthand, which can be used instead of the full boiler plate text. The update does not remove existing license information as this has to be done on a case by case basis and the copyright holders might have to be consulted. This will happen in a separate step. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. See the previous patch in this series for the methodology of how this patch was researched. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02License cleanup: add SPDX license identifier to uapi header files with no ↵Greg Kroah-Hartman
license Many user space API headers are missing licensing information, which makes it hard for compliance tools to determine the correct license. By default are files without license information under the default license of the kernel, which is GPLV2. Marking them GPLV2 would exclude them from being included in non GPLV2 code, which is obviously not intended. The user space API headers fall under the syscall exception which is in the kernels COPYING file: NOTE! This copyright does *not* cover user programs that use kernel services by normal system calls - this is merely considered normal use of the kernel, and does *not* fall under the heading of "derived work". otherwise syscall usage would not be possible. Update the files which contain no license information with an SPDX license identifier. The chosen identifier is 'GPL-2.0 WITH Linux-syscall-note' which is the officially assigned identifier for the Linux syscall exception. SPDX license identifiers are a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. See the previous patch in this series for the methodology of how this patch was researched. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-22arch: remove unused *_segments() macros/functionsTobias Klauser
Some architectures define the no-op macros/functions copy_segments, release_segments and forget_segments. These are used nowhere in the tree, so removed them. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Vineet Gupta <vgupta@synopsys.com> [for arch/arc] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-12Merge tag 'dma-mapping-4.14' of git://git.infradead.org/users/hch/dma-mappingLinus Torvalds
Pull dma-mapping updates from Christoph Hellwig: - removal of the old dma_alloc_noncoherent interface - remove unused flags to dma_declare_coherent_memory - restrict OF DMA configuration to specific physical busses - use the iommu mailing list for dma-mapping questions and patches * tag 'dma-mapping-4.14' of git://git.infradead.org/users/hch/dma-mapping: dma-coherent: fix dma_declare_coherent_memory() logic error ARM: imx: mx31moboard: Remove unused 'dma' variable dma-coherent: remove an unused variable MAINTAINERS: use the iommu list for the dma-mapping subsystem dma-coherent: remove the DMA_MEMORY_MAP and DMA_MEMORY_IO flags dma-coherent: remove the DMA_MEMORY_INCLUDES_CHILDREN flag of: restrict DMA configuration dma-mapping: remove dma_alloc_noncoherent and dma_free_noncoherent i825xx: switch to switch to dma_alloc_attrs au1000_eth: switch to dma_alloc_attrs sgiseeq: switch to dma_alloc_attrs dma-mapping: reduce dma_mapping_error inline bloat
2017-09-06metag/numa: remove the unused parent_node() macroDou Liyang
Commit a7be6e5a7f8d ("mm: drop useless local parameters of __register_one_node()") removes the last user of parent_node(). The parent_node() macro in METAG architecture is unnecessary. Remove it for cleanup. Link: http://lkml.kernel.org/r/1501076076-1974-4-git-send-email-douly.fnst@cn.fujitsu.com Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com> Reported-by: Michael Ellerman <mpe@ellerman.id.au> Cc: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-04Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "The interrupt subsystem delivers this time: - Refactoring of the GIC-V3 driver to prepare for the GIC-V4 support - Initial GIC-V4 support - Consolidation of the FSL MSI support - Utilize the effective affinity interface in various ARM irqchip drivers - Yet another interrupt chip driver (UniPhier AIDET) - Bulk conversion of the irq chip driver to use %pOF - The usual small fixes and improvements all over the place" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (77 commits) irqchip/ls-scfg-msi: Add MSI affinity support irqchip/ls-scfg-msi: Add LS1043a v1.1 MSI support irqchip/ls-scfg-msi: Add LS1046a MSI support arm64: dts: ls1046a: Add MSI dts node arm64: dts: ls1043a: Share all MSIs arm: dts: ls1021a: Share all MSIs arm64: dts: ls1043a: Fix typo of MSI compatible string arm: dts: ls1021a: Fix typo of MSI compatible string irqchip/ls-scfg-msi: Fix typo of MSI compatible strings irqchip/irq-bcm7120-l2: Use correct I/O accessors for irq_fwd_mask irqchip/mmp: Make mmp_intc_conf const irqchip/gic: Make irq_chip const irqchip/gic-v3: Advertise GICv4 support to KVM irqchip/gic-v4: Enable low-level GICv4 operations irqchip/gic-v4: Add some basic documentation irqchip/gic-v4: Add VLPI configuration interface irqchip/gic-v4: Add VPE command interface irqchip/gic-v4: Add per-VM VPE domain creation irqchip/gic-v3-its: Set implementation defined bit to enable VLPIs irqchip/gic-v3-its: Allow doorbell interrupts to be injected/cleared ...
2017-09-04Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: - Add 'cross-release' support to lockdep, which allows APIs like completions, where it's not the 'owner' who releases the lock, to be tracked. It's all activated automatically under CONFIG_PROVE_LOCKING=y. - Clean up (restructure) the x86 atomics op implementation to be more readable, in preparation of KASAN annotations. (Dmitry Vyukov) - Fix static keys (Paolo Bonzini) - Add killable versions of down_read() et al (Kirill Tkhai) - Rework and fix jump_label locking (Marc Zyngier, Paolo Bonzini) - Rework (and fix) tlb_flush_pending() barriers (Peter Zijlstra) - Remove smp_mb__before_spinlock() and convert its usages, introduce smp_mb__after_spinlock() (Peter Zijlstra) * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits) locking/lockdep/selftests: Fix mixed read-write ABBA tests sched/completion: Avoid unnecessary stack allocation for COMPLETION_INITIALIZER_ONSTACK() acpi/nfit: Fix COMPLETION_INITIALIZER_ONSTACK() abuse locking/pvqspinlock: Relax cmpxchg's to improve performance on some architectures smp: Avoid using two cache lines for struct call_single_data locking/lockdep: Untangle xhlock history save/restore from task independence locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time being futex: Remove duplicated code and fix undefined behaviour Documentation/locking/atomic: Finish the document... locking/lockdep: Fix workqueue crossrelease annotation workqueue/lockdep: 'Fix' flush_work() annotation locking/lockdep/selftests: Add mixed read-write ABBA tests mm, locking/barriers: Clarify tlb_flush_pending() barriers locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETIONS truly non-interactive locking/lockdep: Explicitly initialize wq_barrier::done::map locking/lockdep: Rename CONFIG_LOCKDEP_COMPLETE to CONFIG_LOCKDEP_COMPLETIONS locking/lockdep: Reword title of LOCKDEP_CROSSRELEASE config locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE part of CONFIG_PROVE_LOCKING locking/refcounts, x86/asm: Implement fast refcount overflow protection locking/lockdep: Fix the rollback and overwrite detection logic in crossrelease ...
2017-08-29dma-mapping: remove dma_alloc_noncoherent and dma_free_noncoherentChristoph Hellwig
No users left, everyone switched to the _attrs versions. Signed-off-by: Christoph Hellwig <hch@lst.de>
2017-08-18irqchip/metag-ext: Report that effective affinity is a single targetMarc Zyngier
The metag-ext driver only targets a single CPU at a time, even if the notional affinity is wider. Let's inform the core code about this. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Lunn <andrew@lunn.ch> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Chris Zankel <chris@zankel.net> Cc: Kevin Cernekee <cernekee@gmail.com> Cc: Wei Xu <xuwei5@hisilicon.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Gregory Clement <gregory.clement@free-electrons.com> Cc: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: http://lkml.kernel.org/r/20170818083925.10108-10-marc.zyngier@arm.com
2017-08-17arch: Remove spin_unlock_wait() arch-specific definitionsPaul E. McKenney
There is no agreed-upon definition of spin_unlock_wait()'s semantics, and it appears that all callers could do just as well with a lock/unlock pair. This commit therefore removes the underlying arch-specific arch_spin_unlock_wait() for all architectures providing them. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: <linux-arch@vger.kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Andrea Parri <parri.andrea@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Boqun Feng <boqun.feng@gmail.com>
2017-08-10locking/atomic: Fix atomic_set_release() for 'funny' architecturesPeter Zijlstra
Those architectures that have a special atomic_set implementation also need a special atomic_set_release(), because for the very same reason WRITE_ONCE() is broken for them, smp_store_release() is too. The vast majority is architectures that have spinlock hash based atomic implementation except hexagon which seems to have a hardware 'feature'. The spinlock based atomics should be SC, that is, none of them appear to place extra barriers in atomic_cmpxchg() or any of the other SC atomic primitives and therefore seem to rely on their spinlock implementation being SC (I did not fully validate all that). Therefore, the normal atomic_set() is SC and can be used at atomic_set_release(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile] Cc: Boqun Feng <boqun.feng@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: davem@davemloft.net Cc: james.hogan@imgtec.com Cc: jejb@parisc-linux.org Cc: rkuo@codeaurora.org Cc: vgupta@synopsys.com Link: http://lkml.kernel.org/r/20170609110506.yod47flaav3wgoj5@hirez.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-10metag: move generic-y of exported headers to uapi/asm/KbuildMasahiro Yamada
Since commit fcc8487d477a ("uapi: export all headers under uapi directories"), all (and only) headers under uapi directories are exported, but asm-generic wrappers are still exceptions. To complete de-coupling the uapi from kernel headers, move generic-y of exported headers to uapi/asm/Kbuild. With this change, "make headers_install" will just need to parse uapi/asm/Kbuild to build up exported headers. Also, move "generic-y += kprobes.h" up in order to keep the entries sorted. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-07-06Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc updates from Andrew Morton: - a few hotfixes - various misc updates - ocfs2 updates - most of MM * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (108 commits) mm, memory_hotplug: move movable_node to the hotplug proper mm, memory_hotplug: drop CONFIG_MOVABLE_NODE mm, memory_hotplug: drop artificial restriction on online/offline mm: memcontrol: account slab stats per lruvec mm: memcontrol: per-lruvec stats infrastructure mm: memcontrol: use generic mod_memcg_page_state for kmem pages mm: memcontrol: use the node-native slab memory counters mm: vmstat: move slab statistics from zone to node counters mm/zswap.c: delete an error message for a failed memory allocation in zswap_dstmem_prepare() mm/zswap.c: improve a size determination in zswap_frontswap_init() mm/zswap.c: delete an error message for a failed memory allocation in zswap_pool_create() mm/swapfile.c: sort swap entries before free mm/oom_kill: count global and memory cgroup oom kills mm: per-cgroup memory reclaim stats mm: kmemleak: treat vm_struct as alternative reference to vmalloc'ed objects mm: kmemleak: factor object reference updating out of scan_block() mm: kmemleak: slightly reduce the size of some structures on 64-bit architectures mm, mempolicy: don't check cpuset seqlock where it doesn't matter mm, cpuset: always use seqlock when changing task's nodemask mm, mempolicy: simplify rebinding mempolicies when updating cpusets ...
2017-07-06Merge branch 'uaccess.strlen' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull user access str* updates from Al Viro: "uaccess str...() dead code removal" * 'uaccess.strlen' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: s390 keyboard.c: don't open-code strndup_user() mips: get rid of unused __strnlen_user() get rid of unused __strncpy_from_user() instances kill strlen_user()
2017-07-06mm/hugetlb: add size parameter to huge_pte_offset()Punit Agrawal
A poisoned or migrated hugepage is stored as a swap entry in the page tables. On architectures that support hugepages consisting of contiguous page table entries (such as on arm64) this leads to ambiguity in determining the page table entry to return in huge_pte_offset() when a poisoned entry is encountered. Let's remove the ambiguity by adding a size parameter to convey additional information about the requested address. Also fixup the definition/usage of huge_pte_offset() throughout the tree. Link: http://lkml.kernel.org/r/20170522133604.11392-4-punit.agrawal@arm.com Signed-off-by: Punit Agrawal <punit.agrawal@arm.com> Acked-by: Steve Capper <steve.capper@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: James Hogan <james.hogan@imgtec.com> (odd fixer:METAG ARCHITECTURE) Cc: Ralf Baechle <ralf@linux-mips.org> (supporter:MIPS) Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Rich Felker <dalias@libc.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Michal Hocko <mhocko@suse.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-23metag: Adjust system_state checkThomas Gleixner
To enable smp_processor_id() and might_sleep() debug checks earlier, it's required to add system states between SYSTEM_BOOTING and SYSTEM_RUNNING. Adjust the system_state check in stop_this_cpu() to handle the extra states. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: James Hogan <james.hogan@imgtec.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20170516184735.283420315@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-05-18devicetree: Move include prefixes from arch to separate directoryOlof Johansson
We use a directory under arch/$ARCH/boot/dts as an include path that has links outside of the subtree to find dt-bindings from under include/dt-bindings. That's been working well, but new DT architectures haven't been adding them by default. Recently there's been a desire to share some of the DT material between arm and arm64, which originally caused developers to create symlinks or relative includes between the subtrees. This isn't ideal -- it breaks if the DT files aren't stored in the exact same hierarchy as the kernel tree, and generally it's just icky. As a somewhat cleaner solution we decided to add a $ARCH/ prefix link once, and allow DTS files to reference dtsi (and dts) files in other architectures that way. Original approach was to create these links under each architecture, but it lead to the problem of recursive symlinks. As a remedy, move the include link directories out of the architecture trees into a common location. At the same time, they can now share one directory and one dt-bindings/ link as well. Fixes: 4027494ae6e3 ('ARM: dts: add arm/arm64 include symlinks') Reported-by: Russell King <linux@armlinux.org.uk> Reported-by: Omar Sandoval <osandov@osandov.com> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Rob Herring <robh@kernel.org> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Russell King <linux@armlinux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Frank Rowand <frowand.list@gmail.com> Cc: linux-arch <linux-arch@vger.kernel.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2017-05-15kill strlen_user()Al Viro
no callers, no consistent semantics, no sane way to use it... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-05-10Merge tag 'kbuild-uapi-v4.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull Kbuild UAPI updates from Masahiro Yamada: "Improvement of headers_install by Nicolas Dichtel. It has been long since the introduction of uapi directories, but the de-coupling of exported headers has not been completed. Headers listed in header-y are exported whether they exist in uapi directories or not. His work fixes this inconsistency. All (and only) headers under uapi directories are now exported. The asm-generic wrappers are still exceptions, but this is a big step forward" * tag 'kbuild-uapi-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: arch/include: remove empty Kbuild files uapi: export all arch specifics directories uapi: export all headers under uapi directories smc_diag.h: fix include from userland btrfs_tree.h: fix include from userland uapi: includes linux/types.h before exporting files Makefile.headersinst: remove destination-y option Makefile.headersinst: cleanup input files x86: stop exporting msr-index.h to userland nios2: put setup.h in uapi h8300: put bitsperlong.h in uapi
2017-05-10Merge tag 'metag-for-v4.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag updates from James Hogan: "These patches primarily make some usercopy improvements (following on from the recent usercopy fixes): - reformat and simplify rapf copy loops - add 64-bit get_user support And fix a couple more uaccess issues, partily pointed out by Al: - fix access_ok() serious shortcomings - fix strncpy_from_user() address validation Also included is a trivial removal of a redundant increment" * tag 'metag-for-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag/mm: Drop pointless increment metag/uaccess: Check access_ok in strncpy_from_user metag/uaccess: Fix access_ok() metag/usercopy: Add 64-bit get_user support metag/usercopy: Simplify rapf loop fixup corner case metag/usercopy: Reformat rapf loop inline asm
2017-05-11uapi: export all headers under uapi directoriesNicolas Dichtel
Regularly, when a new header is created in include/uapi/, the developer forgets to add it in the corresponding Kbuild file. This error is usually detected after the release is out. In fact, all headers under uapi directories should be exported, thus it's useless to have an exhaustive list. After this patch, the following files, which were not exported, are now exported (with make headers_install_all): asm-arc/kvm_para.h asm-arc/ucontext.h asm-blackfin/shmparam.h asm-blackfin/ucontext.h asm-c6x/shmparam.h asm-c6x/ucontext.h asm-cris/kvm_para.h asm-h8300/shmparam.h asm-h8300/ucontext.h asm-hexagon/shmparam.h asm-m32r/kvm_para.h asm-m68k/kvm_para.h asm-m68k/shmparam.h asm-metag/kvm_para.h asm-metag/shmparam.h asm-metag/ucontext.h asm-mips/hwcap.h asm-mips/reg.h asm-mips/ucontext.h asm-nios2/kvm_para.h asm-nios2/ucontext.h asm-openrisc/shmparam.h asm-parisc/kvm_para.h asm-powerpc/perf_regs.h asm-sh/kvm_para.h asm-sh/ucontext.h asm-tile/shmparam.h asm-unicore32/shmparam.h asm-unicore32/ucontext.h asm-x86/hwcap2.h asm-xtensa/kvm_para.h drm/armada_drm.h drm/etnaviv_drm.h drm/vgem_drm.h linux/aspeed-lpc-ctrl.h linux/auto_dev-ioctl.h linux/bcache.h linux/btrfs_tree.h linux/can/vxcan.h linux/cifs/cifs_mount.h linux/coresight-stm.h linux/cryptouser.h linux/fsmap.h linux/genwqe/genwqe_card.h linux/hash_info.h linux/kcm.h linux/kcov.h linux/kfd_ioctl.h linux/lightnvm.h linux/module.h linux/nbd-netlink.h linux/nilfs2_api.h linux/nilfs2_ondisk.h linux/nsfs.h linux/pr.h linux/qrtr.h linux/rpmsg.h linux/sched/types.h linux/sed-opal.h linux/smc.h linux/smc_diag.h linux/stm.h linux/switchtec_ioctl.h linux/vfio_ccw.h linux/wil6210_uapi.h rdma/bnxt_re-abi.h Note that I have removed from this list the files which are generated in every exported directories (like .install or .install.cmd). Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all subdirs with a pure makefile command. For the record, note that exported files for asm directories are a mix of files listed by: - include/uapi/asm-generic/Kbuild.asm; - arch/<arch>/include/uapi/asm/Kbuild; - arch/<arch>/include/asm/Kbuild. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Acked-by: Mark Salter <msalter@redhat.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-03metag/mm: Drop pointless incrementJames Hogan
The increment of entry in the loop in mmu_init for meta1 is redundant as it isn't used again, so drop it. Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2017-05-02Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto updates from Herbert Xu: "Here is the crypto update for 4.12: API: - Add batch registration for acomp/scomp - Change acomp testing to non-unique compressed result - Extend algorithm name limit to 128 bytes - Require setkey before accept(2) in algif_aead Algorithms: - Add support for deflate rfc1950 (zlib) Drivers: - Add accelerated crct10dif for powerpc - Add crc32 in stm32 - Add sha384/sha512 in ccp - Add 3des/gcm(aes) for v5 devices in ccp - Add Queue Interface (QI) backend support in caam - Add new Exynos RNG driver - Add ThunderX ZIP driver - Add driver for hardware random generator on MT7623 SoC" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (101 commits) crypto: stm32 - Fix OF module alias information crypto: algif_aead - Require setkey before accept(2) crypto: scomp - add support for deflate rfc1950 (zlib) crypto: scomp - allow registration of multiple scomps crypto: ccp - Change ISR handler method for a v5 CCP crypto: ccp - Change ISR handler method for a v3 CCP crypto: crypto4xx - rename ce_ring_contol to ce_ring_control crypto: testmgr - Allow ecb(cipher_null) in FIPS mode Revert "crypto: arm64/sha - Add constant operand modifier to ASM_EXPORT" crypto: ccp - Disable interrupts early on unload crypto: ccp - Use only the relevant interrupt bits hwrng: mtk - Add driver for hardware random generator on MT7623 SoC dt-bindings: hwrng: Add Mediatek hardware random generator bindings crypto: crct10dif-vpmsum - Fix missing preempt_disable() crypto: testmgr - replace compression known answer test crypto: acomp - allow registration of multiple acomps hwrng: n2 - Use devm_kcalloc() in n2rng_probe() crypto: chcr - Fix error handling related to 'chcr_alloc_shash' padata: get_next is never NULL crypto: exynos - Add new Exynos RNG driver ...
2017-05-02metag/uaccess: Check access_ok in strncpy_from_userJames Hogan
The metag implementation of strncpy_from_user() doesn't validate the src pointer, which could allow reading of arbitrary kernel memory. Add a short access_ok() check to prevent that. Its still possible for it to read across the user/kernel boundary, but it will invariably reach a NUL character after only 9 bytes, leaking only a static kernel address being loaded into D0Re0 at the beginning of __start, which is acceptable for the immediate fix. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Cc: stable@vger.kernel.org
2017-05-02metag/uaccess: Fix access_ok()James Hogan
The __user_bad() macro used by access_ok() has a few corner cases noticed by Al Viro where it doesn't behave correctly: - The kernel range check has off by 1 errors which permit access to the first and last byte of the kernel mapped range. - The kernel range check ends at LINCORE_BASE rather than META_MEMORY_LIMIT, which is ineffective when the kernel is in global space (an extremely uncommon configuration). There are a couple of other shortcomings here too: - Access to the whole of the other address space is permitted (i.e. the global half of the address space when the kernel is in local space). This isn't ideal as it could theoretically still contain privileged mappings set up by the bootloader. - The size argument is unused, permitting user copies which start on valid pages at the end of the user address range and cross the boundary into the kernel address space (e.g. addr = 0x3ffffff0, size > 0x10). It isn't very convenient to add size checks when disallowing certain regions, and it seems far safer to be sure and explicit about what userland is able to access, so invert the logic to allow certain regions instead, and fix the off by 1 errors and missing size checks. This also allows the get_fs() == KERNEL_DS check to be more easily optimised into the user address range case. We now have 3 such allowed regions: - The user address range (incorporating the get_fs() == KERNEL_DS check). - NULL (some kernel code expects this to work, and we'll always catch the fault anyway). - The core code memory region. Fixes: 373cd784d0fc ("metag: Memory handling") Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Cc: stable@vger.kernel.org
2017-05-01Merge branch 'work.uaccess' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull uaccess unification updates from Al Viro: "This is the uaccess unification pile. It's _not_ the end of uaccess work, but the next batch of that will go into the next cycle. This one mostly takes copy_from_user() and friends out of arch/* and gets the zero-padding behaviour in sync for all architectures. Dealing with the nocache/writethrough mess is for the next cycle; fortunately, that's x86-only. Same for cleanups in iov_iter.c (I am sold on access_ok() in there, BTW; just not in this pile), same for reducing __copy_... callsites, strn*... stuff, etc. - there will be a pile about as large as this one in the next merge window. This one sat in -next for weeks. -3KLoC" * 'work.uaccess' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (96 commits) HAVE_ARCH_HARDENED_USERCOPY is unconditional now CONFIG_ARCH_HAS_RAW_COPY_USER is unconditional now m32r: switch to RAW_COPY_USER hexagon: switch to RAW_COPY_USER microblaze: switch to RAW_COPY_USER get rid of padding, switch to RAW_COPY_USER ia64: get rid of copy_in_user() ia64: sanitize __access_ok() ia64: get rid of 'segment' argument of __do_{get,put}_user() ia64: get rid of 'segment' argument of __{get,put}_user_check() ia64: add extable.h powerpc: get rid of zeroing, switch to RAW_COPY_USER esas2r: don't open-code memdup_user() alpha: fix stack smashing in old_adjtimex(2) don't open-code kernel_setsockopt() mips: switch to RAW_COPY_USER mips: get rid of tail-zeroing in primitives mips: make copy_from_user() zero tail explicitly mips: clean and reorder the forest of macros... mips: consolidate __invoke_... wrappers ...
2017-04-26CONFIG_ARCH_HAS_RAW_COPY_USER is unconditional nowAl Viro
all architectures converted Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-04-26Merge branches 'uaccess.alpha', 'uaccess.arc', 'uaccess.arm', ↵Al Viro
'uaccess.arm64', 'uaccess.avr32', 'uaccess.bfin', 'uaccess.c6x', 'uaccess.cris', 'uaccess.frv', 'uaccess.h8300', 'uaccess.hexagon', 'uaccess.ia64', 'uaccess.m32r', 'uaccess.m68k', 'uaccess.metag', 'uaccess.microblaze', 'uaccess.mips', 'uaccess.mn10300', 'uaccess.nios2', 'uaccess.openrisc', 'uaccess.parisc', 'uaccess.powerpc', 'uaccess.s390', 'uaccess.score', 'uaccess.sh', 'uaccess.sparc', 'uaccess.tile', 'uaccess.um', 'uaccess.unicore32', 'uaccess.x86' and 'uaccess.xtensa' into work.uaccess
2017-04-21linux/kernel.h: Add ALIGN_DOWN macroKrzysztof Kozlowski
Few parts of kernel define their own macro for aligning down so provide a common define for this, with the same usage and assumptions as existing ALIGN. Convert also three existing implementations to this one. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2017-04-07Merge tag 'metag-for-v4.11-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag usercopy fixes from James Hogan: "Metag usercopy fault handling fixes These patches fix a bunch of longstanding (some over a decade old) metag user copy fault handling bugs. Thanks go to Al Viro for spotting some of the questionable code in the first place" * tag 'metag-for-v4.11-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag/usercopy: Add missing fixups metag/usercopy: Fix src fixup in from user rapf loops metag/usercopy: Set flags before ADDZ metag/usercopy: Zero rest of buffer from copy_from_user metag/usercopy: Add early abort to copy_to_user metag/usercopy: Fix alignment error checking metag/usercopy: Drop unused macros
2017-04-05metag/usercopy: Switch to RAW_COPY_USERJames Hogan
Switch to using raw user copy instead of providing metag specific [__]copy_{to,from}_user[_inatomic](). This simplifies the metag uaccess.h and allows us to take advantage of extra checking in the generic versions. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-metag@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-04-05Merge branch 'fixes' of ↵Al Viro
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag into uaccess.metag
2017-04-05metag/usercopy: Add 64-bit get_user supportJames Hogan
Metag already supports 64-bit put_user, so add support for 64-bit get_user too so that the test_user_copy module can test both. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org
2017-04-05metag/usercopy: Simplify rapf loop fixup corner caseJames Hogan
The final fixup in the rapf loops must handle a corner case due to the intermediate decrementing of the destination pointer before writing the last element to it again and re-incrementing it. This decrement (and the associated increment in the fixup code) can be easily avoided by using SETL/SETD with an offset of -8/-4. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org
2017-04-05metag/usercopy: Reformat rapf loop inline asmJames Hogan
Reformat rapf loop inline assembly to make it more readable and easier to modify in future. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org
2017-04-05metag/usercopy: Add missing fixupsJames Hogan
The rapf copy loops in the Meta usercopy code is missing some extable entries for HTP cores with unaligned access checking enabled, where faults occur on the instruction immediately after the faulting access. Add the fixup labels and extable entries for these cases so that corner case user copy failures don't cause kernel crashes. Fixes: 373cd784d0fc ("metag: Memory handling") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Cc: stable@vger.kernel.org
2017-04-05metag/usercopy: Fix src fixup in from user rapf loopsJames Hogan
The fixup code to rewind the source pointer in __asm_copy_from_user_{32,64}bit_rapf_loop() always rewound the source by a single unit (4 or 8 bytes), however this is insufficient if the fault didn't occur on the first load in the loop, as the source pointer will have been incremented but nothing will have been stored until all 4 register [pairs] are loaded. Read the LSM_STEP field of TXSTATUS (which is already loaded into a register), a bit like the copy_to_user versions, to determine how many iterations of MGET[DL] have taken place, all of which need rewinding. Fixes: 373cd784d0fc ("metag: Memory handling") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Cc: stable@vger.kernel.org
2017-04-05metag/usercopy: Set flags before ADDZJames Hogan
The fixup code for the copy_to_user rapf loops reads TXStatus.LSM_STEP to decide how far to rewind the source pointer. There is a special case for the last execution of an MGETL/MGETD, since it leaves LSM_STEP=0 even though the number of MGETLs/MGETDs attempted was 4. This uses ADDZ which is conditional upon the Z condition flag, but the AND instruction which masked the TXStatus.LSM_STEP field didn't set the condition flags based on the result. Fix that now by using ANDS which does set the flags, and also marking the condition codes as clobbered by the inline assembly. Fixes: 373cd784d0fc ("metag: Memory handling") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Cc: stable@vger.kernel.org
2017-04-05metag/usercopy: Zero rest of buffer from copy_from_userJames Hogan
Currently we try to zero the destination for a failed read from userland in fixup code in the usercopy.c macros. The rest of the destination buffer is then zeroed from __copy_user_zeroing(), which is used for both copy_from_user() and __copy_from_user(). Unfortunately we fail to zero in the fixup code as D1Ar1 is set to 0 before the fixup code entry labels, and __copy_from_user() shouldn't even be zeroing the rest of the buffer. Move the zeroing out into copy_from_user() and rename __copy_user_zeroing() to raw_copy_from_user() since it no longer does any zeroing. This also conveniently matches the name needed for RAW_COPY_USER support in a later patch. Fixes: 373cd784d0fc ("metag: Memory handling") Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Cc: stable@vger.kernel.org
2017-04-05metag/usercopy: Add early abort to copy_to_userJames Hogan
When copying to userland on Meta, if any faults are encountered immediately abort the copy instead of continuing on and repeatedly faulting, and worse potentially copying further bytes successfully to subsequent valid pages. Fixes: 373cd784d0fc ("metag: Memory handling") Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Cc: stable@vger.kernel.org
2017-04-05metag/usercopy: Fix alignment error checkingJames Hogan
Fix the error checking of the alignment adjustment code in raw_copy_from_user(), which mistakenly considers it safe to skip the error check when aligning the source buffer on a 2 or 4 byte boundary. If the destination buffer was unaligned it may have started to copy using byte or word accesses, which could well be at the start of a new (valid) source page. This would result in it appearing to have copied 1 or 2 bytes at the end of the first (invalid) page rather than none at all. Fixes: 373cd784d0fc ("metag: Memory handling") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Cc: stable@vger.kernel.org
2017-04-05metag/usercopy: Drop unused macrosJames Hogan
Metag's lib/usercopy.c has a bunch of copy_from_user macros for larger copies between 5 and 16 bytes which are completely unused. Before fixing zeroing lets drop these macros so there is less to fix. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-metag@vger.kernel.org Cc: stable@vger.kernel.org
2017-04-02Merge branch 'parisc-4.11-3' of ↵Al Viro
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux into uaccess.parisc
2017-03-29Merge branch 'regset' (PTRACE_SETREGSET data leakage)Linus Torvalds
Merge PTRACE_SETREGSET leakage fixes from Dave Martin: "This series is the collection of fixes I proposed on this topic, that have not yet appeared upstream or in the stable branches, The issue can leak kernel stack, but doesn't appear to allow userspace to attack the kernel directly. The affected architectures are c6x, h8300, metag, mips and sparc. [ Mark Salter points out that c6x has no MMU or other mechanism to prevent userspace access to kernel code or data on c6x, but it doesn't hurt to clean that case up too. ] The bugs arise from use of user_regset_copyin(). Users of user_regset_copyin() can work in one of two ways: 1) Copy directly to thread_struct or equivalent. (This seems to be the design assumption of the regset API, and is the most common approach.) 2) Copy to a local variable and then transfer to thread_struct. (A significant minority of cases.) Buggy code typically involves approach 2" * emailed patches from Dave Martin <Dave.Martin@arm.com>: sparc/ptrace: Preserve previous registers for short regset write mips/ptrace: Preserve previous registers for short regset write metag/ptrace: Reject partial NT_METAG_RPIPE writes metag/ptrace: Provide default TXSTATUS for short NT_PRSTATUS metag/ptrace: Preserve previous registers for short regset write h8300/ptrace: Fix incorrect register transfer count c6x/ptrace: Remove useless PTRACE_SETREGSET implementation
2017-03-29metag/ptrace: Reject partial NT_METAG_RPIPE writesDave Martin
It's not clear what behaviour is sensible when doing partial write of NT_METAG_RPIPE, so just don't bother. This patch assumes that userspace will never rely on a partial SETREGSET in this case, since it's not clear what should happen anyway. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Acked-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-29metag/ptrace: Provide default TXSTATUS for short NT_PRSTATUSDave Martin
Ensure that if userspace supplies insufficient data to PTRACE_SETREGSET to fill TXSTATUS, a well-defined default value is used, based on the task's current value. Suggested-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-29metag/ptrace: Preserve previous registers for short regset writeDave Martin
Ensure that if userspace supplies insufficient data to PTRACE_SETREGSET to fill all the registers, the thread's old registers are preserved. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Acked-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-28metag: kill verify_area()Al Viro
Deprecated in 2.6.12, killed in 2.6.13. Time to end that depravity, let's bury the body... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
