path: root/arch/metag
2017-05-25metag/uaccess: Check access_ok in strncpy_from_userJames Hogan
commit 3a158a62da0673db918b53ac1440845a5b64fd90 upstream. The metag implementation of strncpy_from_user() doesn't validate the src pointer, which could allow reading of arbitrary kernel memory. Add a short access_ok() check to prevent that. Its still possible for it to read across the user/kernel boundary, but it will invariably reach a NUL character after only 9 bytes, leaking only a static kernel address being loaded into D0Re0 at the beginning of __start, which is acceptable for the immediate fix. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25metag/uaccess: Fix access_ok()James Hogan
commit 8a8b56638bcac4e64cccc88bf95a0f9f4b19a2fb upstream. The __user_bad() macro used by access_ok() has a few corner cases noticed by Al Viro where it doesn't behave correctly: - The kernel range check has off by 1 errors which permit access to the first and last byte of the kernel mapped range. - The kernel range check ends at LINCORE_BASE rather than META_MEMORY_LIMIT, which is ineffective when the kernel is in global space (an extremely uncommon configuration). There are a couple of other shortcomings here too: - Access to the whole of the other address space is permitted (i.e. the global half of the address space when the kernel is in local space). This isn't ideal as it could theoretically still contain privileged mappings set up by the bootloader. - The size argument is unused, permitting user copies which start on valid pages at the end of the user address range and cross the boundary into the kernel address space (e.g. addr = 0x3ffffff0, size > 0x10). It isn't very convenient to add size checks when disallowing certain regions, and it seems far safer to be sure and explicit about what userland is able to access, so invert the logic to allow certain regions instead, and fix the off by 1 errors and missing size checks. This also allows the get_fs() == KERNEL_DS check to be more easily optimised into the user address range case. We now have 3 such allowed regions: - The user address range (incorporating the get_fs() == KERNEL_DS check). - NULL (some kernel code expects this to work, and we'll always catch the fault anyway). - The core code memory region. Fixes: 373cd784d0fc ("metag: Memory handling") Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12metag/usercopy: Add missing fixupsJames Hogan
commit b884a190afcecdbef34ca508ea5ee88bb7c77861 upstream. The rapf copy loops in the Meta usercopy code is missing some extable entries for HTP cores with unaligned access checking enabled, where faults occur on the instruction immediately after the faulting access. Add the fixup labels and extable entries for these cases so that corner case user copy failures don't cause kernel crashes. Fixes: 373cd784d0fc ("metag: Memory handling") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12metag/usercopy: Fix src fixup in from user rapf loopsJames Hogan
commit 2c0b1df88b987a12d95ea1d6beaf01894f3cc725 upstream. The fixup code to rewind the source pointer in __asm_copy_from_user_{32,64}bit_rapf_loop() always rewound the source by a single unit (4 or 8 bytes), however this is insufficient if the fault didn't occur on the first load in the loop, as the source pointer will have been incremented but nothing will have been stored until all 4 register [pairs] are loaded. Read the LSM_STEP field of TXSTATUS (which is already loaded into a register), a bit like the copy_to_user versions, to determine how many iterations of MGET[DL] have taken place, all of which need rewinding. Fixes: 373cd784d0fc ("metag: Memory handling") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12metag/usercopy: Set flags before ADDZJames Hogan
commit fd40eee1290ad7add7aa665e3ce6b0f9fe9734b4 upstream. The fixup code for the copy_to_user rapf loops reads TXStatus.LSM_STEP to decide how far to rewind the source pointer. There is a special case for the last execution of an MGETL/MGETD, since it leaves LSM_STEP=0 even though the number of MGETLs/MGETDs attempted was 4. This uses ADDZ which is conditional upon the Z condition flag, but the AND instruction which masked the TXStatus.LSM_STEP field didn't set the condition flags based on the result. Fix that now by using ANDS which does set the flags, and also marking the condition codes as clobbered by the inline assembly. Fixes: 373cd784d0fc ("metag: Memory handling") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12metag/usercopy: Zero rest of buffer from copy_from_userJames Hogan
commit 563ddc1076109f2b3f88e6d355eab7b6fd4662cb upstream. Currently we try to zero the destination for a failed read from userland in fixup code in the usercopy.c macros. The rest of the destination buffer is then zeroed from __copy_user_zeroing(), which is used for both copy_from_user() and __copy_from_user(). Unfortunately we fail to zero in the fixup code as D1Ar1 is set to 0 before the fixup code entry labels, and __copy_from_user() shouldn't even be zeroing the rest of the buffer. Move the zeroing out into copy_from_user() and rename __copy_user_zeroing() to raw_copy_from_user() since it no longer does any zeroing. This also conveniently matches the name needed for RAW_COPY_USER support in a later patch. Fixes: 373cd784d0fc ("metag: Memory handling") Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12metag/usercopy: Add early abort to copy_to_userJames Hogan
commit fb8ea062a8f2e85256e13f55696c5c5f0dfdcc8b upstream. When copying to userland on Meta, if any faults are encountered immediately abort the copy instead of continuing on and repeatedly faulting, and worse potentially copying further bytes successfully to subsequent valid pages. Fixes: 373cd784d0fc ("metag: Memory handling") Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12metag/usercopy: Fix alignment error checkingJames Hogan
commit 2257211942bbbf6c798ab70b487d7e62f7835a1a upstream. Fix the error checking of the alignment adjustment code in raw_copy_from_user(), which mistakenly considers it safe to skip the error check when aligning the source buffer on a 2 or 4 byte boundary. If the destination buffer was unaligned it may have started to copy using byte or word accesses, which could well be at the start of a new (valid) source page. This would result in it appearing to have copied 1 or 2 bytes at the end of the first (invalid) page rather than none at all. Fixes: 373cd784d0fc ("metag: Memory handling") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12metag/usercopy: Drop unused macrosJames Hogan
commit ef62a2d81f73d9cddef14bc3d9097a57010d551c upstream. Metag's lib/usercopy.c has a bunch of copy_from_user macros for larger copies between 5 and 16 bytes which are completely unused. Before fixing zeroing lets drop these macros so there is less to fix. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-31metag/ptrace: Reject partial NT_METAG_RPIPE writesDave Martin
commit 7195ee3120d878259e8d94a5d9f808116f34d5ea upstream. It's not clear what behaviour is sensible when doing partial write of NT_METAG_RPIPE, so just don't bother. This patch assumes that userspace will never rely on a partial SETREGSET in this case, since it's not clear what should happen anyway. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Acked-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-31metag/ptrace: Provide default TXSTATUS for short NT_PRSTATUSDave Martin
commit 5fe81fe98123ce41265c65e95d34418d30d005d1 upstream. Ensure that if userspace supplies insufficient data to PTRACE_SETREGSET to fill TXSTATUS, a well-defined default value is used, based on the task's current value. Suggested-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-31metag/ptrace: Preserve previous registers for short regset writeDave Martin
commit a78ce80d2c9178351b34d78fec805140c29c193e upstream. Ensure that if userspace supplies insufficient data to PTRACE_SETREGSET to fill all the registers, the thread's old registers are preserved. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Acked-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-14Merge tag 'metag-for-v4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag architecture fix from James Hogan: "A simple build fix for irqsoff atomics which has started hitting meta1_defconfig during the 4.9 merge window" * tag 'metag-for-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag: Only define atomic_dec_if_positive conditionally
2016-10-07nmi_backtrace: generate one-line reports for idle cpusChris Metcalf
When doing an nmi backtrace of many cores, most of which are idle, the output is a little overwhelming and very uninformative. Suppress messages for cpus that are idling when they are interrupted and just emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN". We do this by grouping all the cpuidle code together into a new .cpuidle.text section, and then checking the address of the interrupted PC to see if it lies within that section. This commit suitably tags x86 and tile idle routines, and only adds in the minimal framework for other architectures. Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm] Tested-by: Petr Mladek <pmladek@suse.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07metag: Only define atomic_dec_if_positive conditionallyGuenter Roeck
The definition of atomic_dec_if_positive() assumes that atomic_sub_if_positive() exists, which is only the case if metag specific atomics are used. This results in the following build error when trying to build metag1_defconfig. kernel/ucount.c: In function 'dec_ucount': kernel/ucount.c:211: error: implicit declaration of function 'atomic_sub_if_positive' Moving the definition of atomic_dec_if_positive() into the metag conditional code fixes the problem. Fixes: 6006c0d8ce94 ("metag: Atomics, locks and bitops") Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: <stable@vger.kernel.org> # 3.9.x-
2016-09-13metag: copy_from_user() should zero the destination on access_ok() failureAl Viro
Cc: stable@vger.kernel.org Acked-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-08-09metag: Drop show_mem() from mem_init()James Hogan
The recent commit 599d0c954f91 ("mm, vmscan: move LRU lists to node"), changed memory management code so that show_mem() is no longer safe to call prior to setup_per_cpu_pageset(), as pgdat->per_cpu_nodestats will still be NULL. This causes an oops on metag due to the call to show_mem() from mem_init(): node_page_state_snapshot(...) + 0x48 pgdat_reclaimable(struct pglist_data * pgdat = 0x402517a0) show_free_areas(unsigned int filter = 0) + 0x2cc show_mem(unsigned int filter = 0) + 0x18 mem_init() mm_init() start_kernel() + 0x204 This wasn't a problem before with zone_reclaimable() as zone_pcp_init() was already setting zone->pageset to &boot_pageset, via setup_arch() and paging_init(), which happens before mm_init(): zone_pcp_init(...) free_area_init_core(...) + 0x138 free_area_init_node(int nid = 0, ...) + 0x1a0 free_area_init_nodes(...) + 0x440 paging_init(unsigned long mem_end = 0x4fe00000) + 0x378 setup_arch(char ** cmdline_p = 0x4024e038) + 0x2b8 start_kernel() + 0x54 No other arches appear to call show_mem() during boot, and it doesn't really add much value to the log, so lets just drop it from mem_init(). Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: linux-metag@vger.kernel.org
2016-08-05Merge tag 'metag-for-v4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag architecture updates from James Hogan: "Just a few minor fixes: - Fix another incorrect inline asm register constraint, which has been lying quietly for 5 and a half years before finally causing build breakage during this merge window. - Removal of duplicated KERN_INFO from Joe Perches - Typo fixes from Andrea Gelmini" * tag 'metag-for-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag: Fix __cmpxchg_u32 asm constraint for CMP metag: Remove duplicate KERN_<LEVEL> prefix metag: Fix typos
2016-08-04metag: Fix __cmpxchg_u32 asm constraint for CMPJames Hogan
The LNKGET based atomic sequence in __cmpxchg_u32 has slightly incorrect constraints for the return value which under certain circumstances can allow an address unit register to be used as the first operand of a CMP instruction. This isn't a valid instruction however as the encodings only allow a data unit to be specified. This would result in an assembler error like the following: Error: failed to assemble instruction: "CMP A0.2,D0Ar6" Fix by changing the constraint from "=&da" (assigned, early clobbered, data or address unit register) to "=&d" (data unit register only). The constraint for the second operand, "bd" (an op2 register where op1 is a data unit register and the instruction supports O2R) is already correct assuming the first operand is a data unit register. Other cases of CMP in inline asm have had their constraints checked, and appear to all be fine. Fixes: 6006c0d8ce94 ("metag: Atomics, locks and bitops") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Cc: <stable@vger.kernel.org> # 3.9.x-
2016-08-04dma-mapping: use unsigned long for dma_attrsKrzysztof Kozlowski
The dma-mapping core and the implementations do not change the DMA attributes passed by pointer. Thus the pointer can point to const data. However the attributes do not have to be a bitfield. Instead unsigned long will do fine: 1. This is just simpler. Both in terms of reading the code and setting attributes. Instead of initializing local attributes on the stack and passing pointer to it to dma_set_attr(), just set the bits. 2. It brings safeness and checking for const correctness because the attributes are passed by value. Semantic patches for this change (at least most of them): virtual patch virtual context @r@ identifier f, attrs; @@ f(..., - struct dma_attrs *attrs + unsigned long attrs , ...) { ... } @@ identifier r.f; @@ f(..., - NULL + 0 ) and // Options: --all-includes virtual patch virtual context @r@ identifier f, attrs; type t; @@ t f(..., struct dma_attrs *attrs); @@ identifier r.f; @@ f(..., - NULL + 0 ) Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Robin Murphy <robin.murphy@arm.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Mark Salter <msalter@redhat.com> [c6x] Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris] Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm] Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp] Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core] Acked-by: David Vrabel <david.vrabel@citrix.com> [xen] Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb] Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon] Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390] Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32] Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc] Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-30Merge tag 'devicetree-for-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: - remove most of_platform_populate() calls in arch code. Now the DT core code calls it in the default case and platforms only need to call it if they have special needs - use pr_fmt on all the DT core print statements - CoreSight binding doc improvements to block name descriptions - add dt_to_config script which can parse dts files and list corresponding kernel config options - fix memory leak hit with a PowerMac DT - correct a bunch of STMicro compatible strings to use the correct vendor prefix - fix DA9052 PMIC binding doc to match what is actually used in dts files * tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits) documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table" xtensa: Fix build error due to missing include file MIPS: ath79: Add missing include file Fix spelling errors in Documentation/devicetree ARM: dts: fix STMicroelectronics compatible strings powerpc/dts: fix STMicroelectronics compatible strings Documentation: dt: i2c: use correct STMicroelectronics vendor prefix scripts/dtc: dt_to_config - kernel config options for a devicetree of: fdt: mark unflattened tree as detached of: overlay: add resolver error prints coresight: document binding acronyms Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties of: use pr_fmt prefix for all console printing of/irq: Mark initialised interrupt controllers as populated of: fix memory leak related to safe_name() Revert "of/platform: export of_default_bus_match_table" of: unittest: use of_platform_default_populate() to populate default bus memory: omap-gpmc: use of_platform_default_populate() to populate default bus bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus ...
2016-07-29Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull smp hotplug updates from Thomas Gleixner: "This is the next part of the hotplug rework. - Convert all notifiers with a priority assigned - Convert all CPU_STARTING/DYING notifiers The final removal of the STARTING/DYING infrastructure will happen when the merge window closes. Another 700 hundred line of unpenetrable maze gone :)" * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (70 commits) timers/core: Correct callback order during CPU hot plug leds/trigger/cpu: Move from CPU_STARTING to ONLINE level powerpc/numa: Convert to hotplug state machine arm/perf: Fix hotplug state machine conversion irqchip/armada: Avoid unused function warnings ARC/time: Convert to hotplug state machine clocksource/atlas7: Convert to hotplug state machine clocksource/armada-370-xp: Convert to hotplug state machine clocksource/exynos_mct: Convert to hotplug state machine clocksource/arm_global_timer: Convert to hotplug state machine rcu: Convert rcutree to hotplug state machine KVM/arm/arm64/vgic-new: Convert to hotplug state machine smp/cfd: Convert core to hotplug state machine x86/x2apic: Convert to CPU hotplug state machine profile: Convert to hotplug state machine timers/core: Convert to hotplug state machine hrtimer: Convert to hotplug state machine x86/tboot: Convert to hotplug state machine arm64/armv8 deprecated: Convert to hotplug state machine hwtracing/coresight-etm4x: Convert to hotplug state machine ...
2016-07-26mm: do not pass mm_struct into handle_mm_faultKirill A. Shutemov
We always have vma->vm_mm around. Link: http://lkml.kernel.org/r/1466021202-61880-8-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-25Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "The locking tree was busier in this cycle than the usual pattern - a couple of major projects happened to coincide. The main changes are: - implement the atomic_fetch_{add,sub,and,or,xor}() API natively across all SMP architectures (Peter Zijlstra) - add atomic_fetch_{inc/dec}() as well, using the generic primitives (Davidlohr Bueso) - optimize various aspects of rwsems (Jason Low, Davidlohr Bueso, Waiman Long) - optimize smp_cond_load_acquire() on arm64 and implement LSE based atomic{,64}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}() on arm64 (Will Deacon) - introduce smp_acquire__after_ctrl_dep() and fix various barrier mis-uses and bugs (Peter Zijlstra) - after discovering ancient spin_unlock_wait() barrier bugs in its implementation and usage, strengthen its semantics and update/fix usage sites (Peter Zijlstra) - optimize mutex_trylock() fastpath (Peter Zijlstra) - ... misc fixes and cleanups" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (67 commits) locking/atomic: Introduce inc/dec variants for the atomic_fetch_$op() API locking/barriers, arch/arm64: Implement LDXR+WFE based smp_cond_load_acquire() locking/static_keys: Fix non static symbol Sparse warning locking/qspinlock: Use __this_cpu_dec() instead of full-blown this_cpu_dec() locking/atomic, arch/tile: Fix tilepro build locking/atomic, arch/m68k: Remove comment locking/atomic, arch/arc: Fix build locking/Documentation: Clarify limited control-dependency scope locking/atomic, arch/rwsem: Employ atomic_long_fetch_add() locking/atomic, arch/qrwlock: Employ atomic_fetch_add_acquire() locking/atomic, arch/mips: Convert to _relaxed atomics locking/atomic, arch/alpha: Convert to _relaxed atomics locking/atomic: Remove the deprecated atomic_{set,clear}_mask() functions locking/atomic: Remove linux/atomic.h:atomic_fetch_or() locking/atomic: Implement atomic{,64,_long}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}() locking/atomic: Fix atomic64_relaxed() bits locking/atomic, arch/xtensa: Implement atomic_fetch_{add,sub,and,or,xor}() locking/atomic, arch/x86: Implement atomic{,64}_fetch_{add,sub,and,or,xor}() locking/atomic, arch/tile: Implement atomic{,64}_fetch_{add,sub,and,or,xor}() locking/atomic, arch/sparc: Implement atomic{,64}_fetch_{add,sub,and,or,xor}() ...
2016-07-15metag: Remove duplicate KERN_<LEVEL> prefixJoe Perches
Use a bare printk to avoid a duplicate KERN_<LEVEL> in logging output. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2016-07-15metag: Fix typosAndrea Gelmini
Fix typos in metag architecture. [james.hogan@imgtec.com: squashed patches and fixed "detailed"] Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2016-07-15metag/perf: Convert to hotplug state machineRichard Cochran
Install the callbacks via the state machine and let the core invoke the callbacks on the already online CPUs. Signed-off-by: Richard Cochran <rcochran@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: James Hogan <james.hogan@imgtec.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-metag@vger.kernel.org Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153336.717395164@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-24tree wide: get rid of __GFP_REPEAT for order-0 allocations part IMichal Hocko
This is the third version of the patchset previously sent [1]. I have basically only rebased it on top of 4.7-rc1 tree and dropped "dm: get rid of superfluous gfp flags" which went through dm tree. I am sending it now because it is tree wide and chances for conflicts are reduced considerably when we want to target rc2. I plan to send the next step and rename the flag and move to a better semantic later during this release cycle so we will have a new semantic ready for 4.8 merge window hopefully. Motivation: While working on something unrelated I've checked the current usage of __GFP_REPEAT in the tree. It seems that a majority of the usage is and always has been bogus because __GFP_REPEAT has always been about costly high order allocations while we are using it for order-0 or very small orders very often. It seems that a big pile of them is just a copy&paste when a code has been adopted from one arch to another. I think it makes some sense to get rid of them because they are just making the semantic more unclear. Please note that GFP_REPEAT is documented as * __GFP_REPEAT: Try hard to allocate the memory, but the allocation attempt * _might_ fail. This depends upon the particular VM implementation. while !costly requests have basically nofail semantic. So one could reasonably expect that order-0 request with __GFP_REPEAT will not loop for ever. This is not implemented right now though. I would like to move on with __GFP_REPEAT and define a better semantic for it. $ git grep __GFP_REPEAT origin/master | wc -l 111 $ git grep __GFP_REPEAT | wc -l 36 So we are down to the third after this patch series. The remaining places really seem to be relying on __GFP_REPEAT due to large allocation requests. This still needs some double checking which I will do later after all the simple ones are sorted out. I am touching a lot of arch specific code here and I hope I got it right but as a matter of fact I even didn't compile test for some archs as I do not have cross compiler for them. Patches should be quite trivial to review for stupid compile mistakes though. The tricky parts are usually hidden by macro definitions and thats where I would appreciate help from arch maintainers. [1] http://lkml.kernel.org/r/1461849846-27209-1-git-send-email-mhocko@kernel.org This patch (of 19): __GFP_REPEAT has a rather weak semantic but since it has been introduced around 2.6.12 it has been ignored for low order allocations. Yet we have the full kernel tree with its usage for apparently order-0 allocations. This is really confusing because __GFP_REPEAT is explicitly documented to allow allocation failures which is a weaker semantic than the current order-0 has (basically nofail). Let's simply drop __GFP_REPEAT from those places. This would allow to identify place which really need allocator to retry harder and formulate a more specific semantic for what the flag is supposed to do actually. Link: http://lkml.kernel.org/r/1464599699-30131-2-git-send-email-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andy Lutomirski <luto@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> [for tile] Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: John Crispin <blogic@openwrt.org> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-23metag: Remove unnecessary of_platform_populate with default match tableKefeng Wang
After patch "of/platform: Add common method to populate default bus", it is possible for arch code to remove unnecessary callers of of_platform_populate with default match table. Cc: James Hogan <james.hogan@imgtec.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-16locking/atomic: Remove linux/atomic.h:atomic_fetch_or()Peter Zijlstra
Since all architectures have this implemented now natively, remove this dead code. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-16locking/atomic, arch/metag: Implement atomic_fetch_{add,sub,and,or,xor}()Peter Zijlstra
Implement FETCH-OP atomic primitives, these are very similar to the existing OP-RETURN primitives we already have, except they return the value of the atomic variable _before_ modification. This is especially useful for irreversible operations -- such as bitops (because it becomes impossible to reconstruct the state prior to modification). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: James Hogan <james.hogan@imgtec.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: linux-metag@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-14locking/spinlock, arch: Update and fix spin_unlock_wait() implementationsPeter Zijlstra
This patch updates/fixes all spin_unlock_wait() implementations. The update is in semantics; where it previously was only a control dependency, we now upgrade to a full load-acquire to match the store-release from the spin_unlock() we waited on. This ensures that when spin_unlock_wait() returns, we're guaranteed to observe the full critical section we waited on. This fixes a number of spin_unlock_wait() users that (not unreasonably) rely on this. I also fixed a number of ticket lock versions to only wait on the current lock holder, instead of for a full unlock, as this is sufficient. Furthermore; again for ticket locks; I added an smp_rmb() in between the initial ticket load and the spin loop testing the current value because I could not convince myself the address dependency is sufficient, esp. if the loads are of different sizes. I'm more than happy to remove this smp_rmb() again if people are certain the address dependency does indeed work as expected. Note: PPC32 will be fixed independently Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: chris@zankel.net Cc: cmetcalf@mellanox.com Cc: davem@davemloft.net Cc: dhowells@redhat.com Cc: james.hogan@imgtec.com Cc: jejb@parisc-linux.org Cc: linux@armlinux.org.uk Cc: mpe@ellerman.id.au Cc: ralf@linux-mips.org Cc: realmz6@gmail.com Cc: rkuo@codeaurora.org Cc: rth@twiddle.net Cc: schwidefsky@de.ibm.com Cc: tony.luck@intel.com Cc: vgupta@synopsys.com Cc: ysato@users.sourceforge.jp Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-05-25Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Mostly tooling and PMU driver fixes, but also a number of late updates such as the reworking of the call-chain size limiting logic to make call-graph recording more robust, plus tooling side changes for the new 'backwards ring-buffer' extension to the perf ring-buffer" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (34 commits) perf record: Read from backward ring buffer perf record: Rename variable to make code clear perf record: Prevent reading invalid data in record__mmap_read perf evlist: Add API to pause/resume perf trace: Use the ptr->name beautifier as default for "filename" args perf trace: Use the fd->name beautifier as default for "fd" args perf report: Add srcline_from/to branch sort keys perf evsel: Record fd into perf_mmap perf evsel: Add overwrite attribute and check write_backward perf tools: Set buildid dir under symfs when --symfs is provided perf trace: Only auto set call-graph to "dwarf" when syscalls are being traced perf annotate: Sort list of recognised instructions perf annotate: Fix identification of ARM blt and bls instructions perf tools: Fix usage of max_stack sysctl perf callchain: Stop validating callchains by the max_stack sysctl perf trace: Fix exit_group() formatting perf top: Use machine->kptr_restrict_warned perf trace: Warn when trying to resolve kernel addresses with kptr_restrict=1 perf machine: Do not bail out if not managing to read ref reloc symbol perf/x86/intel/p4: Trival indentation fix, remove space ...
2016-05-24Merge tag 'asm-generic-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic cleanup from Arnd Bergmann: "I have only one patch for asm-generic in this release, this one is from James Hogan and updates the generic system call table for renameat2 so we don't need to provide both renameat and renameat2 in newly added architectures" * tag 'asm-generic-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: Drop renameat syscall from default list
2016-05-20lib/GCD.c: use binary GCD algorithm instead of EuclideanZhaoxiu Zeng
The binary GCD algorithm is based on the following facts: 1. If a and b are all evens, then gcd(a,b) = 2 * gcd(a/2, b/2) 2. If a is even and b is odd, then gcd(a,b) = gcd(a/2, b) 3. If a and b are all odds, then gcd(a,b) = gcd((a-b)/2, b) = gcd((a+b)/2, b) Even on x86 machines with reasonable division hardware, the binary algorithm runs about 25% faster (80% the execution time) than the division-based Euclidian algorithm. On platforms like Alpha and ARMv6 where division is a function call to emulation code, it's even more significant. There are two variants of the code here, depending on whether a fast __ffs (find least significant set bit) instruction is available. This allows the unpredictable branches in the bit-at-a-time shifting loop to be eliminated. If fast __ffs is not available, the "even/odd" GCD variant is used. I use the following code to benchmark: #include <stdio.h> #include <stdlib.h> #include <stdint.h> #include <string.h> #include <time.h> #include <unistd.h> #define swap(a, b) \ do { \ a ^= b; \ b ^= a; \ a ^= b; \ } while (0) unsigned long gcd0(unsigned long a, unsigned long b) { unsigned long r; if (a < b) { swap(a, b); } if (b == 0) return a; while ((r = a % b) != 0) { a = b; b = r; } return b; } unsigned long gcd1(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; b >>= __builtin_ctzl(b); for (;;) { a >>= __builtin_ctzl(a); if (a == b) return a << __builtin_ctzl(r); if (a < b) swap(a, b); a -= b; } } unsigned long gcd2(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; r &= -r; while (!(b & r)) b >>= 1; for (;;) { while (!(a & r)) a >>= 1; if (a == b) return a; if (a < b) swap(a, b); a -= b; a >>= 1; if (a & r) a += b; a >>= 1; } } unsigned long gcd3(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; b >>= __builtin_ctzl(b); if (b == 1) return r & -r; for (;;) { a >>= __builtin_ctzl(a); if (a == 1) return r & -r; if (a == b) return a << __builtin_ctzl(r); if (a < b) swap(a, b); a -= b; } } unsigned long gcd4(unsigned long a, unsigned long b) { unsigned long r = a | b; if (!a || !b) return r; r &= -r; while (!(b & r)) b >>= 1; if (b == r) return r; for (;;) { while (!(a & r)) a >>= 1; if (a == r) return r; if (a == b) return a; if (a < b) swap(a, b); a -= b; a >>= 1; if (a & r) a += b; a >>= 1; } } static unsigned long (*gcd_func[])(unsigned long a, unsigned long b) = { gcd0, gcd1, gcd2, gcd3, gcd4, }; #define TEST_ENTRIES (sizeof(gcd_func) / sizeof(gcd_func[0])) #if defined(__x86_64__) #define rdtscll(val) do { \ unsigned long __a,__d; \ __asm__ __volatile__("rdtsc" : "=a" (__a), "=d" (__d)); \ (val) = ((unsigned long long)__a) | (((unsigned long long)__d)<<32); \ } while(0) static unsigned long long benchmark_gcd_func(unsigned long (*gcd)(unsigned long, unsigned long), unsigned long a, unsigned long b, unsigned long *res) { unsigned long long start, end; unsigned long long ret; unsigned long gcd_res; rdtscll(start); gcd_res = gcd(a, b); rdtscll(end); if (end >= start) ret = end - start; else ret = ~0ULL - start + 1 + end; *res = gcd_res; return ret; } #else static inline struct timespec read_time(void) { struct timespec time; clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &time); return time; } static inline unsigned long long diff_time(struct timespec start, struct timespec end) { struct timespec temp; if ((end.tv_nsec - start.tv_nsec) < 0) { temp.tv_sec = end.tv_sec - start.tv_sec - 1; temp.tv_nsec = 1000000000ULL + end.tv_nsec - start.tv_nsec; } else { temp.tv_sec = end.tv_sec - start.tv_sec; temp.tv_nsec = end.tv_nsec - start.tv_nsec; } return temp.tv_sec * 1000000000ULL + temp.tv_nsec; } static unsigned long long benchmark_gcd_func(unsigned long (*gcd)(unsigned long, unsigned long), unsigned long a, unsigned long b, unsigned long *res) { struct timespec start, end; unsigned long gcd_res; start = read_time(); gcd_res = gcd(a, b); end = read_time(); *res = gcd_res; return diff_time(start, end); } #endif static inline unsigned long get_rand() { if (sizeof(long) == 8) return (unsigned long)rand() << 32 | rand(); else return rand(); } int main(int argc, char **argv) { unsigned int seed = time(0); int loops = 100; int repeats = 1000; unsigned long (*res)[TEST_ENTRIES]; unsigned long long elapsed[TEST_ENTRIES]; int i, j, k; for (;;) { int opt = getopt(argc, argv, "n:r:s:"); /* End condition always first */ if (opt == -1) break; switch (opt) { case 'n': loops = atoi(optarg); break; case 'r': repeats = atoi(optarg); break; case 's': seed = strtoul(optarg, NULL, 10); break; default: /* You won't actually get here. */ break; } } res = malloc(sizeof(unsigned long) * TEST_ENTRIES * loops); memset(elapsed, 0, sizeof(elapsed)); srand(seed); for (j = 0; j < loops; j++) { unsigned long a = get_rand(); /* Do we have args? */ unsigned long b = argc > optind ? strtoul(argv[optind], NULL, 10) : get_rand(); unsigned long long min_elapsed[TEST_ENTRIES]; for (k = 0; k < repeats; k++) { for (i = 0; i < TEST_ENTRIES; i++) { unsigned long long tmp = benchmark_gcd_func(gcd_func[i], a, b, &res[j][i]); if (k == 0 || min_elapsed[i] > tmp) min_elapsed[i] = tmp; } } for (i = 0; i < TEST_ENTRIES; i++) elapsed[i] += min_elapsed[i]; } for (i = 0; i < TEST_ENTRIES; i++) printf("gcd%d: elapsed %llu\n", i, elapsed[i]); k = 0; srand(seed); for (j = 0; j < loops; j++) { unsigned long a = get_rand(); unsigned long b = argc > optind ? strtoul(argv[optind], NULL, 10) : get_rand(); for (i = 1; i < TEST_ENTRIES; i++) { if (res[j][i] != res[j][0]) break; } if (i < TEST_ENTRIES) { if (k == 0) { k = 1; fprintf(stderr, "Error:\n"); } fprintf(stderr, "gcd(%lu, %lu): ", a, b); for (i = 0; i < TEST_ENTRIES; i++) fprintf(stderr, "%ld%s", res[j][i], i < TEST_ENTRIES - 1 ? ", " : "\n"); } } if (k == 0) fprintf(stderr, "PASS\n"); free(res); return 0; } Compiled with "-O2", on "VirtualBox 4.4.0-22-generic #38-Ubuntu x86_64" got: zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 10174 gcd1: elapsed 2120 gcd2: elapsed 2902 gcd3: elapsed 2039 gcd4: elapsed 2812 PASS zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 9309 gcd1: elapsed 2280 gcd2: elapsed 2822 gcd3: elapsed 2217 gcd4: elapsed 2710 PASS zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 9589 gcd1: elapsed 2098 gcd2: elapsed 2815 gcd3: elapsed 2030 gcd4: elapsed 2718 PASS zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10 gcd0: elapsed 9914 gcd1: elapsed 2309 gcd2: elapsed 2779 gcd3: elapsed 2228 gcd4: elapsed 2709 PASS [akpm@linux-foundation.org: avoid #defining a CONFIG_ variable] Signed-off-by: Zhaoxiu Zeng <zhaoxiu.zeng@gmail.com> Signed-off-by: George Spelvin <linux@horizon.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20exit_thread: accept a task parameter to be exitedJiri Slaby
We need to call exit_thread from copy_process in a fail path. So make it accept task_struct as a parameter. [v2] * s390: exit_thread_runtime_instr doesn't make sense to be called for non-current tasks. * arm: fix the comment in vfp_thread_copy * change 'me' to 'tsk' for task_struct * now we can change only archs that actually have exit_thread [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Jonas Bonn <jonas@southpole.se> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20exit_thread: remove empty bodiesJiri Slaby
Define HAVE_EXIT_THREAD for archs which want to do something in exit_thread. For others, let's define exit_thread as an empty inline. This is a cleanup before we change the prototype of exit_thread to accept a task parameter. [akpm@linux-foundation.org: fix mips] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Jonas Bonn <jonas@southpole.se> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19metag: mm: use hugetlb_bad_size()Vaishali Thakkar
Update setup_hugepagesz() to call hugetlb_bad_size() when unsupported hugepage size is found. Signed-off-by: Vaishali Thakkar <vaishali.thakkar@oracle.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Yaowei Bai <baiyaowei@cmss.chinamobile.com> Cc: Dominik Dingel <dingel@linux.vnet.ibm.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-17Merge tag 'gpio-v4.7-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for kernel cycle v4.7: Core infrastructural changes: - Support for natively single-ended GPIO driver stages. This means that if the hardware has registers to configure open drain or open source configuration, we use that rather than (as we did before) try to emulate it by switching the line to an input to get high impedance. This is also documented throughly in Documentation/gpio/driver.txt for those of you who did not understand one word of what I just wrote. - Start to do away with the unnecessarily complex and unitelligible ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB, another evolutional artifact from the time when the GPIO subsystem was unmaintained. Archs can now just select GPIOLIB and be done with it, cleanups to arches will trickle in for the next kernel. Some minor archs ACKed the changes immediately so these are included in this pull request. - Advancing the use of the data pointer inside the GPIO device for storing driver data by switching the PowerPC, Super-H Unicore and a few other subarches or subsystem drivers in ALSA SoC, Input, serial, SSB, staging etc to use it. - The initialization now reads the input/output state of the GPIO lines, so that each GPIO descriptor knows - if this callback is implemented - whether the line is input or output. This also reflects nicely in userspace "lsgpio". - It is now possible to name GPIO producer names, line names, from the device tree. (Platform data has been supported for a while). I bet we will get a similar mechanism for ACPI one of those days. This makes is possible to get sensible producer names for e.g. GPIO rails in "lsgpio" in userspace. New drivers: - New driver for the Loongson1. - The XLP driver now supports Broadcom Vulcan ARM64. - The IT87 driver now supports IT8620 and IT8628. - The PCA953X driver now supports Galileo Gen2. Driver improvements: - MCP23S08 was switched to use the gpiolib irqchip helpers and now also suppors level-triggered interrupts. - 74x164 and RCAR now supports the .set_multiple() callback - AMDPT was converted to use generic GPIO. - TC3589x, TPS65218, SX150X, F7188X, MENZ127, VX855, WM831X, WM8994 support the new single ended callback for open drain and in some cases open source. - Implement the .get_direction() callback for a few more drivers like PL061, Xgene. Cleanups: - Paul Gortmaker combed through the drivers and de-modularized those who are not really modules. - Move the GPIO poweroff DT bindings to the power subdir where they belong. - Rename gpio-generic.c to gpio-mmio.c, which is much more to the point. That's what it is handling, nothing more, nothing less" * tag 'gpio-v4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (126 commits) MIPS: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB gpio: zevio: make it explicitly non-modular gpio: timberdale: make it explicitly non-modular gpio: stmpe: make it explicitly non-modular gpio: sodaville: make it explicitly non-modular pinctrl: sh-pfc: Let gpio_chip.to_irq() return zero on error gpio: dwapb: Add ACPI device ID for DWAPB GPIO controller on X-Gene platforms gpio: dt-bindings: add wd,mbl-gpio bindings gpio: of: make it possible to name GPIO lines gpio: make gpiod_to_irq() return negative for NO_IRQ gpio: xgene: implement .get_direction() gpio: xgene: Enable ACPI support for X-Gene GFC GPIO driver gpio: tegra: Implement gpio_get_direction callback gpio: set up initial state from .get_direction() gpio: rename gpio-generic.c into gpio-mmio.c gpio: generic: fix GPIO_GENERIC_PLATFORM is set to module case gpio: dwapb: add gpio-signaled acpi event support gpio: dwapb: convert device node to fwnode gpio: dwapb: remove name from dwapb_port_property gpio/qoriq: select IRQ_DOMAIN ...
2016-05-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (21 commits) gitignore: fix wording mfd: ab8500-debugfs: fix "between" in printk memstick: trivial fix of spelling mistake on management cpupowerutils: bench: fix "average" treewide: Fix typos in printk IB/mlx4: printk fix pinctrl: sirf/atlas7: fix printk spelling serial: mctrl_gpio: Grammar s/lines GPIOs/line GPIOs/, /sets/set/ w1: comment spelling s/minmum/minimum/ Blackfin: comment spelling s/divsor/divisor/ metag: Fix misspellings in comments. ia64: Fix misspellings in comments. hexagon: Fix misspellings in comments. tools/perf: Fix misspellings in comments. cris: Fix misspellings in comments. c6x: Fix misspellings in comments. blackfin: Fix misspelling of 'register' in comment. avr32: Fix misspelling of 'definitions' in comment. treewide: Fix typos in printk Doc: treewide : Fix typos in DocBook/filesystem.xml ...
2016-05-16perf core: Add a 'nr' field to perf_event_callchain_contextArnaldo Carvalho de Melo
We will use it to count how many addresses are in the entry->ip[] array, excluding PERF_CONTEXT_{KERNEL,USER,etc} entries, so that we can really return the number of entries specified by the user via the relevant sysctl, kernel.perf_event_max_contexts, or via the per event perf_event_attr.sample_max_stack knob. This way we keep the perf_sample->ip_callchain->nr meaning, that is the number of entries, be it real addresses or PERF_CONTEXT_ entries, while honouring the max_stack knobs, i.e. the end result will be max_stack entries if we have at least that many entries in a given stack trace. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-s8teto51tdqvlfhefndtat9r@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-05-16perf core: Pass max stack as a perf_callchain_entry contextArnaldo Carvalho de Melo
This makes perf_callchain_{user,kernel}() receive the max stack as context for the perf_callchain_entry, instead of accessing the global sysctl_perf_event_max_stack. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: Wang Nan <wangnan0@huawei.com> Cc: Zefan Li <lizefan@huawei.com> Link: http://lkml.kernel.org/n/tip-kolmn1yo40p7jhswxwrc7rrd@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-05-16Merge tag 'metag-for-v4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull metag architecture updates from James Hogan: "Three minor fixes: - removal of stale comment - fix build for Meta1 when perf events are enabled - fix inline asm constraint in atomics" * tag 'metag-for-v4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag: Fix atomic_*_return inline asm constraints metag: perf: fix build on Meta1 metag: ftrace: remove the misleading comment for ftrace_dyn_arch_init
2016-05-05asm-generic: Drop renameat syscall from default listJames Hogan
The newer renameat2 syscall provides all the functionality provided by the renameat syscall and adds flags, so future architectures won't need to include renameat. Therefore drop the renameat syscall from the generic syscall list unless __ARCH_WANT_RENAMEAT is defined by the architecture's unistd.h prior to including asm-generic/unistd.h, and adjust all architectures using the generic syscall list to define it so that no in-tree architectures are affected. Signed-off-by: James Hogan <james.hogan@imgtec.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: linux-arch@vger.kernel.org Cc: linux-snps-arc@lists.infradead.org Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Cc: linux-metag@vger.kernel.org Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ley Foon Tan <lftan@altera.com> Cc: nios2-dev@lists.rocketboards.org Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-05-03metag: Fix atomic_*_return inline asm constraintsJames Hogan
The argument i of atomic_*_return() operations is given to inline asm with the "bd" constraint, which means "An Op2 register where Op1 is a data unit register and the instruction supports O2R", however Op1 is constrained by "da" which allows an address unit register to be used. Fix the constraint to use "br", meaning "An Op2 register and the instruction supports O2R", i.e. not requiring Op1 to be a data unit register. Fixes: d6dfe2509da9 ("locking,arch,metag: Fold atomic_ops") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linux-metag@vger.kernel.org
2016-05-03metag: perf: fix build on Meta1James Hogan
Meta1 doesn't support PERF_ICORE or PERF_CHAN registers resulting in build errors due to missing definitions. Fix this with an ifdef matching the one in asm/metag_mem.h. The build errors (found by a randconfig): arch/metag/kernel/perf/perf_event.c: In function 'metag_pmu_enable_counter': arch/metag/kernel/perf/perf_event.c:639: error: 'PERF_ICORE0' undeclared (first use in this function) arch/metag/kernel/perf/perf_event.c:639: error: (Each undeclared identifier is reported only once arch/metag/kernel/perf/perf_event.c:639: error: for each function it appears in.) arch/metag/kernel/perf/perf_event.c:643: error: 'PERF_CHAN0' undeclared (first use in this function) Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org
2016-04-29metag: ftrace: remove the misleading comment for ftrace_dyn_arch_initLi Bin
ftrace_dyn_arch_init no longer in kstop_machine, so remove the corresponding comment. Signed-off-by: Li Bin <huawei.libin@huawei.com> Signed-off-by: James Hogan <james.hogan@imgtec.com>
2016-04-27perf core: Allow setting up max frame stack depth via sysctlArnaldo Carvalho de Melo
The default remains 127, which is good for most cases, and not even hit most of the time, but then for some cases, as reported by Brendan, 1024+ deep frames are appearing on the radar for things like groovy, ruby. And in some workloads putting a _lower_ cap on this may make sense. One that is per event still needs to be put in place tho. The new file is: # cat /proc/sys/kernel/perf_event_max_stack 127 Chaging it: # echo 256 > /proc/sys/kernel/perf_event_max_stack # cat /proc/sys/kernel/perf_event_max_stack 256 But as soon as there is some event using callchains we get: # echo 512 > /proc/sys/kernel/perf_event_max_stack -bash: echo: write error: Device or resource busy # Because we only allocate the callchain percpu data structures when there is a user, which allows for changing the max easily, its just a matter of having no callchain users at that point. Reported-and-Tested-by: Brendan Gregg <brendan.d.gregg@gmail.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Acked-by: David Ahern <dsahern@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Milian Wolff <milian.wolff@kdab.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: Wang Nan <wangnan0@huawei.com> Cc: Zefan Li <lizefan@huawei.com> Link: http://lkml.kernel.org/r/20160426002928.GB16708@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-04-26metag: remove ARCH_WANT_OPTIONAL_GPIOLIBLinus Walleij
This symbols is not needed to get access to selecting the GPIOLIB anymore: any arch can select GPIOLIB. Cc: Michael Büsch <m@bues.ch> Cc: linux-metag@vger.kernel.org Acked-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-18metag: Fix misspellings in comments.Adam Buchbinder
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
