path: root/arch/microblaze/platform
2010-10-21microblaze: Add PVR for endians plus detectionMichal Simek
Upcomming microblaze version will support little-endian. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-21microblaze: Remove additional compatible propertiesMichal Simek
Device-tree BSP generates longer compatible properties that's why we can remove extra/old one. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-10-21microblaze: Fix generic DTS to ensure OF requirementsMichal Simek
LL Temac dts nodes should contain ranges property. It is sufficient to use empty ranges property. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Use lowest-common-denominator default CPU settingsJohn Williams
This will ensure that kernels built with no custom CPU settings will still boot OK on hardware that has additional CPU hardware instructions etc. Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Update default generic DTSMichal Simek
It is generated with longer compatible list Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Enable asm optimization only for HW with barrel-shifterMichal Simek
Asm code uses barrel-shifter instruction that's why we have to protect cases when HW don't have it. Reported-by: John Linn <john.linn@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Remove the buggy ALLOW_EDIT_AUTO config optionJohn Williams
This was intended to allow manual override of CPU settings copied automatically to Kconfig.auto, however it's problematic for several reasons, but mostly: * If the defconfig doesn't have ALLOW_EDIT_AUTO=y, then it's impossible for that defconfig to iverride the values in the kernel source tree. This leads to very strange errors where the kernel is compiled with the wrong CPUFLAGS. Next patch in the series will back out the default in Kconfig.auto to baseline settings, so a kernel built with no default values will at least boot on any hardware, just not make use of additional CPU features. Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: GPIO reset supportMichal Simek
2009-03-27microblaze_v8: Makefiles for Microblaze cpuMichal Simek
Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: John Linn <john.linn@xilinx.com> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-03-27microblaze_v8: Kconfig patchesMichal Simek
2009-03-27microblaze_v8: Generic dts file for platformsMichal Simek
Reviewed-by: Ingo Molnar <mingo@elte.hu> Reviewed-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: John Linn <john.linn@xilinx.com> Acked-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-03-27microblaze_v8: Platform bus registrationMichal Simek
