commit 0a5191efe06b5103909206e4fbcff81d30283f8e upstream.
Since commit aef9a7bd9b67 ("serial/uart/8250: Add tunable RX interrupt
trigger I/F of FIFO buffers"), the port's default FCR value isn't used
in serial8250_do_set_termios anymore, but copied over once in
serial8250_config_port and then modified as needed.
Unfortunately, serial8250_config_port will never be called if the port
is shared between kernel and userspace, and the port's flag doesn't have
UPF_BOOT_AUTOCONF, which would trigger a serial8250_config_port as well.
This causes garbled output from userspace:
[ 5.220000] random: procd urandom read with 49 bits of entropy available
ers
[kee
Fix this by forcing it to be configured on boot, resulting in the
expected output:
[ 5.250000] random: procd urandom read with 50 bits of entropy available
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
Fixes: aef9a7bd9b67 ("serial/uart/8250: Add tunable RX interrupt trigger I/F of FIFO buffers")
Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com>
Cc: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Nicolas Schichan <nschichan@freebox.fr>
Cc: linux-mips@linux-mips.org
Cc: linux-serial@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/17544/
Cc: James Hogan <jhogan@kernel.org>
commit b084116f8587b222a2c5ef6dcd846f40f24b9420 upstream.
Without UPF_FIXED_TYPE, the data from the PORT_AR7 uart_config entry is
never copied, resulting in a dead port.
Fixes: 154615d55459 ("MIPS: AR7: Use correct UART port type")
Signed-off-by: Oswald Buddenhagen <oswald.buddenhagen@gmx.de>
[jonas.gorski: add Fixes tag]
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Cc: Oswald Buddenhagen <oswald.buddenhagen@gmx.de>
Patchwork: https://patchwork.linux-mips.org/patch/17543/
Signed-off-by: James Hogan <jhogan@kernel.org>
commit e6b03ab63b4d270e0249f96536fde632409dc1dc upstream.
When called from prom init code, ar7_gpio_init() will fail as it will
call gpiochip_add() which relies on a working kmalloc() to alloc
the gpio_desc array and kmalloc is not useable yet at prom init time.
Move ar7_gpio_init() to ar7_register_devices() (a device_initcall)
where kmalloc works.
Fixes: 14e85c0e69d5 ("gpio: remove gpio_descs global array")
Patchwork: https://patchwork.linux-mips.org/patch/17542/
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for 4.3 for MIPS. Here's the summary:
Three fixes that didn't make 4.2-stable:
- a -Os build might compile the kernel using the MIPS16 instruction
set but the R2 optimized inline functions in <uapi/asm/swab.h> are
implemented using 32-bit wide instructions which is invalid.
- a build error in pgtable-bits.h for a particular kernel
configuration.
- accessing registers of the CM GCR might have been compiled to use
64 bit accesses but these registers are onl 32 bit wide.
And also a few new bits:
- move the ATH79 GPIO driver to drivers/gpio
- the definition of IRQCHIP_DECLARE has moved to linux/irqchip.h,
change ATH79 accordingly.
- fix definition of pgprot_writecombine
- add an implementation of dma_map_ops.mmap
- fix alignment of quiet build output for vmlinuz link
- BCM47xx: Use kmemdup rather than duplicating its implementation
- Netlogic: Fix 0x0x prefixes of constants.
- merge Bjorn Helgaas' series to remove most of the weak keywords
from function declarations.
- CP0 and CP1 registers are best considered treated as unsigned
values to avoid large values from becoming negative values.
- improve support for the MIPS GIC timer.
- enable common clock framework for Malta and SEAD3.
- a number of improvments and fixes to dump_tlb().
- document the MIPS TLB dump functionality in Magic SysRq.
- Cavium Octeon CN68XX improvments.
- NetLogic improvments.
- irq: Use access helper irq_data_get_affinity_mask.
- handle MSA unaligned accesses.
- a number of R6-related math-emu fixes.
- support for I6400.
- improvments to MSA support.
- add uprobes support.
- move from deprecated __initcall to arch_initcall.
- remove finish_arch_switch().
- IRQ cleanups by Thomas Gleixner.
- migrate to new 'set-state' interface.
- random small cleanups"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (148 commits)
MIPS: UAPI: Fix unrecognized opcode WSBH/DSBH/DSHD when using MIPS16.
MIPS: Fix alignment of quiet build output for vmlinuz link
MIPS: math-emu: Remove unused handle_dsemul function declaration
MIPS: math-emu: Add support for the MIPS R6 MAX{, A} FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MIN{, A} FPU instruction
MIPS: math-emu: Add support for the MIPS R6 CLASS FPU instruction
MIPS: math-emu: Add support for the MIPS R6 RINT FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MSUBF FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MADDF FPU instruction
MIPS: math-emu: Add support for the MIPS R6 SELNEZ FPU instruction
MIPS: math-emu: Add support for the MIPS R6 SELEQZ FPU instruction
MIPS: math-emu: Add support for the CMP.condn.fmt R6 instruction
MIPS: inst.h: Add new MIPS R6 FPU opcodes
MIPS: Octeon: Fix management port MII address on Kontron S1901
MIPS: BCM47xx: Use kmemdup rather than duplicating its implementation
STAGING: Octeon: Use common helpers for determining interface and port
MIPS: Octeon: Support interfaces 4 and 5
MIPS: Octeon: Set up 1:1 mapping between CN68XX PKO queues and ports
MIPS: Octeon: Initialize CN68XX PKO
STAGING: Octeon: Support CN68XX style WQE
Currently CONFIG_ARCH_HAVE_CUSTOM_GPIO_H is defined for all MIPS
machines, and each machine type provides its own gpio.h. However
only a handful really implement the GPIO API, most just forward
everythings to gpiolib.
The Alchemy machine is notable as it provides a system to allow
implementing the GPIO API at the board level. But it is not used by
any board currently supported, so it can also be removed.
For most machine types we can just remove the custom gpio.h, as well
as the custom wrappers if some exists. Some of the code found in
the wrappers must be moved to the respective GPIO driver.
A few more fixes are need in some drivers as they rely on linux/gpio.h
to provides some machine specific definitions, or used asm/gpio.h
instead of linux/gpio.h for the gpio API.
Signed-off-by: Alban Bedel <albeu@free.fr>
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Cc: Rafał Miłecki <zajec5@gmail.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Florian Fainelli <florian@openwrt.org>
Cc: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Joe Perches <joe@perches.com>
Cc: Daniel Walter <dwalter@google.com>
Cc: Sergey Ryazanov <ryazanov.s.a@gmail.com>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: James Hartley <james.hartley@imgtec.com>
Cc: Andrew Bresticker <abrestic@chromium.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Varka Bhadram <varkabhadram@gmail.com>
Cc: Masanari Iida <standby24x7@gmail.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Michael Buesch <m@bues.ch>
Cc: abdoulaye berthe <berthe.ab@gmail.com>
Cc: linux-ide@vger.kernel.org
Cc: linux-gpio@vger.kernel.org
Cc: linux-input@vger.kernel.org
Cc: netdev@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/10828/
An SFP module may have a link up/down status pin which can be
connection to a GPIO line of the host. Add support for reading such an
GPIO in the fixed_phy driver.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Replace sscanf() with mac_pton().
[ralf@linux-mips.org: Resolved conflict.]
Signed-off-by: Daniel Walter <dwalter@google.com>
Patchwork: https://patchwork.linux-mips.org/patch/7151/
Use the much more common pr_warn instead of pr_warning
with the goal of removing pr_warning eventually.
Other miscellanea:
o Coalesce formats
o Realign arguments
Cc: linux-mips <linux-mips@linux-mips.org>
Cc: LKML <linux-kernel@vger.kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/7935/
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
This patch changes the physmap-flash platform data on AR7 to pass the
correct partition parser: ar7part to used by the "physmap-flash" mapping
driver so we get the partitions probed correctly.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Cc: blogic@openwrt.org
Patchwork: https://patchwork.linux-mips.org/patch/4654/
Convert the existing uses of random_ether_addr to
the new eth_random_addr.
'next/cavium', 'next/generic', 'next/kprobes', 'next/lantiq', 'next/perf' and 'next/raza' into mips-for-linux-next
Patchwork: https://patchwork.linux-mips.org/patch/2981/
Panic() invokes printk() to add a \n internally, so panic arguments should
not themselves end in \n. Panic invocations in arch/mips and elsewhere
are inconsistently sometimes terminating in \n, sometimes not.
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2490/
Add support for Titan TNETV1050,1055,1056,1060 variants. This SoC is almost
completely identical to AR7 except on a few points:
- a second bank of gpios is available
- vlynq0 on titan is vlynq1 on ar7
- different PHY addresses for cpmac0
This SoC can be found on commercial products like the Linksys WRTP54G
Original patch by Xin with improvments by Florian.
Signed-off-by: Xin Zhen <xlonestar2000@aim.com>
Patchwork: http://patchwork.linux-mips.org/patch/1563/
Shamelessly stealing wisdom from pasemi_mac.c, I found char2hex() could
be replaced with a single call to sscanf(), looks cleaner to me at
least. The result is 100 bytes trimmed off the size of a compiled
cpmac_get_mac() and as an extra bonus it grumbles and gracefully fails
over to using random_ether_addr() when an attempt to parse an invalid
MAC address is made.
Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
Cc: florian@openwrt.org
PORT_AR7 has the correct TRIG flag (UART_FCR_R_TRIG_00) as well as
UART_CAP_AFE being set. This fixes UART on TNETD7300 revision 0x02,
which would otherwise mangle some characters, no side effects on
other revisions.
Patchwork: http://patchwork.linux-mips.org/patch/1246/
ar7_regiser_devices needs ar7_clocks_init to have been called first,
however clock.o is currently linked later due to its order in the Makefile,
therefore ar7_clocks_init always gets called later than ar7_register_devices
because both have the same initcall level. Fix this by moving
ar7_register_devices to the right initcall level.
Reported-by: Michael J. Evans <mjevans1983@gmail.com>
Patchwork: http://patchwork.linux-mips.org/patch/1212/
Instead of doing yet another switch/case on the chip_id, use existing
inline function to set the watchdog base address.
Patchwork: http://patchwork.linux-mips.org/patch/1211/
Seems I trimmed one too many lines in
29ca2d81bd2a62fa86bc9a72ddadcf03d7daf795 (lmo) rsp
7084338eb8eb0cc021ba86c340157bad397f3f0b (kernel.org) which led to no
functioning Ethernet on my WAG54Gv2. This patch restores the AWOL line.
Patchwork: http://patchwork.linux-mips.org/patch/1065/
Seems in my whitespace cleanup 0f2536082d01448daeced8d9e82c3ba1751fefa3
(lmo) rsp. 8c2961da46abd85a71d20f2b169bf80618e (kernel.org) caused AR7
to no longer get as far as init. Fixed my phat fingering.
Patchwork: http://patchwork.linux-mips.org/patch/1064/
[Ralf: Fixed up the rejects and changed all the new printk(KERN_...); to
pr_xxx() as suggested by Wu.]
Patchwork: http://patchwork.linux-mips.org/patch/920/
Patchwork: http://patchwork.linux-mips.org/patch/919/
[Ralf: Fixed up reject and Wu's complaints about comment style.]
Patchwork: http://patchwork.linux-mips.org/patch/921/
This patch makes the ar7 clock code implement the Linux clk API. Drivers
using the various clocks available in the SoC are updated accordingly.
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Cc: Wim Van Sebroeck <wim@iguana.be>
Patchwork: http://patchwork.linux-mips.org/patch/881/
This patch implements gpiolib for the AR7 SoC.
Patchwork: http://patchwork.linux-mips.org/patch/816/
Several static uninitialized variables are used in the scope of __init
functions but are themselves not marked as __initdata. This patch is to put
those variables to where they belong and to reduce the memory footprint a
little bit.
Also, a couple of lines with spaces instead of tabs were fixed.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com>
Patchwork: http://patchwork.linux-mips.org/patch/698/
Acked-by: Florian Fainelli <florian@openwrt.org>
This patch checks if the watchdog enable bit is set in the DCL register
meaning that the hardware watchdog actually works and if so, register the
ar7_wdt platform_device.
This patch makes the board code register the ar7_wdt driver as a platform
device. We move the dynamic resource calculation here since the driver
should not be aware of the AR7 SoC version it is running on.
arch/microblaze/include/asm/socket.h
This patch adds fixed PHY support for the two on-chip
cpmac Ethernet adapters.
This patch fixes the following build failure when CONFIG_SERIAL_8250
is not enabled in the kernel configuration:
arch/mips/ar7/built-in.o: In function 'ar7_register_devices':
platform.c:(.init.text+0x61c): undefined reference to 'early_serial_setup'
platform.c:(.init.text+0x61c): relocation truncated to fit: R_MIPS_26 against 'early_serial_setup'
platform.c:(.init.text+0x68c): undefined reference to 'early_serial_setup'
platform.c:(.init.text+0x68c): relocation truncated to fit: R_MIPS_26 against 'early_serial_setup'
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
This patch adds support for the Texas Instruments AR7 System-on-a-Chip.
It supports the TNETD7100, 7200 and 7300 versions of the SoC.
Signed-off-by: Matteo Croce <matteo@openwrt.org>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Eugene Konev <ejka@openwrt.org>
Signed-off-by: Nicolas Thill <nico@openwrt.org>
