path: root/arch/mips/Kconfig.debug
2008-07-30[MIPS] kgdb: Remove existing implementationJason Wessel
This patch explicitly removes the kgdb implementation, for mips which is intended to be followed by a patch that adds a kgdb implementation for MIPS that makes use of the kgdb core in the kernel. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Allow setting of the cache attribute at run time.Chris Dearman
Slightly tacky, but there is a precedent in the sparc archirecture code. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-22[MIPS] Kbuild: Use the new cc-cross-prefix feature.Ralf Baechle
2007-07-06[MIPS] SMTC: Fix cut'n'paste bug in Kconfig.debugRalf Baechle
This effectivly turned the SMTC_IDLE_HOOK_DEBUG debug option into a no-op. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] Make SMTC_IDLE_HOOK_DEBUG a proper option in Kconfig.debug.Ralf Baechle
2007-02-20[MIPS] Allow selection of KGDB only on platforms where it's supported.Ralf Baechle
2007-02-06[MIPS] Fix some whitespace damageJan Altenberg
Signed-off-by: Jan Altenberg <jan@linutronix.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] TRACE_IRQFLAGS_SUPPORT support.Ralf Baechle
2006-04-27[MIPS] Kconfig: Clarify description of CROSSCOMPILE.Ralf Baechle
